为了解决显示器刷新率的问题,可以用dpkg-reconfigure xserver-xorg来重新设置。那就需要知道显示器场频和行频,下面把一些显示器场频和行频列表贴上,供大家参考。
# Each line has format:
# <Manufacturer>; <Monitor name>; <EISA ID (if any)>; <horiz sync in \
# Khz>; <verc sync in Hz>; DPMS support
# Horiz and vert sync can be a range; like 35.2-55.75; or 31.5,35.5
# BUT remember to use ';' to separate fields
Aamazing; Aamazing CM-8426; cm-8426; 31.0-60.0; 40.0-80.0; 1
Aamazing; Aamazing MS-8431; ms-8431; 15.0-36.0; 50.0-70.0; 1
Acer; Acer 11D; API440B; 31.0-35.5; 50.0-90.0
Acer; Acer 1455; API5514; 30.0-54.0; 50.0-120.0
Acer; Acer 1555; API5515; 30.0-54.0; 50.0-120.0
Acer; Acer 211c; API9708; 30.0-107.0; 50.0-160.0
Acer; Acer 33D; API4421; 31.0-35.5; 50.0-100.0
Acer; Acer 33DL; API4C21; 31.0-35.5; 50.0-100.0
Acer; Acer 34e-2; API9709; 30.0-54.0; 50.0-110.0
Acer; Acer 34e; API4522; 30.0-54.0; 50.0-110.0
Acer; Acer 34T; API5422; 31.0-48.0; 50.0-100.0
Acer; Acer 34TL; API4C22; 31.0-48.0; 50.0-100.0
Acer; Acer 35c; API9703; 30.0-54.0; 50.0-110.0
Acer; Acer 35c; API970A; 30.0-54.0; 50.0-110.0
Acer; Acer 54e; API4536; 31.0-54.0; 50.0-110.0
Acer; Acer 54es; API9715; 31.0-54.0; 50.0-110.0
Acer; Acer 55; API0037; 30.0-56.9; 50.0-80.0
Acer; Acer 55c; API9704; 30.0-54.0; 50.0-110.0
Acer; Acer 55e; API9701; 30.0-54.0; 50.0-110.0
Acer; Acer 55L; API4C37; 30.0-56.9; 50.0-80.0
Acer; Acer 56c; API9705; 30.0-69.0; 50.0-110.0
Acer; Acer 56e-2; API9710; 30.0-69.0; 50.0-110.0
Acer; Acer 56e; API4538; 30.0-69.0; 50.0-110.0
Acer; Acer 56i-2; API9712; 30.0-69.0; 50.0-110.0
Acer; Acer 56i; API4938; 30.0-69.0; 50.0-110.0
Acer; Acer 56is-2; API4138; 30.0-69.0; 50.0-110.0
Acer; Acer 56is; API0138; 30.0-69.0; 50.0-110.0
Acer; Acer 56j; API9713; 30.0-69.0; 50.0-110.0
Acer; Acer 56L; API4C38; 30.0-64.0; 50.0-110.0
Acer; Acer 57c; API971B; 30.0-70.0; 50.0-120.0
Acer; Acer 57e; API9809; 30.0-70.0; 50.0-110.0
Acer; Acer 57i; API971B; 30.0-70.0; 50.0-110.0
Acer; Acer 76c; API9706; 30.0-72.0; 50.0-120.0
Acer; Acer 76e; API9702; 30.0-72.0; 50.0-110.0
Acer; Acer 76i; API494C; 30.0-64.0; 50.0-110.0
Acer; Acer 76ie; API424C; 30.0-69.0; 50.0-110.0
Acer; Acer 76j; API9711; 30.0-72.0; 50.0-110.0
Acer; Acer 76N; API4E4C; 30.0-64.0; 50.0-110.0
Acer; Acer 76sl; API9717; 30.0-72.0; 50.0-110.0
Acer; Acer 77c; API9720; 30.0-72.0; 50.0-120.0
Acer; Acer 77c; API980A; 30.0-72.0; 50.0-120.0
Acer; Acer 77e; API971C; 30.0-72.0; 50.0-120.0
Acer; Acer 77e; API9808; 30.0-72.0; 50.0-120.0
Acer; Acer 78c; API9719; 30.0-86.0; 50.0-120.0
Acer; Acer 78c; API9805; 31.0-86.0; 50.0-120.0
Acer; Acer 78i; API494E; 30.0-82.0; 50.0-110.0
Acer; Acer 78ie; API424E; 30.0-86.0; 50.0-120.0
Acer; Acer 78ie; API454E; 30.0-86.0; 50.0-120.0
Acer; Acer 79g; API9716; 30.0-95.0; 50.0-160.0
Acer; Acer 79g; API971E; 30.0-95.0; 50.0-160.0
Acer; Acer 98e; API9806; 30.0-86.0; 50.0-160.0
Acer; Acer 98i; API4962; 30.0-82.0; 50.0-120.0
Acer; Acer 99c; API9718; 30.0-95.0; 50.0-160.0
Acer; Acer 99g; API9804; 30.0-107.0; 50.0-160.0
Acer; Acer 99sl; API9721; 30.0-98.0; 50.0-160.0
Acer; Acer FP500; API7606; 48.4; 60
Acer; Acer FP502; API760D; 48.4; 60
Acer; Acer FP51e; API760A; 31.5-60.0; 56.0-75.0
Acer; Acer FP550; API7612; 31.5-60.0; 56.0-75.0
Acer; Acer FP551; API7607; 31.5-60.0; 56.0-85.0
Acer; Acer FP555; API7609; 31.5-60.0; 56.0-75.0
Acer; Acer FP560; API7608; 48.4; 60
Acer; Acer FP561; API760B; 31.5-60.0; 56.0-75.0
Acer; Acer FP850; API7605; 31.5-80.0; 56.0-75.0
Acer; Acer FP851; API760C; 31.5-80.0; 56.0-75.0
Acer; Acer FP855; API7611; 31.5-80.0; 56.0-75.0
Acer; Acer G772; API9902; 30.0-72.0; 50.0-120.0
Acer; Acer LM551; API760E; 31.5-60.0; 56.0-85.0
Acer; Acer LM552; API760F; 48.4; 60
Acer; Acer LM554; API7610; 48.4; 60
Acer; Acer 11D; api440b; 31.0-40.0; 55.0-90.0; 1
Acer; Acer 15P; acer_15p; 15.0-70.0; 45.0-90.0; 1
Acer; Acer 33; acer_33; 31.0-38.0; 50.0-90.0; 1
Acer; Acer 33D; api4421; 31.0-40.0; 55.0-90.0; 1
Acer; Acer 33DL; api4c21; 31.0-40.0; 55.0-90.0; 1
Acer; Acer 34T; api5422; 31.0-50.0; 55.0-90.0; 1
Acer; Acer 34TL; api4c22; 31.0-50.0; 55.0-90.0; 1
Acer; Acer 35; acer_35; 30.0-55.0; 45.0-90.0; 1
Acer; Acer 55; api0037; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 55L; api4c37; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 56L; api4c38; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 7015; acer_7015; 15.0-36.0; 45.0-90.0; 1
Acer; Acer 7133s; api5321; 31.0-40.0; 55.0-90.0; 1
Acer; Acer 7134e; api4522; 31.0-60.0; 55.0-90.0; 1
Acer; Acer 7134s; api5322; 31.0-60.0; 55.0-90.0; 1
Acer; Acer 7154e; api4536; 31.0-60.0; 55.0-90.0; 1
Acer; Acer 7154s; api5336; 31.0-60.0; 55.0-90.0; 1
Acer; Acer 7156e; api4538; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 7156i; api4938; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 7156s; api5338; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 7176ie; api454c; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 7176is; api534c; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 7178ie; api454e; 31.0-90.0; 55.0-90.0; 1
Acer; Acer 76i; api494c; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 76N; api4e4c; 31.0-70.0; 55.0-90.0; 1
Acer; Acer 78i; api494e; 31.0-90.0; 55.0-90.0; 1
Acer; Acer 98i; api4962; 31.0-90.0; 55.0-90.0; 1
Acer; Acer F31; api1035; 31.5-60.0; 56.0-75.0; 1
Acer; Acer F31e; api7601; 31.5-60.0; 56.0-85.0; 1
Acer; Acer F50p; api7604; 48.4; 60; 1
Acer; Acer F51; api7602; 31.5-60.0; 56.0-85.0; 1
Acer; Aspire 33s; API5321; 31.0-35.5; 50.0-100.0
Acer; Aspire 34Ts; API5322; 31.0-48.0; 50.0-100.0
Acer; Aspire 54s; API5336; 30.0-54.0; 50.0-110.0
Acer; Aspire 55s; API9802; 30.0-54.0; 50.0-120.0
Acer; Aspire 56s; API5338; 30.0-66.0; 50.0-110.0
Acer; Aspire 76is; API414C; 30.0-69.0; 50.0-110.0
Acer; Aspire 76is; API534C; 30.0-69.0; 50.0-110.0
Acer; Aspire 77is; API9707; 30.0-69.0; 50.0-110.0
Acer; Aspire 77s; API9803; 30.0-72.0; 50.0-120.0
Action Systems, Inc.; Action Monitor CA-1454; ACI0608; 30.0-54.0; 50.0-100.0; 1
Action Systems, Inc.; Action Monitor CH-1999; ACI1999; 30.0-99.0; 50.0-160.0; 1
Action Systems, Inc.; Action Monitor CK-1566; ACI061E; 30.0-66.0; 50.0-120.0; 1
Action Systems, Inc.; Action Monitor CL-1999; ACI1999; 30.0-99.0; 50.0-160.0; 1
Action Systems, Inc.; Action Monitor CL-1792; ACI1792; 30.0-92.0; 50.0-160.0; 1
Action Systems, Inc.; Action Monitor CL-1770; ACI1770; 30.0-70.0; 50.0-120.0; 1
Action Systems, Inc.; Action Monitor CX-4158; ACI103E; 30.0-60.0; 50.0-100.0; 1
Action Systems, Inc.; Action Monitor CL-1766; ACI06E6; 30.0-66.0; 50.0-120.0; 1
Action Systems, Inc.; Action Monitor CX-1566; ACI061E; 30.0-66.0; 50.0-120.0; 1
Action Systems, Inc.; Action Monitor CA-1570; ACI0622; 30.0-70.0; 50.0-120.0; 1
Action Systems, Inc.; Action Monitor CK-4148; ACI1034; 30.0-50.0; 50.0-85.0; 1
Action Systems, Inc.; AXION LCD Monitor LA-1560U; ACI1560; 30.0-60.0; 50.0-75.0; 1
Action Systems, Inc.; Action Monitor CL-1566; ACI061E; 30.0-66.0; 50.0-120.0; 1
Action Systems, Inc.; Action Monitor CL-1570; ACI1570; 30.0-70.0; 50.0-120.0; 1
Action Systems, Inc.; Action Monitor CK-4158; ACI103E; 30.0-60.0; 50.0-100.0; 1
Actix; Actix Systems CX1557; cx1557; 30.0-57.0; 40.0-100.0; 1
Adara; Adara AML-1402; aml-1402; 15.0-36.0; 45.0-90.0; 1
Adara; Adara AML-2001; aml-2001; 30.0-36.5; 50.0-90.0; 1
ADI; ADI DMC-2304; adidmc; 30.6-36.0; 50.0-90.0; 1
ADI; ADI Duo; adi1430; 30.0-69.0; 50.0-120.0; 1
ADI; ADI Duo; adi1452; 30.0-69.0; 50.0-120.0; 1
ADI; ADI Duo; adi1453; 30.0-69.0; 50.0-120.0; 1
ADI; ADI Duo; adi1454; 30.0-69.0; 50.0-120.0; 1
ADI; ADI Duo; adi1455; 30.0-69.0; 50.0-120.0; 1
ADI; ADI MicroScan 17; adi1130; 30.0-87.5; 50.0-120.0; 1
ADI; ADI MicroScan 17; adi1131; 30.0-87.5; 50.0-120.0; 1
ADI; ADI MicroScan 17; adi1140; 30.0-87.5; 50.0-120.0; 1
ADI; ADI MicroScan 17; adi1150; 30.0-87.5; 50.0-120.0; 1
ADI; ADI MicroScan 17X; adi0e30; 24.6-60.0; 50.0-120.0; 1
ADI; ADI MicroScan 17X; adi0e31; 24.6-60.0; 50.0-120.0; 1
ADI; ADI MicroScan 17X; adi0e32; 24.6-60.0; 50.0-120.0; 1
ADI; ADI MicroScan 17X; adi0e40; 24.6-60.0; 50.0-120.0; 1
ADI; ADI MicroScan 17X+; adi0f30; 24.6-60.0; 50.0-120.0; 1
ADI; ADI MicroScan 17X+; adi0f40; 24.6-60.0; 50.0-120.0; 1
ADI; ADI MicroScan 2E; sm5514b; 30.0-38.0; 50.0-100.0; 1
ADI; ADI MicroScan 3E; sm5514a; 30.0-50.0; 50.0-100.0; 1
ADI; ADI MicroScan 3E+; sm-5514e; 30.0-58.0; 50.0-100.0; 1
ADI; ADI MicroScan 3V; adi0610; 24.6-48.9; 50.0-100.0; 1
ADI; ADI MicroScan 3V; adi0620; 24.6-48.9; 50.0-100.0; 1
ADI; ADI MicroScan 3V; adi0630; 24.6-48.9; 50.0-100.0; 1
ADI; ADI MicroScan 3V; adi0638; 24.6-48.9; 50.0-100.0; 1
ADI; ADI MicroScan 3V; adi0640; 24.6-48.9; 50.0-100.0; 1
ADI; ADI MicroScan 4A; sm-5515; 30.0-58.0; 50.0-100.0; 1
ADI; ADI MicroScan 4G; adi4g; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 4GP; adi4gp; 30-64; 50-100; 1
ADI; ADI MicroScan 4P/4P+; adi1630; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1632; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1633; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1634; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1635; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1640; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1642; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1643; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1644; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1645; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1650; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1653; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1654; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1655; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1f30; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1f40; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi1f50; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi2130; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi2140; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi2150; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi2530; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi2540; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4P/4P+; adi2550; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 4V; adi0730; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi0739; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi073c; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi073e; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi073f; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi0740; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi0750; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi0755; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi0940; 30-64; 50-100; 1
ADI; ADI MicroScan 4V; adi4v; 30-64; 50-95; 1
ADI; ADI MicroScan 5AP; adi5ap; 30-64; 50-100; 1
ADI; ADI MicroScan 5EP; adi5ep; 30-64; 50-100; 1
ADI; ADI MicroScan 5G; adi1550; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1552; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1553; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1554; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1555; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1556; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1572; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1c50; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5G; adi1c52; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 5L; adi3e50; 30.0-56.0; 50.0-100.0; 1
ADI; ADI MicroScan 5L; adi3f50; 30.0-56.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1730; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1733; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1734; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1735; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1740; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1743; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1750; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1751; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1753; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1754; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1755; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi1772; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2230; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2240; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2250; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2430; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2440; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2443; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2444; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2445; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2450; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2480; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2481; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2630; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2640; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5P/5P+; adi2650; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan 5T; adi3650; 30.0-56.0; 50.0-100.0; 1
ADI; ADI MicroScan 5T; adi3750; 30.0-56.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V; adi0b30; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V; adi0b32; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V; adi0b35; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V; adi0b40; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V; adi0b50; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V+; adi0c30; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V+; adi0c32; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V+; adi0c40; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V+; adi0c50; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V+; adi0c51; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 5V+; adi0d40; 30.0-64.0; 50.0-100.0; 1
ADI; ADI MicroScan 6G; adi1250; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1252; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1253; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1254; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1255; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1256; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1257; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1270; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6G; adi1272; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6L; adi4050; 30.0-56.0; 50.0-100.0; 1
ADI; ADI MicroScan 6P; adi2050; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6P; adi20b0; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6P; adi20b1; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6P; adi20b2; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6P; adi20b3; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6P; adi20b4; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan 6P; adi20b5; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan G55; adi3630; 30.0-86.0; 50.0-120.0; 1
ADI; ADI MicroScan G56; adi3730; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan G60; adi3930; 30.0-86.0; 50.0-120.0; 1
ADI; ADI MicroScan G66; adi3e50; 30.0-95.0; 50.0-120.0; 1
ADI; ADI MicroScan G70; adi3830; 30.0-110.0; 50.0-120.0; 1
ADI; ADI MicroScan P40; adi2c30; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan P50; adi3330; 30.0-69.0; 50.0-100.0; 1
ADI; ADI MicroScan P55; adi3430; 30.0-82.0; 50.0-120.0; 1
ADI; ADI ProVista 14; adi1350; 30.6-48.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1830; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1832; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1833; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1834; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1835; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1836; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1840; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E30; adi1843; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E33; adi2d30; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E35; adi2330; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E35; adi2332; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E35; adi2340; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E35; adi2342; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E35; adi2350; 30.0-54.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1930; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1932; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1933; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1934; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1935; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1936; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1937; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1938; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1940; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1942; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1943; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1944; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1950; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E40; adi1952; 30.0-64.0; 50.0-100.0; 1
ADI; ADI ProVista E44; adi2e30; 30.0-69.0; 50.0-100.0; 1
ADI; ADI ProVista E55; adi4430; 30.0-69.0; 50.0-100.0; 1
ADI; ADI ProVista E66; adi3e30; 30.0-86.0; 50.0-120.0; 1
ADI; ADI adiv30; adi3230; 30.0-48.5; 50.0-100.0; 1
AOC; AOC CM-324; cm-324; 15.0-37.0; 50.0-90.0; 1
AOC; AOC CM-325; cm-325; 31.0-38.0; 50.0-90.0; 1
AOC; AOC CM-326; cm-326; 15.0-38.0; 50.0-90.0; 1
AOC; AOC Monochrome MM-415; mm-415; 30.0-38.0; 50.0-90.0; 1
AOC; AOC SPECTRUM 21Hlr; aoce2182; 30.0-66.0; 50.0-100.0; 1
AOC; AOC SPECTRUM 4V,4VA,4Vlr & 4VlrA, 4Vn, 4VnA; aocd350; 30.0-50.0; 50.0-100.0; 1
AOC; AOC SPECTRUM 4Vlr & 4VlrA & 4V & 4VA; aocd356; 30.0-54.0; 50.0-120.0; 1
AOC; AOC SPECTRUM 5Elr & 5ElrA & 5E & 5EA; aocd556; 30.0-54.0; 50.0-120.0; 1
AOC; AOC SPECTRUM 5Glr & 5GlrA & 5Glr+ & 5GlrA+; aoc569e; 30.0-69.0; 50.0-120.0; 1
AOC; AOC SPECTRUM 5Glr; aoce570; 30.0-64.0; 50.0-120.0; 1
AOC; AOC SPECTRUM 5Llr & 5LlrA; aocc564; 30.0-64.0; 50.0-90.0; 1
AOC; AOC SPECTRUM 5Nlr; aoca566; 30.0-66.0; 50.0-100.0; 1
AOC; AOC SPECTRUM 5Nlr; aoca569; 30.0-69.0;50.0-120; 1
AOC; AOC SPECTRUM 5Vlr & 5VlrA; aocd566; 30.0-66.0; 50.0-100.0; 1
AOC; AOC SPECTRUM 7Clr; aocf764; 30.0-64.0; 47.0-100.0; 1
AOC; AOC SPECTRUM 7Dlr & 7DlrA; aoce750; 30.0-68.0; 50.0-120.0; 1
AOC; AOC SPECTRUM 7Glr & 7GlrA; aoca785; 30.0-85.0; 50.0-130.0; 1
AOC; AOC SPECTRUM 7Nlr; aoca782; 30.0-82.0; 50.0-110.0; 1
AOC; AOC SPECTRUM 7Vlr & 7VlrA & 7Vlr+ & 7VlrA+; aoca770; 30.0-70.0; 50.0-130.0; 1
AOC; AOC SPECTRUM 9Glr; aoce995; 30.0-95.0; 47.0-150.0; 1
Apollo; Apollo 1280x1024-68Hz; 0; 73.702; 68.24
Apollo; Apollo 1280x1024-70Hz; 0; 75.118; 70.07
Apple; HiRes Display 1152x864; 0; 30.0-100.0; 50.0-160.0
Apple; HiRes Display 1280x1024; 0; 30.0-130.0; 50.0-160.0
Apple; LoRes Display 640x480; 0; 28.0-33.0; 43.0-72.0
Apple; Studio Display 17 1280x1024; 0; 30.0-85.0; 48.0-160.0
Apple; TiPowerBook 1152x768; 0; 30.0-100.0; 50.0-160.0
Apple; iBook 800x600; 0; 28.0-50.0; 43.0-75.0
Apple; iBook2 1024x768; 0; 28.0-49.0; 43.0-72.0
Apple; iMac/PowerBook 1024x768; 0; 30.0-70.0; 50.0-160.0
AST; AST Sabre; ast8009; 30.0-64.0; 50.0-90.0; 1
AST; AST Vision 20H; ast8008; 29.0-82.0; 50.0-150.0; 1
AST; AST Vision 4I; ast8002; 30.0-38.0; 50.0-90.0; 1
AST; AST Vision 4L; ast8004; 30.0-64.0; 50.0-90.0; 1
AST; AST Vision 4N; ast8003; 30.0-64.0; 50.0-90.0; 1
AST; AST Vision 4V; ast8001; 31.5; 60.0-70.0; 1
AST; AST Vision 5L; ast8005; 30.0-64.0; 50.0-90.0; 1
AST; AST Vision 5V; ast800a; 30.0-50.0; 50.0-120.0; 1
AST; AST Vision 7H; ast8007; 30.0-82.0; 50.0-90.0; 1
AST; AST Vision 7L; ast8006; 30.0-64.0; 50.0-90.0; 1
AT&T; AT&T 14 in. Color Economy; 0; 31.5; 50-90
AT&T; AT&T 14 in. Color Economy; 0; 35.0; 50-90
AT&T; AT&T 14 in. Color Value; 0; 31.5; 50-90
AT&T; AT&T 14 in. Color Value; 0; 38.0; 50-90
AT&T; AT&T 14 in. Color Value; 0; 48.0; 50-90
AT&T; AT&T 14 in. Mono; 0; 31; 55-75
AT&T; AT&T 15 in. Color; 0; 30-64; 50-90
AT&T; AT&T 17 in. Color Professional; 0; 30-82; 50-160
AT&T; AT&T 17 in. Color Value; 0; 30-64; 50-90
AT&T; AT&T CRT-365; 0; 30.0-75.0; 60.0-70.0
AT&T; AT&T CRT-395; 0; 30.0-66.0; 50.0-90.0
Belinea; Belinea 101410; 0; 24-61.0; 50.0-77.0
Belinea; Belinea 101510; 0; 24-61.0; 50.0-77.0
Belinea; Belinea 101520; 0; 48.0-48.0; 60.0-60.0
Belinea; Belinea 101530; 0; 30.0-70.0; 50.0-85.0
Belinea; Belinea 101550; 0; 30.0-70.0; 50.0-85.0
Belinea; Belinea 101810; 0; 31.0-80.0; 60.0-85.0
Belinea; Belinea 102010; 0; 30.0-54.0; 50.0-120.0
Belinea; Belinea 102020; 0; 30.0-70.0; 50.0-120.0
Belinea; Belinea 102030; 0; 30.0-70.0; 50.0-120.0
Belinea; Belinea 103010; 0; 30.0-70.0; 50.0-150.0
Belinea; Belinea 103015; 0; 30.0-70.0; 50.0-120.0
Belinea; Belinea 103020; 0; 30.0-70.0; 50.0-120.0
Belinea; Belinea 103030; 0; 30.0-70.0; 50.0-150.0
Belinea; Belinea 103040; 0; 30.0-86.0; 50.0-150.0
Belinea; Belinea 103050; 0; 30.0-95.0; 50.0-160.0
Belinea; Belinea 103060; 0; 30.0-95.0; 50.0-150.0
Belinea; Belinea 103070; 0; 30.0-95.0; 50.0-160.0
Belinea; Belinea 104010; 0; 30.0-54.0; 50.0-120.0
Belinea; Belinea 104040; 0; 30.0-38.0; 50.0-90.0
Belinea; Belinea 104050; 0; 31.5-50.0; 50.0-100.0
Belinea; Belinea 104060; 0; 30.0-50.0; 50.0-100.0
Belinea; Belinea 104065; 0; 30.0-50.0; 50.0-120.0
Belinea; Belinea 104070; 0; 30.0-38.0; 50.0-90.0
Belinea; Belinea 105030; 0; 30.0-64.0; 50.0-100.0
Belinea; Belinea 105035; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105045; 0; 30.0-70.0; 50.0-120.0
Belinea; Belinea 105046; 0; 30.0-70.0; 50.0-120.0
Belinea; Belinea 105050; 0; 30.0-64.0; 50.0-100.0
Belinea; Belinea 105060; 0; 30.0-64.0; 50.0-90.0
Belinea; Belinea 105065; 0; 30.0-64.0; 50.0-100.0
Belinea; Belinea 105066; 0; 30.0-65.0; 50.0-120.0
Belinea; Belinea 105070; 0; 30.0-65.0; 50.0-100.0
Belinea; Belinea 105075; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105076; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105080; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105090; 0; 30.0-64.0; 55.0-90.0
Belinea; Belinea 105095; 0; 30.0-64.0; 55.0-120.0
Belinea; Belinea 105520; 0; 30.0-64.0; 50.0-100.0
Belinea; Belinea 105540; 0; 30.0-64.0; 50.0-90.0
Belinea; Belinea 105550; 0; 24.0-69.0; 50.0-120.0
Belinea; Belinea 105560; 0; 24.0-68.0; 50.0-100.0
Belinea; Belinea 105570; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105575; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105576; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105586; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 105590; 0; 30.0-85.0; 50.0-120.0
Belinea; Belinea 105595; 0; 30.0-85.0; 50.0-120.0
Belinea; Belinea 105596; 0; 30.0-85.0; 50.0-120.0
Belinea; Belinea 106020; 0; 30.0-95.0; 50.0-150.0
Belinea; Belinea 106030; 0; 30.0-96.0; 50.0-160.0
Belinea; Belinea 106040; 0; 30.0-82.0; 50.0-90.0
Belinea; Belinea 106050; 0; 30.0-85.0; 50.0-120.0
Belinea; Belinea 106060; 0; 30.0-95.0; 50.0-160.0
Belinea; Belinea 106070; 0; 30.0-95.0; 50.0-180.0
Belinea; Belinea 106090; 0; 30.0-95.0; 50.0-150.0
Belinea; Belinea 107010; 0; 30.0-69.0; 50.0-160.0
Belinea; Belinea 107015; 0; 30.0-70.0; 50.0-180.0
Belinea; Belinea 107020; 0; 30.0-70.0; 50.0-120.0
Belinea; Belinea 107025; 0; 30.0-70.0; 50.0-180.0
Belinea; Belinea 107030; 0; 30.0-86.0; 50.0-160.0
Belinea; Belinea 107035; 0; 30.0-95.0; 50.0-180.0
Belinea; Belinea 107040; 0; 30.0-85.0; 50.0-120.0
Belinea; Belinea 107050; 0; 30.0-95.0; 50.0-160.0
Belinea; Belinea 107060; 0; 30.0-69.0; 50.0-120.0
Belinea; Belinea 107065; 0; 30.0-95.0; 50.0-160.0
Belinea; Belinea 108010; 0; 30.0-115.0; 50.0-160.0
Belinea; Belinea 108015; 0; 30.0-115.0; 50.0-160.0
Belinea; Belinea 108020; 0; 30.0-107.0; 50.0-160.0
Belinea; Belinea 108050; 0; 30.0-95.0; 50.0-160.0
Belinea; Belinea 108060; 0; 30.0-115.0; 50.0-160.0
Belinea; Belinea 108090; 0; 30.0-95.0; 50.0-160.0
Belinea; Belinea 108095; 0; 30.0-95.0; 50.0-160.0
Bridge; Bridge BM17C; brg00ab; 30.0-70.0; 50.0-160.0; 1
Bus Computer Systems; Bus Computer Systems Bus_VGA; bus_vga; 31.5-38.0; 50.0-70.0; 1
Carroll Touch; Carroll Touch CT1381A; ct1381a; 15.7-38.0; 45.0-90.0; 1
Colorgraphic; Colorgraphic EG2040; eg2040; 20.0-40.0; 40.0-100.0; 1
Compaq; Compaq 1024; cpq0011; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0012; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0013; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0014; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0015; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0016; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0100; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0146; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 1024; cpq0147; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 140; cpq0d46; 31-49; 48-80; 1
