RV670 Radeon HD 3870x2"Proprietary driver for AMD"
寺島聰子
系统: debian11 mate
帖子 寺島聰子 » 2018-08-27 20:41
久しぶりです!long time no see!
OSはmint17.2mate 64bit 。
RV670 Radeon HD 3870x2に、最適の「AMD向けプロプライエタリドライバ」をインストールしたいのですが、
I would like to install the most suitable "proprietary driver for AMD"
I followed THIS WEBPAGE.
https://help.ubuntu.com/community/RadeonDriver
1. First, check your graphic card name and chipset:
$ lspci -nn | grep -E 'VGA|Display'
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] RV670 [Radeon HD 3870] [1002:9501]
Ubuntu 14.04 LTS: if you have Ubuntu 14.04 LTS with Linux kernel 4.4.0 (HWE stack Xenial), you can't install the proprietary fglrx/Catalyst driver. However the open source AMDGPU driver is available to install through the xserver-xorg-video-amdgpu package.
$ uname -r
4.4.0-127-generic
今までインストールに失敗してきた原因はコレじゃないですか?
カーネルを古い方へ戻せない?
Is not this the reason why the installation has failed so far?
Can I return the kernel to the old one? :Haha
onlylove
Re: RV670 Radeon HD 3870x2"Proprietary driver for AMD"
帖子 onlylove » 2018-08-28 0:16
I am not sure if this will work, just some info for you
sudo apt-get update
sudo apt-cache search linux-image
and then install the kernel you want
then update grub to boot with the old kernel
https://help.ubuntu.com/community/Grub2/Submenus
帖子 poloshiao » 2018-08-28 7:49
1. This page is for open source driver Radeon, not for proprietary driver.
uname -r
4.4.0-127-generic
2. The proprietary ATI Radeon HD 3870 Drivers would not be supported by Kernel version 4.4.0
2-1. https://www.amd.com/en/support/graphics ... on-hd-3870
ATI Radeon HD 3870 Drivers & Support
2-2. https://www.amd.com/en/support/graphics ... on-hd-3870
Linux x86_64
AMD Catalyst 13.1 Proprietary Linux x86 Display Driver
Driver Details
Automated installer and Display Drivers for Xorg 6.9 to Xserver 1.12 and Kernel version up to 3.4
3. You had better use open source driver radeon which was installed by default.
3-1. https://help.ubuntu.com/community/Radeo ... _supported
Fully supported
RV670
Radeon HD 3690/3850/3870
The right 3 columns :
All versions of Ubuntu would be supported by openware driver Radeon
3-2. These words are for Unsupported chips, not for Fully supported chips.
寺島聰子
系统: debian11 mate
帖子 寺島聰子 » 2018-08-29 12:48
親愛的onlylove 様
元来私が 「AMD向けプロプライエタリドライバをインストールしたい」と思ったのは、AMD社製造ドライバのほうがオープンソースドライバよりも、高い性能が出るはずと考えたからでした。
原本我以為,“我想安裝AMD的專有驅動”確實,因為更多的AMD製造業司機被認為應該也比開源驅動,高性能出來。
ところが、poloshiaoさんによれば
Fully supported
この言葉を信じて、これは終わりにします。
相信這個詞,我會完成這個。
というのは、今回、AMD Catalyst 13.1 Proprietary Linux x86 Display Driverをインストールするために
カーネルをダウングレードさせるのに見合うメリットがあると、どこのサイトにも明言されてないからです。
ありがとうございました!!
This time, in order to install AMD Catalyst 13.1 Proprietary Linux x86 Display Driver
Because there is a merit to downgrade the kernel, it is not made clear on any site.
Thank you very much! !
