教在你的kubuntu上运行android程序
各种窗口管理器和美化相关
flwwater
系统: kubuntu 24.04
帖子 flwwater » 2016-02-22 18:37
个人收藏的数百个精美动态壁纸:
(访问密码:6220
个人收藏的经典国语音乐和纯音乐(钢琴,笛子,二胡等):
(访问密码:6220
如果访问密码不对,可试试这个密码 566816
flwwater
系统: kubuntu 24.04
Re: 教在你的kubuntu上运行android程序
帖子 flwwater » 2016-02-22 18:42
用法:
Once installed grab any Android application package (APK) from the net.
For example our favourite app, Flappy Bird, can be found here: http://beste-apps.chip.de/android/app/f ... .66885070/
Note: If the APK has native code (which most do) the APK must have x86 support.需要下载支持x86架构的apk包,不是下载arm架构的。
Then when asked what to open with type “/opt/shashlik/bin/shashlik-install”.
The app should now be available in the application menu alongside your other apps.
If you experience any issues, please report them in the comments or on github here:
https://github.com/shashlik/shashlik-build/issues
个人收藏的数百个精美动态壁纸:
(访问密码:6220
(访问密码:6220