Compaq; Compaq 140; cpq0d47; 31-49; 48-80; 1
Compaq; Compaq 140; cpq0d48; 31-49; 48-80; 1
Compaq; Compaq 140; cpq0d49; 31-49; 48-80; 1
Compaq; Compaq 140; cpq0d4a; 31-49; 48-80; 1
Compaq; Compaq 140; cpq0d4b; 31-49; 48-80; 1
Compaq; Compaq 140; cpq0d4c; 31-49; 48-80; 1
Compaq; Compaq 140; cpq0d4d; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f46; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f47; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f48; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f49; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f4a; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f4b; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f4c; 31-49; 48-80; 1
Compaq; Compaq 150; cpq0f4d; 31-49; 48-80; 1
Compaq; Compaq 151FS; cpq0022; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0023; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0024; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0025; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0026; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0027; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0028; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0346; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0347; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0348; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq0349; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq034a; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 151FS; cpq034b; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq002d; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq002e; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq002f; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0030; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0031; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0032; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0033; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0546; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0547; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0548; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 171FS; cpq0549; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq 172; cpq_172; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq Advanced Graphics; ags; 54.0; 50.0-75.0; 1
Compaq; Compaq Internal VGA Panel; ivga; 31.5; 50.0-70.0; 1
Compaq; Compaq P70 Color Monitor; cpq1320; 30.0-92.0; 48.0-150.0; 1
Compaq; Compaq P75 Color Monitor; cpq1330; 30.0-85.0; 50.0-150.0; 1
Compaq; Compaq P110 Color Monitor; cpq1321; 30.0-107.0; 48.0-160.0; 1
Compaq; Compaq P710 Color Monitor; cpq1384; 30.0-96.0; 50.0-130.0; 1
Compaq; Compaq P900 Color Monitor; cpq1353; 30.0-107.0; 50.0-120.0; 1
Compaq; Compaq P910 Color Monitor; cpq1385; 30.0-108.0; 50.0-140.0; 1
Compaq; Compaq P1210 Color Monitor; cpq1386; 30.0-121.0; 50.0-160.0; 1
Compaq; Compaq P1610 Color Monitor; cpq1327; 30.0-96.0; 48.0-160.0; 1
Compaq; Compaq Presario 140; cpq0017; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq0018; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq0019; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq001a; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq0020; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq0021; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq0746; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq0747; 31-62; 48-90; 1
Compaq; Compaq Presario 140; cpq0846; 31-49; 48-80; 1
Compaq; Compaq Presario 140; cpq0847; 31-49; 48-80; 1
Compaq; Compaq Presario 140; cpq0848; 31-49; 48-80; 1
Compaq; Compaq Presario 140; cpq0849; 31-49; 48-80; 1
Compaq; Compaq Presario 140; cpq084a; 31-49; 48-80; 1
Compaq; Compaq Presario 140; cpq084b; 31-49; 48-80; 1
Compaq; Compaq Presario 140; cpq084c; 31-49; 48-80; 1
Compaq; Compaq Presario 140; cpq084d; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0029; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq002a; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq002b; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq002c; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq0946; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq0947; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq0948; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq0949; 31-62; 48-90; 1
Compaq; Compaq Presario 150; cpq0a46; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0a47; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0a48; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0a49; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0a4a; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0a4b; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0a4c; 31-49; 48-80; 1
Compaq; Compaq Presario 150; cpq0a4d; 31-49; 48-80; 1
Compaq; Compaq Presario Integrated Monitor; pres; 35.2-38.0; 56.0-60.0; 1
Compaq; Compaq Presario MV400 Color Monitor; cpq3014; 31-50; 50-90; 1
Compaq; Compaq Presario MV500 Color Monitor; cpq3012; 31-54; 50-90; 1
Compaq; Compaq Presario MV700 Color Monitor; cpq3013; 30-70; 50-100; 1
Compaq; Compaq QVision 150; cpq_qv150; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq QVision 170; cpq_qv170; 31.5-57.0; 50.0-90.0; 1
Compaq; Compaq QVision 172; cpq0040; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 172; cpq0041; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 172; cpq0042; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 200; cpq0043; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 200; cpq0044; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 200; cpq0045; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 210; cpq0046; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 210; cpq0047; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 210; cpq0048; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq QVision 210; cpq0049; 31.5-82.0; 50.0-90.0; 1
Compaq; Compaq S500 Color Monitor; cpq1356; 30.0-54.0; 50.0-120.0; 1
Compaq; Compaq S510 Color Monitor; cqp1371; 30.0-61.0; 50.0-120.0; 1
Compaq; Compaq S700 Color Monitor; cpq1349; 30.0-70.0; 50.0-160.0; 1
Compaq; Compaq S710 Color Monitor; cpq1362; 30.0-70.0; 50.0-160.0; 1
Compaq; Compaq S900 Color Monitor; cpq1350; 30.0-95.0; 50.0-160.0; 1
Compaq; Compaq S910 Color Monitor; cpq1361; 30.0-95.0; 50.0-160.0; 1
Compaq; Compaq SVGA; svga; 35.2-38.0; 56.0-60.0; 1
Compaq; Compaq TFT450 Flat Panel Monitor; cpq1333; 31.5-60.0; 56.3-85.0; 1
Compaq; Compaq TFT500 Flat Panel Monitor; cpq1324; 32.0-60.0; 57.0-85.0; 1
Compaq; Compaq TFT5000 Flat Panel Monitor; cpq1341; 32.0-60.0; 57.0-85.0; 1
Compaq; Compaq TFT5005 Flat Panel Monitor; cpq1383; 24.0-61.0; 56.0-75.0; 1
Compaq; Compaq TFT5010 Flat Panel Monitor; cpq1370; 31.5-60.0; 58.0-78.75; 1
Compaq; Compaq TFT8000 Flat Panel Monitor; cpq1329; 31.0-80.0; 58.0-85.0; 1
Compaq; Compaq TFT8020 Flat Panel Monitor; cpq1345; 31.5-80.0; 58.0-85.0; 1
Compaq; Compaq V40 Color Monitor; cpq1334; 31.0-48.0; 50.0-100.0; 1
Compaq; Compaq V45 Color Monitor; cpq1338; 31-48; 50-100; 1
Compaq; Compaq V50 Color Monitor; cpq1322; 30.0-60.0; 50-125.0; 1
Compaq; Compaq V55 Color Monitor; cpq1331; 30.0-60.0; 47.5-125.0; 1
Compaq; Compaq V70 Color Monitor; cpq170a; 30.0-69.0; 50-125.0; 1
Compaq; Compaq V75 Color Monitor; cpq1332; 31.5-69.0; 50.0-100.0; 1
Compaq; Compaq V700 Color Monitor; cpq1340; 30.0-85.0; 50.0-160.0; 1
Compaq; Compaq V710 Color Monitor; cpq1382; 30.0-85.0; 50.0-160.0; 1
Compaq; Compaq V900 Color Monitor; cpq1325; 30.0-96.0; 48.0-160.0; 1
Compaq; Compaq V1000 Color Monitor; cpq1347; 30.0-107.0; 48.0-160.0; 1
Compaq; Compaq V1100 Color Monitor; cpq1336; 30.0-107.0; 48.0-160.0; 1
Compaq; Compaq VGA; cvga; 31.5; 50.0-70.0; 1
Compdyne; Compudyne KD-1500N; 0; 30.00-66; 50-90
Compeq USA/Focus; Compeq CT-1458; ct-1458; 15.0-48.0; 47.0-100.0; 1
Compeq USA/Focus; Compeq CT-1958; ct-1958; 15.0-51.0; 47.0-100.0; 1
Conrac; Conrac 7126; 7126; 15.0-32.0; 48.0-75.0; 1
Conrac; Conrac 7211; 7211; 15.0-37.0; 47.0-80.0; 1
Conrac; Conrac 7214; 7214; 15.0-37.5; 48.0-90.0; 1
Conrac; Conrac 7241; 7241; 15.0-37.0; 47.0-80.0; 1
Conrac; Conrac 7250; 7250; 15.5-37.0; 47.0-80.0; 1
Conrac; Conrac 7351; 7351; 62.5-67.5; 47.0-63.0; 1
Conrac; Conrac 7550; 7550; 46.0-80.0; 47.0-80.0; 1
Conrac; Conrac 9250; 9250; 15.0-37.5; 48.0-90.0; 1
Cordata; Cordata CMC-141M; cmc-141m; 15.5-39.0; 50.0-70.0; 1
Cordata; Cordata CMC-1500BF; cmc-1500bf; 15.5-39.0; 50.0-90.0; 1
Cordata; Cordata CMC-1500M; cmc-1500m; 30.0-65.0; 50.0-90.0; 1
Cordata; Cordata CMC-1500TF; cmc-1500tf; 35.0-38.5; 50.0-90.0; 1
Cordata; Cordata CMC-1700M; cmc-1700m; 30.0-65.0; 50.0-90.0; 1
Cordata; Cordata CMC-2100H; cmc-2100h; 60.0-65.0; 50.0-85.0; 1
Cordata; Cordata CMC-2100M; cmc-2100m; 30.0-65.0; 50.0-90.0; 1
Cornerstone; Cornerstone c1001; crn000e; 31.0-95.0; 50.0-160.0; 1
Cornerstone; Cornerstone c700; crn000a; 31.0-95.0; 50.0-130.0; 1
Cornerstone; Cornerstone c900; 0; 30.0-95.0; 50.0-180.0
Cornerstone; Cornerstone Color 20/70; 0; 60.0-87.0; 60.0-120.0
Cornerstone; Cornerstone Color 20/77; 0; 31.0-96.0; 50.0-160.0
Cornerstone; Cornerstone Color 21/75; 0; 30.0-94.0; 50.0-150.0
Cornerstone; Cornerstone Color 40/95; 0; 30.0-95.0; 50.0-180.0
Cornerstone; Cornerstone Color 45/101sf; 0; 31.0-100.7; 50.0-160.0
Cornerstone; Cornerstone Color 50/101sf, 21/81; 0; 31.0-100.7; 50.0-160.0
Cornerstone; Cornerstone p1400; crn000d; 31.0-107.0; 50.0-160.0; 1
Cornerstone; Cornerstone p1401; crn0016; 31.0-110.0; 50.0-180.0; 1
Cornerstone; Cornerstone p1500; crn000f; 31.0-107.0; 50.0-160.0; 1
Cornerstone; Cornerstone p1600; crn0010; 31.0-117.0; 50.0-160.0; 1
Cornerstone; Cornerstone p1700; crn0012; 31.0-130.0; 50.0-160.0; 1
Cornerstone; Cornerstone v300; crn0013; 31.0-93.0; 50.0-160.0; 1
CTX; CTX 5090; ctx5090; 30.0-107.0; 50.0-160.0; 1
CTX; CTX 1451; ctx1451; 30.0-50.0; 45.0-90.0; 1
CTX; CTX 1451ES; ctx-1451es; 30-50; 50-90; 1
CTX; CTX 1451GM; ctx-1451gm; 30-50; 50-90; 1
CTX; CTX 1462GM; ctx-1462; 30.0-62.0; 50.0-90.0; 1
CTX; CTX 1551; ctx1551; 30.0-50.0; 45.0-90.0; 1
CTX; CTX 1562; ctx1562; 30.0-62.0; 45.0-90.0; 1
CTX; CTX 1562ES; ctx-1562es; 30-62; 50-90; 1
CTX; CTX 1562GM; ctx-1562gm; 30-62; 50-90; 1
CTX; CTX 1565; ctx1565; 30.0-65.0; 45.0-90.0; 1
CTX; CTX 1565; ctx5650; 30.0-65.0; 50.0-100.0; 1
CTX; CTX 1565GM; ctx-1565gm; 30.0-65.0; 50.0-90.0; 1
CTX; CTX 1569; ctx0150; 30.0-70.0; 50.0-130.0; 1
CTX; CTX 15-Group 65KHz/100Hz Monitor; ctx3500; 30.0-65.0; 50.0-100.0; 1
CTX; CTX 1765; ctx1765; 30.0-65.0; 45.0-110.0; 1
CTX; CTX 1765GM; ctx-1765gm; 30.0-65.0; 50.0-100.0; 1
CTX; CTX 1769UA; 0; 30.0-70.0; 50.0-160.0
CTX; CTX 1785; ctx1785; 30.0-85.0; 45.0-110.0; 1
CTX; CTX 1785GM; ctx-1785gm; 30.0-85.0; 50.0-100.0; 1
CTX; CTX 1792UA; 0; 30.0-95.0; 50.0-160.0
CTX; CTX 1792UD; 0; 30.0-95.0; 50.0-160.0
CTX; CTX 19D-Group 107KHz/160Hz Monitor; ctx5100; 30.0-107.0; 50.0-160.0; 1
CTX; CTX 2085; ctx2085; 30.0-85.0; 45.0-110.0; 1
CTX; CTX 2185; ctx2185; 30.0-85.0; 45.0-110.0; 1
CTX; CTX 960D Class Monitor; ctx5102; 30.0-107.0; 50.0-160.0; 1
CTX; CTX 960T Class Monitor; ctx5092; 30.0-107.0; 50.0-160.0; 1
CTX; CTX CPS-1460; cps-1460; 30.0-60.0; 50.0-90.0; 1
CTX; CTX CPS-1560; cps-1560; 30.0-60.0; 50.0-90.0; 1
CTX; CTX CPS-1561; cps-1561; 30.0-60.0; 50.0-90.0; 1
CTX; CTX CPS-1750; cps-1750; 30.0-60.0; 50.0-90.0; 1
CTX; CTX CPS-1760; cps-1760; 30.0-65.0; 50.0-90.0; 1
CTX; CTX CPS-2160; cps-2160; 30.0-65.0; 50.0-100.0; 1
CTX; CTX CPS-2180; cps-2180; 30.0-80.0; 50.0-100.0; 1
CTX; CTX CVP-5439; cvp-5439; 30.0-35.0; 50.0-90.0; 1
CTX; CTX CVP-5468; cvp-5468; 30.0-38.0; 50.0-90.0; 1
CTX; CTX CVP-5468NI; cvp-5468ni; 44.0-50.0; 50.0-90.0; 1
CTX; CTX CVP-5468NL; cvp-5468nl; 30.0-38.0; 50.0-90.0; 1
CTX; CTX CVS-3436; cvp-3436; 15.0-38.0; 50.0-90.0; 1
CTX; CTX CVS-3450; cvp-3450; 20.0-38.0; 50.0-90.0; 1
CTX; CTX EX1200 series; ctx3800; 30.0-95.0; 50.0-160.0; 1
CTX; CTX EX1200 series; ctx3810; 30.0-95.0; 50.0-160.0; 1
CTX; CTX EX1300; ctx3900; 30.0-110.0; 50.0-160.0; 1
CTX; CTX EX1300; ctx3902; 30.0-110.0; 50.0-160.0; 1
CTX; CTX EX1300 series; ctx3911; 30.0-110.0; 50.0-160.0; 1
CTX; CTX EX700; ctx3670; 30.0-85.0; 50.0-120.0; 1
CTX; CTX EX800; ctx3720; 30.0-85.0; 50.0-120.0; 1
CTX; CTX EX900; ctx3750; 30.0-85.0; 50.0-120.0; 1
CTX; CTX EX960 series; ctx3780; 30.0-107.0; 50.0-160.0; 1
CTX; CTX EX960 series; ctx3781; 30.0-107.0; 50.0-160.0; 1
CTX; CTX MS600; ctx3600; 30.0-60.0; 50.0-120.0; 1
CTX; CTX Multiscan 3436; multiscan-3436; 15.0-38.0; 50.0-90.0; 1
CTX; CTX PR1200 series; ctx3830; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR1200 series; ctx3831; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR1250 series; ctx3835; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR1250 series; ctx3836; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR1300 series; ctx3904; 30.0-110.0; 50.0-160.0; 1
CTX; CTX PR1300 series; ctx3905; 30.0-110.0; 50.0-160.0; 1
CTX; CTX PR1350 series; ctx3907; 30.0-110.0; 50.0-160.0; 1
CTX; CTX PR1350 series; ctx3908; 30.0-110.0; 50.0-160.0; 1
CTX; CTX PR1400F; ctx3920; 30.0-125.0; 50.0-160.0; 1
CTX; CTX PR1400 series; ctx3915; 30.0-115.0; 50.0-160.0; 1
CTX; CTX PR1400 series; ctx3916; 30.0-115.0; 50.0-160.0; 1
CTX; CTX PR1450 series; ctx3918; 30.0-115.0; 50.0-160.0; 1
CTX; CTX PR1450 series; ctx3919; 30.0-115.0; 50.0-160.0; 1
CTX; CTX PR500 series; ctx3524; 30.0-70.0; 50.0-160.0; 1
CTX; CTX PR500 series; ctx3525; 30.0-70.0; 50.0-160.0; 1
CTX; CTX PR500 series; ctx5694; 30.0-70.0; 50.0-160.0; 1
CTX; CTX PR700 series; ctx5010; 30.0-70.0; 50.0-160.0; 1
CTX; CTX PR700 series; ctx7691; 30.0-70.0; 50.0-160.0; 1
CTX; CTX PR705F series; ctx5310; 30.0-85.0; 50.0-160.0; 1
CTX; CTX PR710, PR711 series; ctx5050; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR710, PR711 series; ctx5053; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR710, PR711 series; ctx7920; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR710 series; ctx5020; 30.0-92.0; 50.0-160.0; 1
CTX; CTX PR710 series; ctx5021; 30.0-92.0; 50.0-160.0; 1
CTX; CTX PR711F series; ctx5320; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR715 series; ctx5030; 30.0-92.0; 50.0-160.0; 1
CTX; CTX PR715 series; ctx5031; 30.0-92.0; 50.0-160.0; 1
CTX; CTX PR715 series; ctx5060; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR715 series; ctx5063; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR715 series; ctx5066; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR950 series; ctx5070; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR950 series; ctx5072; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR955 series; ctx5080; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR955 series; ctx5082; 30.0-95.0; 50.0-160.0; 1
CTX; CTX PR960F series; ctx5420; 30.0-110.0; 50.0-160.0; 1
CTX; CTX TopView 150-A; ctxa002; 30.0-60.0; 60.0-75.0; 1
CTX; CTX TopView 150; ctxa001; 30.0-65.0; 60.0-120.0; 1
CTX; CTX VL400, PL4; ctx3400; 30.0-50.0; 50.0-90.0; 1
CTX; CTX VL400, PL4; ctx3410; 30.0-50.0; 50.0-90.0; 1
CTX; CTX VL400, PL4; ctx4516; 30.0-50.0; 50.0-90.0; 1
CTX; CTX VL410; ctx3450; 30.0-54.0; 50.0-110.0; 1
CTX; CTX VL410; ctx3451; 30.0-54.0; 50.0-110.0; 1
CTX; CTX VL410; ctx3455; 30.0-55.0; 50.0-110.0; 1
CTX; CTX VL410; ctx3456; 30.0-55.0; 50.0-110.0; 1
CTX; CTX VL500 series, MS500 series; ctx0150; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL500 series, MS500 series; ctx3520; 30.0-70.0; 50.0-160.0; 1
CTX; CTX VL500 series, MS500 series; ctx3521; 30.0-70.0; 50.0-160.0; 1
CTX; CTX VL500 series, MS500 series; ctx3550; 30.0-70.0; 50.0-100.0; 1
CTX; CTX VL500 series, MS500 series; ctx3560; 30.0-70.0; 50.0-100.0; 1
CTX; CTX VL500 series, MS500 series; ctx3571; 30.0-70.0; 50.0-130.0; 1
CTX; CTX VL500 series, MS500 series; ctx3572; 30.0-70.0; 50.0-130.0; 1
CTX; CTX VL500 series, MS500 series; ctx3575; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL500 series, MS500 series; ctx3576; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL500 series, MS500 series; ctx5002; 30.0-70.0; 50.0-100.0; 1
CTX; CTX VL500 series, MS500 series; ctx5690; 30.0-70.0; 50.0-100.0; 1
CTX; CTX VL500 series, MS500 series; ctx5695; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL500 series, MS500 series; ctx5696; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL500 series, MS500 series; ctx5698; 30.0-70.0; 50.0-160.0; 1
CTX; CTX VL500 series, MS500 series; ctx5699; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL510 series, PL5 series; ctx3580; 30.0-55.0; 50.0-110.0; 1
CTX; CTX VL510 series, PL5 series; ctx3590; 30.0-55.0; 50.0-110.0; 1
CTX; CTX VL510 series, PL5 series; ctx5655; 30.0-55.0; 50.0-110.0; 1
CTX; CTX VL700; ctx3615; 30.0-65.0; 50.0-120.0; 1
CTX; CTX VL700; ctx3621; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL700 series, MS700 series, PL7 series; ctx3620; 30.0-70.0; 50.0-120.0; 1
CTX; CTX VL700 series, MS700 series, PL7 series; ctx3650; 30.0-70.0; 50.0-130.0; 1
CTX; CTX VL700 series, MS700 series, PL7 series; ctx3651; 30.0-70.0; 50.0-130.0; 1
CTX; CTX VL700 series, MS700 series, PL7 series; ctx3655; 30.0-70.0; 50.0-160.0; 1
CTX; CTX VL700 series, MS700 series, PL7 series; ctx3656; 30.0-70.0; 50.0-160.0; 1
CTX; CTX VL700 series, MS700 series, PL7 series; ctx7694; 30.0-70.0; 50.0-160.0; 1
CTX; CTX VL700 series, MS700 series, PL7 series; ctx7695; 30.0-70.0; 50.0-160.0; 1
CTX; CTX VL705; ctx3675; 30.0-85.0; 50.0-160.0; 1
CTX; CTX VL710 series; ctx3680; 30.0-95.0; 50.0-160.0; 1
CTX; CTX VL710 series; ctx3683; 30.0-95.0; 50.0-160.0; 1
CTX; CTX VL710 series; ctx3685; 30.0-95.0; 50.0-160.0; 1
CTX; CTX VL710 series; ctx7854; 30.0-95.0; 50.0-160.0; 1
CTX; CTX VL710 series; ctx7855; 30.0-95.0; 50.0-160.0; 1
CTX; CTX VL710 series; ctx7927; 30.0-95.0; 50.0-160.0; 1
CTX; CTX VL710 series, EX710 series; ctx3660; 30.0-92.0; 50.0-160.0; 1
CTX; CTX VL710 series, EX710 series; ctx3661; 30.0-92.0; 50.0-160.0; 1
CTX; CTX VL950 series, EX950 series, PL9 series; ctx3700; 30.0-95.0; 50.0-160.0; 1
CTX; CTX VL950 series, EX950 series, PL9 series; ctx3710; 30.0-95.0; 50.0-160.0; 1
Cybervision; Cybervision C40; CYB5031; 30-50; 50-90; 1
Cybervision; Cybervision C50; CYB5331; 30-50; 50-90; 1
Cybervision; Cybervision C52; CYB5332; 30-70; 50-90; 1
Cybervision; Cybervision C70; CYB5631; 30-70; 50-90; 1
Cybervision; Cybervision C72; CYB5632; 30-70; 50-120; 1
Cybervision; Cybervision C92; CYB5931; 30-85; 50-150; 1
Cybervision; Cybervision C112; CYB3131; 30-95; 50-150; 1
Cybervision; Cybervision CP21; CYB5032; 30-50; 50-75; 1
Cybervision; Cybervision CP45; CYB5333; 30-62; 50-75; 1
Cybervision; Cybervision C50-2; CYB5434; 30-54; 50-100; 1
Cybervision; Cybervision C52-2; CYB5334; 30-70; 50-120; 1
Cybervision; Cybervision C70-2; CYB5635; 30-70; 50-120; 1
Cybervision; Cybervision C72-2; CYB5637; 30-70; 50-120; 1
Daewoo; Daewoo 1509B; dwe5093; 30.0-69.0; 50.0-120.0; 1
Daewoo; Daewoo 1705B; dwe7053; 30.0-69.0; 50.0-120.0; 1
Daewoo; Daewoo 431X; dwe4312; 30.0-54.0; 50.0-120.0; 1
Daewoo; Daewoo 511B; dwe5113; 30.0-69.0; 50.0-120.0; 1
Daewoo; Daewoo 512B; dwe5123; 30.0-69.0; 50.0-120.0; 1
Daewoo; Daewoo 518B; dwe5183; 30.0-69.0; 50.0-120.0; 1
Daewoo; Daewoo 518X; dwe5182; 30.0-54.0; 50.0-120.0; 1
Daewoo; Daewoo 519B; dwe5193; 30.0-69.0; 50.0-120.0; 1
Daewoo; Daewoo 707B; dwe7073; 30.0-69.0; 50.0-120.0; 1
Daewoo; Daewoo 710B; dwe7103; 30.0-69.0; 50.0-160.0; 1
Daewoo; Daewoo 710C; dwe7104; 30.0-86.0; 50.0-160.0; 1
Daewoo; Daewoo 901D; dwe9015; 30.0-95.0; 50.0-160.0; 1
Daewoo; Daewoo CMC-1423B1; dwe1423; 30.0-64.0; 50.0-120.0; 1
Daewoo; Daewoo CMC-1427X1; dwe1427; 30.0-48.0; 50.0-75.0; 1
Daewoo; Daewoo CMC-1502B1; dwe1502; 30.0-64.0; 50.0-120.0; 1
Daewoo; Daewoo CMC-1505X; dwe1505; 30.0-50.0; 50.0-100.0; 1
Daewoo; Daewoo CMC-1507X1; dwe1507; 30.0-48.0; 50.0-75.0; 1
Daewoo; Daewoo CMC-1703B; dwe1703; 30.0-64.0; 50.0-120.0; 1
Daewoo; Daewoo CMC-1704C; dwe7044; 24.0-86.0; 50.0-150.0; 1
Darius; Darius TSM-1431; tsm-1431; 15.5-39.0; 50.0-90.0; 1
Daytek; Vista v19; STC032b; 30.0-95.0; 50.0-160.0
Daytek; Daewoo DT-1414AV; dwe4142; 30.0-48.0; 50.0-90.0; 0
Daytek; Daewoo DT-1414BA; dwe4143; 30.0-58.0; 50.0-90.0; 0
Daytek; Daewoo DT-1418S; dwe418b; 30.0-35.5; 50.0-70.0; 0
Daytek; Daewoo DT-1420AV; dwe4202; 30.0-48.0; 50.0-90.0; 0
Daytek; Daewoo DT-1420BA; dwe4203; 30.0-58.0; 50.0-90.0; 0
Daytek; Daewoo DT-1501BA1/MPR; dwe501a; 30.0-64.0; 50.0-90.0; 1
Daytek; Daewoo DT-1501BA/MPR; dwe5013; 30.0-58.0; 50.0-90.0; 0
Daytek; Daewoo DT-1503B/MPR; dwe503a; 30.0-64.0; 50.0-120.0; 1
Daytek; Daewoo DT-1701M2/MPR; dwe701b; 30.0-82.0; 50.0-90.0; 1
Daytek; Daewoo DT-1704C/MPR; dwe7044; 24.0-86.0; 50.0-150.0; 1
Daytek; Daewoo DT-2000M/MPR; dwe0000; 30.0-78.0; 50.0-90.0; 1
Daytek; Daewoo DT-2102M/MPR; dwe102a; 30.0-78.0; 50.0-90.0; 0
Daytek; Daytek DT-1531D; oec020f; 30.0-70.0; 50.0-120.0; 1
Daytek; Daytek DT-1536D; oec0504; 30.0-54.0; 50.0-120.0; 1
Daytek; Daytek DT-1569D; oec020f; 30.0-70.0; 50.0-120.0; 1
Daytek; Daytek DT-1728D; oec0707; 30.0-70.0; 50.0-120.0; 1
Daytek; Daytek DT-1731D; oec0211; 30.0-70.0; 50.0-120.0; 1
Daytek; Daytek DT-1770; oec0706; 30.0-70.0; 50.0-150.0; 1
Daytek; Daytek DT-1995D; oec19db; 31.0-96.0; 50.0-155.0; 1
Daytek; Daytek TM-1554D; oec0504; 30.0-54.0; 50.0-120.0; 1
Daytek; Daytek TM-1569D; oec020f; 30.0-70.0; 50.0-120.0; 1
Daytek; Daytek TM-1769D; oec0211; 30.0-70.0; 50.0-120.0; 1
Daytek; Daytek TM-1770D; oec0707; 30.0-70.0; 50.0-120.0; 1
Dell; Dell 1024i; 0; 35.5; 87.0; 1
Dell; Dell 1024i-P/1024i-Color; 0; 35.5; 87.0; 1
Dell; Dell 1024X Laptop Display Panel; 0; 31.5-48.5; 59.0-75.0; 1
Dell; Dell 1280X Laptop Display Panel; 0; 31.5-90.0; 59.0-75.0; 1
Dell; Dell 1400FP; del8162; 31.0-60.0; 55.0-86.0; 1
Dell; Dell 1400X Laptop Display Panel; 0; 31.5-90.0; 59.0-75.0; 1
Dell; Dell 1401FP; delc0ec; 31.0-80.0; 56.0-76.0; 1
Dell; Dell 1500FP; del715d; 30.0-61.0; 56.0-75.0; 1
Dell; Dell 1501FP(Analog); del73a4; 30.0-61.0; 56.0-75.0; 1
Dell; Dell 1501FP(Digital); del7140; 30.0-61.0; 56.0-75.0; 1
Dell; Dell 1503FP(Analog); del3004; 31.0-60.0; 60.0-75.0; 1
Dell; Dell 1503FP(Digital); del3003; 31.0-60.0; 60.0-75.0; 1
Dell; Dell 1569; del1569; 30.0-69.0; 50.0-110.0; 1
Dell; Dell 1569; del6915; 30.0-69.0; 50.0-110.0; 1
Dell; Dell 1600X Laptop Display Panel; 0; 31.5-90.0; 59.0-85.0; 1
Dell; Dell 1700FP; del3092; 30.0-80.0; 56.0-76.0; 1
Dell; Dell 1701FP (Analog); del3002; 31.0-80.0; 56.0-76.0; 1
Dell; Dell 1701FP (Digital); del3001; 31.0-80.0; 56.0-76.0; 1
Dell; Dell 1702FP (Analog); DEL3007; 30.0-80.0; 56.0-76.0; 1
Dell; Dell 1702FP (Digital); DEL3006; 30.0-80.0; 56.0-76.0; 1
Dell; Dell 1800FP (Analog); DELE000; 30.0-80.0; 56.0-85.0; 1
Dell; Dell 1800FP (Digital); DELE001; 30.0-70.0; 56.0-85.0; 1
Dell; Dell 1900FP (Analog); DEL300B; 30.0-80.0; 56.0-76.0; 1
Dell; Dell 1900FP (Digital); DEL3009; 30.0-80.0; 56.0-76.0; 1
Dell; Dell 2000FP (Analog); DELA002; 31.5-80.0; 56.0-76.0; 1
Dell; Dell 2000FP (Digital); DELA003; 31.5-80.0; 56.0-76.0; 1
Dell; Dell 1726T-HS/D1025HT; del5319; 31.0-85.0; 50.0-100.0; 1
Dell; Dell 800M; del5697; 30.0-70.0; 50.0-120.0; 1
Dell; Dell 800M; del5697; 30.0-70.0; 50.0-130.0; 1
Dell; Dell 828FI; del3319; 30.0-70.0; 50.0-120.0; 1
Dell; Dell D1025HE; del6124; 31.0-92.0; 50.0-120.0; 1
Dell; Dell D1025HTX; del5062; 31.0-70.0; 50.0-120.0; 1
Dell; Dell D1025TM; del5155; 31.0-85.0; 50.0-160.0; 1
Dell; Dell D1028L; del730b; 31.0-70.0; 50.0-120.0; 1
Dell; Dell D1226H; del7077; 30.0-95.0; 50.0-160.0; 1
Dell; Dell D1428L; del3276; 31.0-48.0; 43.0-75.0; 1
Dell; Dell D1626HT; del515b; 31.0-107.0; 50.0-160.0; 1
Dell; Dell D2026T; del5314; 31.0-96.0; 50.0-100.0; 1
Dell; Dell D2128-TCO; del602f; 31.0-102.0; 50.0-150.0; 1
Dell; Dell D825HR; del62ff; 31.0-70.0; 50.0-120.0; 1
Dell; Dell D825HT; del5033; 31.0-70.0; 50.0-120.0; 1
Dell; Dell D825TM; del512c; 30.0-70.0; 50.0-120.0; 1
Dell; Dell D828L; del32fe; 31.0-54.0; 50.0-120.0; 1
Dell; Dell E151FP; DELA004; 31.0-60.0; 56.0-75.0; 1
Dell; Dell E151FPp; DEL7006; 30.0-61.0; 56.0-76.0; 1
Dell; Dell E550; dela2f1; 30.0-54.0; 50.0-120.0; 1
Dell; Dell E550mm; dela355; 30.0-54.0; 50.0-120.0; 1
Dell; Dell E551a; dela000; 30.0-54.0; 50.0-120.0; 1
Dell; Dell E551c; deld000; 30.0-54.0; 50.0-120.0; 1
Dell; Dell E770p; del7340; 30.0-70.0; 50.0-160.0; 1
Dell; Dell E770s; del300a; 30.0-70.0; 50.0-160.0; 1
Dell; Dell E771a; delA001; 30.0-70.0; 50.0-160.0; 1
Dell; Dell E771p; del7002; 30.0-70.0; 50.0-160.0; 1
Dell; Dell E771mm; DEL7003; 30.0-70.0; 50.0-160.0; 1
Dell; Dell E772c; DELD002; 30.0-70.0; 50.0-160.0; 1
Dell; Dell E772p; DEL7005; 30.0-70.0; 50.0-160.0; 1
