办公室使用一台松下MB1667的一体机,打印驱动都正确安装,也添加了打印机,可是就是打印测试页的时候报错,还有就是扫描驱动无法安装,以前用深度的时候都能正常使用扫描,当时打印也是安装后无法打印,好在那个上面有个深度云打印可以用,现在换XUBUNTU了就麻烦了,有没有高人知道怎么破
打印机驱动最高只支持到15.10,今天退回到14.04后就一切正常了,对于更新驱动是不报希望了
已解决-网络打印机安装
已解决-网络打印机安装
上次由 风软农夫 在 2017-03-27 21:23,总共编辑 3 次。
- daf3707
- 来自: 在他乡
Re: 网络打印机安装
看日志,提供有用的信息才行
Re: 网络打印机安装
怎么我上传不了附件,只有贴一段
/2017:14:33:34 +0800] [cups-deviced] PID 4094 (gutenprint52+usb) stopped with status 1!
W [14/Mar/2017:14:34:32 +0800] Bad resolution "Draft" for printer Panasonic-KX-MB1667.
W [14/Mar/2017:14:34:32 +0800] Bad resolution "Standard" for printer Panasonic-KX-MB1667.
E [14/Mar/2017:14:34:35 +0800] [Job 1] (PID 4158) Cannot load libgs or libgs version too old then 8.0
E [14/Mar/2017:14:34:35 +0800] [Job 1] Job stopped due to filter errors; please consult the error_log file for details.
D [14/Mar/2017:14:34:35 +0800] [Job 1] The following messages were recorded from 14时34分35秒 to 14时34分35秒
D [14/Mar/2017:14:34:35 +0800] [Job 1] Adding start banner page "none".
D [14/Mar/2017:14:34:35 +0800] [Job 1] Adding end banner page "none".
D [14/Mar/2017:14:34:35 +0800] [Job 1] File of type application/vnd.cups-pdf-banner queued by "gongyu".
D [14/Mar/2017:14:34:35 +0800] [Job 1] hold_until=0
D [14/Mar/2017:14:34:35 +0800] [Job 1] Queued on "Panasonic-KX-MB1667" by "gongyu".
D [14/Mar/2017:14:34:35 +0800] [Job 1] time-at-processing=1489473275
D [14/Mar/2017:14:34:35 +0800] [Job 1] 4 filters for job:
D [14/Mar/2017:14:34:35 +0800] [Job 1] bannertopdf (application/vnd.cups-pdf-banner to application/pdf, cost 32)
D [14/Mar/2017:14:34:35 +0800] [Job 1] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
D [14/Mar/2017:14:34:35 +0800] [Job 1] pdftops (application/vnd.cups-pdf to application/vnd.cups-postscript, cost 100)
D [14/Mar/2017:14:34:35 +0800] [Job 1] L_H0JDGCZAZ (application/vnd.cups-postscript to printer/Panasonic-KX-MB1667, cost 0)
D [14/Mar/2017:14:34:35 +0800] [Job 1] job-sheets=none,none
D [14/Mar/2017:14:34:35 +0800] [Job 1] argv[0]="Panasonic-KX-MB1667"
D [14/Mar/2017:14:34:35 +0800] [Job 1] argv[1]="1"
D [14/Mar/2017:14:34:35 +0800] [Job 1] argv[2]="gongyu"
D [14/Mar/2017:14:34:35 +0800] [Job 1] argv[3]="Test Page"
D [14/Mar/2017:14:34:35 +0800] [Job 1] argv[4]="1"
D [14/Mar/2017:14:34:35 +0800] [Job 1] argv[5]="job-uuid=urn:uuid:38093fb9-08ec-33cd-64fc-7c9aee180e9e job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1489473275 time-at-processing=1489473275"
D [14/Mar/2017:14:34:35 +0800] [Job 1] argv[6]="/var/spool/cups/d00001-001"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[1]="CUPS_DATADIR=/usr/share/cups"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[4]="CUPS_REQUESTROOT=/var/spool/cups"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[5]="CUPS_SERVERBIN=/usr/lib/cups"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[6]="CUPS_SERVERROOT=/etc/cups"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[7]="CUPS_STATEDIR=/var/run/cups"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[8]="HOME=/var/spool/cups/tmp"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[10]="SERVER_ADMIN=root@gongyu-H81MHP2-LSP"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[11]="SOFTWARE=CUPS/2.1.3"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[12]="TMPDIR=/var/spool/cups/tmp"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[13]="USER=root"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[14]="CUPS_MAX_MESSAGE=2047"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[15]="CUPS_SERVER=/var/run/cups/cups.sock"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