各位大佬,麻烦解答下问题,谢谢!
本人装的是双系统,Linux distribution选的是Ubuntu16.04.4 desktop,安装好后,按Ctrl+Alt+F1进入文字界面后,一直出现这样的东西:
[ 67.048326] pci 0000:05:00.0:BAR 0 error updating (0xf1c00000 != oxffffffff)
[ 12.819980] pci 0000:05:00.0:BAR 0 error updating (0xf1c00000 != oxffffffff)
中间偶尔还会出现这个
[ 114.927554] pci 0000:05:00.0:unknown header thpe 7f, ignoring device
实在是不知道该怎么办,很影响学习,希望大佬们能帮忙解决下本人的问题,谢谢!
文本界面中一直弹出pci 0000:05:00.0:BAR 0 error updating (0xf1c00000 != oxffffffff)
Re: 文本界面中一直弹出pci 0000:05:00.0:BAR 0 error updating (0xf1c00000 != oxffffffff)
先确认一下05:00.0是哪个设备。用lspci
[/size]
xxw@xxw-ThundeRobot:~$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5)
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM87 Express LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 960M] (rev a2)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
04:00.0 Network controller: Intel Corporation Wireless 7260 (rev bb)
以上是全部结果
好的,谢谢。下面是用lspci指令得到的结果,但没有找到05:00.0,结果您看下
以上是全部结果
普通模式不行的话,用特殊模式看
lspci -s 05:00.0 -H1
和
lspci -s 05:00.0 -H2
和
好的,谢谢。
这个也试过了,显示的结果是
05:00.0 Unassigned class [ff00]:Realtek.Semiconductor.Co., Ltd. RTS5227 PCI.Express Card.Reader (rev 01)
以上是全部结果。
我觉得可能是我电脑本身的原因,拿window 10举例,刚开机后,我的电脑会特别卡,鼠标,键盘,声卡都会卡,但过个几分钟后,一切都恢复正常,然后昨天我在想ubuntu会不会也是这样,然后在图形界面等了几分钟后,再进去文字界面,之前一直出现的代码就没有出现了……
如果你不怎么用电脑上的读卡器,bios里又能设置关闭读卡器的话,你可以把它关掉试试。这个有可能是相关的pcie接口有问题