Dell; Dell Eizo 9080i; 0; 30.0-64.0; 50.0-90.0; 1
Dell; Dell ES-17; del635e; 31.0-85.0; 50.0-100.0; 1
Dell; Dell GPD-16C; 0; 20.0-50.0; 50.0-90.0; 1
Dell; Dell GPD-19C; 0; 30.0-64.0; 50.0-130.0; 1
Dell; Dell Hewitt; 0; 30.0-48.1; 50.0-72.0; 1
Dell; Dell M1110; del93d5; 30.0-107.0; 50.0-160.0; 1
Dell; Dell M570; del30cc; 30.0-70.0; 50.0-160.0; 1
Dell; Dell M770; del71a5; 30.0-69.0; 48.0-160.0; 1
Dell; Dell M780; del3142; 30.0-85.0; 50.0-160.0; 1
Dell; Dell M781p; del73bd; 30.0-85.0; 50.0-160.0; 1
Dell; Dell M781s; del32b0; 30.0-85.0; 50.0-160.0; 1
Dell; Dell M782; DEL3008; 30.0-85.0; 50.0-160.0; 1
Dell; Dell M791; del7001; 30.0-96.0; 50.0-160.0; 1
Dell; Dell M990; del708a; 30.0-95.0; 50.0-160.0; 1
Dell; Dell M991; DEL7001; 30.0-96.0; 50.0-160.0; 1
Dell; Dell M992; DEL300E; 30.0-96.0; 50.0-160.0; 1
Dell; Dell P1110; del50ab; 30.0-121.0; 48.0-160.0; 1
Dell; Dell P1130; del5000; 30.0-130.0; 48.0-170.0; 1
Dell; Dell P1690; del5348; 30.0-96.0; 50.0-160.0; 1
Dell; Dell P780; del510f; 30.0-85.0; 48.0-120.0; 1
Dell; Dell P790; del62f5; 30.0-92.0; 50.0-150.0; 1
Dell; Dell P791; del3000; 30.0-96.0; 50.0-160.0; 1
Dell; Dell P792; DEL5001; 30.0-96.0; 48.0-170.0; 1
Dell; Dell P793; DEL3005; 30.0-96.0; 50.0-160.0; 1
Dell; Dell P990; del50dd; 30.0-96.0; 48.0-120.0; 1
Dell; Dell P991; del5178; 30.0-95.0; 50.0-160.0; 1
Dell; Dell P992; DEL5002; 30.0-107.0; 48.0-170.0; 1
Dell; Dell Super VGA; 0; 30.0-38.5; 50.0-90.0; 1
Dell; Dell Super VGA Colour; 0; 29.0-38.0; 47.0-100.0; 1
Dell; Dell Super VGA DL 1428 I/L; 0; 35.5; 87.0; 1
Dell; Dell Super VGA Jostens; 0; 30.0-48.1; 50.0-72.0; 1
Dell; Dell UGA DL 1460 NI; 0; 30.0-58.2; 50.0-72.2; 1
Dell; Dell Ultrascan 14C; 0; 30.0-50.0; 50.0-90.0; 1
Dell; Dell Ultrascan 14C-E; 0; 30.0-60.0; 50.0-100.0; 1
Dell; Dell Ultrascan 14C-EN; 0; 30.0-60.0; 50.0-100.0; 1
Dell; Dell Ultrascan 14ES; 0; 31.5-62.0; 50.0-90.0; 1
Dell; Dell Ultrascan 14LR; 0; 30.0-58.0; 50.0-90.0; 1
Dell; Dell Ultrascan 14XE; del139a; 30.0-62.0; 50.0-120.0; 1
Dell; Dell Ultrascan 14XE; del139b; 30.0-62.0; 50.0-120.0; 1
Dell; Dell Ultrascan 14XE; del139c; 30.0-62.0; 50.0-120.0; 1
Dell; Dell Ultrascan 14XE; del139d; 30.0-62.0; 50.0-120.0; 1
Dell; Dell Ultrascan 15ES/15ES-P; 0; 31.5-62.0; 50.0-90.0; 1
Dell; Dell Ultrascan 15FS/15FS-E; 0; 30.0-60.0; 50.0-90.0; 1
Dell; Dell Ultrascan 15FS-N/15FS-EN; 0; 30.0-60.0; 50.0-100.0; 1
Dell; Dell Ultrascan 15LR; 0; 31.5-57.0; 55.0-90.0; 1
Dell; Dell Ultrascan 15TE; 0; 31.0-64.0; 50.0-120.0; 1
Dell; Dell Ultrascan 17ES; 0; 30.0-78.0; 50.0-130.0; 1
Dell; Dell Ultrascan 17FS-ELR; 0; 30.0-64.0; 50.0-100.0; 1
Dell; Dell Ultrascan 17FS-EN; 0; 30.0-64.0; 50.0-130.0; 1
Dell; Dell Ultrascan 17FS-LR; 0; 30.0-64.0; 50.0-130.0; 1
Dell; Dell Ultrascan 17FS-N; 0; 30.0-64.0; 50.0-130.0; 1
Dell; Dell Ultrascan 21FS; 0; 30.0-78.0; 50.0-130.0; 1
Dell; Dell Ultrascan 21TE; del2214; 30.0-93.0; 50.0-152.0; 1
Dell; Dell Ultrascan 21TE; del2215; 30.0-93.0; 50.0-152.0; 1
Dell; Dell Ultrascan 21TE; del2216; 30.0-93.0; 50.0-152.0; 1
Dell; Dell Ultrascan 21TE; del2217; 30.0-93.0; 50.0-152.0; 1
Dell; Dell Ultrascan V17X; del2210; 30.0-85.0; 50.0-130.0; 1
Dell; Dell Ultrascan V17X; del2211; 30.0-85.0; 50.0-130.0; 1
Dell; Dell Ultrascan V17X; del2212; 30.0-85.0; 50.0-130.0; 1
Dell; Dell Ultrascan V17X; del2213; 30.0-85.0; 50.0-130.0; 1
Dell; Dell V15X; del4273; 57.0-64.0; 55.0-90.0; 1
Dell; Dell V17X; 0; 30.0-64.0; 50.0-100.0; 1
Dell; Dell VC15 Colour; 0; 31.0-64.0; 50.0-90.0; 1
Dell; Dell VGA 800; 0; 29.0-38.0; 50.0-87.0; 1
Dell; Dell VGA Color/Color Plus; 0; 31.5; 60.0; 1
Dell; Dell VGA Monochrome; 0; 31.5; 60.0; 1
Dell; Dell Vi14X; 0; 35.5; 87.0; 1
Dell; Dell VS14/15; 0; 30.0-58.5; 50.0-90.0; 1
Dell; Dell VS17; 0; 30.0-62.0; 50.0-90.0; 1
Dell; Dell VS17X; del3024; 30.0-65.0; 50.0-120.0; 1
Dell; Dell VS17X; del3025; 30.0-65.0; 50.0-120.0; 1
Dell; Dell VS17X; del3026; 30.0-65.0; 50.0-120.0; 1
Dell; Dell VS17X; del3027; 30.0-65.0; 50.0-120.0; 1
Delta; Delta DA-1565; dpc1565; 30-65; 50-100; 1
Delta; Delta DA-570; dpc0570; 30-70; 50-100; 1
Delta; Delta DA-995; dpc0995; 30.0-95.0; 50.0-180.0; 1
Delta; Delta DB-1765; dpc1765; 30-65; 50-100; 1
Delta; Delta DB-770; dpc0770; 30-70; 50-100; 1
Delta; Delta DC-770; dpc1770; 30.0-70.0; 50.0-120.0; 1
Delta; Delta DE-570; dpc4570; 30.0-70.0; 50.0-120.0; 1
Digital Equipment Corp.; Digital 14 in. Color (FR-PCXBV-PF); fr-pcxbv-pf; 30.0-65.0; 50.0-100.0; 1
Digital Equipment Corp.; Digital 14 in. Color (FR-PCXBV-SA); fr-pcxbv-sa; 30.0-65.0; 50.0-100.0; 1
Digital Equipment Corp.; Digital 14 in. Color (FR-PCXCV-GE); fr-pcxcv-ge; 31.0-32.0; 59.0-61.0; 1
Digital Equipment Corp.; Digital 14 in. Color (FR-PCXCV-RA); fr-pcxcv-ra; 31.0-32.0; 59.0-61.0; 1
Digital Equipment Corp.; Digital 14 in. Color Monitor (FR-PCXCV-C*); dec770c; 30.0-54.0; 50.0-90.0; 1
Digital Equipment Corp.; Digital 14 in. Monochrome (FR-PC7XV-KA); fr-pc7xv-ka; 31.2-31.7; 57.0-73.0; 1
Digital Equipment Corp.; Digital 15 in. Color (FR-PCXBV-PC); fr-pcxbv-pc; 30.0-66.0; 50.0-110.0; 1
Digital Equipment Corp.; Digital 15 in. Color (FR-PCXBV-RA); fr-pcxbv-ra; 30.0-48.0; 55.0-90.0; 1
Digital Equipment Corp.; Digital 15 in. Color (FR-PCXBV-RD); fr-pcxbv-rd; 30.0-65.0; 55.0-90.0; 1
Digital Equipment Corp.; Digital 15 in. Color (FR-PCXBV-RL); fr-pcxbv-rl; 30.0-65.0; 50.0-100.0; 1
Digital Equipment Corp.; Digital 15 in. Color (FR-PCXBV-SC); fr-pcxbv-sc; 30.0-65.0; 50.0-100.0; 1
Digital Equipment Corp.; Digital 15 in. Color (FR-PCXCV-AC); fr-pcxcv-ac; 31.5; 50.0-90.0; 1
Digital Equipment Corp.; Digital 15 in. Color Monitor (FR-PCXBV-E*); decba08; 30.0-69.0; 50.0-110.0; 1
Digital Equipment Corp.; Digital 15 in. Color Monitor (FR-PCXCV-D*); dec970c; 30.0-54.0; 50.0-90.0; 1
Digital Equipment Corp.; Digital 17 in. Color (FR-PCXAV-EC); fr-pcxav-ec; 29.0-82.0; 50.0-150.0; 1
Digital Equipment Corp.; Digital 17 in. Color (FR-PCXAV-YZ); dec073a; 30.0-85.0; 48.0-150.0; 1
Digital Equipment Corp.; Digital 17 in. Color (FR-PCXBV-KA); fr-pcxbv-ka; 30.0-66.0; 50.0-130.0; 1
Digital Equipment Corp.; Digital 17 in. Color (SN-VRTX7-WA); dece162; 31.5-82; 50-90; 1
Digital Equipment Corp.; Digital 17 in. Color Monitor (FR-PCXBV-F*); decda08; 30.0-69.0; 50.0-120.0; 1
Digital Equipment Corp.; Digital 19 in. Color (FR-PCXAV-CY); dec0479; 30.0-95.0; 48.0-160.0; 1
Digital Equipment Corp.; Digital 19 in. Color (FR-PCXAV-CZ); dec047a; 30.0-95.0; 48.0-160.0; 1
Digital Equipment Corp.; Digital 19 in. Color (FR-PCXAV-TZ); dec9a06; 30.0-96.0; 50.0-160.0; 1
Digital Equipment Corp.; Digital 21 in. Color (FR-PCXAV-HA); fr-pcxav-ha; 30.0-85.0; 50.0-152.0; 1
Digital Equipment Corp.; Digital 21 in. Color (FR-PCXAV-WZ); dec06fa; 30.0-95.0; 50.0-152.0; 1
Digital Equipment Corp.; Digital 21 in. Color (SN-VRCX1-WA); dec62e1; 30.0-95.0; 50.0-152.0; 1
Digital Equipment Corp.; Digital 24 in. Color (FR-PCXAV-AZ); dec043a; 30.0-96.0; 50.0-160.0; 1
Digital Equipment Corp.; Digital FR-PCXAV-VY; dec06d9; 30.0-86.0; 50.0-130.0; 1
Digital Equipment Corp.; Digital FR-PCXAV-WY; dec06f9; 30.0-95.0; 50.0-152.0; 1
Digital Equipment Corp.; Digital FR-PCXAV-YY; dec0739; 30.0-85.0; 48.0-150.0; 1
Eizo; Eizo 9060S; eiz0302; 15.5-38.5; 50.0-90.0; 1
Eizo; Eizo 9065S; eiz0303; 30.0-50.0; 50.0-90.0; 1
Eizo; Eizo 9070S; eiz0306; 20.0-50.0; 50.0-90.0; 1
Eizo; Eizo 9080i; eiz0307; 30.0-64.0; 55.0-90.0; 1
Eizo; Eizo 9400i; eiz0308; 30.0-65.0; 55.0-90.0; 1
Eizo; Eizo 9500; eiz0309; 30.0-78.0; 55.0-90.0; 1
Eizo; Eizo F35; eiz1000; 27.0-70.0; 50.0-120.0; 1
Eizo; Eizo F55; eiz1008; 27.0-70.0; 50.0-120.0; 1
Eizo; Eizo F55S; eiz1015; 30.0-82.0; 50.0-120.0; 1
Eizo; Eizo F56; eiz1004; 27.0-86.0; 50.0-160.0; 1
Eizo; Eizo F57; eiz1020; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo F67; eiz1013; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo F77; eiz1006; 30.0-95.0; 50.0-160.0; 1
Eizo; Eizo F77S; eiz1018; 30.0-110.0; 50.0-160.0; 1
Eizo; Eizo F78; eiz1007; 31.5-110.0; 50.0-160.0; 1
Eizo; Eizo FlexScan 6500; eiz0300; 56.0-80.0; 55.0-90.0; 1
Eizo; Eizo FlexScan 6600; eiz0206; 56.0-110.0; 70.0-90.0; 1
Eizo; Eizo FlexScan E151L; nan1212; 24.0-61.0; 50.0-85.0; 1
Eizo; Eizo FlexScan E54F; nan1220; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo FlexScan E76F; nan1218; 30.0-110.0; 50.0-160.0; 1
Eizo; Eizo FlexScan F340iW; eiz030a; 27.0-61.5; 55.0-90.0; 1
Eizo; Eizo FlexScan F351; eiz0200; 24.5-69.0; 55.0-120.0; 1
Eizo; Eizo FlexScan F550iW; eiz038c; 30.0-65.0; 55.0-90.0; 1
Eizo; Eizo FlexScan F552; eiz030c; 24.5-69.0; 55.0-120.0; 1
Eizo; Eizo FlexScan F553; eiz0201; 24.5-69.0; 55.0-120.0; 1
Eizo; Eizo FlexScan F560iW; eiz030d; 30.0-82.0; 55.0-90.0; 1
Eizo; Eizo FlexScan F563; eiz0202; 24.5-86.0; 55.0-160.0; 1
Eizo; Eizo FlexScan F57; eiz1020; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo FlexScan F750i; eiz030e; 30.0-80.0; 55.0-90.0; 1
Eizo; Eizo FlexScan F760iW; eiz030f; 30.0-78.0; 55.0-90.0; 1
Eizo; Eizo FlexScan F764; eiz0203; 30.0-90.0; 55.0-160.0; 1
Eizo; Eizo FlexScan F77S; eiz1018; 30.0-110.0; 50.0-160.0; 1
Eizo; Eizo FlexScan F780iW; eiz0310; 45.0-100.0; 55.0-120.0; 1
Eizo; Eizo FlexScan F784; eiz0204; 31.5-102.0; 55.0-160.0; 1
Eizo; Eizo FlexScan F931; enc1630 ; 30.0-130.0; 50.0-160.0; 1
Eizo; Eizo FlexScan L23; eiz1009; 24.0-50.0; 50.0-60.0; 1
Eizo; Eizo FlexScan L23; eiz1409; 24.0-50.0; 50.0-60.0; 1
Eizo; Eizo FlexScan L34; eiz1012; 24.0-61.0; 50.0-85.0; 1
Eizo; Eizo FlexScan L34; eiz1412; 24.0-61.0; 50.0-85.0; 1
Eizo; Eizo FlexScan L360; eiz1021; 27.0-61.0; 55.0-75.0; 1
Eizo; Eizo FlexScan L360; eiz1421; 27.0-61.0; 55.0-75.0; 1
Eizo; Eizo FlexScan L66; eiz1019; 27.0-80.0; 50.0-75.0; 1
Eizo; Eizo FlexScan L66; eiz1419; 27.0-80.0; 50.0-75.0; 1
Eizo; Eizo FlexScan T560i; eiz0311; 30.0-82.0; 55.0-90.0; 1
Eizo; Eizo FlexScan T562; eiz0313; 30.0-82.0; 55.0-90.0; 1
Eizo; Eizo FlexScan T563; eiz0305; 24.5-86.0; 55.0-160.0; 1
Eizo; Eizo FlexScan T660i; eiz0312; 30.0-78.0; 55.0-90.0; 1
Eizo; Eizo FlexScan T662; eiz0314; 30.0-85.0; 55.0-160.0; 1
Eizo; Eizo FX-B5; eiz1400; 27.0-70.0; 50.0-120.0; 1
Eizo; Eizo FX-C5; eiz1408; 27.0-70.0; 50.0-120.0; 1
Eizo; Eizo FX-C5S; eiz1415; 30.0-82.0; 50.0-120.0; 1
Eizo; Eizo FX-C6; eiz1404; 27.0-86.0; 50.0-160.0; 1
Eizo; Eizo FX-C7; eiz1420; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo FX-D7; eiz1413; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo FX-E7; eiz1406; 30.0-95.0; 50.0-160.0; 1
Eizo; Eizo FX-E8; eiz1407; 31.5-110.0; 50.0-160.0; 1
Eizo; Eizo NANAO FlexScan FX-C7; eiz1420; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo Nanao FlexScan FX-E7S; eiz1418; 30.0-110.0; 50.0-160.0; 1
Eizo; Eizo T57; eiz1005; 27.0-92.0; 50.0-160.0; 1
Eizo; Eizo T57S; eiz1001; 30.0-92.0; 50.0-160.0; 1
Eizo; Eizo T67; eiz1002; 30.0-95.0; 50.0-160.0; 1
Eizo; Eizo T67S; eiz1003; 30.0-95.0; 50.0-160.0; 1
Eizo; Eizo T68; eiz1014; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo T77; eiz1011; 27.0-70.0; 50.0-120.0; 1
Eizo; Eizo T960; eiz1022; 30.0-115.0; 50.0-160.0; 1
Eizo; Eizo T960; eiz1422; 30.0-115.0; 50.0-160.0; 1
Eizo; Eizo TX-C7; eiz1405; 27.0-92.0; 50.0-160.0; 1
Eizo; Eizo TX-C7S; eiz1401; 30.0-92.0; 50.0-160.0; 1
Eizo; Eizo TX-D7; eiz1414; 30.0-96.0; 50.0-160.0; 1
Eizo; Eizo TX-D7S; eiz1403; 30.0-95.0; 50.0-160.0; 1
Eizo Nanao; Eizo F520; enc1602; 30.0-96.0; 50.0-160.0; 1
Eizo Nanao; Eizo F730; enc1604; 30.0-115.0; 50.0-160.0; 1
Eizo Nanao; Eizo F930; enc1612; 30.0-130.0; 50.0-160.0; 1
Eizo Nanao; Eizo F980; enc1603; 30.0-137.0; 50.0-160.0; 1
Eizo Nanao; Eizo T550; enc1600; 30.0-82.0; 50.0-160.0; 1
Eizo Nanao; Eizo T561; enc1615; 30.0-96.0; 50.0-160.0; 1
Eizo Nanao; Eizo T760; enc1605; 30.0-96.0; 50.0-160.0; 1
Eizo Nanao; Eizo T761; enc1613; 30.0-115.0; 50.0-160.0; 1
Eizo Nanao; Eizo T961; enc1610; 30.0-115.0; 50.0-160.0; 1
Eizo Nanao; Eizo T962; enc1614; 30.0-130.0; 50.0-160.0; 1
Eizo Nanao; Eizo L351; enc1616; 30.0-50.0; 59.0-61.0; 1
Eizo Nanao; Eizo L371D; enc1617; 27.0-65.0; 59.0-61.0; 1
Eizo Nanao; Eizo L371; enc1618; 27.0-61.0; 50.0-75.0; 1
Eizo Nanao; Eizo L771; enc1622; 27.0-81.0; 50.0-75.0; 1
Elitegroup Computer Systems; ECS VERTOS 1401; ecs0001; 30.0-50.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 1501; ecs0002; 24.0-64.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 1502; ecs0003; 24.0-64.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 1503; ecs0004; 24.0-64.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 1700; ecs0005; 24.0-64.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 1701; ecs0006; 24.0-82.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 1702; ecs0007; 24.0-64.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 2101; ecs0008; 24.0-90.0; 50.0-100.0; 1
Elitegroup Computer Systems; ECS VERTOS 2102; ecs0009; 24.0-90.0; 50.0-100.0; 1
Elsa AG; Elsa Ecomo Office; els4160; 30.0-86.0; 50.0-130.0; 1
Elsa AG; Elsa GDM-17E40; 135; 29-82; 50-150
Epson; Epson CG1428I; epson2; 35.5; 56.0-87.0; 1
Epson; Epson CG1428N; epson3; 48.0; 56.0-87.0; 1
Epson; Epson CG1439I; epson1; 35.5; 56.0-87.0; 1
Epson; Epson CG1528N; epson4; 30-65; 50-120.0; 1
Epson; Epson CG1728N; epson5; 30-65; 50-120.0; 1
ESCOM; ESCOM Mono-LCD screen; 28; 30-36; 43-72
Everex Systems, Inc.; Everex Eversync_SVGA; eversync_svga; 15.5-35.0; 50.0-70.0; 1
Falco Data Products, Inc.; Falco Data Products, Inc. FMS; fms; 15.0-38.0; 47.0-90.0; 1
Fora, Inc.; Fora, Inc. MON-7C5; mon-7c5; 15.0-36.0; 45.0-90.0; 1
Forefront Technology Corp.; Forefront Technology MTS-9608S; mts-9608s; 15.0-38.0; 50.0-90.0; 1
Fujikama O.A. Distribution; Fujikama PVGA-1024A; pvga-1024a; 31.5-38.5; 50.0-90.0; 1
Fujitsu; Fujitsu 1554G+; fpa0612; 30-54; 50-120; 1
Fujitsu; Fujitsu FMVC-DP832; fmvcdp832; 35.5-48.0; 60.0-87.0; 1
Fujitsu; Fujitsu FMV-DP845; fuj5501; 30.0-65.0; 50.0-100.0; 1
Fujitsu; Fujitsu FMV-DP846A; fuj5701; 30.0-70.0; 50.0-100.0; 1
Fujitsu; Fujitsu FMV-DP846; fuj5601; 30.0-70.0; 50.0-100.0; 1
Fujitsu; Fujitsu FMV-DP847; fuj3110; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMV-DP84X1; fujb801; 30.0-70.0; 50.0-100.0; 1
Fujitsu; Fujitsu FMV-DP84X2; fuj7110; 30.0-70.0; 50.0-100.0; 1
Fujitsu; Fujitsu FMV-DP84X3(G); fuj7210; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMVDP84X4G; fuj7310; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMVDP84X5G/848; fuj7410; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMV-DP84Y4; fujb601; 30.0-65.0; 50.0-100.0; 1
Fujitsu; Fujitsu FMV-DP84Y5; fujb701; 30.0-65.0; 50.0-100.0; 1
Fujitsu; Fujitsu FMVDP9710; fuj2110; 30.0-70.0; 50.0-160.0; 1
Fujitsu; Fujitsu FMVDP9712; fuj2510; 30.0-70.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP976; fuj4401; 30.0-85.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMV-DP977; fuj4601; 30.0-85.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP978; fuj4701; 30.0-70.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP979; fuj2210; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP97X1; fuja801; 30.0-85.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMV-DP97X2; fuja901; 30.0-92.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMV-DP97X3; fujaa01; 30.0-70.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP97X4; fuj6110; 30.0-92.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMVDP97X5(G)/X6/9711; fuj6210; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMVDP97X7(G)/X8; fuj6310; 30.0-85.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMVDP97X9(G)/9713; fuj6410; 30.0-85.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP97Y3; fuja401; 30.0-85.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMV-DP97Y4; fuja501; 31.0-64.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP97Y5; fuja601; 30.0-65.0; 50.0-110.0; 1
Fujitsu; Fujitsu FMV-DP97Y6; fuja701; 30.0-69.0; 50.0-160.0; 1
Fujitsu; Fujitsu FMV-DP981; fuj1110; 30.0-95.0; 50.0-180.0; 1
Fujitsu; Fujitsu FMV-DP982; fuj1210; 30.0-95.0; 50.0-180.0; 1
Fujitsu; Fujitsu FMV-DP98X1; fuj5110; 30.0-95.0; 50.0-180.0; 1
Fujitsu; Fujitsu FMV-DP994; fuj9301; 30.0-85.0; 50.0-120.0; 1
Fujitsu; Fujitsu FMV-DP995; fu
显示器场频和行频列表
Fujitsu; Fujitsu FMV-DP995; fuj9401; 30.0-107.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP996; fuj0110; 30.0-107.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP997; fuj0210; 30.0-121.0; 48.0-160.0; 1
Fujitsu; Fujitsu FMV-DPA972; fuj4801; 30.0-70.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DPA973; fuj2310; 30.0-70.0; 50.0-150.0; 1
Fujitsu; Fujitsu FP-2500; fuj2112; 24.0-85.0; 50.0-86.0; 1
Fujitsu; Fujitsu VL-1400SS; fuj8501; 31.5-57.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1410SS; fuj8601; 31.5-57.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1410TS; fuj8801; 31.5-56.5; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1420T; fuj4111; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-14TX1; fuj9111; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-14TX2; fuj9211; 30.0-48.4; 56.3-75.0; 1
Fujitsu; Fujitsu VL-1500T; fuj8701; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1510T; fuj3111; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1520A; fuj3311; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1520T; fuj3211; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530A; fuj3511; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530B; fuj3611; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530S; fuj3411; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530SW; fuj3711; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15DX1G; fuj8411; 48.4; 60.0; 1
Fujitsu; Fujitsu VL-15DX2G; fuj8811; 48.4; 60.0; 1
Fujitsu; Fujitsu VL-15DX3G; fuj8711; 48.4; 60.0; 1
Fujitsu; Fujitsu VL-15TX1(G); fuj8111; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15TX2; fuj8311; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15TX3G; fuj8211; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15TX4G; fuj8611; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1800TS; fuj1111; 31.5-80.0; 56.0-85.0; 1
Fujitsu; Fujitsu VL-2100T; fuj8401; 31.5-80.0; 59.9-75.0; 1
Fujitsu; Fujitsu 1568G1; fpa2d30; 30-69; 50-120; 1
Fujitsu; Fujitsu 1769G; fpa2df9; 30-69; 50-120; 1
Fujitsu; Fujitsu e155; fuj3118; 30.0-54.0; 50.0-100.0; 1
Fujitsu; Fujitsu e175; icl2500; 30.0-85.0; 50.0-120.0; 1
Fujitsu; Fujitsu e176; icl2a00; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu e213; icl2700; 30.0-107.0; 50.0-150.0; 1
Fujitsu; Fujitsu ErgoPro e154; icl2200; 30.0-54.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro e174; icl2300; 30.0-69.0; 50.0-160.0; 1
Fujitsu; Fujitsu ErgoPro x153; icl2100; 30.0-69.0; 50.0-160.0; 1
Fujitsu; Fujitsu ErgoPro x174; icl2400; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMVDP97X5(G)/FMVDP97X6; fuj6210; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu ErgoPro 140v; icl-ep140v; 37.9; 58.0-75.0; 1
Fujitsu; Fujitsu ErgoPro 141p; icl0d00; 47.0-49.0; 50.0-90.0; 1
Fujitsu; Fujitsu ErgoPro 141v; icl0b00; 37.9; 58.0-75.0; 1
Fujitsu; Fujitsu ErgoPro 142v; icl1400; 37.9; 58.0-75.0; 1
Fujitsu; Fujitsu ErgoPro 151p AutoBrite; icl0800; 30.0-64.0; 48.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 151p; icl0700; 30.0-64.0; 48.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 151v; icl0a00; 30.0-64.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 152v; icl0f00; 30.0-64.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 171p; icl0200; 30.0-82.0; 50.0-110.0; 1
Fujitsu; Fujitsu ErgoPro 171v; icl0400; 30.0-64.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 211v; icl0100; 24.0-82.0; 50.0-120.0; 1
Fujitsu; Fujitsu ErgoPro e153; icl1600; 30.0-66.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro e173; icl1d00; 30.0-65.0; 50.0-120.0; 1
Fujitsu; Fujitsu ErgoPro x152; icl1c00; 30.0-65.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro x173a; icl1a00; 31.0-85.0; 48.0-100.0; 1
Fujitsu; Fujitsu ErgoPro x173; icl1900; 31.0-85.0; 48.0-100.0; 1
Fujitsu; Fujitsu x150f; fuj0119; 31.0-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu x154; icl2900; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu x176; fuj2118; 30.0-100.0; 50.0-200.0; 1
Fujitsu; Fujitsu x177a; fuj2318; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu x177; fuj2218; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu x191; icl2800; 30.0-96.0; 50.0-160.0; 1
Funai Electric Company of Taiwan; Funai 17GD; fcm3313; 30.0-70.0; 50.0-120.0; 1
Gateway; Gateway EV700; gwy7658; 30.0-70.0; 50.0-120.0; 1
Gateway; Gateway EV900; gwy8883; 30.0-95.0; 50.0-160.0; 1
Gateway; Gateway EV700-H; gwy7659; 30.0-70.0; 50.0-120.0; 1
Gateway; Gateway VX900; gwy9095; 30.0-95.0; 50.0-160.0; 1
Gateway; Gateway 14SVGA; 14svga; 31.5-35.5; 50-90; 1
Gateway; Gateway AN1_15; gwy07d0; 30-60; 50-100; 1
Gateway; Gateway CM751; gwy0013; 31-95; 50-160; 1
Gateway; Gateway CM803; gwy138b; 31.0-115.0; 50.0-160.0; 1
Gateway; Gateway CrystalScan 1024; cs1024; 31.5-35.5; 50-90; 1
Gateway; Gateway CrystalScan 1024NI2G; cs1024ni2g; 31.5-48; 50-90; 1
Gateway; Gateway CrystalScan 1024NI; cs1024ni; 30-50; 50-90; 1
Gateway; Gateway CrystalScan 1572DG; 1572dg; 30-62; 50-120; 1
Gateway; Gateway CrystalScan 1572DGM; cs1572dgm; 30-62; 50-100; 1
Gateway; Gateway CrystalScan 1572FS; 1572fs; 30-62; 50-120; 1
Gateway; Gateway CrystalScan 17762LEG; cs17762leg; 30-64; 50-100; 1
Gateway; Gateway CrystalScan 500-069; gwy138a; 31-69; 50-110; 1
Gateway; Gateway CrystalScan 500; gwy0f04; 30-64; 50-100; 1
Gateway; Gateway CrystalScan 700-069; gwy1b5a; 31-69; 50-110; 1
Gateway; Gateway CrystalScan 700-069; gwy1b5b; 31-69; 50-110; 1
Gateway; Gateway DL27-1; gwy0a8d; 31.0-38.0; 50-75; 1
Gateway; Gateway DL31-1; gwy0089; 31.0-38.0; 50-75; 1
Gateway; Gateway DL31-1; gwy0c1e; 31.0-38.0; 50-75; 1
Gateway; Gateway DL36-1; gwy0e11; 31.0-38.0; 50-75; 1
Gateway; Gateway EV500; gwy138a; 31-69; 50-110; 1
Gateway; Gateway EV500; gwy138b; 31-69; 50-110; 1
Gateway; Gateway EV500; gwy138c; 31-69; 50-110; 1
Gateway; Gateway EV500; gwy5005; 31-69; 50-110; 1
Gateway; Gateway EV575; gwy15c7; 31.0-60.0; 50.0-110.0+; 1
Gateway; Gateway EV700; gwy1b5a; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5b; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5c; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5d; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5e; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5f; 31-69; 50-110; 1
Gateway; Gateway EVF720; gwy031b; 30.0-96.0; 50.0-130.0; 1
Gateway; Gateway FPD1500; gwy05dc; 30-61; 56-75; 1
Gateway; Gateway FPD1800; gwy0708; 63.9; 60.0; 1
Gateway; Gateway PFL2-15A; gwy060e; 48.0; 60; 1
Gateway; Gateway Vivitron 15; vivitron15; 31-64; 50-120; 1
Gateway; Gateway Vivitron 17; vivitron17; 31.5-64; 50-120; 1
Gateway; Gateway Vivitron 20; vivitron20; 29-82; 50-150; 1
Gateway; Gateway VX1100; gwy0454; 31.0-108.0; 50.0-160.0; 1
Gateway; Gateway VX1110; gwy045b; 31.0-115.0; 50.0-160.0; 1
Gateway; Gateway VX1120; gwy0460; 30-121; 50-160; 1
Gateway; Gateway VX700A; gwy044e; 30.0-86.0; 50.0-130.0; 1
Gateway; Gateway VX700; gwy044d; 30.0-86.0; 50.0-120.0; 1
Gateway; Gateway VX700; mel1673; 30.0-86.0; 50.0-120.0; 1
Gateway; Gateway VX720; gwy02d0; 30.0-96.0; 50.0-130.0; 1
Gateway; Gateway VX900; gwy0013; 30.0-95.0; 50.0-160.0; 1
Gateway; Gateway VX900T; gwy00c0; 30.0-96.0; 48.0-120.0; 1
Gateway; Gateway VX920; gwy0398; 30.0-96.0; 50.0-140.0; 1
Generic; 800x600 @ 60 Hz; 0; 31.5-37.9; 50-70
Generic; 1024x768 @ 70 Hz; 0; 31.5-57.0; 50-70
Generic; Flat Panel 1024x768; 0; 31.5-48.5; 40-70
Generic; Flat Panel 1280x1024; 0; 31.5-67; 50-75
Generic; Flat Panel 1400x1050; 0; 31.5-90; 59-75
Generic; Flat Panel 1600x1200; 0; 31.5-90; 60
Generic; Flat Panel 640x480; 0; 31.5; 40-70
Generic; Flat Panel 800x600; 0; 31.5-37.9; 40-70
Generic; 1280x1024 @ 60 Hz; 0; 31.5-64.3; 50-70
Generic; 1280x1024 @ 74 Hz; 0; 31.5-79.0; 50-90
Generic; 1280x1024 @ 76 Hz; 0; 31.5-82; 50-90
Generic; 1600x1200 @ 70 Hz; 0; 31.5-88.0; 50-90
Generic; 1600x1200 @ 76 Hz; 0; 31.5-94.0; 50-90
Generic; 1024x768 @ 60 Hz; 0; 31.5-48.5; 50-70
Generic; 640x480 @ 60 Hz; 0; 31.5; 50-61
Generic; 800x600 @ 56 Hz; 0; 31.5-35.1; 50-61
Golden Dragon; Golden Dragon TY-1411; ty-1411; 15.5-37.0; 50.0-120.0; 1
Golden Dragon; Golden Dragon TY-2015; ty-2015; 30.0-65.0; 49.0-88.0; 1
Goldstar; Goldstar LG StudioWorks20i; 0; 30.0-85.0; 50.0-120.0
Goldstar; Goldstar LG StudioWorks56i; 0; 30.0-60.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks56m; 0; 30.0-65.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks74m; 0; 30.0-50.0; 50.0-90.0
Goldstar; Goldstar LG StudioWorks76i; 0; 30.0-65.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks76m; 0; 30.0-65.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks77i; 0; 30.0-70.0; 50.0-160.0; 1
Goldstar; Goldstar LG StudioWorks78i; 0; 30.0-85.0; 50.0-120.0
