打印机在14.04里面能用,今天没注意,结果升级到16.04后打印机就无法使用了,不想重做系统,而且扫描也不能用了,重新安装驱动说无法找到扫描易,但是我都安装了的
Page 1 (<troubleshoot.SchedulerNotRunning.SchedulerNotRunning object at 0x7f00b47db630>):
{'cups_connection_failure': False}
Page 2 (<troubleshoot.CheckLocalServerPublishing.CheckLocalServerPublishing object at 0x7f00b47dbba8>):
{'local_server_exporting_printers': False}
Page 3 (<troubleshoot.ChoosePrinter.ChoosePrinter object at 0x7f00b47dbcf8>):
{'cups_dest': <cups.Dest Panasonic-KX-MB1600series (default)>,
'cups_instance': None,
'cups_queue': 'Panasonic-KX-MB1600series',
'cups_queue_listed': True}
Page 4 (<troubleshoot.CheckPrinterSanity.CheckPrinterSanity object at 0x7f00b47dbfd0>):
{'cups_device_uri_scheme': 'socket',
'cups_printer_dict': {'device-uri': 'socket://192.168.0.101:9100',
'printer-info': 'Panasonic KX-MB1600series',
'printer-is-shared': True,
'printer-location': '192.168.0.101',
'printer-make-and-model': 'Panasonic KX-MB1600series '
'GDI',
'printer-state': 3,
'printer-state-message': '(PID 4166) Cannot load libgs '
'or libgs version too old then '
'8.0',
'printer-state-reasons': ['none'],
'printer-type': 8556740,
'printer-uri-supported': 'ipp://localhost/printers/Panasonic-KX-MB1600series'},
'cups_printer_remote': False,
'is_cups_class': False,
'local_cups_queue_attributes': {'charset-configured': 'utf-8',
'charset-supported': ['us-ascii', 'utf-8'],
'color-supported': False,
'compression-supported': ['none', 'gzip'],
'copies-default': 1,
'copies-supported': (1, 9999),
'cups-version': '2.1.3',
'document-format-default': 'application/octet-stream',
'document-format-supported': ['application/octet-stream',
'application/pdf',
'application/postscript',
'application/vnd.adobe-reader-postscript',
'application/vnd.cups-command',
'application/vnd.cups-pdf',
'application/vnd.cups-pdf-banner',
'application/vnd.cups-postscript',
'application/vnd.cups-raster',
'application/vnd.cups-raw',
'application/x-cshell',
'application/x-csource',
'application/x-perl',
'application/x-shell',
'image/gif',
'image/jpeg',
'image/png',
'image/pwg-raster',
'image/tiff',
'image/urf',
'image/x-bitmap',
'image/x-photocd',
'image/x-portable-anymap',
'image/x-portable-bitmap',
'image/x-portable-graymap',
'image/x-portable-pixmap',
'image/x-sgi-rgb',
'image/x-sun-raster',
'image/x-xbitmap',
'image/x-xpixmap',
'image/x-xwindowdump',
'text/css',
'text/html',
'text/plain'],
'finishings-default': 3,
'finishings-supported': [3],
'generated-natural-language-supported': ['zh-cn'],
'ipp-features-supported': ['subscription-object'],
'ipp-versions-supported': ['1.0',
'1.1',
'2.0',
'2.1'],
'ippget-event-life': 15,
'job-cancel-after-default': 10800,
'job-cancel-after-supported': (0, 2147483647),
'job-creation-attributes-supported': ['copies',
'finishings',
'ipp-attribute-fidelity',
'job-hold-until',
'job-name',
'job-priority',
'job-sheets',
'media',
'media-col',
'multiple-document-handling',
'number-up',
'output-bin',
'orientation-requested',
'page-ranges',
'print-color-mode',
'print-quality',
'printer-resolution',
'sides'],
'job-hold-until-default': 'no-hold',
'job-hold-until-supported': ['no-hold',
'indefinite',
'day-time',
'evening',
'night',
'second-shift',
'third-shift',
'weekend'],
'job-ids-supported': True,
'job-k-limit': 0,
'job-k-octets-supported': (0, 58926252),
'job-page-limit': 0,
'job-priority-default': 50,
'job-priority-supported': [100],
'job-quota-period': 0,
'job-settable-attributes-supported': ['copies',
'finishings',
