mint 17 如何升级到mint18 beta?
除了重新安装18,还有别的方法可以直接升级么?
- 系统: Debian 9
Re: mint 17 如何升级到mint18 beta?
也许是修改sources.list ?
把LiveCD的sources.list复制出来替换现有系统的sources.list
然后看这个:
http://wiki.ubuntu.org.cn/UbuntuSkills# ... 4.E6.96.B0
但需要注意这种升级会较大概率出现异常现象,所以升级前务必备份重要数据
然后看这个:
官網不鼓勵 在 stable 版本以前 升級到 Beta 版本还有别的方法可以直接升级么?
http://blog.linuxmint.com/?p=3035
Upgrade instructions:
This BETA release might contain critical bugs, please only use it for testing purposes and to help the Linux Mint team fix issues prior to the stable release.
It will be possible to upgrade from this BETA to the stable release.
It will also be possible to upgrade from Linux Mint 17.3. Upgrade instructions will be published next month after the stable release of Linux Mint 18.
