升级到18.04后发热严重
arthurfk
系统: Ubuntu 18.04
升级到18.04后发热严重
帖子 arthurfk » 2018-04-25 11:30
在16.04时关闭独显后基本不发热,风扇也基本听不到声音,更新同样关闭独显后风扇声音很大,续航下降了50!难道是gnome的原因吗
Re: 升级到18.04后发热严重
帖子 poloshiao » 2018-04-25 12:09
把下面指令 複製 貼進終端機 執行
1-1. uname -a
1-2. sudo lspci -knn | grep -A2 -i "3d\|display\|vga"
1-5. sudo efibootmgr -v
1-6. echo $DESKTOP_SESSION
1-7. sudo cat /etc/os-release
把指令及結果直接 選取/複製 貼上來
arthurfk
系统: Ubuntu 18.04
Re: 升级到18.04后发热严重
帖子 arthurfk » 2018-04-25 12:20
uname -a
Linux arthur-T5 4.15.0-19-generic #20-Ubuntu SMP Sun Apr 22 00:03:34 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
00:02.0 VGA compatible controller [0300]: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller [8086:0416] (rev 06)
Subsystem: CLEVO/KAPOK Computer 4th Gen Core Processor Integrated Graphics Controller [1558:6555]
Kernel driver in use: i915
01:00.0 3D controller [0302]: NVIDIA Corporation GM204M [GeForce GTX 970M] [10de:13d8] (rev a1)
Subsystem: CLEVO/KAPOK Computer GM204M [GeForce GTX 970M] [1558:6555]
Kernel driver in use: nouveau
*-display
description: 3D controller
product: GM204M [GeForce GTX 970M] [10DE:13D8]
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom
configuration: driver=nouveau latency=0
resources: irq:35 memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
*-display
product: 4th Gen Core Processor Integrated Graphics Controller [8086:416]
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
resources: irq:30 memory:f7400000-f77fffff memory:d0000000-dfffffff ioport:f000(size=64) memory:c0000-dffff
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd000013D8sv00001558sd00006555bc03sc02i00
vendor : NVIDIA Corporation
model : GM204M [GeForce GTX 970M]
driver : nvidia-driver-390 - distro non-free recommended
sudo efibootmgr -v
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0000,0004
Boot0000* Windows Boot Manager HD(2,GPT,566d21cb-5f06-4b99-a722-67b389340d5c,0x96800,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...a................
Boot0001* ubuntu HD(2,GPT,566d21cb-5f06-4b99-a722-67b389340d5c,0x96800,0x32000)/File(\EFI\UBUNTU\SHIMX64.EFI)
Boot0004* ubuntu HD(2,GPT,566d21cb-5f06-4b99-a722-67b389340d5c,0x96800,0x32000)/File(\EFI\UBUNTU\GRUBX64.EFI)
ubuntu
NAME="Ubuntu"
VERSION="18.04 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu Bionic Beaver (development branch)"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and- ... acy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
Re: 升级到18.04后发热严重
帖子 poloshiao » 2018-04-25 15:37
*-display
physical id: 0
version: a1
width: 64 bits
clock: 33MHz
*-display
physical id: 2
version: 06
width: 64 bits
clock: 33MHz
1. 雙顯卡 可以獲得 Ubuntu 自己編譯的 kernel 支援
但是 必須安裝 閉源驅動 nvidia
1-1. 目前 nvidia 顯卡
作用中 顯卡驅動 是 開源驅動 nouveau
1-2. 安裝 nvidia-driver-390
sudo apt install nvidia-driver-390
1-2-1. 參閱
https://packages.ubuntu.com/bionic/nvidia-driver-390
1-3. 把 開源驅動 nouveau 加入載入黑名單
1-3-1. 方法參閱
https://askubuntu.com/a/868209
1-4. 然後 重新開機
2. 補充
網路上 有許多 Ubuntu 18.04
把 開源驅動 nouveau 加入載入黑名單 會有問題的貼文
還沒看到 徹底解決方案
foxbabymm
Re: 升级到18.04后发热严重
帖子 foxbabymm » 2018-04-26 8:15
正式版还没发布啊,官网没动静啊 ~
icefrog09
系统: windows98
Re: 升级到18.04后发热严重
帖子 icefrog09 » 2018-04-27 9:34
還沒看到 徹底解決方案
我按照上述贴文操作后还是有问题,明明已经加入黑名单了,看起来nouveau还在工作
dmesg | grep nou
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-20-generic root=UUID=6937587d-41b8-41e2-821e-9845a6cc8bd5 ro quiet splash nouveau.runpm=0 vt.handoff=1
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-20-generic root=UUID=6937587d-41b8-41e2-821e-9845a6cc8bd5 ro quiet splash nouveau.runpm=0 vt.handoff=1
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    3.857167] nouveau: detected PR support, will not use DSM
[    3.857348] nouveau 0000:01:00.0: NVIDIA GM107 (1171b0a2)
[    4.005544] nouveau 0000:01:00.0: bios: version 82.07.80.00.20
[    4.112567] nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
[    4.112579] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ IBUS ]
[    4.118515] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 10ac08 [ IBUS ]
[    5.416865] nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
[    5.416865] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[    5.416868] nouveau 0000:01:00.0: DRM: Pointer to TMDS table invalid
[    5.416869] nouveau 0000:01:00.0: DRM: DCB version 4.0
[    5.417319] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[    5.417325] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
lspci | grep NVIDIA
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 960M] (rev a2)
Canonical:I would like to give you a big hi everyday with an error report
Re: 升级到18.04后发热严重
帖子 poloshiao » 2018-04-27 11:53
1. 看看 nouveau 是否還被載入
lsmod | grep nouveau
2. 看看 GeForce GTX 970M 是否還被 nouveau 佔用中
mars.c
系统: Ubuntu
Re: 升级到18.04后发热严重
帖子 mars.c » 2018-05-02 19:14
笔记本掉电厉害是因为这个吗?我的也是双显卡的本本,重新安装了再测试一下!
