求分析:
Fontconfig error: Cannot load config file "infinality/conf.d"
Error: Unable to open ~/.mtpz-data for reading.
(rhythmbox:4280): GLib-GObject-WARNING **: specified class size for type `GstPulseSrc' is smaller than the parent type's `GstAudioSrc' class size
(rhythmbox:4280): GLib-GObject-CRITICAL **: g_type_add_interface_static: assertion `G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(rhythmbox:4280): GLib-CRITICAL **: g_once_init_leave: assertion `result != 0' failed
(rhythmbox:4280): GStreamer-CRITICAL **: gst_element_register: assertion `g_type_is_a (type, GST_TYPE_ELEMENT)' failed
Cannot connect to server socket err = 没有那个文件或目录
jack server is not running or cannot be started
(rhythmbox:4280): GLib-GObject-WARNING **: specified class size for type `GstAlsaSrc' is smaller than the parent type's `GstAudioSrc' class size
(rhythmbox:4280): GLib-GObject-WARNING **: specified class size for type `GstOss4Sink' is smaller than the parent type's `GstAudioSink' class size
(rhythmbox:4280): GLib-GObject-WARNING **: specified class size for type `GstOssSrc' is smaller than the parent type's `GstAudioSrc' class size
(rhythmbox:4280): GLib-GObject-WARNING **: specified class size for type `GstOpenALSink' is smaller than the parent type's `GstAudioSink' class size
(rhythmbox:4280): GLib-GObject-WARNING **: specified class size for type `GstEsdSink' is smaller than the parent type's `GstAudioSink' class size
(rhythmbox:4280): GLib-GObject-WARNING **: cannot register existing type `GstAudioClock'
(rhythmbox:4280): GLib-GObject-CRITICAL **: g_object_new: assertion `G_TYPE_IS_OBJECT (object_type)' failed
段错误
opensuse12.2 升到gnome3.6后就不能用rhythmbox了(更新后已解决问题)
- zhanshime
- 来自: http://hi.baidu.com/jinzhanshi/
黛玉道:“宝姐姐和你好你怎么样?宝姐姐不和你好你怎么样?宝姐姐前儿和你好,如今不和你好你怎么样?今儿和你好,后来不和你好你怎么样?你和他好他偏不和你好你怎么样?你不和他好他偏要和你好你怎么样?”
宝玉呆了半晌,忽然大笑道:“任凭弱水三千,我只取一瓢饮。”