'job-hold-until',
'job-name',
'job-priority',
'media',
'media-col',
'number-up',
'output-bin',
'page-ranges',
'print-color-mode',
'print-quality',
'sides'],
'job-sheets-default': ('none', 'none'),
'job-sheets-supported': ['none',
'classified',
'confidential',
'form',
'secret',
'standard',
'topsecret',
'unclassified'],
'jpeg-k-octets-supported': (0, 58926252),
'jpeg-x-dimension-supported': (0, 65535),
'jpeg-y-dimension-supported': (1, 65535),
'marker-change-time': 1492657035,
'marker-colors': ['none', 'none'],
'marker-levels': [-1, -1],
'marker-names': ['Toner', 'Drum'],
'marker-types': ['toner', 'opc'],
'media-bottom-margin-supported': [423],
'media-col-default': '(unknown IPP value tag '
'0x34)',
'media-col-supported': ['media-bottom-margin',
'media-left-margin',
'media-right-margin',
'media-size',
'media-source',
'media-top-margin',
'media-type'],
'media-default': 'iso_a4_210x297mm',
'media-left-margin-supported': [423],
'media-right-margin-supported': [423],
'media-size-supported': ['(unknown IPP value '
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)'],
'media-source-supported': ['tray-1', 'manual'],
'media-supported': ['na_letter_8.5x11in',
'na_legal_8.5x14in',
'iso_a4_210x297mm',
'jis_b5_182x257mm',
'iso_b5_176x250mm',
'om_16-k_195.09x269.88mm',
'oe_85x13in_85x13in',
'custom_215.9x340.08mm_215.9x340.08mm',
'custom_min_209.9x279.4mm',
'custom_max_8.5x14in'],
'media-top-margin-supported': [423],
'media-type-supported': ['stationery',
'thin-paper',
'thick-paper',
'label'],
'multiple-document-handling-supported': ['separate-documents-uncollated-copies',
'separate-documents-collated-copies'],
'multiple-document-jobs-supported': True,
'multiple-operation-time-out': 300,
'multiple-operation-time-out-action': 'process-job',
'natural-language-configured': 'zh-cn',
'notify-attributes-supported': ['printer-state-change-time',
'notify-lease-expiration-time',
'notify-subscriber-user-name'],
'notify-events-default': ['job-completed'],
'notify-events-supported': ['job-completed',
'job-config-changed',
'job-created',
'job-progress',
'job-state-changed',
'job-stopped',
'printer-added',
'printer-changed',
'printer-config-changed',
'printer-deleted',
'printer-finishings-changed',
'printer-media-changed',
'printer-modified',
'printer-restarted',
'printer-shutdown',
'printer-state-changed',
'printer-stopped',
'server-audit',
'server-restarted',
'server-started',
'server-stopped'],
'notify-lease-duration-default': 86400,
'notify-lease-duration-supported': (0,
2147483647),
'notify-max-events-supported': [100],
'notify-pull-method-supported': ['ippget'],
'notify-schemes-supported': ['dbus',
'mailto',
'rss'],
'number-up-default': 1,
'number-up-supported': [1, 2, 4, 6, 9, 16],
'operations-supported': [2,
4,
5,
6,
8,
9,
10,
11,
12,
13,
16,
17,
18,
19,
20,
21,
22,
23,
24,
25,
26,
27,
28,
34,
35,
37,
38,
56,
57,
59,
16385,
16386,
16387,
16388,
16389,
16390,
16391,
16392,
16393,
16394,
16395,
16396,
16397,
16398,
16399,
16423,
14],
'orientation-requested-default': None,
'orientation-requested-supported': [3,
4,
5,
6],
'output-bin-default': 'face-down',
'output-bin-supported': ['face-down'],
'page-ranges-supported': True,
'pages-per-minute': 18,
'pdf-k-octets-supported': (0, 58926252),
'pdf-versions-supported': ['adobe-1.2',
'adobe-1.3',
'adobe-1.4',
'adobe-1.5',
'adobe-1.6',
'adobe-1.7',
'iso-19005-1_2005',
'iso-32000-1_2008',
'pwg-5102.3'],
'pdl-override-supported': ['attempted'],
'port-monitor': 'none',