Goldstar; Goldstar LG StudioWorks78T; 0; 30.0-85.0; 50.0-120.0
GoldStar Technology, Inc.; GoldStar 1423; 1423; 31.5; 70; 1
GoldStar Technology, Inc.; GoldStar 1423 Plus VGA; 1423+vga; 31.5; 70; 1
GoldStar Technology, Inc.; GoldStar 1453 Plus; 1453_plus; 35.5; 87; 1
GoldStar Technology, Inc.; GoldStar 1460 Plus VGA; 1460+vga; 48.0; 70; 1
GoldStar Technology, Inc.; GoldStar 1470_Plus; 1470_plus; 30.0-50.0; 45.0-90.0; 1
GoldStar Technology, Inc.; GoldStar 1490; 1490; 30.0-64.0; 50.0-120.0; 1
GoldStar Technology, Inc.; GoldStar 1510; 1510; 30.0-60.0; 50.0-105.0; 1
GoldStar Technology, Inc.; GoldStar 1620; 1620; 30.0-50.0; 45.0-90.0; 1
GoldStar Technology, Inc.; GoldStar 1710; 1710; 30.0-60.0; 50.0-105.0; 1
GoldStar Technology, Inc.; GoldStar 1725; 1725; 30-65; 50-120; 1
Hansol Electronics; Hansol Electronics Mazellan14px; hsl0579; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan15ax; hsl05dd; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan17ax; hsl06a6; 30.0-69.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan17px; hsla605; 30.0-85.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan400A; hsl057a; 30.0-50.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan400P; hsl0579; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan500A; hsl05dd; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan500P; hsl05de; 30.0-69.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan700A; hsl06a6; 30.0-69.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan700P; hsl06a5; 30.0-85.0; 50.0-120.0; 1
HCI; HCI Maxiscan; maxiscan; 15.0-35.0; 50.0-70.0; 1
Hewlett-Packard; HP A1295A 24-inch Display; 0; 30-96; 50-160; 1
Hewlett-Packard; HP A4033A 21-inch Display; 0; 30-80; 50-120; 1
Hewlett-Packard; HP A4331A 20-inch Display; 0; 30-82; 48-150; 1
Hewlett-Packard; HP A4576A (P1100) 21-inch Display; 0; 30-107; 50-160; 1
Hewlett-Packard; HP D1187A 20-inch Display; hp_d1187a; 30.0-64.0; 50.0-90.0; 1
Hewlett-Packard; HP D1188A 20-inch Display; hp_d1188a; 30.0-64.0; 50.0-90.0; 1
Hewlett-Packard; HP D1192A VGA Monochrome 14-inch Display; hp_d1192a; 31.5; 70; 1
Hewlett-Packard; HP D1192B VGA Monochrome 14-inch Display; hp_d1192b; 31.5; 70; 1
Hewlett-Packard; HP D1193A Ultra VGA 17-inch; hp_d1193a; 30.0-64.0; 50.0-90.0; 1
Hewlett-Packard; HP D1194A SVGA 14-inch Display; hp_d1194a; 37.9; 72; 1
Hewlett-Packard; HP D1195A Ergo-SVGA 14-inch Display; hp_d1195a; 48.1; 72; 1
Hewlett-Packard; HP D1196A Ergo Ultra VGA 15-inch Display; hp_d1196a; 56.4; 72; 1
Hewlett-Packard; HP D1197A Color VGA 14-inch Display; hp_d1197a; 31.5; 70; 1
Hewlett-Packard; HP D1198A SVGA 14-inch Display; hp_d1198a; 37.9; 70; 1
Hewlett-Packard; HP D1199A Ultra VGA 1600 21-inch Display; hp_d1199a; 30-82; 50-152; 1
Hewlett-Packard; HP D1815A 1024 Low Emissions 14-inch Display; hwp0aff; 31-48.4; 50-100; 1
Hewlett-Packard; HP D2800 Ultra VGA 1600 21-inch Display; hwp0af0; 30.0-85.0; 50.0-160.0; 1
Hewlett-Packard; HP D2801 Monochrome VGA 14-inch Display; hwp0af1; 31.5; 60; 0
Hewlett-Packard; HP D2802 Entry-Level SVGA 14-inch Display; hwp0af2; 35.5; 43.5; 1
Hewlett-Packard; HP D2803 Super VGA 1024i 14-inch Display; hwp0af3; 35.5; 43.5; 1
Hewlett-Packard; HP D2804 Super VGA 1024i 14-inch Display; hwp0af4; 35.5; 43.5; 1
Hewlett-Packard; HP D2805 Ergo 1024 14-inch Display; hwp0af5; 30.0-62.0; 50.0-100.0; 1
Hewlett-Packard; HP D2806 Ergo Ultra VGA 15-inch Display; hwp0af6; 30.0-64.0; 50.0-100.0; 1
Hewlett-Packard; HP D2807 Ultra VGA 1280 17-inch Display; hwp0af7; 30.0-64.0; 50.0-100.0; 1
Hewlett-Packard; HP D2808 1024 Low Emissions 15-inch Display; hwp0af8; 30.0-48.5; 50.0-100.0; 1
Hewlett-Packard; HP D2809 1024 Low Emissions MM 15-inch Display; hwp0af9; 30.0-48.5; 50.0-100.0; 1
Hewlett-Packard; HP D2810 1024 14-inch Display; hwp0afa; 48.4; 60; 1
Hewlett-Packard; HP D2811 1024 Low Emissions 14-inch Display; hwp0afb; 48.4; 60; 1
Hewlett-Packard; HP D2813 1024 14-inch Display; hwp0afd; 30.9-49.0; 50.0-100.0; 1
Hewlett-Packard; HP D2814 Super VGA Low Emissions 14-inch Display; hwp0afe; 35.5; 43.5; 1
Hewlett-Packard; HP D2815 1024 Low Emissions 14-inch Display; hwp0aff; 30.9-49.0; 50.0-100.0; 1
Hewlett-Packard; HP D2817 Ultra VGA 1280 17-inch Display; hwp0b01; 30.0-64.0; 50.0-160.0; 1
Hewlett-Packard; HP D2818 Ultra VGA 1280 17-inch Display; hwp0b02; 30.0-64.0; 50.0-120.0; 1
Hewlett-Packard; HP D2819 Ultra VGA 1280 Extra Low Emissions 17-inch Display; hwp0b03; 30.0-64.0; 50.0-120.0; 1
Hewlett-Packard; HP D2821 1024 Low Emissions 14-inch Display; hwp0b05; 31.0-54.0; 50.0-110.0; 1
Hewlett-Packard; HP D2825 Ultra VGA 1024 15-inch Display; hwp0b09; 31.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2826 HP 50 15-inch Display; hwp0b0a; 31.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2827 HP 51 15-inch Display; hwp0b0b; 31.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2828 HP 52 15-inch Monitor; hwp0b0c; 30.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2830 Ergo 1024 15-inch Display; hwp0b0e; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2831 Ergo 1024 Extra Low Emissions 15-inch Display; hwp0b0f; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2832 HP 500 15-inch Monitor; hwp0b10; 30.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D2835 Ultra VGA 1280 17-inch Display; hwp0b13; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2836 Ultra VGA 1280 Extra Low Emissions 17-inch Display; hwp0b14; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2837 HP 70 17-inch Display; hwp0b15; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D2838 M700 17-inch Display; hwp0b16; 30.0-86.0; 50.0-160.0; 1
Hewlett-Packard; HP D2839 HP 70 17-inch Monitor; hwp0b17; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D2840 Ergo 1280 17-inch Display; hwp0b18; 31.0-92.0; 50.0-150.0; 1
Hewlett-Packard; HP D2842 HP 90 19-inch Display; hwp0b1a; 30.0-96.0; 50.0-160.0; 1
Hewlett-Packard; HP D2843 M900 19-inch Monitor; hwp0b1b; 31.0-95.0; 50.0-160.0; 1
Hewlett-Packard; HP D2845 Ergo 1600 21-inch Display; hwp0b1d; 31.5-95.0; 50.0-160.0; 1
Hewlett-Packard; HP D2846 P1100 21-inch Monitor; hwp0b1e; 30.0-107.0; 48.0-160.0; 1
Hewlett-Packard; HP D2847 P1110 21-inch Monitor; hwp0b1f; 29.0-121.0; 50.0-180.0; 1
Hewlett-Packard; HP D3857A Multi Media 15-inch Display; hwp0f11; 31.0-48.4; 40.0-60.0; 1
Hewlett-Packard; HP D3858A Multi Media 14-inch Display; hwp0f12; 31.469-50.0; 56.0-75.0; 1
Hewlett-Packard; HP D3859A Multi Media 17-inch Display; hwp0f13; 30.0-68.0; 56.0-85.0; 1
Hewlett-Packard; HP D3861A Multi Scan 14-inch Display; hwp0f15; 31.469-50.0; 56.0-75.0; 1
Hewlett-Packard; HP D3899A Multi Media 14-inch Display; hwp0f3b; 31.469-50.0; 56.0-75.0; 1
Hewlett-Packard; HP D5060 1024 14-inch Liquid Crystal Display; hwp13c4; 31.5-61.0; 50.0-90.0; 1
Hewlett-Packard; HP D5061 L1500 15-inch LCD Monitor; hwp13c5; 31.0-69.0; 56.0-85.0; 1
Hewlett-Packard; HP D5065 L1800 18.1-inch LCD Monitor; hwp13c9; 30.0-80.0; 56.0-85.0; 1
Hewlett-Packard; HP D5069 L1810 18.1-inch LCD Monitor; hwp13cd; 30.0-80.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp0102; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp0486; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp04ea; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp054e; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp086e; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp08d2; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp0936; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp148a; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp0487; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp04eb; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp054f; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp148b; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5269A Pavilion M40 Monitor; hwp0491; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5269A Pavilion M40 Monitor; hwp04f5; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5269A Pavilion M40 Monitor; hwp0559; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D6433A Pavilion M90 Monitor; hwp1921; 31.468-98.0; 56.0-85.0; 1
Hewlett-Packard; HP D6433A Pavilion M90 Monitor; hwp1922; 31.468-98.0; 56.0-85.0; 1
Hewlett-Packard; HP D6433A Pavilion M90 Monitor; hwp1923; 31.468-98.0; 56.0-85.0; 1
Hewlett-Packard; HP D7739A Pavilion S50 Monitor; hwp1e3b; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D7740A Pavilion S70 Monitor; hwp1e3c; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D8891 HP 40 14-inch Monitor; hwp22bb; 30.0-50.0; 50.0-90.0; 1
Hewlett-Packard; HP D8894 HP 55 15-inch Monitor; hwp22be; 30.0-54.0; 50.0-90.0; 1
Hewlett-Packard; HP D8895 HP 55 15-inch Monitor; hwp22bf; 30.0-54.0; 50.0-90.0; 1
Hewlett-Packard; HP D8896 HP 55 15-inch Monitor; hwp22c0; 30.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D8897 HP 55 15-inch Monitor; hwp22c1; 30.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D8898 HP 55 TCO95 15-inch Monitor; hwp22c2; 30.0-69.0; 50.0-120.0; 1
Hewlett-Packard; HP D8900 HP 75 17-inch Monitor; hwp22c4; 31.0-86.0; 50.0-160.0; 1
Hewlett-Packard; HP D8901A HP 71 17-inch Monitor; hwp22c5; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D8902A HP 71 17-inch Monitor; hwp22c6; 31.0-72.0; 50.0-120.0; 1
Hewlett-Packard; HP D8903A HP 71 17-inch Monitor; hwp22c7; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D8906A HP P700 17-inch Monitor; hwp22ca; 30.0-86.0; 50.0-160.0; 1
Hewlett-Packard; HP D8910A HP P910 19-inch Monitor; hwp22ce; 29.0-107.0; 50.0-150.0; 1
Hewlett-Packard; HP D8911A HP 91 19-inch Monitor; hwp22cf; 30.0-95.0; 50.0-160.0; 1
Hewlett-Packard; HP D8912A HP P920 19-inch Monitor; hwp22d0; 30.0-107.0; 50.0-160.0; 1
Hewlett-Packard; HP D8915A HP P1120 21-inch Monitor; hwp22d3; 30.0-121.0; 48.0-160.0; 1
Hewlett-Packard; HP Pavilion M45/S40 Monitor; hwp14b2; 31.468-50.0; 56.0-75.0; 1
Hewlett-Packard; HP M500 15-inch Display; 0; 30-70; 50-120
Hewlett-Packard; HP M700 17-inch Display; 0; 30-86; 50-160
Hewlett-Packard; HP M900 19-inch Display; 0; 31-95; 50-150
Hewlett-Packard; HP 1024 LE Flat Panel 14-inch Display; 0; 32-54; 50-105
Hewlett-Packard; HP 1024 LCD Flat Panel 14-inch Display; 0; 32-61; 50-90
Highscreen; Highscreen LE 1024; 45; 31.4-31.6,35.1-35.2,35.5-35.6; 50-87
Hitachi, Ltd.; Hitachi CM640ET/CM640U; htcaffa; 31.0-69.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi 20-AP; 20-ap; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi 20-APF; 20-apf; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi 20-AS; 20-as; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi 21-AP; 21-ap; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX17L; hit1717; 30.0-64.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX20H; hit4830; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX20; hit4810; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX21; hit4811; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue UX4721; hit4711; 30.0-95.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue UX4921; hit4911; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue UX6821; hit6811; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi CM1798M; cm1798m; 30.0-82.0; 50.0-120.0; 1
Hitachi, Ltd.; Hitachi CM2198M; cm2198m; 30.0-94.0; 50.0-150.0; 1
Hitachi, Ltd.; Hitachi CM2199M; cm2199m; 31.5-107.0; 50.0-150; 1
Hitachi, Ltd.; Hitachi CM500E; htcafce; 30.0-69.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi CM620; htcafdd; 31.0-69.0; 47.0-130.0; 1
Hitachi, Ltd.; Hitachi CM630; htcafe2; 31.0-86.0; 47.0-130.0; 1
Hitachi, Ltd.; Hitachi CM640; htcaffa; 31.0-69.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM641; htcafec; 31.0-95.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM643; htcb001; 31.0-95.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM650; htcb004; 31.0-69.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM651; htcb005; 31.0-95.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM751; htcac13; 31.0-94.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM752; htcac15; 31.0-101.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM753; htcac22; 31.0-107.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM761; htcac76; 31.0-96.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM766; htcb00f; 31.0-96.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM768; htcb011; 31.0-107.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM769; htcb02f; 31.0-115.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM771; htcac82; 31.0-96.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM802; htcabe0; 31.0-100.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM803; htcabea; 31.0-115.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM811; htcac46; 31.0-96.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM812; htcac47; 31.0-107.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM813; htcac48; 31.0-115.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM814; htcac49; 31.0-125.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi HM1764; hit1727; 30.0-64.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi HM1782; hit1827; 30.0-82.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi HM4020; hit4020; 60.0-85.0; 60.0-120.0; 1
Hitachi, Ltd.; Hitachi HM4021; hit4021; 60.0-85.0; 60.0-120.0; 1
Hitachi, Ltd.; Hitachi HM4721; hit2147; 30.0-95.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM4820; hit4820; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM4821; hit4821; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM4921; hit2149; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM-5219; hm-5219; 88.0-90.0; 88.0-89.0; 1
Hitachi, Ltd.; Hitachi HM6421; hit6421; 100.0-102.0; 72.0-77.0; 1
Hitachi, Ltd.; Hitachi HM6821; hit6821; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi CM-1711M; htcab6f; 24.8-82.0; 55.0-120.0; 1
Hitachi, Ltd.; Hitachi CM-2110M; htcabcc; 31.0-85.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM-2111M; htcabc7; 31.0-95.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM-2112M; htcabc2; 31.0-107.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM500; htcafc8; 30.0-69.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi CM600; htcafd2; 30.0-64.0; 47.0-104.0; 1
Hitachi, Ltd.; Hitachi CM611; htcafd7; 31.0-92.0; 50.0-120.0; 1
Hitachi, Ltd.; Hitachi CM701; htcabf4; 31.0-96.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM800; htcabe3; 31.0-89.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM801; htcabe2; 31.0-96.0; 50.0-160.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 14; hn/l-4838x; 31.0-38.0; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 14 Plus; hn/l-4848; 31.0-48.4; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 14 Pro; hn/l-4860; 30.0-60.0; 50.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 14S; hei12f0; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 15B; hei16d8; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 15G; hei16e8; 30-64; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 15G+; hei16ee; 30.0-70.0; 50.0-120.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 15; hl-5848; 31.0-48.4; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 15 Pro; hei5864; 30.0-64.0; 50.0-120.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 17B; hei1eb8; 30-64; 50-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 17B+; hei1ebe; 30.0-70.0; 50.0-120.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 17; heib81e; 30.0-64.0; 50.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 17MB/17MS; 0; 30-50; 50-130
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 17 Pro; hei1e02; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 21; hei0b42; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan B790+; hei0790; 30.0-95.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan HLM-1510A; hei151a; 30.0-70.0; 43.0-85.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan P910+; hei0910; 30.0-107.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan V560; hei1560; 30.0-55.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan V570; hei1570; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan V770; hei1770; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-40X; hcm-40x; 31.5; 60.0-70.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-421E; 0; 30-36; 43-72; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-42X; hcm-42x; 35.5; 87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-43X; hcm-43x; 48.3; 60.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-44X; hcm-44x; 56.4; 70.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-2882; hei0b42; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-2885B; hei288b; 30.0-95.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4838E; hei12e6; 30-38; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4848F; hei12f0; 30.0-50.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4848; hei4848; 30-50; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4850B; hei12f2; 30-50; 50-130; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4854B; hei12f6; 30-50; 50-130; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4860E; hei12fc; 30-60; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5848F; hei16d8; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5848; hei5848; 30-48; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5854B; hei585b; 30.0-54.0; 50.0-130.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5854C; hei585c; 30.0-54.0; 50.0-130.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5860; hl-5860; 30.0-60.0; 56.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5864E; hei5864; 30-65; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5864F; hei16e8; 30-65; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870A; hei16ee; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870B; hei58b0; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870BM; hei58b1; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870C; hei587c; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7682A; hei1e02; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7682; hl-7682; 31.0-82.0; 56.0-100.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7682P; hl-7682p; 31.0-82.0; 56.0-100.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7770A; hei777a; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7770RD; hei777d; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7864F; hei7864; 30-65; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7864; hei1eb8; 30-65; 50-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870A; hei1ebe; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870AM; hei78a0; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870B; hei787b; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870S; hei78b0; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7948M; hei1f0c; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HMM-413; hmm-413; 31.5; 56.0-70.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HN-4938; hn-4938; 31.0-38.0; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HN-7448M; hei1d18; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HN/L-4850; hn/l-4850; 30.0-50.0; 50.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HT-2896B; hei289b; 30-96; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HT-7695B; hei769b; 30.0-95.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai ImageFlat F790D; heif790; 30.0-96.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai ImageFlat F910; heif910; 30.0-110.0; 50.0-150.0; 1
IBM; IBM 2112; ibm2112; 31.0-38.0; 50.0-80.0; 1
IBM; IBM 2113; ibm2113; 31.0-38.0; 50.0-80.0; 1
IBM; IBM 2114; ibm2114; 31.0-62.0; 50.0-120.0; 1
IBM; IBM 2115; ibm2115; 31.0-62.0; 50.0-120.0; 1
IBM; IBM 2116 MM55 Multimedia; ibm0844; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 2117; ibm2117; 31.0-65.0; 50.0-120.0; 1
IBM; IBM 2122-xxL; ibm7234; 30.0-54.0; 50.0-110.0; 1
IBM; IBM 2122; ibm2221; 30.0-54.0; 50.0-120.0; 1
IBM; IBM 2124-xxL; ibm7254; 30.0-54.0; 50.0-110.0; 1
IBM; IBM 2124; ibm2421; 30.0-54.0; 50.0-120.0; 1
IBM; IBM 2126; ibm2621; 30.0-69.0; 50.0-110.0; 1
IBM; IBM 2127; ibm2721; 30.0-72.0; 50.0-120.0; 1
IBM; IBM 2128 MM75 Multimedia; ibm0850; 30.0-69.0; 50.0-160.0; 1
IBM; IBM 2131; ibm3121; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 2132; ibm3221; 30.0-72.0; 50.0-120.0; 1
IBM; IBM 2215; ibm2215; 31.0-64.0; 50.0-120.0; 1
IBM; IBM 2235 C50; ibm08bb; 30.0-54.0; 50.0-120.0; 1
IBM; IBM 2236; ibm2236; 30.0-70.0; 50.0-120.0; 1
IBM; IBM 2237 C71; ibm08bd; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 2238; ibm2238; 31.0-38.0; 50.0-80.0; 1
IBM; IBM 2248; ibm2248; 31.0-48.0; 50.0-100.0; 1
IBM; IBM 2264; ibm2264; 31.0-64.0; 50.0-120.0; 1
IBM; IBM 6312; ibm6312; 31.0-50.0; 47.0-100.0; 1
IBM; IBM 6314; ibm6314; 30.0-60.0; 50.0-120.0; 1
IBM; IBM 6315; ibm6315; 31.0-48.5; 50.0-90.0; 1
IBM; IBM 6317; ibm6317; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 6319; ibm6319; 30.0-60.0; 50.0-120.0; 1
IBM; IBM 6321; ibm6321; 31.5-38.0; 56.0-72.0; 1
IBM; IBM 6322; ibm6322; 31.0-48.5; 50.0-90.0; 1
IBM; IBM 6324; ibm6324; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 6325; ibm6325; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 6327; ibm6327; 30.0-64.0; 50.0-130.0; 1
IBM; IBM 6540 G42; ibm198c; 30.0-50.0; 55.0-100.0; 1
IBM; IBM 6541 G51; ibm198d; 30.0-54.0; 55.0-100.0; 1
IBM; IBM 6546 G52; ibm1992; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 6547 G72; ibm1993; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 6549 G94; ibm1995; 30.0-95.0; 50.0-160.0; 1
IBM; IBM 6556 P72; ibm199c; 30.0-85.0; 50.0-150.0; 1
IBM; IBM 6557 P92; ibm199d; 30.0-94.0; 50.0-160.0; 1
IBM; IBM 6558 P202; ibm199e; 30.0-107.0; 50.0-160.0; 1
IBM; IBM 7095; ibm1bb7; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 7097; ibm1bb9; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 8504; ibm8504; 31.5; 60.0-70.0; 1
IBM; IBM 8511; ibm8511; 31.5; 50.0-70.0; 1
IBM; IBM 8512; ibm8512; 31.5; 60.0-70.0; 1
IBM; IBM 8513; ibm8513; 31.5; 60.0-70.0; 1
IBM; IBM 8514; ibm8514; 31.5; 60.0-70.0; 1
IBM; IBM 8515; ibm8515; 35.5; 60.0-87.0; 1
IBM; IBM 8517; ibm8517; 35.5; 60.0-87.0; 1
IBM; IBM 8518; ibm8518; 31.5; 60.0-70.0; 1
IBM; IBM 9504; ibm9504; 101.66; 77.1; 1
IBM; IBM 9513 T55A TFT Monitor; ibm2529; 30.0-61.0; 56.0-75.0; 1
IBM; IBM 9514-B TFT Panel; ibm252a; 48.0-65.0; 60.0-75.0; 1
IBM; IBM 9515; ibm9515; 61.1; 50.0-90.0; 1
IBM; IBM 9517; ibm9517; 59; 50.0-90.0; 1
IBM; IBM 9518; ibm9518; 39.4; 50.0-90.0; 1
IBM; IBM 9521; ibm9521; 30.0-68.0; 50.0-110.0; 1
IBM; IBM 9524; ibm9524; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 9525-0X1; ibm2535; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 9525; ibm9525; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 9527; ibm9527; 30.0-82.0; 50.0-110.0; 1
IBM; IBM Aptiva 9900; ibm26ac; 30.0-54.0; 50.0-120.0; 1
IBM; IBM Aptiva 9901; ibm27ad; 30.0-54.0; 50.0-120.0; 1
IBM; IBM G200; ibm1991; 31.0-82.0; 50.0-120.0; 1
IBM; IBM G41; ibm198e; 31.0-58.5; 50.0-95.0; 1
IBM; IBM G50; ibm198f; 31.0-58.5; 50.0-95.0; 1
IBM; IBM G70; ibm1990; 31.0-64.0; 50.0-105.0; 1
IBM; IBM MM55; ibm0844; 30.0-69.0; 50.0-120.0; 1
IBM; IBM MM75; ibm0850; 30.0-69.0; 50.0-120.0; 1
IBM; IBM P200; ibm199b; 29.0-90.0; 50.0-120.0; 1
IBM; IBM P201; ibmp201; 30.0-107.0; 50.0-160.0; 1
IBM; IBM P50; ibm1999; 30.0-69.0; 50.0-120.0; 1
IBM; IBM P70; ibm199a; 29.0-82.0; 50.0-120.0; 1
ICL; ICL ErgoPro 140v; icl-ep140v; 37.9; 58.0-75.0; 1
ICL; ICL ErgoPro 141p; icl0d00; 47.0-49.0; 50.0-90.0; 1
ICL; ICL ErgoPro 141v; icl0b00; 37.9; 58.0-75.0; 1
ICL; ICL ErgoPro 142v; icl1400; 37.9; 58.0-75.0; 1
ICL; ICL ErgoPro 151p AutoBrite; icl0800; 30.0-64.0; 48.0-100.0; 1
ICL; ICL ErgoPro 151p; icl0700; 30.0-64.0; 48.0-100.0; 1
ICL; ICL ErgoPro 151v; icl0a00; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPro 152v; icl0f00; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPro 171p; icl0200; 30.0-82.0; 50.0-110.0; 1
ICL; ICL ErgoPro 171v; icl0400; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPro 211v; icl0100; 24.0-82.0; 50.0-120.0; 1
ICL; ICL 14C; icl14c; 34.2-36.2; 50.0-90.0; 1
ICL; ICL 14M; icl14m; 31.5; 70; 1
ICL; ICL 14V; icl14v; 37.9; 58.0-75.0; 1
ICL; ICL 15V; icl15v; 30.0-64.0; 50.0-100.0; 1
ICL; ICL 17V; icl17v; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPRO 14C; icl-ep14c; 47.0-49.0; 50.0-90.0; 1
ICL; ICL ErgoPRO 15C; icl-ep15c; 30.0-62.0; 50.0-100.0; 1
ICL; ICL ErgoPRO 17C; icl-ep17c; 30.0-82.0; 50.0-110.0; 1
ICL; ICL ErgoPRO VE15C; icl-epve15c; 30.0-62.0; 48.0-100.0; 1
ICL; ICL ErgoPRO VE15M; icl-epve15m; 44.5; 68.0-89.0; 1
