求助!!!
在Ubuntu下挂载树莓派镜像
$sudo mkdir /mnt/rasp-pi-rootfs
$sudo mount -o loop,offset=62914560 2015-05-05-raspbian-wheezy.img /mnt/rasp-pi-rootfs
出现以下错误:
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
求助!!! 在Ubuntu下挂载树莓派镜像GG了
- 系统: ubuntu 12.04 LTS
Re: 求助!!! 在Ubuntu下挂载树莓派镜像GG了
$ sudo fdisk -l 2015-05-05-raspbian-wheezy.img
[sudo] password for vicky:
Disk 2015-05-05-raspbian-wheezy.img: 3.1 GiB, 3276800000 bytes, 6400000 sectors
Disklabel type: dos
Disk identifier: 0xa6202af7
2015-05-05-raspbian-wheezy.img1 8192 122879 114688 56M c W95 FAT32 (LBA)
2015-05-05-raspbian-wheezy.img2 122880 6399999 6277120 3G 83 Linux
$ python
Python 2.7.12+ (default, Sep 1 2016, 20:27:38)
[GCC 6.2.0 20160822] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> 122880*512
62914560
$ sudo mount -o offset=62914560 -t ext4 2015-05-05-raspbian-wheezy.img /mnt
$ ls /mnt
bin dev home lost+found mnt proc run selinux sys usr
boot etc lib media opt root sbin srv tmp var
$ cat /mnt/etc/issue
Raspbian GNU/Linux 7 \n \l
刚刚按照您的方法操作了一遍,还是不行 我用的是ubuntu 12.04 LTS
显示如下:
mount:文件系统类型错误、选项错误、/dev/loop0 有坏超级块,
缺少代码页或助手程序,或其他错误
有些情况下在 syslog 中可以找到一些有用信息- 请尝试
dmesg | tail 这样的命令看看。
显示如下:
缺少代码页或助手程序,或其他错误
看看咱俩的 2015-05-05-raspbian-wheezy.img 一样吗?我的是从这下载的:摩洛哥 写了:mount:文件系统类型错误、选项错误、/dev/loop0 有坏超级块
http://ftp.jaist.ac.jp/pub/raspberrypi/ ... wheezy.zip
$ md5sum 2015-05-05-raspbian-wheezy.img
6eef7926c8ef67e613e0daed35d3c1b4 2015-05-05-raspbian-wheezy.img
$ sha256sum 2015-05-05-raspbian-wheezy.img
f97a255a647a7f647cd157f81a699a93ffdd947de14698fad7e3a5a46643dd2c 2015-05-05-raspbian-wheezy.img
