GAMIT and GLOBK to be installed into /opt/gamit10.5
If you need help with command line options type CTL_C now and type
install_software -help on the command line
The compressed tarfiles will be removed after extraction of the
directories, but except for that, the script may be stopped and
rerun safely from any point. Tarfiles to be uncompressed:
ls: No match.
Continue ? (y/n)
Y
.. uncompressing and extracting the directories:
.. adding /opt/gamit10.5/com to your search path to continue installation
To execute GAMIT and GLOBK you will need to set your login path to
include /opt/gamit10.5/com /opt/gamit10.5/gamit/bin /opt/gamit10.5/kf/bin
You will also need the alias or link gg --> /opt/gamit10.5
Your Operating System type is: Linux
Your default awk version is: /usr/bin/awk
Searching directories set in libraries/Makefile.config for X11 installation
Verified these paths to X11 libs and includes
X11LIBPATH: /usr/lib/x86_64-linux-gnu
X11INCPATH: /usr/include
Are these paths complete and correct for your system? (y/n)
Y
X11LIBPATH and X11INCPATH OK in libraries/Makefile.config.
GAMIT dimensions in /libraries/Makefile.config are set to
maxsit = 60
maxepc = 2880
maxatm = 25
maxsat = 32
Are these defaults found in Makefile.config correct?
If NOT edit the Makefile.config now before choosing to contine
Continue ? (y/n)
Y
.. removing any existing Makefiles or archive files from libraries directories
rmfresh: Command not found.
.. removing any existing Makefiles or archive files from gamit directories
.. making libraries and gamit
make_gamit: Command not found.
Failure in make_gamit -- install_software terminated
求高人指导~如何解决
求助(Ubuntu14.1上安装GAMIT10.5是错误提示如下)
- 系统: windows
- lhw828
- 来自: 湖北武汉
Re: 求助(Ubuntu14.1上安装GAMIT10.5是错误提示如下)
帮顶
Linux下安装QQ的各种办法——2017年3月7日更新——QQ8.8
Linux/Ubuntu学习笔记——用前人的经验,让你快速进入Linux的怀抱
科学上网的姿势,无痛穿越长城
Ubuntu交流QQ群:16308991(500人群)和10993386(500人群)疯狂招人!大家速来!
