求问No supported Python (2.4 / 2.6 / 2.7) version available.?
Ubuntu各种衍生版本
风动帆起
系统: mint
帖子 风动帆起 » 2015-01-27 22:36
终端第一行出现No supported Python (2.4 / 2.6 / 2.7) version available.是怎么回事?
求问,好像也没什么影响,但是看着不爽
Re: 求问No supported Python (2.4 / 2.6 / 2.7) version availabl
帖子 poloshiao » 2015-01-28 7:39
把下面指令 複製 貼進終端機 執行
1. uname -r
2. sudo dpkg -l | grep python2.
把結果直接 選取/複製 貼上來
不必擷圖
jinjiachen
系统: debian
帖子 jinjiachen » 2015-01-28 8:02
意思是你没有支持的python,
风动帆起
系统: mint
帖子 风动帆起 » 2015-01-28 11:56
poloshiao 写了:
把下面指令 複製 貼進終端機 執行
1. uname -r
把結果直接 選取/複製 貼上來
不必擷圖
3.13.0-37-generic
ii idle-python2.7 2.7.6-8 all IDE for Python (v2.7) using Tkinter
ii libpython2.7:amd64 2.7.6-8 amd64 Shared Python runtime library (version 2.7)
ii libpython2.7-dbg:amd64 2.7.6-8 amd64 Debug Build of the Python Interpreter (version 2.7)
ii libpython2.7-dev:amd64 2.7.6-8 amd64 Header files and a static library for Python (v2.7)
ii libpython2.7-minimal:amd64 2.7.6-8 amd64 Minimal subset of the Python language (version 2.7)
ii libpython2.7-stdlib:amd64 2.7.6-8 amd64 Interactive high-level object-oriented language (standard library, version 2.7)
ii libpython2.7-testsuite 2.7.6-8 all Testsuite for the Python standard library (v2.7)
ii python2.7 2.7.6-8 amd64 Interactive high-level object-oriented language (version 2.7)
ii python2.7-dbg 2.7.6-8 amd64 Debug Build of the Python Interpreter (version 2.7)
ii python2.7-dev 2.7.6-8 amd64 Header files and a static library for Python (v2.7)
ii python2.7-doc 2.7.6-8 all Documentation for the high-level object-oriented language Python (v2.7)
ii python2.7-minimal 2.7.6-8 amd64 Minimal subset of the Python language (version 2.7)
谢谢
帖子 poloshiao » 2015-01-28 13:05
表示 你已安裝 python2.7
sudo ls -al /usr/bin/python
看看 有沒有軟連結到 python2.7
lrwxrwxrwx 1 root root 9 12月 21 2013 /usr/bin/python -> python2.7
如果沒有
sudo update-alternatives --config python