ICL; ICL SE14M; icl-se14m; 31.5; 70; 1
ICL; ICL VE15C; icl-ve15c; 30.0-62.0; 48.0-100.0; 1
ICL; ICL VE17C; icl-ve17c; 30.0-64.0; 48.0-100.0; 1
Iiyama; Iiyama A101GT, VisionMasterPro 501; ivm2118; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama A102GT, VisionMasterPro 502; ivm2128; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama A201HT, VisionMaster Pro 510; ivm2140; 30.0-130.0; 50.0-160.0; 1
Iiyama; Iiyama A701GT, VisionMasterPro 400; ivm1711; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama A702HT, VisionMaster Pro 410; ivm1740; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama A705MT, VisionMaster Pro 411 /i70A; ivm174a; 30.0-86.0; 50.0-180.0; 1
Iiyama; Iiyama A901HT, VisionMaster Pro 450; ivm1901; 27.0-115.0; 50.0-160.0; 1
Iiyama; Iiyama A902MT, VisionMaster Pro 451; ivm1918; 30.0-115.0; 50.0-180.0; 1
Iiyama; Iiyama DR-3114; dr-3114; 38.0; 43.0-70.0; 1
Iiyama; Iiyama MA901U, VisionMaster Pro 452; ivm1928; 30.0-96.0; 50.0-180.0; 1
Iiyama; Iiyama MF-5014A; mf-5014a; 15.5-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5015A; mf-5015a; 15.5-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5017; mf-5017; 15.0-40.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5021; mf-5021; 15.5-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5115; mf-5115; 21.8-50.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5117; mf-5117; 20.0-50.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5121A; mf-5121a; 30.0-65.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5214A; mf-5214a; 30.0-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5215A; mf-5215a; 30.0-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5217; mf-5217; 30.0-60.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5221; mf-5221; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5315; mf-5315; 30.0-68.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5317; mf-5317; 30.0-65.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5321; mf-5321; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5421; mf-5421; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5621; mf-5621; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-8217; mf-8217; 30.0-60.0; 50.0-90.0; 1
Iiyama; Iiyama MF-8221E/T, VisionMaster; ivm2100; 24-94; 50-160; 1
Iiyama; Iiyama MF-8515G, VisionMaster; ivm1501; 27-69; 50-160; 1
Iiyama; Iiyama MF-8617ES, VisionMaster; ivm1701; 27-86; 50-160; 1
Iiyama; Iiyama MF-8617E/T, VisionMaster; ivm1700; 27-86; 50-160; 1
Iiyama; Iiyama MF-8721E, VisionMaster; ivm2101; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama MF901U, VisionMaster 452; ivm1920; 30.0-96.0; 50.0-180.0; 1
Iiyama; Iiyama MR-5314; mf-5314; 30.0-60.0; 50.0-90.0; 1
Iiyama; Iiyama MT-9017E/T, VisionMasterPro; ivm1730; 27-92; 50-160; 1
Iiyama; Iiyama MT-9021E/T, VisionMasterPro; ivm2130; 24-94; 50-160; 1
Iiyama; Iiyama MT-9221, VisionMasterPro; ivm2102; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S101GT, VisionMaster 501; ivm2110; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S102GT, VisionMaster 502; ivm2120; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S103MT, VisionMaster 503; ivm2138; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S104MT, VisionMaster 504; ivm2148; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S500M1; ivm0815; 30.0-69.0; 50.0-120.0; 1
Iiyama; Iiyama S700JT1; ivm17a8; 30.0-70.0; 50.0-160.0; 1
Iiyama; Iiyama S701GT, VisionMaster 400; ivm1702; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S702GT, VisionMaster 400; ivm1703; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S703HT, VisionMaster 403; ivm1742; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S704HT, VisionMaster 404; ivm1744; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S705MT, VisionMaster 405; ivm1748; 30.0-86.0; 50.0-180.0; 1
Iiyama; Iiyama S901GT, VisionMaster 450; ivm1900; 27.0-102.0; 50.0-160.0; 1
Iiyama; Iiyama S902JT, VisionMaster Pro 451; ivm1910; 27.0-115.0; 50.0-160.0; 1
Iiyama; Iiyama TSA3931HT, Prolite39; ivm3900; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TSA4632HT, Prolite46; ivm4600; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TSA4633JT, Prolite46b; ivm4610; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TSA4634JT; ivm4618; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TXA3601GT; ivm3601; 31.5-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3602GT, Prolite36; ivm3602; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3611/3621HT, Prolite36; ivm3604; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3612JT, Prolite36c; ivm3606; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3811/3821HT, Prolite38; ivm3801; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3812JT/3822JT, Prolite38e/38f; ivm3810; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3813/3823MT; ivm3820; 24.8-61.0; 55.0-76.0; 1
Iiyama; Iiyama TXA3832HT, Prolite38c; ivm3808; 24.8-68.7; 56.0-85.0; 1
Iiyama; Iiyama TXA3833JT, Prolite38g; ivm3818; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama Vision Master MF-8221; mf-8221; 24.8-85.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8317; mf-8317; 30.0-65.0; 50.0-90.0; 1
Iiyama; Iiyama Vision Master MF-8421; mf-8421; 24.8-85.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8617E; ivm1700; 23.6-86.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8617; mf-8617; 23.6-86.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8621; mf-8621; 24.8-85.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master Pro 21 MT-9121; mf-9121; 25.0-90.0; 50.0-160.0; 1
Ikegami; Ikegami C/CDE-165VB; cde-165vb; 48.0-64.0; 50.0-70.0; 1
Ikegami; Ikegami C/DM-2010A; dm-2010a; 48.0-64.0; 50.0-70.0; 1
Ikegami; Ikegami C/DM-2060; dm-2060; 48.0-64.0; 50.0-70.0; 1
Ikegami; Ikegami CN-20; cn-20; 45.0-68.0; 50.0-150.0; 1
Ikegami; Ikegami CT-20; ct-20; 48.0-64.0; 50.0-70.0; 1
Image Systems Corp.; Image Systems C21LMAX; cs1lmax; 48.0-96.0; 60.0-80.0; 1
Image Systems Corp.; Image Systems M24LMAX; m24lmax; 48.0-96.0; 60.0-80.0; 1
Impression; Impression 5V J51A; jen9d00; 30-70; 60.0; 1
Impression; Impression 3 3428G; dcm-1488e; 35.5; 87.0; 1
Impression; Impression 3A; jd144c; 35.5; 87.0; 1
Impression; Impression 3 Plus 14; ma-1450; 35.5; 87.0; 1
Impression; Impression 3 Plus 3428NG; dcm-1458e; 35.5; 87.0; 1
Impression; Impression 4VX; jd144k; 48.0; 60.0; 1
Impression; Impression 50 Plus; dwe8251; 30.0-55.0; 50.0-120.0; 1
Impression; Impression 5 5528NG; dcm-1588e; 63.8; 60.0; 1
Impression; Impression 5 Plus; dpc6515; 64.0; 60.0; 1
Impression; Impression 5VM; dwe8351; 30.0-69.0; 50.0-120.0; 1
Impression; Impression 5VX JD155L; jen5510; 30-55; 85.0; 1
Impression; Impression 5VXL DE570BA; dpc7045; 30-70; 60.0; 1
Impression; Impression 5VXM; dwe8f51; 30.0-54.0; 50.0-120.0; 1
Impression; Impression 7 Plus DB770; da-1765; 64.0; 60.0; 1
Impression; Impression 7 Plus DC-770 BA; dpc7017; 30-70; 50-120; 1
Impression; Impression 7SP; imp4191; 30.0-70.0; 50.0-120.0; 1
Impression; Impression 7VX; imp0295; 30.0-96.0; 65.0; 1
Impression; Impression 9VX; dpc9509; 30-96; 60.0-85.0; 1
Impression; Impression Vienna 15; dpc6515; 64.0; 60.0; 1
Impression; Impression Vienna Pro 75; amt3844; 30.0-96.0; 65.0; 1
Impression; Impression Vienna Pro 75; at1782d; 82.0; 65.0; 1
Impression; Impression ViennaPro75; imp9802; 30.0-96.0; 65.0; 1
Intra Electronics USA, Inc.; Intra Electronics USA CM-1403; cm-1403; 15.0-38.0; 40.0-100.0; 1
Iocomm International Technology Corp.; Iocomm CM-7126; cm-7126; 30.0-75.0; 50.0-90.0; 1
JVC Information Products Co.; JVC GD-H4220US; h422ous; 15.0-37.0; 45.0-87.0; 1
KFC Computek Components Corp.; KFC Computek CA-17; ca-17; 30.0-64.0; 50.0-100.0; 1
KFC Computek Components Corp.; KFC Computek CH-14; ch-14; 15.0-36.0; 50.0-86.0; 1
KFC Computek Components Corp.; KFC Computek CM-14; cm-14; 30.0-64.0; 50.0-90.0; 1
KFC; KFC CA1511VX/CA1515VX; sml1511; 30-60; 50-100; 1
KFC; KFC CA15/1505/1506/1507/1515DX; sml1506; 30-60; 50-100; 1
KFC; KFC CA1516CX/CA1716CX; kfcec05; 30-65; 50-75; 1
KFC; KFC CA1702/03/05/06 M2; sml1706; 30-80; 50-100; 1
KFC; KFC CA1712/13/17/18; sml1718; 30-64; 50-100; 1
KFC; KFC CA2011M2; sml2011; 30-80; 50-120; 1
KFC; KFC CA2111M2; sml2111; 30-80; 50-120; 1
KFC; KFC CA6013DX/CA9013DX; sml6013; 30-38; 50-75; 1
KFC; KFC CA6719/29SL/CA6919/29SL; sml6719; 30-95; 50-150; 1
KFC; KFC CA8111SL; sml8111; 30-107; 50-160; 1
KFC; KFC CA8719SL; sml8719; 30-95; 50-150; 1
KFC; KFC CA8729SL; sml8729; 30-95; 50-160; 1
KFC; KFC CA8911SL; sml8911; 30-107; 50-160; 1
KFC; KFC CA8919SL; sml8919; 30-95; 50-160; 1
KFC; KFC CA8929SL; sml8929; 30-95; 50-160; 1
KFC; KFC CA/CB1414VX; sml1414; 30-48; 50-70; 1
KFC; KFC CA/CB6415DX/6515DX; sml6415; 30-54; 50-100; 1
KFC; KFC CA/CB6425DX/6525DX; sml6425; 30-54; 50-100; 1
KFC; KFC CA/CB6736DL/SL(NF); sml501a; 30-65; 50-100; 1
KFC; KFC CA/CB6738SL; sml6738; 30-85; 50-100; 1
KFC; KFC CA/CB6748SL; sml6748; 30-86; 50-150; 1
KFC; KFC L133/L133E; smll133; 30-61; 55-75; 1
KFC; KFC L150/L150E; smll150; 30-61; 55-75; 1
KFC; KFC MA0933; sml0933; 30-31.5; 50-70; 0
KFC; KFC MM/CA6546SX/(NF)/(MN); sml6546; 30-70; 50-100; 1
KFC; KFC MM/CA/CB6536DL/SL(NF); sml8819; 30-65; 50-100; 1
KFC; KFC MM/CA/CB6746SL; sml6746; 30-70; 50-120; 1
KLH Computers; KLH Computers MN275; mn275; 34.5-38.5; 50.0-90.0; 1
Komodo; Komodo P571; 0; 30-70; 50-120
Korea Data Systems; Korea Data Systems Avitron AV-5T; kds1540; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Avitron AV-7T; kds1740; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-195; kds1980; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-19; kds07d0; 31.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-19; kdsd007; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-19SN; kds1981; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-21; kds0834; 30.0-117.0; 50.0-160.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-21; kds3408; 30.0-117.0; 50.0-160.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4D; kds05af; 28.0-55.0; 40.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4D; kdsaf05; 28.0-55.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4(KD-1452); kds05ac; 28.0-50.0; 40.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4; kdsab05; 48.3; 60.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-55; kds05f5; 28.0-55.0; 40.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-55; kdsf505; 28.0-55.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-5; kdse605; 28.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-5/VS-51/VSx-5; kds05e6; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-7; kdsc206; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-7/VSx-7; kds06c2; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-9; kds06d6; 31.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-9; kdsd606; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VSx-5; kdsfa05; 28.0-70.0; 50.0-120.0; 1
Leading Technology, Inc.; Leading Technology 1730S; 1730s; 21.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG 1455; 1455; 37.9; 72.8; 1
LG Electronics Inc.; LG 1455D; 1455d; 37.9; 72.8; 1
LG Electronics Inc.; LG 1455DL; 1455dl; 37.9; 72.8; 1
LG Electronics Inc.; LG 1460DL; 1460dl; 37.9; 72.8; 1
LG Electronics Inc.; LG 1461D; 1461d; 37.9; 72.8; 1
LG Electronics Inc.; LG 1462DM; 1462dm; 37.9; 72.8; 1
LG Electronics Inc.; LG 1465DL; 1465dl; 48.4; 60.0; 1
LG Electronics Inc.; LG 1465DLS; 1465dls; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466; 1466; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466DM; 1466dm; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466LR; 1466lr; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466LRS; 1466lrs; 48.4; 60.0; 1
LG Electronics Inc.; LG 1467; 1467; 48.4; 60.0; 1
LG Electronics Inc.; LG 1468; 1468; 48.4; 60.0; 1
LG Electronics Inc.; LG 1485; 1485; 48.4; 60.0; 1
LG Electronics Inc.; LG 1505; 1505; 37.5; 75.0; 1
LG Electronics Inc.; LG 1505S; gsm3aa0; 48.4; 60.0; 1
LG Electronics Inc.; LG 1515; 1515; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1520; 1520; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1520DM; 1520dm; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1527; 1527; 30.0-57.0; 50.0-110.0; 1
LG Electronics Inc.; LG 1527; gsm3a9a; 30.0-57.0; 50.0-110.0; 1
LG Electronics Inc.; LG 1725; 1725; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1725DM; 1725dm; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1725s; gsm42cf; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1727; 1727; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1730DM; 1730dm; 30.0-82.0; 50.0-120.0; 1
LG Electronics Inc.; LG 2010; 2010; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 20i; gsm4e21; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG Studioworks28i; sw28i; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 44i; gsm36b9; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 44m; gsm36b4; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 45i; gsm36bb; 30.0-54.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 54m; gsm3aa9; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 55i; gsm3abd; 30.0-54.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 56i; gsm3aa8; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 56m; gsm3aa2; 30.0-65.0; 50.0-110.0; 1
LG Electronics Inc.; LG StudioWorks 56T; gsm3aaf; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 5D; gsm3ab6; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 74i; gsm4278; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 74m; gsm4277; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks74m; sw74m; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 76i; gsm426e; 30.0-65.0; 50.0-110.0; 1
LG Electronics Inc.; LG StudioWorks 76m; gsm4273; 30.0-65.0; 50.0-110.0; 1
LG Electronics Inc.; LG StudioWorks 76T; gsm4284; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78D; gsm427f; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78DT; gsm4280; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78i; gsm426c; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78m; gsm4274; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks78T; gsm426b; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78T; gsm426d; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 7D; gsm427e; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 7DT; gsm4281; 30.0-65.0; 50.0-120.0; 1
Link Computer, Inc.; Link Computer CE-8; ce-8; 15.5-38.0; 50.0-90.0; 1
Link Computer, Inc.; Link Computer CM-3; cm-3; 15.5-36.0; 50.0-70.0; 1
Lite-On; Lite-On CM-2090M; cm-2090m; 30.0-75.0; 40.0-120.0; 1
Lite-On; Lite-On 1570; ltn1570; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On S1770NSL; ltn1704; 30-70; 50-160; 1
Lite-On; Lite-On 1770NSL; ltn1770; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On A1454NEL; ltna443; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1454NE; ltna442; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1554NEL; ltna543; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1554NE; ltna542; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1570NSL; ltna595; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1570NST(92); ltna596; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1570NST(95); ltna597; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NSL; ltna795; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NST(92); ltna796; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NST(95); ltna797; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NST(99); ltna798; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1996NST(95); ltna967; 30.0-95.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NSL; ltnb795; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NST(92); ltnb796; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NST(95); ltnb797; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NST(99); ltnb798; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1985NSL; ltnb955; 30.0-86.0; 50.0-160.0; 1
Lite-On; Lite-On B1996NSL; ltnb965; 30.0-95.0; 50.0-160.0; 1
Lite-On; Lite-On B1996NST(95); ltnb967; 30.0-95.0; 50.0-160.0; 1
Lite-On; Lite-On B1996NST(99); ltnb968; 30.0-95.0; 50.0-160.0; 1
Lite-On; Lite-On B1997NST(99); ltn1901; 30.0-95.0; 50.0-120.0; 1
Lite-On; Lite-On BL150ATA; ltn0204; 24.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On BL150AT; ltn0205; 24.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On CM-1412; ltn1412; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1413; ltn1413; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1414; ltn1414; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1435; ltn1435; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1438; ltn1438; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1448; ltn1448; 30.0-48.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1450; ltn1450; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1550MCLR; ltn1550; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1554; ltn1554; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1555NEL; ltn1555; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1565MCLR; ltn1565; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1566; ltn1566; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1754; ltn1754; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1766; ltn1766; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1785NSL; ltn1785; 30.0-86.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1995NST; ltn1995; 30.0-97.0; 50.0-120.0; 1
Lite-On; Lite-On DC150ATA; ltn0208; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On DC150AT; ltn020c; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On DP150AT; ltn020b; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On DR150ATA; ltn0209; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On L140PTA; ltn0201; 45.0-54.0; 57.0-65.0; 1
Lite-On; Lite-On L150ATA; ltn0202; 24.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On L150PTA; ltn0203; 48.0-61.0; 56.0-61.0; 1
Lite-On; Lite-On P150AT; ltn0207; 24.0-61.0; 56.0-85.0; 1
Logitec; Logitec LCM-15FA2; LOG1040; 30.0-70.0; 50.0-120.0
Logitec; Logitec LCM-15FA3; LOG1053; 30.0-70.0; 50.0-120.0
Logitec; Logitec LCM-15FA; LOG1026; 30.0-69.0; 50.0-120.0
Logitec; Logitec LCM-15FS; LOG4536; 30.0-54.0; 50.0-110.0
Logitec; Logitec LCM-15TH; LOG1029; 30.0-70.0; 50.0-130.0
Logitec; Logitec LCM-17DV; LOG1024; 30.0-69.0; 55.0-125.0
Logitec; Logitec LCM-17FA; LOG1027; 30.0-69.0; 50.0-120.0
Logitec; Logitec LCM-17FS2; LOG1052; 30.0-72.0; 50.0-120.0
Logitec; Logitec LCM-17FS; LOG1039; 30.0-72.0; 50.0-120.0
Logitec; Logitec LCM-17TH; LOG1046; 30.0-95.0; 50.0-160.0
Logitec; Logitec LCM-17TS; LOG1054; 30.0-95.0; 50.0-160.0
Logitec; Logitec LCM-17TSU; LOG1048; 30.0-95.0; 50.0-160.0
Logitec; Logitec LCM-17TX; LOG1031; 30.0-92.0; 50.0-160.0
Logitec; Logitec LCM-19FS; LOG1050; 30.0-98.0; 50.0-160.0
Logitec; Logitec LCM-19TS; LOG1062; 30.0-110.0; 50.0-160.0
Logitec; Logitec LCM-21DX; LOG1025; 30.0-86.0; 50.0-132.0
Logitec; Logitec LCM-T041A; LOG1061; 24.8-37.5; 55.0-76.0
Logitec; Logitec LCM-T133A; LOG1035; 31.0-61.0; 56.0-75.0
Logitec; Logitec LCM-T134AS; LOG1058; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T141AS; LOG1049; 31.0-61.0; 56.0-85.0
Logitec; Logitec LCM-T142AS; LOG1055; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T151A; LOG1036; 31.0-61.0; 56.0-87.0
Logitec; Logitec LCM-T151AS; LOG1047; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T152A; LOG1045; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T153A; LOG1056; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T181A; LOG1057; 30.0-72.0; 50.0-120.0
MAG Technology Co., Ltd.; MAG Computronic Colorview/15; colorview15; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG Computronic PMV-14AC/plus; pmv-14ac; 15.0-36.0; 45.0-90.0; 1
MAG Technology Co., Ltd.; MAG Computronic PMV-1531; pmv-1531; 15.0-38.0; 45.0-90.0; 1
MAG Technology Co., Ltd.; MAG InnoVision DX15F; dx15f; 30-64; 50-90; 1
MAG Technology Co., Ltd.; MAG InnoVision DX17F; dx17f; 30-64; 50-90; 1
MAG Technology Co., Ltd.; MAG InnoVision DX21F; dx21f; 30-68; 50-120; 1
MAG Technology Co., Ltd.; MAG InnoVision LX1450; lx1450; 30-50; 50-100; 1
MAG Technology Co., Ltd.; MAG InnoVision MX15F; mx15f; 30.0-68.0; 50.0-110.0; 1
MAG Technology Co., Ltd.; MAG InnoVision MX17F/S; mx17fs; 30.0-68.0; 50.0-110.0; 1
MAG Technology Co., Ltd.; MAG InnoVision MX21NT; mx21nt; 30.0-82.0; 50.0-110.0; 1
MAG Technology Co., Ltd.; MAG 410V2; mag4561; 30.0-50.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG 510V2; mag5662; 30.0-50.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG 570FD; mag9510; 30.0-70.0; 50.0-130.0; 1
MAG Technology Co., Ltd.; MAG 570V; mag9501; 30.0-70.0; 50.0-150.0; 1
MAG Technology Co., Ltd.; MAG 710V2; mag7663; 30.0-65.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG 720V2; mag7764; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG 770T; mag9704; 30.0-70.0; 50.0-130.0; 1
MAG Technology Co., Ltd.; MAG 770V; mag9701; 30.0-70.0; 50.0-150.0; 1
MAG Technology Co., Ltd.; MAG 786FD; mag9705; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG 796FD; mag9706; 30.0-96.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG 800V; mag9807; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG 810FD; mag9809; 30.0-110.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG D410; mag4577; 30.0-54.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG DJ530AV; mag5767; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ530; mag5775; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ700; mag7746; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ702E; mag7747; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ702; mag7748; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ707AV; mag7769; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ707; mag7752; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ717; mag7854; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ800; mag6589; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ810; mag8991; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ920; mag9156; 30.0-110.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ925T; mag9157; 30.0-110.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DX1495; mag11a6; 30.0-50.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX1595; mag15f4; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX-1595; mag5620; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX15F; magdx15; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG DX15T; mag5624; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX1795; mag7626; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX17F; magdx17; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG DX17T; mag00e3; 30.0-69.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX500AV; mag5541; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX500T; mag5781; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG dx700e; mag7745; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX700T; mag7740; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX715T; mag7842; 30.0-86.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX725T; mag7990; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG dx800; mag6589; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG LT530C; mag5020; 45.0-58.0; 57.0-63.0; 1
MAG Technology Co., Ltd.; MAG LT541C; mag5021; 31.5-68.7; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LT541F; magc541; 31.0-69.0; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LT561D; magd561; 31.0-69.0; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LT561E; mage561; 31.0-69.0; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LX1450LG; mag1450; 30.0-50.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG LX1564LG; mag1564; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG MX14S; magm14s; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX15F; magmx15; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX17FG; mag17fg; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX17F; magmx17; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX21F; magmx21; 30.0-82.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MXE15F; mmxe15f; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG MXP17F; mmxp17f; 30.0-82.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG PMV14SV; pmv14sv; 30.0-36.0; 50.0-90.0; 1