[16]="CUPS_ENCRYPTION=IfRequested"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[17]="IPP_PORT=631"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[18]="CHARSET=utf-8"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[19]="LANG=zh_CN.UTF-8"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[20]="PPD=/etc/cups/ppd/Panasonic-KX-MB1667.ppd"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[21]="RIP_MAX_CACHE=128m"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[22]="CONTENT_TYPE=application/vnd.cups-pdf-banner"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[23]="DEVICE_URI=dnssd://MB1667-236B59B5._printer._tcp.local/"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[24]="PRINTER_INFO=Panasonic KX-MB1667"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[25]="PRINTER_LOCATION=办公室"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[26]="PRINTER=Panasonic-KX-MB1667"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[27]="PRINTER_STATE_REASONS=none"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[28]="CUPS_FILETYPE=document"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-postscript"
D [14/Mar/2017:14:34:35 +0800] [Job 1] envp[30]="AUTH_I****"
D [14/Mar/2017:14:34:35 +0800] [Job 1] Started filter /usr/lib/cups/filter/bannertopdf (PID 4155)
D [14/Mar/2017:14:34:35 +0800] [Job 1] Started filter /usr/lib/cups/filter/pdftopdf (PID 4156)
D [14/Mar/2017:14:34:35 +0800] [Job 1] Started filter /usr/lib/cups/filter/pdftops (PID 4157)
D [14/Mar/2017:14:34:35 +0800] [Job 1] Started filter /usr/lib/cups/filter/L_H0JDGCZAZ (PID 4158)
D [14/Mar/2017:14:34:35 +0800] [Job 1] Started backend /usr/lib/cups/backend/dnssd (PID 4159)
D [14/Mar/2017:14:34:35 +0800] [Job 1] (PID 4158) Start Panasonic GDI filter on Panasonic-KX-MB1667
D [14/Mar/2017:14:34:35 +0800] [Job 1] Set job-printer-state-message to "(PID 4158) Cannot load libgs or libgs version too old then 8.0", current level=ERROR
D [14/Mar/2017:14:34:35 +0800] [Job 1] Resolving \"MB1667-236B59B5._printer._tcp.local\"...
D [14/Mar/2017:14:34:35 +0800] [Job 1] STATE: +connecting-to-device
D [14/Mar/2017:14:34:35 +0800] [Job 1] Resolving \"MB1667-236B59B5\", regtype=\"_printer._tcp\", domain=\"local.\"...
D [14/Mar/2017:14:34:35 +0800] [Job 1] pdftops - copying to temp print file \"/tmp/0103d58ca09a2\"
D [14/Mar/2017:14:34:35 +0800] [Job 1] PDF template file doesn\'t have form. It\'s okay.
D [14/Mar/2017:14:34:35 +0800] [Job 1] PID 4155 (/usr/lib/cups/filter/bannertopdf) exited with no errors.
D [14/Mar/2017:14:34:35 +0800] [Job 1] PID 4156 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [14/Mar/2017:14:34:35 +0800] [Job 1] Printer make and model: Panasonic KX-MB1600series
D [14/Mar/2017:14:34:35 +0800] [Job 1] Running command line for pstops: pstops 1 gongyu \'Test Page\' 1 \'job-uuid=urn:uuid:38093fb9-08ec-33cd-64fc-7c9aee180e9e job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1489473275 time-at-processing=1489473275\'
D [14/Mar/2017:14:34:35 +0800] [Job 1] Using image rendering resolution 600 dpi
D [14/Mar/2017:14:34:35 +0800] [Job 1] Running command line for gs: gs -q -dNOPAUSE -dBATCH -dSAFER -sDEVICE=ps2write -sOUTPUTFILE=%stdout -dLanguageLevel=3 -r600 -dCompressFonts=false -dNoT3CCITT -dNOINTERPOLATE -c \'save pop\' -f /tmp/0103d58ca09a2
D [14/Mar/2017:14:34:35 +0800] [Job 1] Started filter gs (PID 4162)
D [14/Mar/2017:14:34:35 +0800] [Job 1] Started filter pstops (PID 4163)
D [14/Mar/2017:14:34:35 +0800] [Job 1] PID 4158 (/usr/lib/cups/filter/L_H0JDGCZAZ) crashed on signal 11.
