18.04开机黑屏30秒
Jiandanlangman
系统: Ubuntu 18.04
18.04开机黑屏30秒
帖子 Jiandanlangman » 2018-05-13 17:49
:Cry 重装好几次了,每次刚刚装完正常,使用几天后开机就特别慢,每次开机都要黑屏30秒,每次都是30秒,不多不少,关闭磁盘检查什么的也没用,下面是日至片段:
[    3.258698] input: HID 046a:010d as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:046A:010D.0001/input/input8
[    3.316786] hid-generic 0003:046A:010D.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 046a:010d] on usb-0000:00:14.0-9/input0
[    3.316877] input: HID 046a:010d as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:046A:010D.0002/input/input9
[    3.376595] hid-generic 0003:046A:010D.0002: input,hidraw1: USB HID v1.11 Device [HID 046a:010d] on usb-0000:00:14.0-9/input1
[    3.772902] [drm] RC6 on
[   34.511009] EXT4-fs (nvme1n1p3): mounted filesystem with ordered data mode. Opts: (null)
[   34.575453] systemd[1]: RTC configured in localtime, applying delta of 480 minutes to system time.
[   34.586961] ip_tables: (C) 2000-2006 Netfilter Core Team
[   34.666631] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   34.684171] systemd[1]: Detected architecture x86-64.
[   34.686427] systemd[1]: Set hostname to <jiandanlangman-TM1701>.
[   34.734784] systemd[1]: Created slice System Slice.
[   34.734840] systemd[1]: Listening on fsck to fsckd communication Socket.
[   34.734906] systemd[1]: Created slice User and Session Slice.
[   34.734930] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   34.734935] systemd[1]: Reached target Slices.
[   34.734999] systemd[1]: Created slice system-systemd\x2dfsck.slice.
九天星
Re: 18.04开机黑屏30秒
帖子 九天星 » 2018-05-15 21:49
在哪个阶段黑的屏?
schoolboy
Re: 18.04开机黑屏30秒
帖子 schoolboy » 2018-05-15 22:01
深表同情...
想象第一次黑屏前,对系统做过什么改动呢?
aerowolf
来自: 西安
Re: 18.04开机黑屏30秒
帖子 aerowolf » 2018-05-16 8:29
考虑下楼上2位的意见,有助于查找根源。
有没有尝试禁用USB键盘鼠标,检查下磁盘挂载,还有时钟设置呢?日志片段中提到这些了。
早起的鸟儿有虫吃
早起的虫儿被鸟吃
http://aerowolf.blog.sohu.com/
亲,点一下免费获得Dropbox空间!
Jiandanlangman
系统: Ubuntu 18.04
Re: 18.04开机黑屏30秒
帖子 Jiandanlangman » 2018-05-16 10:12
aerowolf 写了:考虑下楼上2位的意见,有助于查找根源。
最耗时的是这一行
整整用了30秒,这个盘就是系统的根分区
外设除了电源线之外啥都没了,有个无线鼠标,不多这个是在开机后才启用的
Jiandanlangman
系统: Ubuntu 18.04
Re: 18.04开机黑屏30秒
帖子 Jiandanlangman » 2018-05-16 10:13
九天星 写了:在哪个阶段黑的屏?
内核启动阶段,挂载文件系统根分区时黑屏30秒
Jiandanlangman
系统: Ubuntu 18.04
Re: 18.04开机黑屏30秒
帖子 Jiandanlangman » 2018-05-16 10:15
schoolboy 写了:深表同情...
应该是没有的,因为什么软件都装好了,正常使用好几天后自己出现的
速腾1994
系统: Arch+gnome
Re: 18.04开机黑屏30秒
帖子 速腾1994 » 2018-05-16 12:34
建议进入恢复模式对磁盘进行fsck
九天星
Re: 18.04开机黑屏30秒
帖子 九天星 » 2018-05-16 20:48
你的硬盘是SSD还是机械?用过多久了?
