哇,为什么我新装的17.04是散的。。。。
- 系统: windows98
安装的方式是使用官方提供的网络安装镜像,58M的那个
然后apt install gnome
安装完成后升级系统时发现
the following packages were automatically installed and are no longer required:
argyll argyll-ref baobab caribou cheese dleyna-renderer fig2dev file-roller
fonts-cantarell fonts-liberation fonts-opensymbol gedit gedit-common
gedit-plugins geoclue-2.0 gimp-data gir1.2-champlain-0.12 gir1.2-gdata-0.0
gir1.2-geocodeglib-1.0 gir1.2-gepub-0.4 gir1.2-gfbgraph-0.2
gir1.2-git2-glib-1.0 gir1.2-gmenu-3.0 gir1.2-goa-1.0 gir1.2-grilo-0.3
gir1.2-gspell-1 gir1.2-gtkchamplain-0.12 gir1.2-gucharmap-2.90
gir1.2-mediaart-2.0 gir1.2-rb-3.0 gir1.2-rest-0.7 gir1.2-secret-1
gir1.2-tracker-1.0 gir1.2-zeitgeist-2.0 gir1.2-zpj-0.0 gnome-calculator
gnome-calendar gnome-characters gnome-clocks gnome-color-manager
gnome-dictionary gnome-disk-utility gnome-documents gnome-font-viewer
gnome-getting-started-docs gnome-logs gnome-menus gnome-online-miners
gnome-photos gnome-screenshot gnome-shell-extensions gnome-sound-recorder
gnome-system-monitor gnome-tweak-tool gnome-video-effects gnome-weather
gvfs-fuse hoichess imagemagick imagemagick-6-common imagemagick-6.q16
inkscape libabw-0.1-1 libamd2 libatkmm-1.6-1v5 libavahi-gobject0
libavahi-ui-gtk3-0 libbabl-0.1-0 libblas-common libblas3
libboost-date-time1.62.0 libboost-iostreams1.62.0 libcacard0
libcairomm-1.0-1v5 libcamd2 libcaribou-gtk-module libcaribou-gtk3-module
libccolamd2 libcdr-0.1-1 libcholmod3 libclucene-contribs1v5
libclucene-core1v5 libcmis-0.5-5v5 libcolamd2 libe-book-0.1-1 libeot0
libetonyek-0.1-1 libevent-2.0-5 libexiv2-14 libexttextcat-2.0-0
libexttextcat-data libfreehand-0.1-1 libfreerdp-cache1.1 libfreerdp-codec1.1
libfreerdp-common1.1.0 libfreerdp-core1.1 libfreerdp-crypto1.1
libfreerdp-gdi1.1 libfreerdp-locale1.1 libfreerdp-primitives1.1
libfreerdp-utils1.1 libgdict-1.0-10 libgdict-common libgegl-0.3-0 libgepub0
libgexiv2-2 libgfbgraph-0.2-0 libgfortran3 libgimp2.0 libgit2-24
libgit2-glib-1.0-0 libglibmm-2.4-1v5 libgnome-menu-3-0 libgpod-common
libgpod4 libgsf-bin libgsound0 libgspell-1-1 libgspell-1-common
libgtk-vnc-2.0-0 libgtkmm-2.4-1v5 libgtkmm-3.0-1v5 libgtkspell0
libgucharmap-2-90-7 libgvnc-1.0-0 libhttp-parser2.1 libimage-magick-perl
libimage-magick-q16-perl liblangtag-common liblangtag1 liblapack3 liblqr-1-0
libmagick++-6.q16-7 libmagickcore-6.q16-3 libmagickcore-6.q16-3-extra
libmagickwand-6.q16-3 libmetis5 libmhash2 libminiupnpc10
libmission-control-plugins0 libmspub-0.1-1 libmwaw-0.3-3 libmythes-1.2-0
libnatpmp1 libnetpbm10 libodfgen-0.1-1 libpagemaker-0.0-0 libpangomm-1.4-1v5
libphodav-2.0-0 libphodav-2.0-common libpotrace0 libproxy1-plugin-gsettings
libproxy1-plugin-networkmanager libqqwing2v5 libraptor2-0 librasqal3
libraw16 librdf0 librevenge-0.0-0 librhythmbox-core10 librygel-core-2.6-2
librygel-db-2.6-2 librygel-renderer-2.6-2 librygel-renderer-gst-2.6-2
librygel-server-2.6-2 libsdl1.2debian libsgutils2-2 libsigc++-2.0-0v5
libspice-client-glib-2.0-8 libspice-client-gtk-3.0-5 libssh2-1
libsuitesparseconfig4 libumfpack5 libusbredirhost1 libusbredirparser1
libvisio-0.1-1 libwinpr-crt0.1 libwinpr-dsparse0.1 libwinpr-environment0.1
libwinpr-file0.1 libwinpr-handle0.1 libwinpr-heap0.1 libwinpr-input0.1
libwinpr-interlocked0.1 libwinpr-library0.1 libwinpr-path0.1
libwinpr-pool0.1 libwinpr-registry0.1 libwinpr-rpc0.1 libwinpr-sspi0.1
libwinpr-synch0.1 libwinpr-sysinfo0.1 libwinpr-thread0.1 libwinpr-utils0.1
libwmf-bin libwmf0.2-7 libwpd-0.10-10 libwpg-0.3-3 libwps-0.4-4 libyajl2
libzapojit-0.0-0 media-player-info netpbm polari python-bs4 python-cairo
python-chardet python-gi python-gobject-2 python-gtk2 python-html5lib
python-lxml python-numpy python-pkg-resources python-scour python-six
python-webencodings python3-gi-cairo python3-mako python3-markupsafe rygel
rygel-playbin rygel-tracker simple-scan spice-client-glib-usb-acl-helper
telepathy-idle telepathy-logger telepathy-mission-control-5 transfig
transmission-common transmission-gtk uno-libs3 ure vinagre vino
xdg-user-dirs-gtk xul-ext-ubufox
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
如果我如上所说运行一下autoremove,感觉会出大问题。。。gnome的那几个组件为什么会变成孤包?