D [14/Mar/2017:14:34:35 +0800] [Job 1] Hint: Try setting the LogLevel to "debug" to find out more.
D [14/Mar/2017:14:34:35 +0800] [Job 1] Resolved as \"lpd://MB1667-236B59B5.local:510/lp\"...
D [14/Mar/2017:14:34:35 +0800] [Job 1] STATE: -connecting-to-device,offline-report
D [14/Mar/2017:14:34:35 +0800] [Job 1] Executing backend \"/usr/lib/cups/backend/lpd\"...
D [14/Mar/2017:14:34:35 +0800] [Job 1] Looking up \"MB1667-236B59B5.local\"...
D [14/Mar/2017:14:34:35 +0800] [Job 1] backendWaitLoop(snmp_fd=7, addr=0x55d77a2de658, side_cb=0x55d779b58830)
D [14/Mar/2017:14:34:35 +0800] [Job 1] PID 4159 (/usr/lib/cups/backend/dnssd) exited with no errors.
D [14/Mar/2017:14:34:35 +0800] [Job 1] Page = 595x842; 12,12 to 583,830
D [14/Mar/2017:14:34:35 +0800] [Job 1] slow_collate=0, slow_duplex=0, slow_order=0
D [14/Mar/2017:14:34:35 +0800] [Job 1] Before copy_comments - %!PS-Adobe-3.0
D [14/Mar/2017:14:34:35 +0800] [Job 1] %!PS-Adobe-3.0
D [14/Mar/2017:14:34:35 +0800] [Job 1] %%BoundingBox: 0 0 595 842
D [14/Mar/2017:14:34:35 +0800] [Job 1] %%HiResBoundingBox: 0 0 595.00 842.00
D [14/Mar/2017:14:34:35 +0800] [Job 1] %%Creator: GPL Ghostscript 918 (ps2write)
D [14/Mar/2017:14:34:35 +0800] [Job 1] %%LanguageLevel: 2
D [14/Mar/2017:14:34:35 +0800] [Job 1] %%CreationDate: D:20170314143435+08\'00\'
D [14/Mar/2017:14:34:35 +0800] [Job 1] %%Pages: 1
D [14/Mar/2017:14:34:35 +0800] [Job 1] %%EndComments
D [14/Mar/2017:14:34:35 +0800] [Job 1] Before copy_prolog - %%BeginProlog
D [14/Mar/2017:14:34:35 +0800] [Job 1] Before copy_setup - %%Page: 1 1
D [14/Mar/2017:14:34:35 +0800] [Job 1] Before page loop - %%Page: 1 1
D [14/Mar/2017:14:34:35 +0800] [Job 1] Copying page 1...
D [14/Mar/2017:14:34:35 +0800] [Job 1] pagew = 571.0, pagel = 818.0
D [14/Mar/2017:14:34:35 +0800] [Job 1] bboxx = 0, bboxy = 0, bboxw = 595, bboxl = 842
D [14/Mar/2017:14:34:35 +0800] [Job 1] PageLeft = 12.0, PageRight = 583.0
D [14/Mar/2017:14:34:35 +0800] [Job 1] PageTop = 830.0, PageBottom = 12.0
D [14/Mar/2017:14:34:35 +0800] [Job 1] PageWidth = 595.0, PageLength = 842.0
D [14/Mar/2017:14:34:35 +0800] [Job 1] Wrote 1 pages...
D [14/Mar/2017:14:34:35 +0800] [Job 1] PID 4163 (pstops) exited with no errors.
D [14/Mar/2017:14:34:35 +0800] [Job 1] PID 4162 (gs) exited with no errors.
D [14/Mar/2017:14:34:35 +0800] [Job 1] PID 4157 (/usr/lib/cups/filter/pdftops) exited with no errors.
D [14/Mar/2017:14:34:35 +0800] [Job 1] End of messages
D [14/Mar/2017:14:34:35 +0800] [Job 1] printer-state=3(idle)
D [14/Mar/2017:14:34:35 +0800] [Job 1] printer-state-message="(PID 4158) Cannot load libgs or libgs version too old then 8.0"
D [14/Mar/2017:14:34:35 +0800] [Job 1] printer-state-reasons=none
E [14/Mar/2017:14:40:19 +0800] [cups-deviced] PID 4899 (gutenprint52+usb) stopped with status 1!
