按照要求我已经安装了jre,但是安装zimbra desktop的时候仍然提示需要安装jre,请问怎么解决。
我是安装后面这个网页的方法安装的,到最后一步就出错了,根本没有出现选择安装路径的提示。https://wiki.zimbra.com/wiki/Installing ... top_64bits
mint 19无法安装zimbra desktop
- 附件
- (9.87 KiB) 尚未被下载
- 系统: Kubuntu + Windows 10
Re: mint 19无法安装zimbra desktop
谢谢版主!
现在没有需要安装JRE的提示了,但是到最后创建桌面快捷方式的时候又出错了。也许是我没有理解安装指南里面说的方法吧。Log in as a non-root user to complete the install and follow the on-screen instructions.这里要求用非root用户登录,是登录系统呢还是以非root用户登录终端呢?安装过程及提示如下:
john@john-virtual-machine:~/下载/zdesktop_7_3_1_ga_b13063_linux_x64$ sudo ./install.pl
[sudo] john 的密码:
Welcome to Zimbra Desktop setup wizard. This will install Zimbra Desktop on your computer.
Press enter to continue:
PLEASE READ THIS AGREEMENT CAREFULLY BEFORE USING THE SOFTWARE. SYNACOR INC. WILL ONLY LICENSE THIS SOFTWARE TO YOU IF YOU FIRST ACCEPT THE TERMS OF THIS AGREEMENT. BY DOWNLOADING OR INSTALLING THE SOFTWARE, OR USING THE PRODUCT, YOU ARE CONSENTING TO BE BOUND BY THIS AGREEMENT. IF YOU DO NOT AGREE TO ALL OF THE TERMS OF THIS AGREEMENT, THEN DO NOT DOWNLOAD, INSTALL OR USE THE PRODUCT.
License Terms for this Zimbra Desktop Software: http://www.zimbra.com/license/zimbra_public_eula.html
(A)ccept or (D)ecline [A]: A
Choose the folder where you would like to install Zimbra Desktop's application files [/opt/zimbra/zdesktop]:
Installing application files...done
You have finished installing application files.
Would you like to continue to install data files for user: root ?
(Y)es or (N)o [N]: N
To install data files for additional users, please login as the user and run this command:
/opt/zimbra/zdesktop/linux/user-install.pl
john@john-virtual-machine:~/下载/zdesktop_7_3_1_ga_b13063_linux_x64$ /opt/zibmra/zdesktop/linux/user-install.pl
bash: /opt/zibmra/zdesktop/linux/user-install.pl: 没有那个文件或目录
john@john-virtual-machine:~/下载/zdesktop_7_3_1_ga_b13063_linux_x64$ /opt/zimbra/zdesktop/linux/user-install.pl
Choose the folder where you would like to install Zimbra Desktop's user data files, full path please [/home/john/zdesktop]:
Choose the folder where you would like to create desktop icon [/home/john/Desktop]:
Installing user data files...done
Initializing user data...done
Creating desktop icon...Error: cannot open file /home/john/Desktop/zd.desktop
[sudo] john 的密码:
- 附件
- Zimbra_Desktop_Install_Guide_7.3.1.pdf
- (2.26 MiB) 已下载 169 次
