平板有两块屏,分别为:eDP1,HDMI1,正常显示如下(但在有些板上,HDMI1不显示):
a@a-WT5D-Z8350:~$ xrandr
Screen 0: minimum 8 x 8, current 2166 x 1280, maximum 32767 x 32767
eDP1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
1366x768 60.00*+ 40.00
1360x768 59.80 59.96
1280x720 60.00
1024x768 60.00
1024x576 60.00
960x540 60.00
800x600 60.32 56.25
864x486 60.00
640x480 59.94
720x405 60.00
680x384 60.00
640x360 60.00
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 connected 800x1280+1366+0 (normal left inverted right x axis y axis) 1920mm x 1080mm
800x1280 59.36*+
2880x480i 60.00 59.94
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
如何排查问题,目前没头绪,谢谢!
HDMI1无法显示,如何排查问题?
Re: HDMI1无法显示,如何排查问题?
試試xrandr
xrandr -q
參閱
1. https://wiki.ubuntu.com/X/Config/Resolution
xrandr -q
2. http://manpages.ubuntu.com/manpages/zes ... ndr.1.html
-q, --query
When this option is present, or when no configuration changes
are requested, xrandr will display the current state of the
system.
a@a-WT5D-Z8350:~$ xrandr -q
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 32767 x 32767
1366x768 60.0*+ 40.0
1360x768_60.00 59.8
1360x768 59.8 60.0
1280x768_60.00 59.9
1280x720_60.00 59.9
1280x720 60.0
1024x768 60.0
1024x768_60.00 59.9
1024x576 60.0
960x540 60.0
800x600 60.3 56.2
864x486 60.0
640x480 59.9
720x405 60.0
680x384 60.0
640x360 60.0
HDMI1 disconnected (normal left inverted right x axis y axis)
1360x768_60.00 59.8
1360x768 59.8 60.0
1280x768_60.00 59.9
1280x720_60.00 59.9
1280x720 60.0
1024x768 60.0
1024x768_60.00 59.9
1024x576 60.0
960x540 60.0
800x600 60.3 56.2
864x486 60.0
640x480 59.9
720x405 60.0
680x384 60.0
640x360 60.0
目前處於斷線狀態HDMI1 disconnected (normal left inverted right x axis y axis)
詳見你的 顯卡 使用說明書
原生的ubuntu14.04.4系统,屏显是正常的。但我给系统打上wifi,蓝牙的补丁后,新内核启动系统,hdmi1在进入系统登录界面时,能闪亮一下,后面即不能再显示了。怀疑还是新内核造成的。
但怎么去定位问题呢?
感谢回复!
但怎么去定位问题呢?
感谢回复!
再补充:目前发现,是有能正常显示的一台机器。
软件,硬件都一样。四台有三台不能正常显示。
原生的ubuntu14.04.4系统
把下面指令 複製 貼進 每一台電腦 終端機 執行目前发现,是有能正常显示的一台机器。
sudo dmesg | grep HDMI
比較結果看看
正常的,与不正常的:显示的内容是一样的。
是HDMI audio,不是HDMI1的显示。
1. 這裡有一篇 Bug Report目前发现,是有能正常显示的一台机器。
https://bugs.freedesktop.org/show_bug.cgi?id=25224
Bug 25224 - [G45 HDMI] HDMI output not detected as connected
HDMI output port 老是無法 偵測成 connected
1-1. 參閱看看 其解決的過程及使用的指令 對你有沒有幫助
2. 進一步參閱
2-1. http://manpages.ubuntu.com/manpages/zes ... ndr.1.html
注意 RandR version 1.4 / 1.3 / 1.2 / 1.1 參數不同
2-2. https://wiki.ubuntu.com/X/Config/Resolution
2-3. http://www.x.org/wiki/Projects/XRandR/
2-4. https://www.x.org/archive/
根據你的 X.org 版本 參閱
2-4-1. https://www.x.org/archive/X11R7.5/doc/m ... ndr.1.html
2-4-2. https://www.x.org/releases/X11R7.6/doc/ ... dr.1.xhtml
2-4-3. https://www.x.org/releases/X11R7.7/doc/ ... dr.1.xhtml