E [14/Mar/2017:14:40:33 +0800] [Job 2] (PID 4921) Cannot load libgs or libgs version too old then 8.0
E [14/Mar/2017:14:40:33 +0800] [Job 2] Job stopped due to filter errors; please consult the error_log file for details.
D [14/Mar/2017:14:40:33 +0800] [Job 2] The following messages were recorded from 14时40分32秒 to 14时40分33秒
D [14/Mar/2017:14:40:33 +0800] [Job 2] Adding start banner page "none".
D [14/Mar/2017:14:40:33 +0800] [Job 2] Adding end banner page "none".
D [14/Mar/2017:14:40:33 +0800] [Job 2] File of type application/vnd.cups-pdf-banner queued by "gongyu".
D [14/Mar/2017:14:40:33 +0800] [Job 2] hold_until=0
D [14/Mar/2017:14:40:33 +0800] [Job 2] Queued on "Panasonic-KX-MB1667" by "gongyu".
D [14/Mar/2017:14:40:33 +0800] [Job 2] time-at-processing=1489473632
D [14/Mar/2017:14:40:33 +0800] [Job 2] 4 filters for job:
D [14/Mar/2017:14:40:33 +0800] [Job 2] bannertopdf (application/vnd.cups-pdf-banner to application/pdf, cost 32)
D [14/Mar/2017:14:40:33 +0800] [Job 2] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
D [14/Mar/2017:14:40:33 +0800] [Job 2] pdftops (application/vnd.cups-pdf to application/vnd.cups-postscript, cost 100)
D [14/Mar/2017:14:40:33 +0800] [Job 2] L_H0JDGCZAZ (application/vnd.cups-postscript to printer/Panasonic-KX-MB1667, cost 0)
D [14/Mar/2017:14:40:33 +0800] [Job 2] job-sheets=none,none
D [14/Mar/2017:14:40:33 +0800] [Job 2] argv[0]="Panasonic-KX-MB1667"
D [14/Mar/2017:14:40:33 +0800] [Job 2] argv[1]="2"
D [14/Mar/2017:14:40:33 +0800] [Job 2] argv[2]="gongyu"
D [14/Mar/2017:14:40:33 +0800] [Job 2] argv[3]="Test Page"
D [14/Mar/2017:14:40:33 +0800] [Job 2] argv[4]="1"
D [14/Mar/2017:14:40:33 +0800] [Job 2] argv[5]="job-uuid=urn:uuid:d97fa48d-fbc6-34cb-4227-ba13e3edae50 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1489473632 time-at-processing=1489473632"
D [14/Mar/2017:14:40:33 +0800] [Job 2] argv[6]="/var/spool/cups/d00002-001"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[1]="CUPS_DATADIR=/usr/share/cups"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[4]="CUPS_REQUESTROOT=/var/spool/cups"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[5]="CUPS_SERVERBIN=/usr/lib/cups"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[6]="CUPS_SERVERROOT=/etc/cups"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[7]="CUPS_STATEDIR=/var/run/cups"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[8]="HOME=/var/spool/cups/tmp"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[10]="SERVER_ADMIN=root@gongyu-H81MHP2-LSP"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[11]="SOFTWARE=CUPS/2.1.3"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[12]="TMPDIR=/var/spool/cups/tmp"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[13]="USER=root"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[14]="CUPS_MAX_MESSAGE=2047"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[15]="CUPS_SERVER=/var/run/cups/cups.sock"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[16]="CUPS_ENCRYPTION=IfRequested"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[17]="IPP_PORT=631"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[18]="CHARSET=utf-8"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[19]="LANG=zh_CN.UTF-8"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[20]="PPD=/etc/cups/ppd/Panasonic-KX-MB1667.ppd"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[21]="RIP_MAX_CACHE=128m"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[22]="CONTENT_TYPE=application/vnd.cups-pdf-banner"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[23]="DEVICE_URI=socket://192.168.1.100:9100"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[24]="PRINTER_INFO=Panasonic KX-MB1667"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[25]="PRINTER_LOCATION=办公室"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[26]="PRINTER=Panasonic-KX-MB1667"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[27]="PRINTER_STATE_REASONS=none"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[28]="CUPS_FILETYPE=document"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-postscript"
D [14/Mar/2017:14:40:33 +0800] [Job 2] envp[30]="AUTH_I****"
D [14/Mar/2017:14:40:33 +0800] [Job 2] Started filter /usr/lib/cups/filter/bannertopdf (PID 4918)
D [14/Mar/2017:14:40:33 +0800] [Job 2] Started filter /usr/lib/cups/filter/pdftopdf (PID 4919)
D [14/Mar/2017:14:40:33 +0800] [Job 2] Started filter /usr/lib/cups/filter/pdftops (PID 4920)
D [14/Mar/2017:14:40:33 +0800] [Job 2] Started filter /usr/lib/cups/filter/L_H0JDGCZAZ (PID 4921)
D [14/Mar/2017:14:40:33 +0800] [Job 2] Started backend /usr/lib/cups/backend/socket (PID 4922)
D [14/Mar/2017:14:40:33 +0800] [Job 2] (PID 4921) Start Panasonic GDI filter on Panasonic-KX-MB1667
D [14/Mar/2017:14:40:33 +0800] [Job 2] pdftops - copying to temp print file \"/tmp/0133858d6af2c\"
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: +connecting-to-device
D [14/Mar/2017:14:40:33 +0800] [Job 2] Looking up \"192.168.1.100\"...
