只降频不降电压对CPU是否有损害?
CPU/显卡/打印机/USB设备等硬件问题
flac
只降频不降电压对CPU是否有损害?
帖子 flac » 2017-07-13 21:50
我的CPU是:Intel(R) Celeron(R) D CPU 3.46GHz
无法自动降频,加载p4-clockmod模块后,可以手动降频。
我看到redhat的文档里写:p4-clockmod只能降频,不会降电压,要使用acpi-cpufreq模块才能同时降频和降电压。
我试过,在不加载p4-clockmod模块的情况下,加载acpi-cpufreq模块就会出错。必须先加载p4-clockmod模块后才能加载acpi-cpufreq模块。
请问同时加载p4-clockmod模块和acpi-cpufreq模块是否会造成冲突? :What
如果只能加载p4-clockmod模块的话,只降频不降电压对CPU是否有损害? :What
When choosing an appropriate CPUfreq driver, always choose acpi-cpufreq over p4-clockmod. While using the p4-clockmod driver reduces the clock frequency of a CPU, it does not reduce the voltage. acpi-cpufreq, on the other hand, reduces voltage along with CPU clock frequency, allowing less power consumption and heat output for each unit reduction in performance.
https://access.redhat.com/documentation ... setup.html
当​​​​​​​选​​​​​​​择​​​​​​​适​​​​​​​当​​​​​​​的​​​​​​​ CPUfreq 驱​​​​​​​动​​​​​​​程​​​​​​​序​​​​​​​时​​​​​​​,总​​​​​​​是​​​​​​​选​​​​​​​择​​​​​​​ p4-clockmod 中​​​​​​​的​​​​​​​ acpi-cpufreq。​​​​​​​当​​​​​​​使​​​​​​​用​​​​​​​ p4-clockmod 驱​​​​​​​动​​​​​​​程​​​​​​​序​​​​​​​降​​​​​​​低​​​​​​​ CPU 的​​​​​​​时​​​​​​​钟​​​​​​​频​​​​​​​率​​​​​​​时​​​​​​​,它​​​​​​​不​​​​​​​会​​​​​​​降​​​​​​​低​​​​​​​电​​​​​​​压​​​​​​​。​​​​​​​另​​​​​​​一​​​​​​​方​​​​​​​面​​​​​​​,acpi-cpufreq 会​​​​​​​随​​​​​​​着​​​​​​​ CPU 时​​​​​​​钟​​​​​​​频​​​​​​​率​​​​​​​降​​​​​​​低​​​​​​​电​​​​​​​压​​​​​​​,允​​​​​​​许​​​​​​​每​​​​​​​个​​​​​​​性​​​​​​​能​​​​​​​单​​​​​​​位​​​​​​​降​​​​​​​低​​​​​​​有​​​​​​​更​​​​​​​少​​​​​​​电​​​​​​​力​​​​​​​消​​​​​​​耗​​​​​​​和​​​​​​​散​​​​​​​热​​​​​​​。​​​​​​​
cat /sys/devices/system/cpu/cpu0/driver/cpu0/cpufreq/scaling_available_frequencies
433322 866645 1299967 1733290 2166612 2599935 3033257 3466580
如果我把CPU降频降到最小的433322,久而久之,CPU会不会出事啊? :em06
onlylove
Re: 只降频不降电压对CPU是否有损害?
帖子 onlylove » 2017-07-13 22:21
如果会出事的话,笔记本上那些降频节电功能要来作甚
bzimage
帖子 bzimage » 2017-07-14 15:27
不降电压,只降频是没有意义的,也不能减少发热,也不节电 :Music
flac
帖子 flac » 2017-07-14 21:18
bzimage 写了:不降电压,只降频是没有意义的,也不能减少发热,也不节电 :Music
真的? :em20
