ubuntu 14.04安装ic610的问题
shzlll
系统: win7
帖子 shzlll » 2017-10-12 21:17
新人
安装时提示这个
InstallScape installation directory: /home/eda/installscape
Extracting InstallScape version 03.40.p06
for platform lnx86 in /home/eda/installscape
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/eda/installscape/iscape/bin/iscape.sh /home/sun/IC610_lnx86.Base/CDROM1:::/home/eda/ic610
Initializing InstallScape using JVM at /home/eda/installscape/iscape/runtime/LNX86/bin/java. This might take some time...
/home/eda/installscape/iscape/bin/iscape.sh: 209: exec: /home/eda/installscape/iscape/runtime/LNX86/bin/java: not found
请问怎么解决
root@ubuntu:~# java -version
java version "1.8.0_144"
Java(TM) SE Runtime Environment (build 1.8.0_144-b01)
Java HotSpot(TM) 64-Bit Server VM (build 25.144-b01, mixed mode)
root@ubuntu:~#
这样算安装了java吗
onlylove
Re: ubuntu 14.04安装ic610的问题
帖子 onlylove » 2017-10-12 23:43
/home/eda/installscape/iscape/bin/iscape.sh: 209: exec: /home/eda/installscape/iscape/runtime/LNX86/bin/java:not found
