https://hyper.is/#hyperpower
在源裡安裝了hyper 但是hyperpower這個插件不知道該怎麼安裝 小白一個 真的看不懂 求指教
請教這個插件怎麼安裝!!
- 系统: linux
Re: 請教這個插件怎麼安裝!!
与其它插件的安装方法一样,您可以按照此处 https://hyper.is/#extensions 说明的步骤安装插件,或使用 hyperterm 的插件管理器 https://github.com/zeit/hpm
- 系统: linux
Re: 請教這個插件怎麼安裝!!
vickycq 写了:与其它插件的安装方法一样,您可以按照此处 https://hyper.is/#extensions 说明的步骤安装插件,或使用 hyperterm 的插件管理器 https://github.com/zeit/hpm
[code]// Future versions of Hyper may add additional config options,
// which will not automatically be merged into this file.
// See https://hyper.is#cfg for all currently supported options.
module.exports = {
config: {
// Choose either "stable" for receiving highly polished,
// or "canary" for less polished but more frequent updates
updateChannel: 'stable',
// default font size in pixels for all tabs
fontSize: 16,
// font family with optional fallbacks
fontFamily: 'Menlo, "Source Code Pro", Consolas, "Lucida Console", monospace',
// terminal cursor background color and opacity (hex, rgb, hsl, hsv, hwb or cmyk)
cursorColor: 'rgba(248,28,229,0.8)',
// `BEAM` for |, `UNDERLINE` for _, `BLOCK` for █
cursorShape: 'BLOCK',
// set to true for blinking cursor
cursorBlink: false,
// color of the text
foregroundColor: '#fff',
// terminal background color
backgroundColor: '#262626',
// border color (window, tabs)
borderColor: '#333',
// custom css to embed in the main window
css: '',
// custom css to embed in the terminal window
termCSS: '',
// set to `true` (without backticks and without quotes) if you're using a
// Linux setup that doesn't show native menus
// default: `false` on Linux, `true` on Windows (ignored on macOS)
showHamburgerMenu: 'false',
// set to `false` if you want to hide the minimize, maximize and close buttons
// additionally, set to `'left'` if you want them on the left, like in Ubuntu
// default: `true` on windows and Linux (ignored on macOS)
showWindowControls: '',
// custom padding (css format, i.e.: `top right bottom left`)
padding: '8px 35px',
// the full list. if you're going to provide the full color palette,
// including the 6 x 6 color cubes and the grayscale map, just provide
// an array here instead of a color map object
colors: {
black: '#000000',
red: '#ff0000',
green: '#33ff00',
yellow: '#ffff00',
blue: '#0066ff',
magenta: '#cc00ff',
cyan: '#00ffff',
white: '#d0d0d0',
lightBlack: '#808080',
lightRed: '#ff0000',
lightGreen: '#33ff00',
lightYellow: '#ffff00',
lightBlue: '#0066ff',
lightMagenta: '#cc00ff',
lightCyan: '#00ffff',
lightWhite: '#ffffff',
// the shell to run when spawning a new session (i.e. /usr/local/bin/fish)
// if left empty, your system's login shell will be used by default
// Windows
// - Make sure to use a full path if the binary name doesn't work
// - Remove `--login` in shellArgs
// Bash on Windows
// - Example: `C:\\Windows\\System32\\bash.exe`
// Powershell on Windows
// - Example: `C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\powershell.exe`
shell: '',
// for setting shell arguments (i.e. for using interactive shellArgs: ['-i'])
// by default ['--login'] will be used
shellArgs: ['--login'],
// for environment variables
env: {},
// set to false for no bell
bell: 'SOUND',
// if true, selected text will automatically be copied to the clipboard
copyOnSelect: false,
// if true, on right click selected text will be copied or pasted if no
// selection is present (true by default on Windows)
// quickEdit: true,
// URL to custom bell
// bellSoundURL: 'http://example.com/bell.mp3',
// for advanced config flags please refer to https://hyper.is/#cfg
// a list of plugins to fetch and install from npm
// format: [@org/]project[#version]
// examples:
// `hyperpower`
// `@company/project`
// `project#1.0.1`
plugins: [
`hyperpower`
// in development, you can create a directory under
// `~/.hyper_plugins/local/` and include it here
// to load it and avoid it being `npm install`ed
localPlugins: [
keymaps: {
// Example
// 'window:devtools': 'cmd+alt+o',
Re: 請教這個插件怎麼安裝!!
如果您的 hyper 无法自动安装插件,您可以尝试手动下载 https://github.com/zeit/hyperpower
将项目文件 (index.js, package.json) 放到 ~/.hyper_plugins/local/hyperpower
然后,将 "hyperpower" 添加到 ~/.hyper.js 中的 localPlugins 中。
- 系统: linux
Re: 請教這個插件怎麼安裝!!
按照您說的辦法全部試了vickycq 写了:如果您的 hyper 无法自动安装插件,您可以尝试手动下载 https://github.com/zeit/hyperpower
我用hpm安裝了hyperpower等一些插件 提示也是安裝成功 但僅僅是在hyper.js裡顯示插件名字而已 而local裡根本沒有文件 於是我又手動安裝進去 但是結果還是不行
看網站提示 好像只要安裝好就能立刻看到效果 難道是系統原因 是不是只有mac才可以啊
Re: 請教這個插件怎麼安裝!!
项目 issues 里有人提到在 hyper 2.1.1 中此插件无法工作,检查您的 hyper 版本
https://github.com/zeit/hyperpower/issues/48
- 系统: linux
Re: 請教這個插件怎麼安裝!!
正是2.1.1vickycq 写了:项目 issues 里有人提到在 hyper 2.1.1 中此插件无法工作,检查您的 hyper 版本
如果是這樣的話 那就無所謂了
謝謝您