D [14/Mar/2017:14:40:33 +0800] [Job 2] Set job-printer-state-message to "(PID 4921) Cannot load libgs or libgs version too old then 8.0", current level=ERROR
D [14/Mar/2017:14:40:33 +0800] [Job 2] hrDeviceDesc=\"Panasonic KX-MB1667\"
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtGeneralCurrentLocalization=2
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtLocalizationCharacterSet=2025
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesColorantIndex.1.1 = 0
D [14/Mar/2017:14:40:33 +0800] [Job 2] PDF template file doesn\'t have form. It\'s okay.
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesColorantIndex.1.2 = 0
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesClass.1.1 = 3
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesClass.1.2 = 3
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesType.1.1 = 3
D [14/Mar/2017:14:40:33 +0800] [Job 2] Printer make and model: Panasonic KX-MB1600series
D [14/Mar/2017:14:40:33 +0800] [Job 2] Running command line for pstops: pstops 2 gongyu \'Test Page\' 1 \'job-uuid=urn:uuid:d97fa48d-fbc6-34cb-4227-ba13e3edae50 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1489473632 time-at-processing=1489473632\'
D [14/Mar/2017:14:40:33 +0800] [Job 2] Using image rendering resolution 600 dpi
D [14/Mar/2017:14:40:33 +0800] [Job 2] Running command line for gs: gs -q -dNOPAUSE -dBATCH -dSAFER -sDEVICE=ps2write -sOUTPUTFILE=%stdout -dLanguageLevel=3 -r600 -dCompressFonts=false -dNoT3CCITT -dNOINTERPOLATE -c \'save pop\' -f /tmp/0133858d6af2c
D [14/Mar/2017:14:40:33 +0800] [Job 2] Started filter gs (PID 4924)
D [14/Mar/2017:14:40:33 +0800] [Job 2] Started filter pstops (PID 4925)
D [14/Mar/2017:14:40:33 +0800] [Job 2] PID 4918 (/usr/lib/cups/filter/bannertopdf) exited with no errors.
D [14/Mar/2017:14:40:33 +0800] [Job 2] PID 4919 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesType.1.2 = 9
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesDescription.1.1 = \"Toner\"
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesDescription.1.2 = \"Drum\"
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesSupplyUnit.1.1 = 7
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesSupplyUnit.1.2 = 7
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesMaxCapacity.1.1 = -2
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesMaxCapacity.1.2 = -2
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesLevel.1.1 = -3
D [14/Mar/2017:14:40:33 +0800] [Job 2] prtMarkerSuppliesLevel.1.2 = -3
D [14/Mar/2017:14:40:33 +0800] [Job 2] ATTR: marker-colors=none,none
D [14/Mar/2017:14:40:33 +0800] [Job 2] ATTR: marker-names=\'\"Toner\"\',\'\"Drum\"\'
D [14/Mar/2017:14:40:33 +0800] [Job 2] ATTR: marker-types=toner,opc
D [14/Mar/2017:14:40:33 +0800] [Job 2] ATTR: marker-levels=-1,-1
D [14/Mar/2017:14:40:33 +0800] [Job 2] new_supply_state=0, change_state=ffff
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -developer-low-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -developer-empty-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -marker-supply-low-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -marker-supply-empty-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -opc-near-eol-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -opc-life-over-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -toner-low-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -toner-empty-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -waste-receptacle-almost-full-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -waste-receptacle-full-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -cleaner-life-almost-over-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -cleaner-life-over-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] new_state=0, change_state=ffff
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -media-empty-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -door-open-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -media-jam-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -input-tray-missing-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -output-tray-missing-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -marker-supply-missing-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -output-area-almost-full-report
D [14/Mar/2017:14:40:33 +0800] [Job 2] STATE: -output-area-full-warning
D [14/Mar/2017:14:40:33 +0800] [Job 2] backendWaitLoop(snmp_fd=7, addr=0x5578d09305c8, side_cb=0x5578cf20b000)
D [14/Mar/2017:14:40:33 +0800] [Job 2] PID 4921 (/usr/lib/cups/filter/L_H0JDGCZAZ) crashed on signal 11.