MAG Technology Co., Ltd.; MAG XJ500; mag5801; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ500T; mag5779; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ530; mag5776; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ700; mag7771; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ700T; mag7780; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ707; mag7772; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ717; mag7874; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG xj770; mag9702; 30.0-70.0; 50.0-130.0; 1
MAG Technology Co., Ltd.; MAG XJ796; mag9703; 30.0-96.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG XJ810; mag8997; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG XJ910; mag9158; 30.0-110.0; 50.0-160.0; 1
Magnavox; Magnavox MB4010(14inch/CM1300); 0; 30.0-54.0; 50.0-110.0
Magnavox; Magnavox MB5314(15inch/CM1200); 0; 30.0-66.0; 50.0-110.0
Magnavox; Magnavox MB7000(17inch/CM6800); 0; 30.0-66.0; 50.0-130.0
Magnavox; Magnavox MV5011(15inch/CM1300); 0; 30.0-54.0; 50.0-110.0
Maxdata Computer; Maxdata Belinea 10 40 65; max4065; 30.0-50.0; 50.0-120.0; 1
Maxdata Computer; Maxdata Belinea 10 50 95; max3539; 30.0-64.0; 55.0-90.0; 1
Maxdata Computer; Maxdata Belinea 10 55 75; max7555; 30.0-69.0; 50.0-120.0; 1
MegaImage; MegaImage 17; 106; 30-64; 50-100
Microvitec, Inc.; Microvitec 1020/LP; 1020lp; 15.0-36.5; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 1020/SP; 1020sp; 15.0-36.5; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 2012/LP; 2012lp; 15.0-40.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 2014/LP; 2014lp; 15.0-40.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 2014/SVGA; 2014svga; 30.0-40.0; 45.0-90.0; 1
Microvitec, Inc.; Microvitec 2019/SP; 2019sp; 15.0-38.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 4015/FST; 4015fst; 30.0-50.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 604/FST; 604fst; 15.0-36.5; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 704/FST; 704fst; 15.0-36.5; 45.0-100.0; 1
Miro Computer Products AG; Miro miroD1568; mir6815; 31.5-68.0; 50.0-100.0; 1
Miro Computer Products AG; Miro miroD1769; mir6917; 31.5-69.0; 50.0-100.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC1768; mir6817; 29.0-68.0; 50.0-100.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC1782; mir8217; 29.0-82.0; 50.0-120.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC2085 E; mir8520; 29.0-85.0; 50.0-160.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC21107; mir0721; 31.5-107.0; 50.0-150.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC2185; mir8521; 30.0-85.0; 50.0-152.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC2193; mir9321; 30.0-93.0; 50.0-150.0; 1
MiTAC; MiTAC 1450FD; mtc0003; 31.0-50.0; 50.0-90.0; 1
MiTAC; MiTAC 1450FV; mtc0001; 31.0-50.0; 50.0-90.0; 1
MiTAC; MiTAC 1564FD/1564FS; mtc0002; 30.0-66.0; 50.0-100.0; 1
Mitsuba Corp.; Mitsuba Corp. 710MH; 710mh; 15.0-38.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Plus 100 (TFW1105); mel40e1; 30.0-108.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Plus 120u (TFA1105); mel42f0; 30.0-115.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Plus 200u (NSH1117); mel43f0; 30.0-108.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Plus 70 (TF-7700P); mel4190; 30.0-70.0; 50.0-180.0; 1
Mitsubishi; Mitsubishi Diamond Plus 71 (TFV6708); mel4240; 30.0-69.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Plus 72 (TFV8705); mel4160; 30.0-86.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Plus 73 (N9705); mel4460; 31.0-69.0; 59.0-86.0; 1
Mitsubishi; Mitsubishi Diamond Plus 91 (NFL9905); mel43a0; 30.0-96.0; 50.0-140.0; 1
Mitsubishi; Mitsubishi Diamond Pro 1000 (TFX1105); mel4100; 30.0-115.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 1010 (TUX1107); mel4101; 30.0-115.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 14 (FW6405); mel6405; 30.0-58; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Pro 14 Plus (SD45xx); mel4500; 30.0-57.0; 50.0-90.0; 0
Mitsubishi; Mitsubishi Diamond Pro 15FS (SD56xx); mel5600; 31.5-64.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Pro 17 (TFS6705); mel6705; 30.0-64.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 17TX (TFG8705); mel4040; 30.0-86.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 2020u (NUB1107); mel4310; 30.0-121.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Pro 2040u (NSB1107); mel4311; 30.0-121.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Pro 20 (HL7955); mel7955; 30.0-78.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Pro 20X (FR8905); mel2040; 30.0-82.0; 50.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Pro 21FS (FFL7165); mel7165b; 30.0-78.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Pro 21T (THZ8155); mel8155; 30.0-85.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 21TX (THN9105); mel0040; 30.0-93.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 26H (HJ6505); mel6505; 45.0-70.0; 50.0-80.0; 1
Mitsubishi; Mitsubishi Diamond Pro 26M (HC3505); mel3505; 15.7-38.0; 45.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Pro 29 (XC2930); mel2930; 15.0-82.0; 40.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Pro 37 (XC3725); mel3725; 24.0-64.0; 40.0-120.0; 0
Mitsubishi; Mitsubishi Diamond Pro 67TXV (TFV6705); mel4064; 30.0-69.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 700 (TFK9705); mel4110; 30.0-95.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 710 (NFF8705); mel4360; 30.0-86.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 720 (NFN9705); mel4381; 30.0-96.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 87TXM (TFM8705); mel40c0; 30.0-86.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 900u (NFJ9905); mel42c0; 30.0-95.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 91TXM (TFW9105); mel40e0; 30.0-95.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro SVGA (SD43xx); mel4300; 30.0-38.5; 50.0-70.0; 1
Mitsubishi; Mitsubishi Diamond Pro VGA (SD41xx); mel4100; 31.5; 60.0-70.0; 1
Mitsubishi; Mitsubishi Diamond Scan 15FS (SD55xx); mel5500; 31.5-57.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Scan 15HX (SD57xx); mel8040; 31.5-65.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Scan 15VX (SD58xx); mel408f; 30-65.0; 50.0-100.0; 1
Mitsubishi; Mitsubishi Diamond Scan 17FS (FFY7705); mel7705; 30.0-78.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Scan 17HX (FFF8705); mel6140; 30.0-82.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Scan 20H (FR8905); mel2040; 30.0-82.0; 50.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Scan 20 (HL6945/55); mel6955; 30.0-64.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Scan 20M (HC3925); mel3925; 15.7-38.0; 45.0-90.0; 0
Mitsubishi; Mitsubishi Diamond Scan 21 (FFL7165); mel7165; 30.0-78.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Scan 33 (XC3315); mel3315; 15.0-38.0; 40.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Scan 37 (XC3715); mel3715; 15.0-36.5; 40.0-120.0; 0
Mitsubishi; Mitsubishi Diamond Scan 50 (SD5904);
Fujitsu; Fujitsu FMV-DP996; fuj0110; 30.0-107.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DP997; fuj0210; 30.0-121.0; 48.0-160.0; 1
Fujitsu; Fujitsu FMV-DPA972; fuj4801; 30.0-70.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMV-DPA973; fuj2310; 30.0-70.0; 50.0-150.0; 1
Fujitsu; Fujitsu FP-2500; fuj2112; 24.0-85.0; 50.0-86.0; 1
Fujitsu; Fujitsu VL-1400SS; fuj8501; 31.5-57.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1410SS; fuj8601; 31.5-57.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1410TS; fuj8801; 31.5-56.5; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1420T; fuj4111; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-14TX1; fuj9111; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-14TX2; fuj9211; 30.0-48.4; 56.3-75.0; 1
Fujitsu; Fujitsu VL-1500T; fuj8701; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1510T; fuj3111; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1520A; fuj3311; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1520T; fuj3211; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530A; fuj3511; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530B; fuj3611; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530S; fuj3411; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1530SW; fuj3711; 31.5-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15DX1G; fuj8411; 48.4; 60.0; 1
Fujitsu; Fujitsu VL-15DX2G; fuj8811; 48.4; 60.0; 1
Fujitsu; Fujitsu VL-15DX3G; fuj8711; 48.4; 60.0; 1
Fujitsu; Fujitsu VL-15TX1(G); fuj8111; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15TX2; fuj8311; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15TX3G; fuj8211; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-15TX4G; fuj8611; 31.5-48.4; 56.0-75.0; 1
Fujitsu; Fujitsu VL-1800TS; fuj1111; 31.5-80.0; 56.0-85.0; 1
Fujitsu; Fujitsu VL-2100T; fuj8401; 31.5-80.0; 59.9-75.0; 1
Fujitsu; Fujitsu 1568G1; fpa2d30; 30-69; 50-120; 1
Fujitsu; Fujitsu 1769G; fpa2df9; 30-69; 50-120; 1
Fujitsu; Fujitsu e155; fuj3118; 30.0-54.0; 50.0-100.0; 1
Fujitsu; Fujitsu e175; icl2500; 30.0-85.0; 50.0-120.0; 1
Fujitsu; Fujitsu e176; icl2a00; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu e213; icl2700; 30.0-107.0; 50.0-150.0; 1
Fujitsu; Fujitsu ErgoPro e154; icl2200; 30.0-54.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro e174; icl2300; 30.0-69.0; 50.0-160.0; 1
Fujitsu; Fujitsu ErgoPro x153; icl2100; 30.0-69.0; 50.0-160.0; 1
Fujitsu; Fujitsu ErgoPro x174; icl2400; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu FMVDP97X5(G)/FMVDP97X6; fuj6210; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu ErgoPro 140v; icl-ep140v; 37.9; 58.0-75.0; 1
Fujitsu; Fujitsu ErgoPro 141p; icl0d00; 47.0-49.0; 50.0-90.0; 1
Fujitsu; Fujitsu ErgoPro 141v; icl0b00; 37.9; 58.0-75.0; 1
Fujitsu; Fujitsu ErgoPro 142v; icl1400; 37.9; 58.0-75.0; 1
Fujitsu; Fujitsu ErgoPro 151p AutoBrite; icl0800; 30.0-64.0; 48.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 151p; icl0700; 30.0-64.0; 48.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 151v; icl0a00; 30.0-64.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 152v; icl0f00; 30.0-64.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 171p; icl0200; 30.0-82.0; 50.0-110.0; 1
Fujitsu; Fujitsu ErgoPro 171v; icl0400; 30.0-64.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro 211v; icl0100; 24.0-82.0; 50.0-120.0; 1
Fujitsu; Fujitsu ErgoPro e153; icl1600; 30.0-66.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro e173; icl1d00; 30.0-65.0; 50.0-120.0; 1
Fujitsu; Fujitsu ErgoPro x152; icl1c00; 30.0-65.0; 50.0-100.0; 1
Fujitsu; Fujitsu ErgoPro x173a; icl1a00; 31.0-85.0; 48.0-100.0; 1
Fujitsu; Fujitsu ErgoPro x173; icl1900; 31.0-85.0; 48.0-100.0; 1
Fujitsu; Fujitsu x150f; fuj0119; 31.0-60.0; 56.0-75.0; 1
Fujitsu; Fujitsu x154; icl2900; 30.0-70.0; 50.0-120.0; 1
Fujitsu; Fujitsu x176; fuj2118; 30.0-100.0; 50.0-200.0; 1
Fujitsu; Fujitsu x177a; fuj2318; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu x177; fuj2218; 30.0-92.0; 50.0-150.0; 1
Fujitsu; Fujitsu x191; icl2800; 30.0-96.0; 50.0-160.0; 1
Funai Electric Company of Taiwan; Funai 17GD; fcm3313; 30.0-70.0; 50.0-120.0; 1
Gateway; Gateway EV700; gwy7658; 30.0-70.0; 50.0-120.0; 1
Gateway; Gateway EV900; gwy8883; 30.0-95.0; 50.0-160.0; 1
Gateway; Gateway EV700-H; gwy7659; 30.0-70.0; 50.0-120.0; 1
Gateway; Gateway VX900; gwy9095; 30.0-95.0; 50.0-160.0; 1
Gateway; Gateway 14SVGA; 14svga; 31.5-35.5; 50-90; 1
Gateway; Gateway AN1_15; gwy07d0; 30-60; 50-100; 1
Gateway; Gateway CM751; gwy0013; 31-95; 50-160; 1
Gateway; Gateway CM803; gwy138b; 31.0-115.0; 50.0-160.0; 1
Gateway; Gateway CrystalScan 1024; cs1024; 31.5-35.5; 50-90; 1
Gateway; Gateway CrystalScan 1024NI2G; cs1024ni2g; 31.5-48; 50-90; 1
Gateway; Gateway CrystalScan 1024NI; cs1024ni; 30-50; 50-90; 1
Gateway; Gateway CrystalScan 1572DG; 1572dg; 30-62; 50-120; 1
Gateway; Gateway CrystalScan 1572DGM; cs1572dgm; 30-62; 50-100; 1
Gateway; Gateway CrystalScan 1572FS; 1572fs; 30-62; 50-120; 1
Gateway; Gateway CrystalScan 17762LEG; cs17762leg; 30-64; 50-100; 1
Gateway; Gateway CrystalScan 500-069; gwy138a; 31-69; 50-110; 1
Gateway; Gateway CrystalScan 500; gwy0f04; 30-64; 50-100; 1
Gateway; Gateway CrystalScan 700-069; gwy1b5a; 31-69; 50-110; 1
Gateway; Gateway CrystalScan 700-069; gwy1b5b; 31-69; 50-110; 1
Gateway; Gateway DL27-1; gwy0a8d; 31.0-38.0; 50-75; 1
Gateway; Gateway DL31-1; gwy0089; 31.0-38.0; 50-75; 1
Gateway; Gateway DL31-1; gwy0c1e; 31.0-38.0; 50-75; 1
Gateway; Gateway DL36-1; gwy0e11; 31.0-38.0; 50-75; 1
Gateway; Gateway EV500; gwy138a; 31-69; 50-110; 1
Gateway; Gateway EV500; gwy138b; 31-69; 50-110; 1
Gateway; Gateway EV500; gwy138c; 31-69; 50-110; 1
Gateway; Gateway EV500; gwy5005; 31-69; 50-110; 1
Gateway; Gateway EV575; gwy15c7; 31.0-60.0; 50.0-110.0+; 1
Gateway; Gateway EV700; gwy1b5a; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5b; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5c; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5d; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5e; 31-69; 50-110; 1
Gateway; Gateway EV700; gwy1b5f; 31-69; 50-110; 1
Gateway; Gateway EVF720; gwy031b; 30.0-96.0; 50.0-130.0; 1
Gateway; Gateway FPD1500; gwy05dc; 30-61; 56-75; 1
Gateway; Gateway FPD1800; gwy0708; 63.9; 60.0; 1
Gateway; Gateway PFL2-15A; gwy060e; 48.0; 60; 1
Gateway; Gateway Vivitron 15; vivitron15; 31-64; 50-120; 1
Gateway; Gateway Vivitron 17; vivitron17; 31.5-64; 50-120; 1
Gateway; Gateway Vivitron 20; vivitron20; 29-82; 50-150; 1
Gateway; Gateway VX1100; gwy0454; 31.0-108.0; 50.0-160.0; 1
Gateway; Gateway VX1110; gwy045b; 31.0-115.0; 50.0-160.0; 1
Gateway; Gateway VX1120; gwy0460; 30-121; 50-160; 1
Gateway; Gateway VX700A; gwy044e; 30.0-86.0; 50.0-130.0; 1
Gateway; Gateway VX700; gwy044d; 30.0-86.0; 50.0-120.0; 1
Gateway; Gateway VX700; mel1673; 30.0-86.0; 50.0-120.0; 1
Gateway; Gateway VX720; gwy02d0; 30.0-96.0; 50.0-130.0; 1
Gateway; Gateway VX900; gwy0013; 30.0-95.0; 50.0-160.0; 1
Gateway; Gateway VX900T; gwy00c0; 30.0-96.0; 48.0-120.0; 1
Gateway; Gateway VX920; gwy0398; 30.0-96.0; 50.0-140.0; 1
Generic; 800x600 @ 60 Hz; 0; 31.5-37.9; 50-70
Generic; 1024x768 @ 70 Hz; 0; 31.5-57.0; 50-70
Generic; Flat Panel 1024x768; 0; 31.5-48.5; 40-70
Generic; Flat Panel 1280x1024; 0; 31.5-67; 50-75
Generic; Flat Panel 1400x1050; 0; 31.5-90; 59-75
Generic; Flat Panel 1600x1200; 0; 31.5-90; 60
Generic; Flat Panel 640x480; 0; 31.5; 40-70
Generic; Flat Panel 800x600; 0; 31.5-37.9; 40-70
Generic; 1280x1024 @ 60 Hz; 0; 31.5-64.3; 50-70
Generic; 1280x1024 @ 74 Hz; 0; 31.5-79.0; 50-90
Generic; 1280x1024 @ 76 Hz; 0; 31.5-82; 50-90
Generic; 1600x1200 @ 70 Hz; 0; 31.5-88.0; 50-90
Generic; 1600x1200 @ 76 Hz; 0; 31.5-94.0; 50-90
Generic; 1024x768 @ 60 Hz; 0; 31.5-48.5; 50-70
Generic; 640x480 @ 60 Hz; 0; 31.5; 50-61
Generic; 800x600 @ 56 Hz; 0; 31.5-35.1; 50-61
Golden Dragon; Golden Dragon TY-1411; ty-1411; 15.5-37.0; 50.0-120.0; 1
Golden Dragon; Golden Dragon TY-2015; ty-2015; 30.0-65.0; 49.0-88.0; 1
Goldstar; Goldstar LG StudioWorks20i; 0; 30.0-85.0; 50.0-120.0
Goldstar; Goldstar LG StudioWorks56i; 0; 30.0-60.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks56m; 0; 30.0-65.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks74m; 0; 30.0-50.0; 50.0-90.0
Goldstar; Goldstar LG StudioWorks76i; 0; 30.0-65.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks76m; 0; 30.0-65.0; 50.0-110.0
Goldstar; Goldstar LG StudioWorks77i; 0; 30.0-70.0; 50.0-160.0; 1
Goldstar; Goldstar LG StudioWorks78i; 0; 30.0-85.0; 50.0-120.0
Goldstar; Goldstar LG StudioWorks78T; 0; 30.0-85.0; 50.0-120.0
GoldStar Technology, Inc.; GoldStar 1423; 1423; 31.5; 70; 1
GoldStar Technology, Inc.; GoldStar 1423 Plus VGA; 1423+vga; 31.5; 70; 1
GoldStar Technology, Inc.; GoldStar 1453 Plus; 1453_plus; 35.5; 87; 1
GoldStar Technology, Inc.; GoldStar 1460 Plus VGA; 1460+vga; 48.0; 70; 1
GoldStar Technology, Inc.; GoldStar 1470_Plus; 1470_plus; 30.0-50.0; 45.0-90.0; 1
GoldStar Technology, Inc.; GoldStar 1490; 1490; 30.0-64.0; 50.0-120.0; 1
GoldStar Technology, Inc.; GoldStar 1510; 1510; 30.0-60.0; 50.0-105.0; 1
GoldStar Technology, Inc.; GoldStar 1620; 1620; 30.0-50.0; 45.0-90.0; 1
GoldStar Technology, Inc.; GoldStar 1710; 1710; 30.0-60.0; 50.0-105.0; 1
GoldStar Technology, Inc.; GoldStar 1725; 1725; 30-65; 50-120; 1
Hansol Electronics; Hansol Electronics Mazellan14px; hsl0579; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan15ax; hsl05dd; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan17ax; hsl06a6; 30.0-69.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan17px; hsla605; 30.0-85.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan400A; hsl057a; 30.0-50.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan400P; hsl0579; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan500A; hsl05dd; 30.0-54.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan500P; hsl05de; 30.0-69.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan700A; hsl06a6; 30.0-69.0; 50.0-120.0; 1
Hansol Electronics; Hansol Electronics Mazellan700P; hsl06a5; 30.0-85.0; 50.0-120.0; 1
HCI; HCI Maxiscan; maxiscan; 15.0-35.0; 50.0-70.0; 1
Hewlett-Packard; HP A1295A 24-inch Display; 0; 30-96; 50-160; 1
Hewlett-Packard; HP A4033A 21-inch Display; 0; 30-80; 50-120; 1
Hewlett-Packard; HP A4331A 20-inch Display; 0; 30-82; 48-150; 1
Hewlett-Packard; HP A4576A (P1100) 21-inch Display; 0; 30-107; 50-160; 1
Hewlett-Packard; HP D1187A 20-inch Display; hp_d1187a; 30.0-64.0; 50.0-90.0; 1
Hewlett-Packard; HP D1188A 20-inch Display; hp_d1188a; 30.0-64.0; 50.0-90.0; 1
Hewlett-Packard; HP D1192A VGA Monochrome 14-inch Display; hp_d1192a; 31.5; 70; 1
Hewlett-Packard; HP D1192B VGA Monochrome 14-inch Display; hp_d1192b; 31.5; 70; 1
Hewlett-Packard; HP D1193A Ultra VGA 17-inch; hp_d1193a; 30.0-64.0; 50.0-90.0; 1
Hewlett-Packard; HP D1194A SVGA 14-inch Display; hp_d1194a; 37.9; 72; 1
Hewlett-Packard; HP D1195A Ergo-SVGA 14-inch Display; hp_d1195a; 48.1; 72; 1
Hewlett-Packard; HP D1196A Ergo Ultra VGA 15-inch Display; hp_d1196a; 56.4; 72; 1
Hewlett-Packard; HP D1197A Color VGA 14-inch Display; hp_d1197a; 31.5; 70; 1
Hewlett-Packard; HP D1198A SVGA 14-inch Display; hp_d1198a; 37.9; 70; 1
Hewlett-Packard; HP D1199A Ultra VGA 1600 21-inch Display; hp_d1199a; 30-82; 50-152; 1
Hewlett-Packard; HP D1815A 1024 Low Emissions 14-inch Display; hwp0aff; 31-48.4; 50-100; 1
Hewlett-Packard; HP D2800 Ultra VGA 1600 21-inch Display; hwp0af0; 30.0-85.0; 50.0-160.0; 1
Hewlett-Packard; HP D2801 Monochrome VGA 14-inch Display; hwp0af1; 31.5; 60; 0
Hewlett-Packard; HP D2802 Entry-Level SVGA 14-inch Display; hwp0af2; 35.5; 43.5; 1
Hewlett-Packard; HP D2803 Super VGA 1024i 14-inch Display; hwp0af3; 35.5; 43.5; 1
Hewlett-Packard; HP D2804 Super VGA 1024i 14-inch Display; hwp0af4; 35.5; 43.5; 1
Hewlett-Packard; HP D2805 Ergo 1024 14-inch Display; hwp0af5; 30.0-62.0; 50.0-100.0; 1
Hewlett-Packard; HP D2806 Ergo Ultra VGA 15-inch Display; hwp0af6; 30.0-64.0; 50.0-100.0; 1
Hewlett-Packard; HP D2807 Ultra VGA 1280 17-inch Display; hwp0af7; 30.0-64.0; 50.0-100.0; 1
Hewlett-Packard; HP D2808 1024 Low Emissions 15-inch Display; hwp0af8; 30.0-48.5; 50.0-100.0; 1
Hewlett-Packard; HP D2809 1024 Low Emissions MM 15-inch Display; hwp0af9; 30.0-48.5; 50.0-100.0; 1
Hewlett-Packard; HP D2810 1024 14-inch Display; hwp0afa; 48.4; 60; 1
Hewlett-Packard; HP D2811 1024 Low Emissions 14-inch Display; hwp0afb; 48.4; 60; 1
Hewlett-Packard; HP D2813 1024 14-inch Display; hwp0afd; 30.9-49.0; 50.0-100.0; 1
Hewlett-Packard; HP D2814 Super VGA Low Emissions 14-inch Display; hwp0afe; 35.5; 43.5; 1
Hewlett-Packard; HP D2815 1024 Low Emissions 14-inch Display; hwp0aff; 30.9-49.0; 50.0-100.0; 1
Hewlett-Packard; HP D2817 Ultra VGA 1280 17-inch Display; hwp0b01; 30.0-64.0; 50.0-160.0; 1
Hewlett-Packard; HP D2818 Ultra VGA 1280 17-inch Display; hwp0b02; 30.0-64.0; 50.0-120.0; 1
Hewlett-Packard; HP D2819 Ultra VGA 1280 Extra Low Emissions 17-inch Display; hwp0b03; 30.0-64.0; 50.0-120.0; 1
Hewlett-Packard; HP D2821 1024 Low Emissions 14-inch Display; hwp0b05; 31.0-54.0; 50.0-110.0; 1
Hewlett-Packard; HP D2825 Ultra VGA 1024 15-inch Display; hwp0b09; 31.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2826 HP 50 15-inch Display; hwp0b0a; 31.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2827 HP 51 15-inch Display; hwp0b0b; 31.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2828 HP 52 15-inch Monitor; hwp0b0c; 30.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D2830 Ergo 1024 15-inch Display; hwp0b0e; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2831 Ergo 1024 Extra Low Emissions 15-inch Display; hwp0b0f; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2832 HP 500 15-inch Monitor; hwp0b10; 30.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D2835 Ultra VGA 1280 17-inch Display; hwp0b13; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2836 Ultra VGA 1280 Extra Low Emissions 17-inch Display; hwp0b14; 30.0-69.0; 50.0-160.0; 1
Hewlett-Packard; HP D2837 HP 70 17-inch Display; hwp0b15; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D2838 M700 17-inch Display; hwp0b16; 30.0-86.0; 50.0-160.0; 1
Hewlett-Packard; HP D2839 HP 70 17-inch Monitor; hwp0b17; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D2840 Ergo 1280 17-inch Display; hwp0b18; 31.0-92.0; 50.0-150.0; 1
Hewlett-Packard; HP D2842 HP 90 19-inch Display; hwp0b1a; 30.0-96.0; 50.0-160.0; 1
Hewlett-Packard; HP D2843 M900 19-inch Monitor; hwp0b1b; 31.0-95.0; 50.0-160.0; 1
Hewlett-Packard; HP D2845 Ergo 1600 21-inch Display; hwp0b1d; 31.5-95.0; 50.0-160.0; 1
Hewlett-Packard; HP D2846 P1100 21-inch Monitor; hwp0b1e; 30.0-107.0; 48.0-160.0; 1
Hewlett-Packard; HP D2847 P1110 21-inch Monitor; hwp0b1f; 29.0-121.0; 50.0-180.0; 1
Hewlett-Packard; HP D3857A Multi Media 15-inch Display; hwp0f11; 31.0-48.4; 40.0-60.0; 1
Hewlett-Packard; HP D3858A Multi Media 14-inch Display; hwp0f12; 31.469-50.0; 56.0-75.0; 1
Hewlett-Packard; HP D3859A Multi Media 17-inch Display; hwp0f13; 30.0-68.0; 56.0-85.0; 1
Hewlett-Packard; HP D3861A Multi Scan 14-inch Display; hwp0f15; 31.469-50.0; 56.0-75.0; 1
Hewlett-Packard; HP D3899A Multi Media 14-inch Display; hwp0f3b; 31.469-50.0; 56.0-75.0; 1
Hewlett-Packard; HP D5060 1024 14-inch Liquid Crystal Display; hwp13c4; 31.5-61.0; 50.0-90.0; 1
Hewlett-Packard; HP D5061 L1500 15-inch LCD Monitor; hwp13c5; 31.0-69.0; 56.0-85.0; 1
Hewlett-Packard; HP D5065 L1800 18.1-inch LCD Monitor; hwp13c9; 30.0-80.0; 56.0-85.0; 1
Hewlett-Packard; HP D5069 L1810 18.1-inch LCD Monitor; hwp13cd; 30.0-80.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp0102; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp0486; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp04ea; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp054e; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp086e; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp08d2; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp0936; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5258A Pavilion M50 Monitor; hwp148a; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp0487; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp04eb; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp054f; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5259A Pavilion M70 Monitor; hwp148b; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D5269A Pavilion M40 Monitor; hwp0491; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5269A Pavilion M40 Monitor; hwp04f5; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D5269A Pavilion M40 Monitor; hwp0559; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D6433A Pavilion M90 Monitor; hwp1921; 31.468-98.0; 56.0-85.0; 1
Hewlett-Packard; HP D6433A Pavilion M90 Monitor; hwp1922; 31.468-98.0; 56.0-85.0; 1
Hewlett-Packard; HP D6433A Pavilion M90 Monitor; hwp1923; 31.468-98.0; 56.0-85.0; 1
Hewlett-Packard; HP D7739A Pavilion S50 Monitor; hwp1e3b; 31.468-54.0; 56.0-85.0; 1
Hewlett-Packard; HP D7740A Pavilion S70 Monitor; hwp1e3c; 31.468-71.0; 56.0-85.0; 1
Hewlett-Packard; HP D8891 HP 40 14-inch Monitor; hwp22bb; 30.0-50.0; 50.0-90.0; 1
Hewlett-Packard; HP D8894 HP 55 15-inch Monitor; hwp22be; 30.0-54.0; 50.0-90.0; 1
Hewlett-Packard; HP D8895 HP 55 15-inch Monitor; hwp22bf; 30.0-54.0; 50.0-90.0; 1
Hewlett-Packard; HP D8896 HP 55 15-inch Monitor; hwp22c0; 30.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D8897 HP 55 15-inch Monitor; hwp22c1; 30.0-54.0; 50.0-120.0; 1
Hewlett-Packard; HP D8898 HP 55 TCO95 15-inch Monitor; hwp22c2; 30.0-69.0; 50.0-120.0; 1
Hewlett-Packard; HP D8900 HP 75 17-inch Monitor; hwp22c4; 31.0-86.0; 50.0-160.0; 1
