哪位好心人帮我看看这是怎么回事,wps卸载不掉
- fanshouxiang
fsx@fsx-Vostro1310:~$ sudo apt-get remove wps-office
[sudo] password for fsx:
Reading package lists... Done
Building dependency tree
E: The package wps-office needs to be reinstalled, but I can't find an archive for it.
系统是kubuntu最新版
系统是kubuntu最新版
DELL vostro 1310
Inter Core2 T8100 2.1GHz
DDR2 667MHz 1G
NVIDIA Geforce 8400M GS 128M
DDR2 667MHz 1G
- photor
- fanshouxiang
Re: 哪位好心人帮我看看这是怎么回事,wps卸载不掉
直接安装的deb包
DELL vostro 1310
DDR2 667MHz 1G
DDR2 667MHz 1G
- fanshouxiang
其实我是想卸载完后安装一个新版本,结果不成
DELL vostro 1310
DDR2 667MHz 1G
DDR2 667MHz 1G
- fanshouxiang
事实上,我安装的另一个软件,同样是安装的deb包,也出现同样的问题卸载不掉
DELL vostro 1310
DDR2 667MHz 1G
DDR2 667MHz 1G
- fanshouxiang
包管理器中也查找不到相应的安装包
DELL vostro 1310
DDR2 667MHz 1G
DDR2 667MHz 1G
- fanshouxiang
sudo dpkg --remove wps-office
dpkg: error processing package wps-office (--remove):
package is in a very bad inconsistent state; you should
reinstall it before attempting a removal
wps-office
wps-office
DELL vostro 1310
DDR2 667MHz 1G
DDR2 667MHz 1G
- photor
那你就按照它说的,先重新安装一下原来版本的deb包,再尝试卸载fanshouxiang 写了:sudo dpkg --remove wps-office
wps-office
- fanshouxiang
重新安装过了,还是不行,主要是还有其他软件也是这样,感觉这就像是系统问题
DELL vostro 1310
DDR2 667MHz 1G
DDR2 667MHz 1G
- 系统: UbuntuKylin14.10
软件名字不叫wps-office 好像是wps-i386 具体是什么我也忘了 我卸载过
- 系统: Ubuntu
试试这个:dpkg --remove --force-remove-reinstreq wps-office