'port-monitor-supported': ['none'],
'print-color-mode-default': 'monochrome',
'print-color-mode-supported': ['monochrome'],
'print-quality-default': 4,
'print-quality-supported': [4],
'printer-commands': ['AutoConfigure',
'Clean',
'PrintSelfTestPage'],
'printer-config-change-date-time': '(IPP_TAG_DATE)',
'printer-config-change-time': 1492657033,
'printer-current-time': '(IPP_TAG_DATE)',
'printer-dns-sd-name': None,
'printer-error-policy': 'retry-job',
'printer-error-policy-supported': ['abort-job',
'retry-current-job',
'retry-job',
'stop-printer'],
'printer-geo-location': '(unknown IPP value '
'tag 0x12)',
'printer-get-attributes-supported': ['document-format'],
'printer-icons': 'http://localhost/icons/Panasonic-KX-MB1600series.png',
'printer-is-accepting-jobs': True,
'printer-make-and-model': 'Panasonic '
'KX-MB1600series '
'GDI',
'printer-more-info': 'http://localhost/printers/Panasonic-KX-MB1600series',
'printer-name': 'Panasonic-KX-MB1600series',
'printer-op-policy': 'default',
'printer-op-policy-supported': ['authenticated',
'default'],
'printer-organization': '',
'printer-organizational-unit': '',
'printer-resolution-default': (300, 300, 3),
'printer-resolution-supported': [(300, 300, 3),
(300,
300,
3)],
'printer-settable-attributes-supported': ['printer-geo-location',
'printer-info',
'printer-location',
'printer-organization',
'printer-organizational-unit'],
'printer-state': 3,
'printer-state-change-date-time': '(IPP_TAG_DATE)',
'printer-state-change-time': 1492657037,
'printer-state-message': '(PID 4166) Cannot '
'load libgs or libgs '
'version too old '
'then 8.0',
'printer-supply': ['(unknown IPP value tag '
'0x30)',
'0x30)'],
'printer-supply-description': ['Toner',
'Drum'],
'printer-up-time': 1492657047,
'printer-uri-supported': ['ipp://localhost/printers/Panasonic-KX-MB1600series'],
'printer-uuid': 'urn:uuid:3d62b01b-0be9-3b3d-4c20-e13a02be31fa',
'pwg-raster-document-resolution-supported': [(300,
300,
3),
(300,
300,
3)],
'pwg-raster-document-sheet-back': 'normal',
'pwg-raster-document-type-supported': ['adobergb-8',
'adobergb-16',
'black-1',
'black-8',
'black-16',
'cmyk-8',
'cmyk-16',
'rgb-8',
'rgb-16',
'sgray-1',
'sgray-8',
'sgray-16',
'srgb-8',
'srgb-16'],
'queued-job-count': 1,
'server-is-sharing-printers': False,
'sides-default': 'one-sided',
'sides-supported': ['one-sided'],
'uri-authentication-supported': ['requesting-user-name'],
'uri-security-supported': ['none'],
'which-jobs-supported': ['completed',
'not-completed',
'aborted',
'all',
'canceled',
'pending',
'pending-held',
'processing',
'processing-stopped']}}
Page 5 (<troubleshoot.CheckPPDSanity.CheckPPDSanity object at 0x7f00b47db940>):
{'cups_printer_ppd_defaults': {'General': {'InputSlot': 'Tray1',
'MediaType': 'Plain',
'PageRegion': 'A4',
'PageSize': 'A4',
'Poster': 'None'},
'Output': {'Collate': 'True'},
'Quality': {'Resolution': 'Standard',
'TonerSave': 'False'}},
'cups_printer_ppd_valid': True,
'missing_pkgs_and_exes': ([], [])}
Page 6 (<troubleshoot.LocalOrRemote.LocalOrRemote object at 0x7f00b47db668>):
{'printer_is_remote': False}
Page 7 (<troubleshoot.PrinterStateReasons.PrinterStateReasons object at 0x7f00b47f8c18>):
{'printer-state-message': '(PID 4166) Cannot load libgs or libgs version too '
'old then 8.0',
'printer-state-reasons': ['none']}
Page 8 (<troubleshoot.Locale.Locale object at 0x7f00b4c19710>):
{'printer_page_size': 'A4',
'system_locale_lang': None,
'user_locale_ctype': 'zh_CN',
'user_locale_messages': 'zh_CN'}