Hewlett-Packard; HP D8901A HP 71 17-inch Monitor; hwp22c5; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D8902A HP 71 17-inch Monitor; hwp22c6; 31.0-72.0; 50.0-120.0; 1
Hewlett-Packard; HP D8903A HP 71 17-inch Monitor; hwp22c7; 31.0-70.0; 50.0-120.0; 1
Hewlett-Packard; HP D8906A HP P700 17-inch Monitor; hwp22ca; 30.0-86.0; 50.0-160.0; 1
Hewlett-Packard; HP D8910A HP P910 19-inch Monitor; hwp22ce; 29.0-107.0; 50.0-150.0; 1
Hewlett-Packard; HP D8911A HP 91 19-inch Monitor; hwp22cf; 30.0-95.0; 50.0-160.0; 1
Hewlett-Packard; HP D8912A HP P920 19-inch Monitor; hwp22d0; 30.0-107.0; 50.0-160.0; 1
Hewlett-Packard; HP D8915A HP P1120 21-inch Monitor; hwp22d3; 30.0-121.0; 48.0-160.0; 1
Hewlett-Packard; HP Pavilion M45/S40 Monitor; hwp14b2; 31.468-50.0; 56.0-75.0; 1
Hewlett-Packard; HP M500 15-inch Display; 0; 30-70; 50-120
Hewlett-Packard; HP M700 17-inch Display; 0; 30-86; 50-160
Hewlett-Packard; HP M900 19-inch Display; 0; 31-95; 50-150
Hewlett-Packard; HP 1024 LE Flat Panel 14-inch Display; 0; 32-54; 50-105
Hewlett-Packard; HP 1024 LCD Flat Panel 14-inch Display; 0; 32-61; 50-90
Highscreen; Highscreen LE 1024; 45; 31.4-31.6,35.1-35.2,35.5-35.6; 50-87
Hitachi, Ltd.; Hitachi CM640ET/CM640U; htcaffa; 31.0-69.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi 20-AP; 20-ap; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi 20-APF; 20-apf; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi 20-AS; 20-as; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi 21-AP; 21-ap; 30.0-65.0; 55.0-80.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX17L; hit1717; 30.0-64.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX20H; hit4830; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX20; hit4810; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue GX21; hit4811; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue UX4721; hit4711; 30.0-95.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue UX4921; hit4911; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi Accuvue UX6821; hit6811; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi CM1798M; cm1798m; 30.0-82.0; 50.0-120.0; 1
Hitachi, Ltd.; Hitachi CM2198M; cm2198m; 30.0-94.0; 50.0-150.0; 1
Hitachi, Ltd.; Hitachi CM2199M; cm2199m; 31.5-107.0; 50.0-150; 1
Hitachi, Ltd.; Hitachi CM500E; htcafce; 30.0-69.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi CM620; htcafdd; 31.0-69.0; 47.0-130.0; 1
Hitachi, Ltd.; Hitachi CM630; htcafe2; 31.0-86.0; 47.0-130.0; 1
Hitachi, Ltd.; Hitachi CM640; htcaffa; 31.0-69.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM641; htcafec; 31.0-95.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM643; htcb001; 31.0-95.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM650; htcb004; 31.0-69.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM651; htcb005; 31.0-95.0; 50.0-130.0; 1
Hitachi, Ltd.; Hitachi CM751; htcac13; 31.0-94.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM752; htcac15; 31.0-101.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM753; htcac22; 31.0-107.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM761; htcac76; 31.0-96.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM766; htcb00f; 31.0-96.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM768; htcb011; 31.0-107.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM769; htcb02f; 31.0-115.0; 50.0-180.0; 1
Hitachi, Ltd.; Hitachi CM771; htcac82; 31.0-96.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM802; htcabe0; 31.0-100.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM803; htcabea; 31.0-115.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM811; htcac46; 31.0-96.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM812; htcac47; 31.0-107.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM813; htcac48; 31.0-115.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM814; htcac49; 31.0-125.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi HM1764; hit1727; 30.0-64.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi HM1782; hit1827; 30.0-82.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi HM4020; hit4020; 60.0-85.0; 60.0-120.0; 1
Hitachi, Ltd.; Hitachi HM4021; hit4021; 60.0-85.0; 60.0-120.0; 1
Hitachi, Ltd.; Hitachi HM4721; hit2147; 30.0-95.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM4820; hit4820; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM4821; hit4821; 28.0-90.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM4921; hit2149; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi HM-5219; hm-5219; 88.0-90.0; 88.0-89.0; 1
Hitachi, Ltd.; Hitachi HM6421; hit6421; 100.0-102.0; 72.0-77.0; 1
Hitachi, Ltd.; Hitachi HM6821; hit6821; 30.0-107.0; 50.0-152.0; 1
Hitachi, Ltd.; Hitachi CM-1711M; htcab6f; 24.8-82.0; 55.0-120.0; 1
Hitachi, Ltd.; Hitachi CM-2110M; htcabcc; 31.0-85.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM-2111M; htcabc7; 31.0-95.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM-2112M; htcabc2; 31.0-107.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM500; htcafc8; 30.0-69.0; 50.0-100.0; 1
Hitachi, Ltd.; Hitachi CM600; htcafd2; 30.0-64.0; 47.0-104.0; 1
Hitachi, Ltd.; Hitachi CM611; htcafd7; 31.0-92.0; 50.0-120.0; 1
Hitachi, Ltd.; Hitachi CM701; htcabf4; 31.0-96.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM800; htcabe3; 31.0-89.0; 50.0-160.0; 1
Hitachi, Ltd.; Hitachi CM801; htcabe2; 31.0-96.0; 50.0-160.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 14; hn/l-4838x; 31.0-38.0; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 14 Plus; hn/l-4848; 31.0-48.4; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 14 Pro; hn/l-4860; 30.0-60.0; 50.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 14S; hei12f0; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 15B; hei16d8; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 15G; hei16e8; 30-64; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 15G+; hei16ee; 30.0-70.0; 50.0-120.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 15; hl-5848; 31.0-48.4; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 15 Pro; hei5864; 30.0-64.0; 50.0-120.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 17B; hei1eb8; 30-64; 50-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 17B+; hei1ebe; 30.0-70.0; 50.0-120.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 17; heib81e; 30.0-64.0; 50.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan 17MB/17MS; 0; 30-50; 50-130
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 17 Pro; hei1e02; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai Deluxscan 21; hei0b42; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan B790+; hei0790; 30.0-95.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan HLM-1510A; hei151a; 30.0-70.0; 43.0-85.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan P910+; hei0910; 30.0-107.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan V560; hei1560; 30.0-55.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan V570; hei1570; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai DeluxScan V770; hei1770; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-40X; hcm-40x; 31.5; 60.0-70.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-421E; 0; 30-36; 43-72; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-42X; hcm-42x; 35.5; 87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-43X; hcm-43x; 48.3; 60.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HCM-44X; hcm-44x; 56.4; 70.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-2882; hei0b42; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-2885B; hei288b; 30.0-95.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4838E; hei12e6; 30-38; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4848F; hei12f0; 30.0-50.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4848; hei4848; 30-50; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4850B; hei12f2; 30-50; 50-130; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4854B; hei12f6; 30-50; 50-130; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-4860E; hei12fc; 30-60; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5848F; hei16d8; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5848; hei5848; 30-48; 50-90; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5854B; hei585b; 30.0-54.0; 50.0-130.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5854C; hei585c; 30.0-54.0; 50.0-130.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5860; hl-5860; 30.0-60.0; 56.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5864E; hei5864; 30-65; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5864F; hei16e8; 30-65; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870A; hei16ee; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870B; hei58b0; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870BM; hei58b1; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-5870C; hei587c; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7682A; hei1e02; 30-82; 45-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7682; hl-7682; 31.0-82.0; 56.0-100.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7682P; hl-7682p; 31.0-82.0; 56.0-100.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7770A; hei777a; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7770RD; hei777d; 30.0-70.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7864F; hei7864; 30-65; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7864; hei1eb8; 30-65; 50-100; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870A; hei1ebe; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870AM; hei78a0; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870B; hei787b; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7870S; hei78b0; 30-70; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HL-7948M; hei1f0c; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HMM-413; hmm-413; 31.5; 56.0-70.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HN-4938; hn-4938; 31.0-38.0; 56.0-87.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HN-7448M; hei1d18; 30-48; 50-120; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HN/L-4850; hn/l-4850; 30.0-50.0; 50.0-90.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HT-2896B; hei289b; 30-96; 50-150; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai HT-7695B; hei769b; 30.0-95.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai ImageFlat F790D; heif790; 30.0-96.0; 50.0-150.0; 1
Hyundai Electronics Industries Co., Ltd.; Hyundai ImageFlat F910; heif910; 30.0-110.0; 50.0-150.0; 1
IBM; IBM 2112; ibm2112; 31.0-38.0; 50.0-80.0; 1
IBM; IBM 2113; ibm2113; 31.0-38.0; 50.0-80.0; 1
IBM; IBM 2114; ibm2114; 31.0-62.0; 50.0-120.0; 1
IBM; IBM 2115; ibm2115; 31.0-62.0; 50.0-120.0; 1
IBM; IBM 2116 MM55 Multimedia; ibm0844; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 2117; ibm2117; 31.0-65.0; 50.0-120.0; 1
IBM; IBM 2122-xxL; ibm7234; 30.0-54.0; 50.0-110.0; 1
IBM; IBM 2122; ibm2221; 30.0-54.0; 50.0-120.0; 1
IBM; IBM 2124-xxL; ibm7254; 30.0-54.0; 50.0-110.0; 1
IBM; IBM 2124; ibm2421; 30.0-54.0; 50.0-120.0; 1
IBM; IBM 2126; ibm2621; 30.0-69.0; 50.0-110.0; 1
IBM; IBM 2127; ibm2721; 30.0-72.0; 50.0-120.0; 1
IBM; IBM 2128 MM75 Multimedia; ibm0850; 30.0-69.0; 50.0-160.0; 1
IBM; IBM 2131; ibm3121; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 2132; ibm3221; 30.0-72.0; 50.0-120.0; 1
IBM; IBM 2215; ibm2215; 31.0-64.0; 50.0-120.0; 1
IBM; IBM 2235 C50; ibm08bb; 30.0-54.0; 50.0-120.0; 1
IBM; IBM 2236; ibm2236; 30.0-70.0; 50.0-120.0; 1
IBM; IBM 2237 C71; ibm08bd; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 2238; ibm2238; 31.0-38.0; 50.0-80.0; 1
IBM; IBM 2248; ibm2248; 31.0-48.0; 50.0-100.0; 1
IBM; IBM 2264; ibm2264; 31.0-64.0; 50.0-120.0; 1
IBM; IBM 6312; ibm6312; 31.0-50.0; 47.0-100.0; 1
IBM; IBM 6314; ibm6314; 30.0-60.0; 50.0-120.0; 1
IBM; IBM 6315; ibm6315; 31.0-48.5; 50.0-90.0; 1
IBM; IBM 6317; ibm6317; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 6319; ibm6319; 30.0-60.0; 50.0-120.0; 1
IBM; IBM 6321; ibm6321; 31.5-38.0; 56.0-72.0; 1
IBM; IBM 6322; ibm6322; 31.0-48.5; 50.0-90.0; 1
IBM; IBM 6324; ibm6324; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 6325; ibm6325; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 6327; ibm6327; 30.0-64.0; 50.0-130.0; 1
IBM; IBM 6540 G42; ibm198c; 30.0-50.0; 55.0-100.0; 1
IBM; IBM 6541 G51; ibm198d; 30.0-54.0; 55.0-100.0; 1
IBM; IBM 6546 G52; ibm1992; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 6547 G72; ibm1993; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 6549 G94; ibm1995; 30.0-95.0; 50.0-160.0; 1
IBM; IBM 6556 P72; ibm199c; 30.0-85.0; 50.0-150.0; 1
IBM; IBM 6557 P92; ibm199d; 30.0-94.0; 50.0-160.0; 1
IBM; IBM 6558 P202; ibm199e; 30.0-107.0; 50.0-160.0; 1
IBM; IBM 7095; ibm1bb7; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 7097; ibm1bb9; 30.0-69.0; 50.0-120.0; 1
IBM; IBM 8504; ibm8504; 31.5; 60.0-70.0; 1
IBM; IBM 8511; ibm8511; 31.5; 50.0-70.0; 1
IBM; IBM 8512; ibm8512; 31.5; 60.0-70.0; 1
IBM; IBM 8513; ibm8513; 31.5; 60.0-70.0; 1
IBM; IBM 8514; ibm8514; 31.5; 60.0-70.0; 1
IBM; IBM 8515; ibm8515; 35.5; 60.0-87.0; 1
IBM; IBM 8517; ibm8517; 35.5; 60.0-87.0; 1
IBM; IBM 8518; ibm8518; 31.5; 60.0-70.0; 1
IBM; IBM 9504; ibm9504; 101.66; 77.1; 1
IBM; IBM 9513 T55A TFT Monitor; ibm2529; 30.0-61.0; 56.0-75.0; 1
IBM; IBM 9514-B TFT Panel; ibm252a; 48.0-65.0; 60.0-75.0; 1
IBM; IBM 9515; ibm9515; 61.1; 50.0-90.0; 1
IBM; IBM 9517; ibm9517; 59; 50.0-90.0; 1
IBM; IBM 9518; ibm9518; 39.4; 50.0-90.0; 1
IBM; IBM 9521; ibm9521; 30.0-68.0; 50.0-110.0; 1
IBM; IBM 9524; ibm9524; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 9525-0X1; ibm2535; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 9525; ibm9525; 30.0-64.0; 50.0-110.0; 1
IBM; IBM 9527; ibm9527; 30.0-82.0; 50.0-110.0; 1
IBM; IBM Aptiva 9900; ibm26ac; 30.0-54.0; 50.0-120.0; 1
IBM; IBM Aptiva 9901; ibm27ad; 30.0-54.0; 50.0-120.0; 1
IBM; IBM G200; ibm1991; 31.0-82.0; 50.0-120.0; 1
IBM; IBM G41; ibm198e; 31.0-58.5; 50.0-95.0; 1
IBM; IBM G50; ibm198f; 31.0-58.5; 50.0-95.0; 1
IBM; IBM G70; ibm1990; 31.0-64.0; 50.0-105.0; 1
IBM; IBM MM55; ibm0844; 30.0-69.0; 50.0-120.0; 1
IBM; IBM MM75; ibm0850; 30.0-69.0; 50.0-120.0; 1
IBM; IBM P200; ibm199b; 29.0-90.0; 50.0-120.0; 1
IBM; IBM P201; ibmp201; 30.0-107.0; 50.0-160.0; 1
IBM; IBM P50; ibm1999; 30.0-69.0; 50.0-120.0; 1
IBM; IBM P70; ibm199a; 29.0-82.0; 50.0-120.0; 1
ICL; ICL ErgoPro 140v; icl-ep140v; 37.9; 58.0-75.0; 1
ICL; ICL ErgoPro 141p; icl0d00; 47.0-49.0; 50.0-90.0; 1
ICL; ICL ErgoPro 141v; icl0b00; 37.9; 58.0-75.0; 1
ICL; ICL ErgoPro 142v; icl1400; 37.9; 58.0-75.0; 1
ICL; ICL ErgoPro 151p AutoBrite; icl0800; 30.0-64.0; 48.0-100.0; 1
ICL; ICL ErgoPro 151p; icl0700; 30.0-64.0; 48.0-100.0; 1
ICL; ICL ErgoPro 151v; icl0a00; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPro 152v; icl0f00; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPro 171p; icl0200; 30.0-82.0; 50.0-110.0; 1
ICL; ICL ErgoPro 171v; icl0400; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPro 211v; icl0100; 24.0-82.0; 50.0-120.0; 1
ICL; ICL 14C; icl14c; 34.2-36.2; 50.0-90.0; 1
ICL; ICL 14M; icl14m; 31.5; 70; 1
ICL; ICL 14V; icl14v; 37.9; 58.0-75.0; 1
ICL; ICL 15V; icl15v; 30.0-64.0; 50.0-100.0; 1
ICL; ICL 17V; icl17v; 30.0-64.0; 50.0-100.0; 1
ICL; ICL ErgoPRO 14C; icl-ep14c; 47.0-49.0; 50.0-90.0; 1
ICL; ICL ErgoPRO 15C; icl-ep15c; 30.0-62.0; 50.0-100.0; 1
ICL; ICL ErgoPRO 17C; icl-ep17c; 30.0-82.0; 50.0-110.0; 1
ICL; ICL ErgoPRO VE15C; icl-epve15c; 30.0-62.0; 48.0-100.0; 1
ICL; ICL ErgoPRO VE15M; icl-epve15m; 44.5; 68.0-89.0; 1
ICL; ICL SE14M; icl-se14m; 31.5; 70; 1
ICL; ICL VE15C; icl-ve15c; 30.0-62.0; 48.0-100.0; 1
ICL; ICL VE17C; icl-ve17c; 30.0-64.0; 48.0-100.0; 1
Iiyama; Iiyama A101GT, VisionMasterPro 501; ivm2118; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama A102GT, VisionMasterPro 502; ivm2128; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama A201HT, VisionMaster Pro 510; ivm2140; 30.0-130.0; 50.0-160.0; 1
Iiyama; Iiyama A701GT, VisionMasterPro 400; ivm1711; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama A702HT, VisionMaster Pro 410; ivm1740; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama A705MT, VisionMaster Pro 411 /i70A; ivm174a; 30.0-86.0; 50.0-180.0; 1
Iiyama; Iiyama A901HT, VisionMaster Pro 450; ivm1901; 27.0-115.0; 50.0-160.0; 1
Iiyama; Iiyama A902MT, VisionMaster Pro 451; ivm1918; 30.0-115.0; 50.0-180.0; 1
Iiyama; Iiyama DR-3114; dr-3114; 38.0; 43.0-70.0; 1
Iiyama; Iiyama MA901U, VisionMaster Pro 452; ivm1928; 30.0-96.0; 50.0-180.0; 1
Iiyama; Iiyama MF-5014A; mf-5014a; 15.5-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5015A; mf-5015a; 15.5-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5017; mf-5017; 15.0-40.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5021; mf-5021; 15.5-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5115; mf-5115; 21.8-50.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5117; mf-5117; 20.0-50.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5121A; mf-5121a; 30.0-65.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5214A; mf-5214a; 30.0-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5215A; mf-5215a; 30.0-38.5; 50.0-90.0; 1
Iiyama; Iiyama MF-5217; mf-5217; 30.0-60.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5221; mf-5221; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5315; mf-5315; 30.0-68.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5317; mf-5317; 30.0-65.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5321; mf-5321; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5421; mf-5421; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-5621; mf-5621; 30.0-80.0; 50.0-90.0; 1
Iiyama; Iiyama MF-8217; mf-8217; 30.0-60.0; 50.0-90.0; 1
Iiyama; Iiyama MF-8221E/T, VisionMaster; ivm2100; 24-94; 50-160; 1
Iiyama; Iiyama MF-8515G, VisionMaster; ivm1501; 27-69; 50-160; 1
Iiyama; Iiyama MF-8617ES, VisionMaster; ivm1701; 27-86; 50-160; 1
Iiyama; Iiyama MF-8617E/T, VisionMaster; ivm1700; 27-86; 50-160; 1
Iiyama; Iiyama MF-8721E, VisionMaster; ivm2101; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama MF901U, VisionMaster 452; ivm1920; 30.0-96.0; 50.0-180.0; 1
Iiyama; Iiyama MR-5314; mf-5314; 30.0-60.0; 50.0-90.0; 1
Iiyama; Iiyama MT-9017E/T, VisionMasterPro; ivm1730; 27-92; 50-160; 1
Iiyama; Iiyama MT-9021E/T, VisionMasterPro; ivm2130; 24-94; 50-160; 1
Iiyama; Iiyama MT-9221, VisionMasterPro; ivm2102; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S101GT, VisionMaster 501; ivm2110; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S102GT, VisionMaster 502; ivm2120; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S103MT, VisionMaster 503; ivm2138; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S104MT, VisionMaster 504; ivm2148; 27.0-110.0; 50.0-160.0; 1
Iiyama; Iiyama S500M1; ivm0815; 30.0-69.0; 50.0-120.0; 1
Iiyama; Iiyama S700JT1; ivm17a8; 30.0-70.0; 50.0-160.0; 1
Iiyama; Iiyama S701GT, VisionMaster 400; ivm1702; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S702GT, VisionMaster 400; ivm1703; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S703HT, VisionMaster 403; ivm1742; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S704HT, VisionMaster 404; ivm1744; 27.0-96.0; 50.0-160.0; 1
Iiyama; Iiyama S705MT, VisionMaster 405; ivm1748; 30.0-86.0; 50.0-180.0; 1
Iiyama; Iiyama S901GT, VisionMaster 450; ivm1900; 27.0-102.0; 50.0-160.0; 1
Iiyama; Iiyama S902JT, VisionMaster Pro 451; ivm1910; 27.0-115.0; 50.0-160.0; 1
Iiyama; Iiyama TSA3931HT, Prolite39; ivm3900; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TSA4632HT, Prolite46; ivm4600; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TSA4633JT, Prolite46b; ivm4610; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TSA4634JT; ivm4618; 24.8-80.0; 56.0-85.0; 1
Iiyama; Iiyama TXA3601GT; ivm3601; 31.5-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3602GT, Prolite36; ivm3602; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3611/3621HT, Prolite36; ivm3604; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3612JT, Prolite36c; ivm3606; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3811/3821HT, Prolite38; ivm3801; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3812JT/3822JT, Prolite38e/38f; ivm3810; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama TXA3813/3823MT; ivm3820; 24.8-61.0; 55.0-76.0; 1
Iiyama; Iiyama TXA3832HT, Prolite38c; ivm3808; 24.8-68.7; 56.0-85.0; 1
Iiyama; Iiyama TXA3833JT, Prolite38g; ivm3818; 24.8-60.0; 56.0-75.0; 1
Iiyama; Iiyama Vision Master MF-8221; mf-8221; 24.8-85.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8317; mf-8317; 30.0-65.0; 50.0-90.0; 1
Iiyama; Iiyama Vision Master MF-8421; mf-8421; 24.8-85.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8617E; ivm1700; 23.6-86.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8617; mf-8617; 23.6-86.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master MF-8621; mf-8621; 24.8-85.0; 50.0-120.0; 1
Iiyama; Iiyama Vision Master Pro 21 MT-9121; mf-9121; 25.0-90.0; 50.0-160.0; 1
Ikegami; Ikegami C/CDE-165VB; cde-165vb; 48.0-64.0; 50.0-70.0; 1
Ikegami; Ikegami C/DM-2010A; dm-2010a; 48.0-64.0; 50.0-70.0; 1
Ikegami; Ikegami C/DM-2060; dm-2060; 48.0-64.0; 50.0-70.0; 1
Ikegami; Ikegami CN-20; cn-20; 45.0-68.0; 50.0-150.0; 1
Ikegami; Ikegami CT-20; ct-20; 48.0-64.0; 50.0-70.0; 1
Image Systems Corp.; Image Systems C21LMAX; cs1lmax; 48.0-96.0; 60.0-80.0; 1
Image Systems Corp.; Image Systems M24LMAX; m24lmax; 48.0-96.0; 60.0-80.0; 1
Impression; Impression 5V J51A; jen9d00; 30-70; 60.0; 1
Impression; Impression 3 3428G; dcm-1488e; 35.5; 87.0; 1
Impression; Impression 3A; jd144c; 35.5; 87.0; 1
Impression; Impression 3 Plus 14; ma-1450; 35.5; 87.0; 1
Impression; Impression 3 Plus 3428NG; dcm-1458e; 35.5; 87.0; 1
Impression; Impression 4VX; jd144k; 48.0; 60.0; 1
Impression; Impression 50 Plus; dwe8251; 30.0-55.0; 50.0-120.0; 1
Impression; Impression 5 5528NG; dcm-1588e; 63.8; 60.0; 1
Impression; Impression 5 Plus; dpc6515; 64.0; 60.0; 1
Impression; Impression 5VM; dwe8351; 30.0-69.0; 50.0-120.0; 1
Impression; Impression 5VX JD155L; jen5510; 30-55; 85.0; 1
Impression; Impression 5VXL DE570BA; dpc7045; 30-70; 60.0; 1
Impression; Impression 5VXM; dwe8f51; 30.0-54.0; 50.0-120.0; 1
Impression; Impression 7 Plus DB770; da-1765; 64.0; 60.0; 1
Impression; Impression 7 Plus DC-770 BA; dpc7017; 30-70; 50-120; 1
Impression; Impression 7SP; imp4191; 30.0-70.0; 50.0-120.0; 1
Impression; Impression 7VX; imp0295; 30.0-96.0; 65.0; 1
Impression; Impression 9VX; dpc9509; 30-96; 60.0-85.0; 1
Impression; Impression Vienna 15; dpc6515; 64.0; 60.0; 1
Impression; Impression Vienna Pro 75; amt3844; 30.0-96.0; 65.0; 1
Impression; Impression Vienna Pro 75; at1782d; 82.0; 65.0; 1
Impression; Impression ViennaPro75; imp9802; 30.0-96.0; 65.0; 1
Intra Electronics USA, Inc.; Intra Electronics USA CM-1403; cm-1403; 15.0-38.0; 40.0-100.0; 1
Iocomm International Technology Corp.; Iocomm CM-7126; cm-7126; 30.0-75.0; 50.0-90.0; 1
JVC Information Products Co.; JVC GD-H4220US; h422ous; 15.0-37.0; 45.0-87.0; 1
KFC Computek Components Corp.; KFC Computek CA-17; ca-17; 30.0-64.0; 50.0-100.0; 1
KFC Computek Components Corp.; KFC Computek CH-14; ch-14; 15.0-36.0; 50.0-86.0; 1
KFC Computek Components Corp.; KFC Computek CM-14; cm-14; 30.0-64.0; 50.0-90.0; 1
KFC; KFC CA1511VX/CA1515VX; sml1511; 30-60; 50-100; 1
KFC; KFC CA15/1505/1506/1507/1515DX; sml1506; 30-60; 50-100; 1
KFC; KFC CA1516CX/CA1716CX; kfcec05; 30-65; 50-75; 1
KFC; KFC CA1702/03/05/06 M2; sml1706; 30-80; 50-100; 1
KFC; KFC CA1712/13/17/18; sml1718; 30-64; 50-100; 1
KFC; KFC CA2011M2; sml2011; 30-80; 50-120; 1
KFC; KFC CA2111M2; sml2111; 30-80; 50-120; 1
KFC; KFC CA6013DX/CA9013DX; sml6013; 30-38; 50-75; 1
KFC; KFC CA6719/29SL/CA6919/29SL; sml6719; 30-95; 50-150; 1
KFC; KFC CA8111SL; sml8111; 30-107; 50-160; 1
KFC; KFC CA8719SL; sml8719; 30-95; 50-150; 1
KFC; KFC CA8729SL; sml8729; 30-95; 50-160; 1
KFC; KFC CA8911SL; sml8911; 30-107; 50-160; 1
KFC; KFC CA8919SL; sml8919; 30-95; 50-160; 1
KFC; KFC CA8929SL; sml8929; 30-95; 50-160; 1
KFC; KFC CA/CB1414VX; sml1414; 30-48; 50-70; 1
KFC; KFC CA/CB6415DX/6515DX; sml6415; 30-54; 50-100; 1
KFC; KFC CA/CB6425DX/6525DX; sml6425; 30-54; 50-100; 1
KFC; KFC CA/CB6736DL/SL(NF); sml501a; 30-65; 50-100; 1
KFC; KFC CA/CB6738SL; sml6738; 30-85; 50-100; 1
KFC; KFC CA/CB6748SL; sml6748; 30-86; 50-150; 1
KFC; KFC L133/L133E; smll133; 30-61; 55-75; 1
KFC; KFC L150/L150E; smll150; 30-61; 55-75; 1
KFC; KFC MA0933; sml0933; 30-31.5; 50-70; 0