D [14/Mar/2017:14:40:33 +0800] [Job 2] Hint: Try setting the LogLevel to "debug" to find out more.
D [14/Mar/2017:14:40:33 +0800] [Job 2] PID 4922 (/usr/lib/cups/backend/socket) exited with no errors.
D [14/Mar/2017:14:40:33 +0800] [Job 2] Page = 595x842; 12,12 to 583,830
D [14/Mar/2017:14:40:33 +0800] [Job 2] slow_collate=0, slow_duplex=0, slow_order=0
D [14/Mar/2017:14:40:33 +0800] [Job 2] Before copy_comments - %!PS-Adobe-3.0
D [14/Mar/2017:14:40:33 +0800] [Job 2] %!PS-Adobe-3.0
D [14/Mar/2017:14:40:33 +0800] [Job 2] %%BoundingBox: 0 0 595 842
D [14/Mar/2017:14:40:33 +0800] [Job 2] %%HiResBoundingBox: 0 0 595.00 842.00
D [14/Mar/2017:14:40:33 +0800] [Job 2] %%Creator: GPL Ghostscript 918 (ps2write)
D [14/Mar/2017:14:40:33 +0800] [Job 2] %%LanguageLevel: 2
D [14/Mar/2017:14:40:33 +0800] [Job 2] %%CreationDate: D:20170314144033+08\'00\'
D [14/Mar/2017:14:40:33 +0800] [Job 2] %%Pages: 1
D [14/Mar/2017:14:40:33 +0800] [Job 2] %%EndComments
D [14/Mar/2017:14:40:33 +0800] [Job 2] Before copy_prolog - %%BeginProlog
D [14/Mar/2017:14:40:33 +0800] [Job 2] Before copy_setup - %%Page: 1 1
D [14/Mar/2017:14:40:33 +0800] [Job 2] Before page loop - %%Page: 1 1
D [14/Mar/2017:14:40:33 +0800] [Job 2] Copying page 1...
D [14/Mar/2017:14:40:33 +0800] [Job 2] pagew = 571.0, pagel = 818.0
D [14/Mar/2017:14:40:33 +0800] [Job 2] bboxx = 0, bboxy = 0, bboxw = 595, bboxl = 842
D [14/Mar/2017:14:40:33 +0800] [Job 2] PageLeft = 12.0, PageRight = 583.0
D [14/Mar/2017:14:40:33 +0800] [Job 2] PageTop = 830.0, PageBottom = 12.0
D [14/Mar/2017:14:40:33 +0800] [Job 2] PageWidth = 595.0, PageLength = 842.0
D [14/Mar/2017:14:40:33 +0800] [Job 2] Wrote 1 pages...
D [14/Mar/2017:14:40:33 +0800] [Job 2] PID 4925 (pstops) exited with no errors.
D [14/Mar/2017:14:40:33 +0800] [Job 2] PID 4924 (gs) exited with no errors.
D [14/Mar/2017:14:40:33 +0800] [Job 2] PID 4920 (/usr/lib/cups/filter/pdftops) exited with no errors.
D [14/Mar/2017:14:40:33 +0800] [Job 2] End of messages
D [14/Mar/2017:14:40:33 +0800] [Job 2] printer-state=3(idle)
D [14/Mar/2017:14:40:33 +0800] [Job 2] printer-state-message="(PID 4921) Cannot load libgs or libgs version too old then 8.0"
D [14/Mar/2017:14:40:33 +0800] [Job 2] printer-state-reasons=none
Re: 网络打印机安装
刚才试了以下,直接用USB链接也打印不能,看来不是链接的问题
查看了错误报告,说unreportablereason 此软件可能没有正确安装