然后apt install gnome
安装完成后升级系统时发现
Canonical:I would like to give you a big hi everyday with an error report
Re: 哇,为什么我新装的17.04是散的。。。。
一般 可以放心使用指令Use 'sudo apt autoremove' to remove them.
sudo apt autoremove
目的是移除 以前因為安裝套件 而被同時安裝的相依套件 但是目前因該套件以被移除 所以不再使用到的 閒置套件
意思是 這是整理你的系統 而非有問題
- ahwad
网络安装,这是个新想法。。。。。。。。。。。。。。。。。
执行以下指令
执行以下指令将结果全部复制贴上来
sudo apt install pastebinit
sudo cat /var/log/apt/history.log | pastebinit
- 系统: windows98
- 系统: windows98
poloshiao, 首先感谢您的回复。
我对autoremove这个命令的理解和您的一致,但是我上面输出的奇怪之处在于:
1.transmission那两个包transmission-common transmission-gtk ,这两者是相互依赖的,结果autoremove想把我这个正常能用的软件连根拔起
2.gnome的一堆包,我桌面环境是gnome,可是autoremove想把gnome-system-monitor gnome-tweak-tool gnome-weather删除掉,这显然是不能接受的
主要是我上面的输出太多了,您应该没留意到
- 系统: windows98
ahwad, 这个50+M的镜像早就有了啊,15的时候就有吧
也許 是 相依關係 不是很嚴謹1.transmission那两个包transmission-common transmission-gtk ,这两者是相互依赖的,结果autoremove想把我这个正常能用的软件连根拔起
通常 也許還有版本是否滿足的問題
養成習慣
要執行 install / remove / purge / autoremove 等等指令以前
先將你的系統 執行
sudo apt update
sudo apt upgrade
沒有錯誤訊息 再執行 install / remove / purge / autoremove 等等指令
可以讓風險 降低到最小
如果你發現 你要使用的套件 被移除了 再安裝一次 就好了
sudo apt install 套件
或
sudo apt-get install --reinstall 套件
- 系统: windows98
poloshiao, 我就是按您所说的做的,没有报错
况且我这个网络安装所有的包都是从网上下载的最新的包啊
反正我感觉是canonical的问题,不是我操作的问题
你是指這個 ?况且我这个网络安装所有的包都是从网上下载的最新的包啊
請提供網址 及 下載檔案 全名稱安装的方式是使用官方提供的网络安装镜像,58M的那个
- 系统: windows98
poloshiao,
镜像地址http://iso.mirrors.ustc.edu.cn/ubuntu/dists/zesty/main/installer-amd64/current/images/netboot/mini.iso
官方地址http://archive.ubuntu.com/ubuntu/dists/zesty/main/installer-amd64/current/images/netboot/mini.iso
這個是 netboot 的 ISO镜像地址http://iso.mirrors.ustc.edu.cn/ubuntu/dists/zesty/main/installer-amd64/current/images/netboot/mini.iso
先參閱
https://help.ubuntu.com/community/Insta ... /MinimalCD
https://help.ubuntu.com/community/Installation/Netboot
https://help.ubuntu.com/community/Insta ... omInternet
楼主在开头说的很明白是用网络安装的啊,poloshiao 写了:這個是 netboot 的 ISO镜像地址http://iso.mirrors.ustc.edu.cn/ubuntu/dists/zesty/main/installer-amd64/current/images/netboot/mini.iso
先參閱
你给这些做啥?这里面有说楼主问题怎么解决了么?安装的方式是使用官方提供的网络安装镜像,58M的那个
2. 你使用 mini.iso 安裝 Ubuntu 時 有勾選什麼額外安裝套件或組件 嗎the following packages were automatically installed and are no longer required:
2-1. <否則 安裝完畢 預設 應該是 console 環境 不應該有 gnome 套件>
3. 請提供這個指令參考的教程網址然后 apt install gnome
- 系统: windows98
poloshiao, 我在最开始的帖子上就写过是apt install gnome
一开始当然是命令行环境
一开始当然是命令行环境