KFC; KFC MM/CA6546SX/(NF)/(MN); sml6546; 30-70; 50-100; 1
KFC; KFC MM/CA/CB6536DL/SL(NF); sml8819; 30-65; 50-100; 1
KFC; KFC MM/CA/CB6746SL; sml6746; 30-70; 50-120; 1
KLH Computers; KLH Computers MN275; mn275; 34.5-38.5; 50.0-90.0; 1
Komodo; Komodo P571; 0; 30-70; 50-120
Korea Data Systems; Korea Data Systems Avitron AV-5T; kds1540; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Avitron AV-7T; kds1740; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-195; kds1980; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-19; kds07d0; 31.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-19; kdsd007; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-19SN; kds1981; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-21; kds0834; 30.0-117.0; 50.0-160.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-21; kds3408; 30.0-117.0; 50.0-160.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4D; kds05af; 28.0-55.0; 40.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4D; kdsaf05; 28.0-55.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4(KD-1452); kds05ac; 28.0-50.0; 40.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-4; kdsab05; 48.3; 60.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-55; kds05f5; 28.0-55.0; 40.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-55; kdsf505; 28.0-55.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-5; kdse605; 28.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-5/VS-51/VSx-5; kds05e6; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-7; kdsc206; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-7/VSx-7; kds06c2; 30.0-70.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-9; kds06d6; 31.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VS-9; kdsd606; 30.0-95.0; 50.0-120.0; 1
Korea Data Systems; Korea Data Systems Visual Sensations VSx-5; kdsfa05; 28.0-70.0; 50.0-120.0; 1
Leading Technology, Inc.; Leading Technology 1730S; 1730s; 21.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG 1455; 1455; 37.9; 72.8; 1
LG Electronics Inc.; LG 1455D; 1455d; 37.9; 72.8; 1
LG Electronics Inc.; LG 1455DL; 1455dl; 37.9; 72.8; 1
LG Electronics Inc.; LG 1460DL; 1460dl; 37.9; 72.8; 1
LG Electronics Inc.; LG 1461D; 1461d; 37.9; 72.8; 1
LG Electronics Inc.; LG 1462DM; 1462dm; 37.9; 72.8; 1
LG Electronics Inc.; LG 1465DL; 1465dl; 48.4; 60.0; 1
LG Electronics Inc.; LG 1465DLS; 1465dls; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466; 1466; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466DM; 1466dm; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466LR; 1466lr; 48.4; 60.0; 1
LG Electronics Inc.; LG 1466LRS; 1466lrs; 48.4; 60.0; 1
LG Electronics Inc.; LG 1467; 1467; 48.4; 60.0; 1
LG Electronics Inc.; LG 1468; 1468; 48.4; 60.0; 1
LG Electronics Inc.; LG 1485; 1485; 48.4; 60.0; 1
LG Electronics Inc.; LG 1505; 1505; 37.5; 75.0; 1
LG Electronics Inc.; LG 1505S; gsm3aa0; 48.4; 60.0; 1
LG Electronics Inc.; LG 1515; 1515; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1520; 1520; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1520DM; 1520dm; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1527; 1527; 30.0-57.0; 50.0-110.0; 1
LG Electronics Inc.; LG 1527; gsm3a9a; 30.0-57.0; 50.0-110.0; 1
LG Electronics Inc.; LG 1725; 1725; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1725DM; 1725dm; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1725s; gsm42cf; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1727; 1727; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG 1730DM; 1730dm; 30.0-82.0; 50.0-120.0; 1
LG Electronics Inc.; LG 2010; 2010; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 20i; gsm4e21; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG Studioworks28i; sw28i; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 44i; gsm36b9; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 44m; gsm36b4; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 45i; gsm36bb; 30.0-54.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 54m; gsm3aa9; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 55i; gsm3abd; 30.0-54.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 56i; gsm3aa8; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 56m; gsm3aa2; 30.0-65.0; 50.0-110.0; 1
LG Electronics Inc.; LG StudioWorks 56T; gsm3aaf; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 5D; gsm3ab6; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 74i; gsm4278; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 74m; gsm4277; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks74m; sw74m; 30.0-50.0; 50.0-90.0; 1
LG Electronics Inc.; LG StudioWorks 76i; gsm426e; 30.0-65.0; 50.0-110.0; 1
LG Electronics Inc.; LG StudioWorks 76m; gsm4273; 30.0-65.0; 50.0-110.0; 1
LG Electronics Inc.; LG StudioWorks 76T; gsm4284; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78D; gsm427f; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78DT; gsm4280; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78i; gsm426c; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78m; gsm4274; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks78T; gsm426b; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 78T; gsm426d; 30.0-85.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 7D; gsm427e; 30.0-65.0; 50.0-120.0; 1
LG Electronics Inc.; LG StudioWorks 7DT; gsm4281; 30.0-65.0; 50.0-120.0; 1
Link Computer, Inc.; Link Computer CE-8; ce-8; 15.5-38.0; 50.0-90.0; 1
Link Computer, Inc.; Link Computer CM-3; cm-3; 15.5-36.0; 50.0-70.0; 1
Lite-On; Lite-On CM-2090M; cm-2090m; 30.0-75.0; 40.0-120.0; 1
Lite-On; Lite-On 1570; ltn1570; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On S1770NSL; ltn1704; 30-70; 50-160; 1
Lite-On; Lite-On 1770NSL; ltn1770; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On A1454NEL; ltna443; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1454NE; ltna442; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1554NEL; ltna543; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1554NE; ltna542; 30.0-54.0; 50.0-100.0; 1
Lite-On; Lite-On A1570NSL; ltna595; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1570NST(92); ltna596; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1570NST(95); ltna597; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NSL; ltna795; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NST(92); ltna796; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NST(95); ltna797; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1770NST(99); ltna798; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On A1996NST(95); ltna967; 30.0-95.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NSL; ltnb795; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NST(92); ltnb796; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NST(95); ltnb797; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1770NST(99); ltnb798; 30.0-69.0; 50.0-120.0; 1
Lite-On; Lite-On B1985NSL; ltnb955; 30.0-86.0; 50.0-160.0; 1
Lite-On; Lite-On B1996NSL; ltnb965; 30.0-95.0; 50.0-160.0; 1
Lite-On; Lite-On B1996NST(95); ltnb967; 30.0-95.0; 50.0-160.0; 1
Lite-On; Lite-On B1996NST(99); ltnb968; 30.0-95.0; 50.0-160.0; 1
Lite-On; Lite-On B1997NST(99); ltn1901; 30.0-95.0; 50.0-120.0; 1
Lite-On; Lite-On BL150ATA; ltn0204; 24.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On BL150AT; ltn0205; 24.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On CM-1412; ltn1412; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1413; ltn1413; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1414; ltn1414; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1435; ltn1435; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1438; ltn1438; 30.0-38.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1448; ltn1448; 30.0-48.0; 55.0-90.0; 1
Lite-On; Lite-On CM-1450; ltn1450; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1550MCLR; ltn1550; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1554; ltn1554; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1555NEL; ltn1555; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1565MCLR; ltn1565; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1566; ltn1566; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1754; ltn1754; 30.0-56.0; 50.0-100.0; 1
Lite-On; Lite-On CM-1766; ltn1766; 30.0-70.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1785NSL; ltn1785; 30.0-86.0; 50.0-120.0; 1
Lite-On; Lite-On CM-1995NST; ltn1995; 30.0-97.0; 50.0-120.0; 1
Lite-On; Lite-On DC150ATA; ltn0208; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On DC150AT; ltn020c; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On DP150AT; ltn020b; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On DR150ATA; ltn0209; 31.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On L140PTA; ltn0201; 45.0-54.0; 57.0-65.0; 1
Lite-On; Lite-On L150ATA; ltn0202; 24.0-61.0; 56.0-85.0; 1
Lite-On; Lite-On L150PTA; ltn0203; 48.0-61.0; 56.0-61.0; 1
Lite-On; Lite-On P150AT; ltn0207; 24.0-61.0; 56.0-85.0; 1
Logitec; Logitec LCM-15FA2; LOG1040; 30.0-70.0; 50.0-120.0
Logitec; Logitec LCM-15FA3; LOG1053; 30.0-70.0; 50.0-120.0
Logitec; Logitec LCM-15FA; LOG1026; 30.0-69.0; 50.0-120.0
Logitec; Logitec LCM-15FS; LOG4536; 30.0-54.0; 50.0-110.0
Logitec; Logitec LCM-15TH; LOG1029; 30.0-70.0; 50.0-130.0
Logitec; Logitec LCM-17DV; LOG1024; 30.0-69.0; 55.0-125.0
Logitec; Logitec LCM-17FA; LOG1027; 30.0-69.0; 50.0-120.0
Logitec; Logitec LCM-17FS2; LOG1052; 30.0-72.0; 50.0-120.0
Logitec; Logitec LCM-17FS; LOG1039; 30.0-72.0; 50.0-120.0
Logitec; Logitec LCM-17TH; LOG1046; 30.0-95.0; 50.0-160.0
Logitec; Logitec LCM-17TS; LOG1054; 30.0-95.0; 50.0-160.0
Logitec; Logitec LCM-17TSU; LOG1048; 30.0-95.0; 50.0-160.0
Logitec; Logitec LCM-17TX; LOG1031; 30.0-92.0; 50.0-160.0
Logitec; Logitec LCM-19FS; LOG1050; 30.0-98.0; 50.0-160.0
Logitec; Logitec LCM-19TS; LOG1062; 30.0-110.0; 50.0-160.0
Logitec; Logitec LCM-21DX; LOG1025; 30.0-86.0; 50.0-132.0
Logitec; Logitec LCM-T041A; LOG1061; 24.8-37.5; 55.0-76.0
Logitec; Logitec LCM-T133A; LOG1035; 31.0-61.0; 56.0-75.0
Logitec; Logitec LCM-T134AS; LOG1058; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T141AS; LOG1049; 31.0-61.0; 56.0-85.0
Logitec; Logitec LCM-T142AS; LOG1055; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T151A; LOG1036; 31.0-61.0; 56.0-87.0
Logitec; Logitec LCM-T151AS; LOG1047; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T152A; LOG1045; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T153A; LOG1056; 31.0-61.0; 56.0-76.0
Logitec; Logitec LCM-T181A; LOG1057; 30.0-72.0; 50.0-120.0
MAG Technology Co., Ltd.; MAG Computronic Colorview/15; colorview15; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG Computronic PMV-14AC/plus; pmv-14ac; 15.0-36.0; 45.0-90.0; 1
MAG Technology Co., Ltd.; MAG Computronic PMV-1531; pmv-1531; 15.0-38.0; 45.0-90.0; 1
MAG Technology Co., Ltd.; MAG InnoVision DX15F; dx15f; 30-64; 50-90; 1
MAG Technology Co., Ltd.; MAG InnoVision DX17F; dx17f; 30-64; 50-90; 1
MAG Technology Co., Ltd.; MAG InnoVision DX21F; dx21f; 30-68; 50-120; 1
MAG Technology Co., Ltd.; MAG InnoVision LX1450; lx1450; 30-50; 50-100; 1
MAG Technology Co., Ltd.; MAG InnoVision MX15F; mx15f; 30.0-68.0; 50.0-110.0; 1
MAG Technology Co., Ltd.; MAG InnoVision MX17F/S; mx17fs; 30.0-68.0; 50.0-110.0; 1
MAG Technology Co., Ltd.; MAG InnoVision MX21NT; mx21nt; 30.0-82.0; 50.0-110.0; 1
MAG Technology Co., Ltd.; MAG 410V2; mag4561; 30.0-50.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG 510V2; mag5662; 30.0-50.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG 570FD; mag9510; 30.0-70.0; 50.0-130.0; 1
MAG Technology Co., Ltd.; MAG 570V; mag9501; 30.0-70.0; 50.0-150.0; 1
MAG Technology Co., Ltd.; MAG 710V2; mag7663; 30.0-65.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG 720V2; mag7764; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG 770T; mag9704; 30.0-70.0; 50.0-130.0; 1
MAG Technology Co., Ltd.; MAG 770V; mag9701; 30.0-70.0; 50.0-150.0; 1
MAG Technology Co., Ltd.; MAG 786FD; mag9705; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG 796FD; mag9706; 30.0-96.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG 800V; mag9807; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG 810FD; mag9809; 30.0-110.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG D410; mag4577; 30.0-54.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG DJ530AV; mag5767; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ530; mag5775; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ700; mag7746; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ702E; mag7747; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ702; mag7748; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ707AV; mag7769; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ707; mag7752; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DJ717; mag7854; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ800; mag6589; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ810; mag8991; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ920; mag9156; 30.0-110.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DJ925T; mag9157; 30.0-110.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG DX1495; mag11a6; 30.0-50.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX1595; mag15f4; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX-1595; mag5620; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX15F; magdx15; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG DX15T; mag5624; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX1795; mag7626; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX17F; magdx17; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG DX17T; mag00e3; 30.0-69.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX500AV; mag5541; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX500T; mag5781; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG dx700e; mag7745; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX700T; mag7740; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX715T; mag7842; 30.0-86.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG DX725T; mag7990; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG dx800; mag6589; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG LT530C; mag5020; 45.0-58.0; 57.0-63.0; 1
MAG Technology Co., Ltd.; MAG LT541C; mag5021; 31.5-68.7; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LT541F; magc541; 31.0-69.0; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LT561D; magd561; 31.0-69.0; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LT561E; mage561; 31.0-69.0; 50.0-85.0; 1
MAG Technology Co., Ltd.; MAG LX1450LG; mag1450; 30.0-50.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG LX1564LG; mag1564; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG MX14S; magm14s; 30.0-64.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX15F; magmx15; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX17FG; mag17fg; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX17F; magmx17; 30.0-68.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MX21F; magmx21; 30.0-82.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG MXE15F; mmxe15f; 30.0-64.0; 50.0-100.0; 1
MAG Technology Co., Ltd.; MAG MXP17F; mmxp17f; 30.0-82.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG PMV14SV; pmv14sv; 30.0-36.0; 50.0-90.0; 1
MAG Technology Co., Ltd.; MAG XJ500; mag5801; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ500T; mag5779; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ530; mag5776; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ700; mag7771; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ700T; mag7780; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ707; mag7772; 30.0-70.0; 50.0-120.0; 1
MAG Technology Co., Ltd.; MAG XJ717; mag7874; 30.0-86.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG xj770; mag9702; 30.0-70.0; 50.0-130.0; 1
MAG Technology Co., Ltd.; MAG XJ796; mag9703; 30.0-96.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG XJ810; mag8997; 30.0-95.0; 50.0-160.0; 1
MAG Technology Co., Ltd.; MAG XJ910; mag9158; 30.0-110.0; 50.0-160.0; 1
Magnavox; Magnavox MB4010(14inch/CM1300); 0; 30.0-54.0; 50.0-110.0
Magnavox; Magnavox MB5314(15inch/CM1200); 0; 30.0-66.0; 50.0-110.0
Magnavox; Magnavox MB7000(17inch/CM6800); 0; 30.0-66.0; 50.0-130.0
Magnavox; Magnavox MV5011(15inch/CM1300); 0; 30.0-54.0; 50.0-110.0
Maxdata Computer; Maxdata Belinea 10 40 65; max4065; 30.0-50.0; 50.0-120.0; 1
Maxdata Computer; Maxdata Belinea 10 50 95; max3539; 30.0-64.0; 55.0-90.0; 1
Maxdata Computer; Maxdata Belinea 10 55 75; max7555; 30.0-69.0; 50.0-120.0; 1
MegaImage; MegaImage 17; 106; 30-64; 50-100
Microvitec, Inc.; Microvitec 1020/LP; 1020lp; 15.0-36.5; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 1020/SP; 1020sp; 15.0-36.5; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 2012/LP; 2012lp; 15.0-40.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 2014/LP; 2014lp; 15.0-40.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 2014/SVGA; 2014svga; 30.0-40.0; 45.0-90.0; 1
Microvitec, Inc.; Microvitec 2019/SP; 2019sp; 15.0-38.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 4015/FST; 4015fst; 30.0-50.0; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 604/FST; 604fst; 15.0-36.5; 45.0-100.0; 1
Microvitec, Inc.; Microvitec 704/FST; 704fst; 15.0-36.5; 45.0-100.0; 1
Miro Computer Products AG; Miro miroD1568; mir6815; 31.5-68.0; 50.0-100.0; 1
Miro Computer Products AG; Miro miroD1769; mir6917; 31.5-69.0; 50.0-100.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC1768; mir6817; 29.0-68.0; 50.0-100.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC1782; mir8217; 29.0-82.0; 50.0-120.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC2085 E; mir8520; 29.0-85.0; 50.0-160.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC21107; mir0721; 31.5-107.0; 50.0-150.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC2185; mir8521; 30.0-85.0; 50.0-152.0; 1
Miro Computer Products AG; Miro PROOFSCREEN miroC2193; mir9321; 30.0-93.0; 50.0-150.0; 1
MiTAC; MiTAC 1450FD; mtc0003; 31.0-50.0; 50.0-90.0; 1
MiTAC; MiTAC 1450FV; mtc0001; 31.0-50.0; 50.0-90.0; 1
MiTAC; MiTAC 1564FD/1564FS; mtc0002; 30.0-66.0; 50.0-100.0; 1
Mitsuba Corp.; Mitsuba Corp. 710MH; 710mh; 15.0-38.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Plus 100 (TFW1105); mel40e1; 30.0-108.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Plus 120u (TFA1105); mel42f0; 30.0-115.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Plus 200u (NSH1117); mel43f0; 30.0-108.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Plus 70 (TF-7700P); mel4190; 30.0-70.0; 50.0-180.0; 1
Mitsubishi; Mitsubishi Diamond Plus 71 (TFV6708); mel4240; 30.0-69.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Plus 72 (TFV8705); mel4160; 30.0-86.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Plus 73 (N9705); mel4460; 31.0-69.0; 59.0-86.0; 1
Mitsubishi; Mitsubishi Diamond Plus 91 (NFL9905); mel43a0; 30.0-96.0; 50.0-140.0; 1
Mitsubishi; Mitsubishi Diamond Pro 1000 (TFX1105); mel4100; 30.0-115.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 1010 (TUX1107); mel4101; 30.0-115.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 14 (FW6405); mel6405; 30.0-58; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Pro 14 Plus (SD45xx); mel4500; 30.0-57.0; 50.0-90.0; 0
Mitsubishi; Mitsubishi Diamond Pro 15FS (SD56xx); mel5600; 31.5-64.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Pro 17 (TFS6705); mel6705; 30.0-64.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 17TX (TFG8705); mel4040; 30.0-86.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 2020u (NUB1107); mel4310; 30.0-121.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Pro 2040u (NSB1107); mel4311; 30.0-121.0; 50.0-160.0; 1
Mitsubishi; Mitsubishi Diamond Pro 20 (HL7955); mel7955; 30.0-78.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Pro 20X (FR8905); mel2040; 30.0-82.0; 50.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Pro 21FS (FFL7165); mel7165b; 30.0-78.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Pro 21T (THZ8155); mel8155; 30.0-85.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 21TX (THN9105); mel0040; 30.0-93.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 26H (HJ6505); mel6505; 45.0-70.0; 50.0-80.0; 1
Mitsubishi; Mitsubishi Diamond Pro 26M (HC3505); mel3505; 15.7-38.0; 45.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Pro 29 (XC2930); mel2930; 15.0-82.0; 40.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Pro 37 (XC3725); mel3725; 24.0-64.0; 40.0-120.0; 0
Mitsubishi; Mitsubishi Diamond Pro 67TXV (TFV6705); mel4064; 30.0-69.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 700 (TFK9705); mel4110; 30.0-95.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 710 (NFF8705); mel4360; 30.0-86.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 720 (NFN9705); mel4381; 30.0-96.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 87TXM (TFM8705); mel40c0; 30.0-86.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro 900u (NFJ9905); mel42c0; 30.0-95.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi Diamond Pro 91TXM (TFW9105); mel40e0; 30.0-95.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Pro SVGA (SD43xx); mel4300; 30.0-38.5; 50.0-70.0; 1
Mitsubishi; Mitsubishi Diamond Pro VGA (SD41xx); mel4100; 31.5; 60.0-70.0; 1
Mitsubishi; Mitsubishi Diamond Scan 15FS (SD55xx); mel5500; 31.5-57.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Scan 15HX (SD57xx); mel8040; 31.5-65.0; 50.0-90.0; 1
Mitsubishi; Mitsubishi Diamond Scan 15VX (SD58xx); mel408f; 30-65.0; 50.0-100.0; 1
Mitsubishi; Mitsubishi Diamond Scan 17FS (FFY7705); mel7705; 30.0-78.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Scan 17HX (FFF8705); mel6140; 30.0-82.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Diamond Scan 20H (FR8905); mel2040; 30.0-82.0; 50.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Scan 20 (HL6945/55); mel6955; 30.0-64.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Scan 20M (HC3925); mel3925; 15.7-38.0; 45.0-90.0; 0
Mitsubishi; Mitsubishi Diamond Scan 21 (FFL7165); mel7165; 30.0-78.0; 50.0-130.0; 0
Mitsubishi; Mitsubishi Diamond Scan 33 (XC3315); mel3315; 15.0-38.0; 40.0-120.0; 1
Mitsubishi; Mitsubishi Diamond Scan 37 (XC3715); mel3715; 15.0-36.5; 40.0-120.0; 0
Mitsubishi; Mitsubishi Diamond Scan 50 (SD5904);
Mitsubishi; Mitsubishi Diamond Scan 70 (SD7704); mel4210; 30.0-70.0; 50.0-100.0; 1
Mitsubishi; Mitsubishi Diamond Scan 90e (FFT9905); mel4220; 30.0-95.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi LCD 40 (LXA420W); mel41c0; 31.5-60.2; 56.3-85.1; 1
Mitsubishi; Mitsubishi LCD 50 (LXA520W); mel41d0; 31.5-60.2; 56.3-85.1; 1
Mitsubishi; Mitsubishi LVP-X300 Projector (LVP-X300); mel3001; 15.0-91.0; 50.0-85.0; 1
Mitsubishi; Mitsubishi MegaView 29 (AM2752); mel2752; 15.0-39.0; 45.0-100.0; 0
Mitsubishi; Mitsubishi MegaView 33 (XC3315); mel3315; 15.0-38.0; 40.0-120.0; 0
Mitsubishi; Mitsubishi MegaView 37 Plus (XC3717); mel3717; 15.0-61.0; 40.0-120.0; 0
Mitsubishi; Mitsubishi MegaView 37 (XC3716); mel3716; 15.0-39.5; 40.0-120.0; 0
Mitsubishi; Mitsubishi MegaView Pro 29 (XC2930); mel2930; 15.0-82.0; 40.0-120.0; 0
Mitsubishi; Mitsubishi MegaView Pro 37 (XC3730); mel3730; 15.0-85.0; 40.0-120.0; 1
Mitsubishi; Mitsubishi MegaView Pro 42 (AM4201); mel4201; 20.0-64.0; 45.0-120.0; 0
Mitsubishi; Mitsubishi MERLIN; tat3044; 30.0-54.0; 50.0-100.0; 1
Mitsubishi; Mitsubishi PC Division V70 (XJ63754); tat3054; 30-70; 50-100; 1
Mitsubishi; Mitsubishi Precise Point 5800; melpp_5800; 30.0-65.0; 50.0-100.0; 1
Mitsubishi; Mitsubishi Precise Point 8705; melpp_8705; 30.0-82.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi Precise Point 8905; melpp_8905; 30.0-82.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi RD15M; mel409f; 30.0-65.0; 50.0-100.0; 1
Mitsubishi; Mitsubishi RD17F; mel6040; 30.0-82.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi RD17GR; mel4065; 30.0-69.0; 55.0-125.0; 1
Mitsubishi; Mitsubishi RD17GZ; mel4150; 30.0-86.0; 50.0-130.0; 1
Mitsubishi; Mitsubishi RD21GH; mel4141; 30.0-115.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi RD21GIII; mel4140; 30.0-115.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi RD21GII; mel40f0; 30.0-95.0; 50.0-152.0; 1
Mitsubishi; Mitsubishi RD21GX; mel40f1; 30.0-86.0; 50.0-132.0; 1
- 来自: Hong Kong
Re: 显示器场频和行频列表
怎么没有CMO1453的参数呢
- leeaman
- 系统: debian sid
Re: 显示器场频和行频列表
楼主有没有老CRT的H,V资料,谢谢,2209085847@qq.com
