[原创]linux下手机与蓝牙的连接配置
笔记本/便携移动设备,手机平板等软硬件
baisnsf
帖子 baisnsf » 2007-03-08 20:50
http://www.cl2.cn/blog/?p=228
linux下手机与蓝牙的连接配置
我的设备如下:
电脑:安装ubuntu 6.06 (6.06版本内核已自带蓝牙模块)
手机: Nokia 5500
电脑上装有USB蓝牙适配器
1.配置/etc/bluetooth/hcid.conf
# HCI daemon configuration file.
# HCId options
options {
 # Automatically initialize new devices
 autoinit yes;
 # Security Manager mode
 #   none - Security manager disabled
 #   auto - Use local PIN for incoming connections
 #   user - Always ask user for a PIN
 #修改成auto模式
 security auto;
 # Pairing mode
 #   none  - Pairing disabled
 #   multi - Allow pairing with already paired devices
 #   once  - Pair once and deny successive attempts
 pairing multi;
 # Default PIN code for incoming connections
 # 默认PIN码,与手机匹配时使用
 passkey "1234";
# Default settings for HCI devices
device {
 # Local device name
 #   %d - device id
 #   %h - host name
 # 设置PC端的蓝牙名称,可随意设置
 name "%h-%d";
 # Local device class
 class 0x3e0100;
 # Default packet type
 #pkt_type DH1,DM1,HV1;
 # Inquiry and Page scan
 iscan enable; pscan enable;
 discovto 0;
 # Default link mode
 #   none   - no specific policy
 #   accept - always accept incoming connections
 #   master - become master on incoming connections,
 #            deny role switch on outgoing connections
 lm accept;
 # Default link policy
 #   rswitch - allow role switch
 #   hold    - allow hold mode
 #   sniff   - allow sniff mode
 #   park    - allow park mode
 lp rswitch,hold,sniff,park;
2.配置完成后,重启蓝牙服务
sudo /etc/init.d/bluetooth restart
3.手机连接PC端蓝牙设备,完成匹配,匹配时需要输入hcid.conf中的匹配码
4.配置/etc/bluetooth/rfcomm.conf
# RFCOMM configuration file.
rfcomm0 {
 # Automatically bind the device at startup
 bind yes;
 # Bluetooth address of the device
 #  手机端的蓝牙地址可以通过hcitool scan获得
 device 00:18:0F:8B:B0:63;
 # RFCOMM channel for the connection
 channel 1;
 # Description of the connection
 comment "NOKIA 5500 Bluetooth device";
配置完成后,可以用rfcomm connect 0连接手机
4.下载安装GNOME下的GUI蓝牙工具
sudo apt-get install gnome-bluetooth gnome-phone-manager
5.开启蓝牙文件共享服务
gnome-obex-server 用来接收手机端发送过来的文件
gnome-obex-send 发送文件到手机端,在gnome里也可以选择文件点右键发送到手机(发送为选择Bluetooth)
gnome-phone-manmager 启用后选择手机设置,可以通过PC端给朋友发短信
备注:gnome-obex-send找不到手机的解决办法
sudo hciconfig hci0 inqmode 0
My BLog:www.cl2.cn
about linux,web2.0,ajax
hujj1
帖子 hujj1 » 2007-05-21 1:54
按楼主的话,试了,可以用,谢谢!!!
希望能出一个电脑通过蓝牙用手机的GPRS功能上网。
kidee
帖子 kidee » 2007-07-18 2:35
hujj1 写了:按楼主的话,试了,可以用,谢谢!!!
是呀,能完成这个功能就是强人一个,我认为。
d5ghost
帖子 d5ghost » 2007-09-09 21:18
搞定!
杂牌usb蓝牙一个:Bus 001 Device 003: ID 0a5c:2035 Broadcom Corp. BCM2035 Bluetooth
插上以后系统自动识别,按lz的方法设置了,我试了两个手机:nokia6300和索爱t618。
从电脑能够搜索到手机,但是配对失败,我确信密码都是对的:1234
从nokia6300搜索可以到电脑,而且配对成功;但是t618就搜索不到电脑。很奇怪不知道为什么?
在gnome里面,右击文件打开菜单选择"发送到...", 都可以成功发送到两部手机上面。
ASUS A6NE( Intel Pentium-M Dothan 1.5GHz,256*2 DDR,2MB Cache)
OS:ubuntu Linux 8.04
taobupt
Re: [原创]linux下手机与蓝牙的连接配置
帖子 taobupt » 2010-10-01 13:48
也遇到这个问题了……
