公司的敏感数据,需要加密和做RAID1
问题来了,最底层的分区是先做RAID1,还是先luks加密呢,那种比较科学?
RAID1 on luks 还是 luks on RAID1
Re: RAID1 on luks 还是 luks on RAID1
luks on RAID1
https://gitlab.com/cryptsetup/cryptsetu ... ns#2-setup
Frequently Asked Questions
2. Setup
2.2 LUKS on partitions or raw disks?
(3) Encrypted RAID: Create your RAID from partitions and/or full devices. Put LUKS on top of the RAID device, just if it were an ordinary block device.
2.8 Encryption on top of RAID or the other way round?
提醒
注意 superblock format 的版本選擇問題
使用 關鍵字 superblock format 搜尋上述文章
參閱
https://raid.wiki.kernel.org/index.php/Superblock
Superblock
https://raid.wiki.kernel.org/index.php/ ... ck_formats
RAID superblock formats
2. Setup
提醒
參閱
Superblock
知道该怎么做了!Encryption on top of RAID or the other way round?
Unless you have special needs, place encryption between RAID and
filesystem, i.e. encryption on top of RAID. You can do it the other
way round, but you have to be aware that you then need to give the
passphrase for each individual disk and RAID autodetection will not
work anymore. Therefore it is better to encrypt the RAID device,
e.g. /dev/dm0 .
This means that the typical layering looks like this:
Filesystem <- top
Encryption
RAID
Raw partitions
Raw disks <- bottom
The big advantage is that you can manage the RAID container just like
any RAID container, it does not care that what is in it is encrypted.
谢谢
