lightdm[3815]: Oops, secure memory pool already initialized
Aug 16 04:02:01 systemd[1]: Starting Stop ureadahead data collection...
Aug 16 04:02:01 systemd[1]: Started Stop ureadahead data collection.
Aug 16 04:02:01 org.gtk.vfs.Daemon[3847]: A connection to the bus can't be made
Aug 16 04:02:01 systemd[1]: Started Session c4 of user .
Aug 16 04:02:02 org.a11y.Bus[4061]: ** (process:4091): WARNING **: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
Aug 16 04:02:02 org.a11y.Bus[4061]: Activating service name='org.a11y.atspi.Registry'
Aug 16 04:02:02 org.a11y.Bus[4061]: Successfully activated service 'org.a11y.atspi.Registry'
Aug 16 04:02:02 org.a11y.atspi.Registry[4098]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Aug 16 04:02:05 dbus[2372]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
Aug 16 04:02:05 systemd[1]: Starting Daemon for power management...
Aug 16 04:02:06 dbus[2372]: [system] Successfully activated service 'org.freedesktop.UPower'
Aug 16 04:02:06 systemd[1]: Started Daemon for power management.
Aug 16 04:02:09 rtkit-daemon[3032]: Successfully made thread 4255 of process 4255 (n/a) owned by '1000' high priority at nice level -11.
Aug 16 04:02:09 rtkit-daemon[3032]: Supervising 5 threads of 2 processes of 2 users.
Aug 16 04:02:10 dbus[2372]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Aug 16 04:02:10 systemd[1]: Starting Disk Manager...
Aug 16 04:02:10 udisksd[4269]: udisks daemon version 2.1.7 starting
Aug 16 04:02:11 dbus[2372]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Aug 16 04:02:11 systemd[1]: Started Disk Manager.
Aug 16 04:02:11 udisksd[4269]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Aug 16 04:02:12 rtkit-daemon[3032]: Supervising 5 threads of 2 processes of 2 users.
Aug 16 04:02:12 rtkit-daemon[3032]: Successfully made thread 4327 of process 4255 (n/a) owned by '1000' RT at priority 5.
Aug 16 04:02:12 rtkit-daemon[3032]: Supervising 6 threads of 2 processes of 2 users.
Aug 16 04:02:13 rtkit-daemon[3032]: Supervising 6 threads of 2 processes of 2 users.
Aug 16 04:02:13 rtkit-daemon[3032]: Successfully made thread 4329 of process 4255 (n/a) owned by '1000' RT at priority 5.
Aug 16 04:02:13 rtkit-daemon[3032]: Supervising 7 threads of 2 processes of 2 users.
Aug 16 04:02:17 pulseaudio[3926]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out
Aug 16 04:02:17 pulseaudio[4255]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out
Aug 16 04:02:23 org.gnome.OnlineAccounts[4061]: goa-daemon-Message: goa-daemon version 3.20.3 starting
Aug 16 04:02:31 org.freedesktop.Telepathy.ConnectionManager.sofiasip[4061]: tp-glib-Message: Exiting
Aug 16 04:02:37 org.gtk.vfs.AfcVolumeMonitor[4061]: Volume monitor alive
Aug 16 04:02:37 org.gtk.vfs.GoaVolumeMonitor[4061]: (process:4309): GVFS-RemoteVolumeMonitorDaemon-WARNING **: monitor says it's not supported
Aug 16 04:02:47 org.freedesktop.Telepathy.ConnectionManager.haze[4061]: tp-glib-Message: Exiting
Aug 16 04:03:30 org.gnome.zeitgeist.Engine[4061]: ** (zeitgeist-datahub:4299): WARNING **: zeitgeist-datahub.vala:212: Error during inserting events: GDBus.Error:org.gnome.zeitgeist.EngineError.InvalidArgument: Incomplete event: interpretation, manifestation and actor are required
Aug 16 04:03:52 systemd[1]: Stopping User Manager for UID 115...
Aug 16 04:03:52 systemd[2824]: Reached target Shutdown.
Aug 16 04:03:52 systemd[2824]: Starting Exit the Session...
Aug 16 04:03:52 systemd[2824]: Stopped target Default.
Aug 16 04:03:52 systemd[2824]: Stopped target Basic System.
Aug 16 04:03:52 systemd[2824]: Stopped target Timers.
Aug 16 04:03:52 systemd[2824]: Stopped target Paths.
Aug 16 04:03:52 systemd[2824]: Stopped target Sockets.
Aug 16 04:03:52 systemd[2824]: Received SIGRTMIN+24 from PID 4510 (kill).
Aug 16 04:03:52 systemd[1]: Stopped User Manager for UID 115.
Aug 16 04:03:52 systemd[1]: Removed slice User Slice of lightdm.
Aug 16 04:05:18 kernel: [ 326.624008] EXT4-fs (sdc2): error count since last fsck: 10
Aug 16 04:05:18 kernel: [ 326.624021] EXT4-fs (sdc2): initial error at time 1466661217: mb_free_blocks:1463: block 675007
Aug 16 04:05:18 kernel: [ 326.624028] EXT4-fs (sdc2): last error at time 1466830445: ext4_mb_generate_buddy:758
Aug 16 04:05:26 anacron[2362]: Job `cron.daily' started
Aug 16 04:05:26 anacron[4540]: Updated timestamp for job `cron.daily' to 2016-08-16
Aug 16 04:05:28 cracklib: no dictionary update necessary.
Aug 16 04:05:30 systemd[1]: Stopping Make remote CUPS printers available locally...
Aug 16 04:05:30 systemd[1]: Stopped Make remote CUPS printers available locally.
Aug 16 04:05:30 systemd[1]: Stopping CUPS Scheduler...
Aug 16 04:05:30 systemd[1]: Stopped CUPS Scheduler.
Aug 16 04:05:30 systemd[1]: Started CUPS Scheduler.
Aug 16 04:05:30 systemd[1]: Started Make remote CUPS printers available locally.
lubuntu 16.10 进去只有壁纸,LXDE桌面正常
- tor
