lsusb能识别:
root@wxh-T5:/home/wxh# lsusb
Bus 002 Device 063: ID 0951:1666 Kingston Technology DataTraveler G4
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 04f2:b5a7 Chicony Electronics Co., Ltd
Bus 001 Device 003: ID 8087:0a2b Intel Corp.
Bus 001 Device 002: ID 1532:0041 Razer USA, Ltd
但fdisk就看不到了:
Disk /dev/nvme0n1: 238.5 GiB, 256060514304 bytes, 500118192 sectors
Disklabel type: gpt
Disk identifier: F98A69B2-A6C0-4A51-BC56-4FE3595B6127
设备 Start 末尾 扇区 Size 类型
/dev/nvme0n1p1 2048 923647 921600 450M Windows recovery environment
/dev/nvme0n1p2 923648 1128447 204800 100M EFI System
/dev/nvme0n1p3 1128448 1161215 32768 16M Microsoft reserved
/dev/nvme0n1p4 1161216 163842047 162680832 77.6G Microsoft basic data
/dev/nvme0n1p5 163842048 500115455 336273408 160.4G Microsoft basic data
Disk /dev/sda: 698.7 GiB, 750156374016 bytes, 1465149168 sectors
Disklabel type: gpt
Disk identifier: 426D3159-DA41-47AC-A231-7601064ABB4F
/dev/sda1 34 262177 262144 128M Microsoft reserved
/dev/sda2 264192 1465147391 1464883200 698.5G Microsoft basic data
Disk /dev/sdb: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Disklabel type: dos
Disk identifier: 0x86b34ce6
设备 启动 Start 末尾 扇区 Size Id 类型
/dev/sdb1 2048 31250431 31248384 14.9G 82 Linux 交换 / Solaris
/dev/sdb2 31252478 234440703 203188226 96.9G 5 扩展
/dev/sdb5 * 31252480 35250175 3997696 1.9G ef EFI (FAT-12/16/32)
/dev/sdb6 35252224 75249663 39997440 19.1G 83 Linux
/dev/sdb7 75251712 211967999 136716288 65.2G 83 Linux
/dev/sdb8 211970048 234440703 22470656 10.7G 83 Linux
插上u盘后dmesg信息:
[ 1855.614195] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 1855.614585] scsi host4: usb-storage 2-1:1.0
[ 1855.614918] usb 2-1: USB disconnect, device number 75
[ 1855.958373] usb 2-1: new SuperSpeed USB device number 76 using xhci_hcd
[ 1855.999956] usb 2-1: New USB device found, idVendor=0951, idProduct=1666
[ 1855.999963] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1855.999967] usb 2-1: Product: DataTraveler 3.0
[ 1855.999971] usb 2-1: Manufacturer: Kingston
[ 1855.999975] usb 2-1: SerialNumber: 60A44C413A8CFE615987005B
[ 1861.246367] usb 2-1: Set SEL for device-initiated U2 failed.
[ 1861.246503] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 1861.246931] scsi host4: usb-storage 2-1:1.0
[ 1861.247278] usb 2-1: USB disconnect, device number 76
[ 1861.554640] usb 2-1: new SuperSpeed USB device number 77 using xhci_hcd
[ 1861.592189] usb 2-1: New USB device found, idVendor=0951, idProduct=1666
[ 1861.592196] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1861.592200] usb 2-1: Product: DataTraveler 3.0
[ 1861.592205] usb 2-1: Manufacturer: Kingston
[ 1861.592208] usb 2-1: SerialNumber: 60A44C413A8CFE615987005B
一直往下循环了。windows上能够识别,各种操作都没问题,但到linux就不行。借的其他u盘和移动硬盘,在linux上识别就没有问题。
求大佬告知,这块u盘还有救吗?
菜鸟求助ubuntu 16.04上无法识别u盘
- 系统: ubuntu 16.04
Re: 菜鸟求助ubuntu 16.04上无法识别u盘
把 u 盤插著这块u盘还有救吗?
把下面指令 複製 貼進終端機 執行
1. sudo parted -l print
把指令及結果直接 選取/複製 貼上來
2. 你使用什麼燒錄程式 燒錄 U 盤 ?
- 系统: ubuntu 16.04
1.poloshiao 写了:把 u 盤插著这块u盘还有救吗?
把下面指令 複製 貼進終端機 執行
把指令及結果直接 選取/複製 貼上來
root@wxh-T5:/home/wxh# sudo parted -l print
Model: ATA Crucial_CT750MX3 (scsi)
磁盘 /dev/sda: 750GB
分区表:gpt
Disk Flags:
数字 开始: End 大小 文件系统 Name 标志
1 17.4kB 134MB 134MB Microsoft reserved partition msftres
2 135MB 750GB 750GB ntfs Basic data partition msftdata
Model: ATA Samsung SSD 850 (scsi)
磁盘 /dev/sdb: 120GB
分区表:msdos
Disk Flags:
数字 开始: End 大小 类型 文件系统 标志
1 1049kB 16.0GB 16.0GB primary linux-swap(v1)
2 16.0GB 120GB 104GB extended
5 16.0GB 18.0GB 2047MB logical fat32 启动, esp
6 18.0GB 38.5GB 20.5GB logical ext4
7 38.5GB 109GB 70.0GB logical ext4
8 109GB 120GB 11.5GB logical ext4
Model: NVMe Device (nvme)
磁盘 /dev/nvme0n1: 256GB
分区表:gpt
Disk Flags:
1 1049kB 473MB 472MB ntfs Basic data partition 隐藏分区, diag
2 473MB 578MB 105MB fat32 EFI system partition 启动, esp
3 578MB 595MB 16.8MB Microsoft reserved partition msftres
4 595MB 83.9GB 83.3GB ntfs Basic data partition msftdata
5 83.9GB 256GB 172GB ntfs Basic data partition msftdata
2.烧录?没烧录啊,就是刚刚在windows上格式化过一遍
1. 你的 U 盤哪一個 ?lsusb 能识别:
2. 請進 Windows 磁盤管理程式 把 U 盤 分割情形 擷圖 貼上來2.烧录?没烧录啊,就是刚刚在windows上格式化过一遍
