koskers@koskers-W35xSTQ-370ST:~$ cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
sudo echo 490 > /sys/class/backlight/intel_backlight/actual_brightness;
exit 0
加不加sudo貌似都不行。
ubuntu 14.10怎么保存屏幕亮度
- KOSKERS
Re: ubuntu 14.10怎么保存屏幕亮度
試試sudo echo 490 > /sys/class/backlight/intel_backlight/actual_brightness;
echo 490 > /sys/class/backlight/intel_backlight/brightness
可以不加 sudo
因為 執行 /etc/rc.local 時
非 root 使用者 還沒登入
- 系统: ubuntu 14.10
后来我直接chmod 777 /sys/class/backlight/intel_backlight/actual_brightness,把权限给所有用户,一切正常了!
- 系统: ubuntu15.04
UBUNTU KYLIN15.04版已能自动保存屏幕亮度,不需作任何修改。
