求救!如何用手机上网(GPRS)
求救!如何用手机上网(GPRS)
我的环境:samsung E818,arkmicro(3116) USB线,ubuntu 6.1,广东移动,全球通.在xp下上网一切正常.
1:我试过用wvdial,用wvdialconf能在/dev/ttyUSB0找到modem,在wvdial.conf加了init3=AT+CGDCONT=1,"IP","cmnet"等语句,所拔的号为*99#.
但用wvdia拔号时l,能连到我的手机,我的手机也会出现GP的标志(所以我觉得好像数据线在linux下是能用,起码电脑和我手机能通信了),但无法到分配IP那一步,出错,pppd会被kill,log显示LCP:timeout sending Config-Requests ,Connetion terminated, Modem Hangup.
为什么呢?我查了很多资料都没用,是wvdial.conf里有问题?
2:安装GPRS_Easy_Connect_301,还是选用ttyUSB0,拔号,更过份,提示我switch on phone?好像连modem都没找到,我的手机没一点反应.
为什么??
请高手急救啊!!!
为什么??
请高手急救啊!!!
- 蒙茶茶
Re: 求救!如何用手机上网(GPRS)
我的多普达818pro和你的情况差不多,找到解决办法告诉我一下zq2232 写了: 2:安装GPRS_Easy_Connect_301,还是选用ttyUSB0,拔号,更过份,提示我switch on phone?好像连modem都没找到,我的手机没一点反应.
为什么??
请高手急救啊!!!
我是 E6手机,一样的
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Activation (ttyACM0) starting connection 'China Mobile'
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> (ttyACM0): device state change: 3 -> 4
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Activation (ttyACM0) Stage 1 of 5 (Device Prepare) scheduled...
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Activation (ttyACM0) Stage 1 of 5 (Device Prepare) started...
Jan 23 15:19:11 lsj-laptop NetworkManager: <debug> [1232695151.029285] nm_serial_device_open(): (ttyACM0) opening device...
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Activation (ttyACM0) Stage 1 of 5 (Device Prepare) complete.
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> (ttyACM0): powering up...
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Registered on Home network
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Associated with network: +COPS: 0, 2, "460-00"
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Connected, Woo!
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Activation (ttyACM0) Stage 2 of 5 (Device Configure) scheduled...
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Activation (ttyACM0) Stage 2 of 5 (Device Configure) starting...
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> (ttyACM0): device state change: 4 -> 5
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Starting pppd connection
Jan 23 15:19:11 lsj-laptop NetworkManager: <debug> [1232695151.683222] nm_ppp_manager_start(): Command line: /usr/sbin/pppd nodetach lock nodefaultroute ttyACM0 noipdefault usepeerdns lcp-echo-failure 0 lcp-echo-interval 0 ipparam /org/freedesktop/NetworkManager/PPP/32 plugin /usr/lib/pppd/2.4.4/nm-pppd-plugin.so
Jan 23 15:19:11 lsj-laptop NetworkManager: <debug> [1232695151.685299] nm_ppp_manager_start(): ppp started with pid 12102
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> Activation (ttyACM0) Stage 2 of 5 (Device Configure) complete.
Jan 23 15:19:11 lsj-laptop NetworkManager: <info> (ttyACM0): device state change: 5 -> 6
Jan 23 15:19:17 lsj-laptop NetworkManager: <info> (ttyACM0): device state change: 6 -> 7
Jan 23 15:19:19 lsj-laptop NetworkManager: <info> (ttyACM0): device state change: 7 -> 9
Jan 23 15:19:19 lsj-laptop NetworkManager: <debug> [1232695159.788249] nm_serial_device_close(): Closing device 'ttyACM0'
Jan 23 15:19:19 lsj-laptop NetworkManager: <info> Marking connection 'China Mobile' invalid.
Jan 23 15:19:19 lsj-laptop NetworkManager: <info> Activation (ttyACM0) failed.
Jan 23 15:19:19 lsj-laptop NetworkManager: <info> (ttyACM0): device state change: 9 -> 3
Jan 23 15:19:19 lsj-laptop NetworkManager: <info> (ttyACM0): deactivating device (reason: 0).
Jan 23 15:19:19 lsj-laptop NetworkManager: nm_system_device_flush_ip4_routes_with_iface: assertion `iface_idx >= 0' failed
Jan 23 15:19:19 lsj-laptop NetworkManager: nm_system_device_flush_ip4_addresses_with_iface: assertion `iface_idx >= 0' failed
Jan 23 15:19:21 lsj-laptop NetworkManager: <debug> [1232695161.791925] ensure_killed(): waiting for ppp pid 12102 to exit
Jan 23 15:19:21 lsj-laptop NetworkManager: <debug> [1232695161.792315] ensure_killed(): ppp pid 12102 cleaned up
- nuanhuai
- 651006151
---------"在ubuntu下安装gnome-ppp及wvdial..
1.使用usb数据线,将手机连接到电脑.运行dmesg 或 cat /var/log/messages 命令,
查看识别出的tty设备名称...一般是ttyACM0或ttyACM1...
2.运行gnome-ppp命令. 点击Setup, 并在modem命令栏中Device配置旁点击Detect.
此时gnome-ppp将自动查找modem设备...应该能查找到刚刚看到的ttyACM0或ttyACM1.
3. 同样在gnome-ppp的Setup中,设置init Strings的init3为"AT+CGDCONT=1,"ip","CMNET""..
(我的联想I908是这样的:AT+CGDCONT=1,"IP","CMNET","",0,0 )
设置Phone numbers 为*99***1#(我的是:*99#).
4. 回到gnome-ppp主窗口,随意填写用户名和密码,然后点击connect... 等待connect成功...可以在"Detail"中查看
连接情况,,或者使用cat /var/log/messages查看...
应该会出现..
pppd 2.4.4 started by root, uid 0
Using interface ppp0
Connect: ppp0 <--> /dev/ttyACM0
PAP authentication succeeded
local IP address 10.71.102.206
remote IP address 10.6.6.6
primary DNS address 211.136.112.50
secondary DNS address 211.136.20.203
的类似信息..."
以上在别的帖子复制过来的,,,在论坛搜一下“gnome-ppp及wvdial“等字眼应该能找到原帖。
---我在桌面以普通身份运行GNOME-PPP时无法连接上。搞了半天。。。。。最后在终端以ROOT身份:'/usr/bin/gnome-ppp',才连接成功 - -~
应该会出现..
的类似信息..."
- 651006151
行吗 ,? 不行M我,
- KOSKERS
651006151, 如何使用山寨手机上网。。。MTK的。。ubtnu9.10 一连就断。。。
10.04默认支持
9.10有办法吗
10.04默认支持
9.10有办法吗
- gdgglhy
- 系统: arch
我用wm6.x时启动手机的网络共享再插上USB线,ubuntu会自动添加一个网卡
用蓝牙时添加拔号服务再按提示完善GPRS拔号信息后就会在“移动宽带”中添加一个名为“China Mobile Internet 1”的连接
- KOSKERS
gdgglhy, 我也是,会自动添加China Mobile Internet 1 ,选择cmnet后,点击China Mobile Internet 1。马上就断了
说GSM已经断开!
说GSM已经断开!
- gdgglhy
- 系统: arch
我用USB时就有这个情况,我一般是重新连接几次后网络就稳定了,应该不是系统的问题,是移动搞的鬼KOSKERS 写了:gdgglhy, 我也是,会自动添加China Mobile Internet 1 ,选择cmnet后,点击China Mobile Internet 1。马上就断了
说GSM已经断开!
