用脚本在ubuntu12.04安装gnuradio报错,需要怎样解决?
orange123sdr
系统: ubuntu12.04
帖子 orange123sdr » 2016-10-28 9:26
因为本人小白,所以用脚本在ubuntu12.04安装gnuradio,但中途报错,以下为代码和报错内容,希望大神能帮忙看看,尝试过手动安装gnuradio,不是失败就是模块安装不全,希望能提供在12.04版脚本安装成功建议,谢谢大家了
Proceed?y
Starting all functions at: 2016年 10月 28日 星期五 09:04:24 CST
SUDO privileges are required
Do you have SUDO privileges?y
Continuing with script
Installing prerequisites.
====> THIS MAY TAKE QUITE SOME TIME <=====
Checking for package libfontconfig1-dev
Checking for package libxrender-dev
Checking for package libpulse-dev
Checking for package swig
Checking for package g++
Checking for package automake
Checking for package autoconf
Checking for package libtool
Checking for package python-dev
Checking for package libfftw3-dev
Checking for package libcppunit-dev
Checking for package libboost1.48-all-dev
Checking for package libusb-dev
Checking for package libusb-1.0-0-dev
Checking for package fort77
Checking for package libsdl1.2-dev
Checking for package python-wxgtk2.8
Checking for package git-core
Checking for package libqt4-dev
Checking for package python-numpy
Checking for package ccache
Checking for package python-opengl
Checking for package libgsl0-dev
Checking for package python-cheetah
Checking for package python-mako
Checking for package python-lxml
Checking for package doxygen
Checking for package qt4-dev-tools
Checking for package libqwt5-qt4-dev
Checking for package libqwtplot3d-qt4-dev
Checking for package pyqt4-dev-tools
Checking for package python-qwt5-qt4
Checking for package cmake
Checking for package wget
Checking for package libxi-dev
Checking for package python-docutils
Checking for package gtk2-engines-pixbuf
Checking for package r-base-dev
Checking for package python-tk
Checking for package liborc-0.4-0
Checking for package liborc-0.4-dev
Checking for package libasound2-dev
Checking for package python-gtk2
Checking for package libzmq
Checking for package libzmq-dev
Checking for package python-requests
Done checking packages
Checking for library libusb ...Found library libusb
Checking for library libboost ...Found library libboost
Checking for library libcppunit ...Found library libcppunit
Checking for library libfftw ...Found library libfftw
Checking for library libgsl ...Found library libgsl
Done
This script will fetch Gnu Radio version 3.7/maint from the repositories, along with compatible
extras.
Is this OK?y
Fetching various packages (Gnu Radio, UHD, gr-osmosdr, gr-iqbal, etc)
via the Internet
Fetching Gnu Radio via GIT...Done
Fetching UHD via GIT...Fetching rtl-sdr (rtl-sdr, gr-osmosdr, gr-iqbal, hackrf, bladeRF and airspy) via GIT
Done
Starting function uhd_build at: 2016年 10月 28日 星期五 09:17:05 CST
Building UHD...
=============> THIS WILL TAKE SOME TIME <=============
UHD build apparently failed
Exiting UHD build
If you have found this script useful and time-saving, consider a
donation to help me keep build-gnuradio, simple_ra, SIDsuite,
meteor_detector, simple_fm_rcv, and multimode maintained and up to date.
A simple paypal transfer to mleech@ripnet.com is all you need to do.
Send success/fail info to sbrac.org?
vickycq
来自: 山东省寿光县
Re: 用脚本在ubuntu12.04安装gnuradio报错,需要怎样解决?
帖子 vickycq » 2016-10-28 9:43
orange123sdr 写了:用脚本在ubuntu12.04安装gnuradio
添加开关 -v 重新运行将输出全部复制贴上来
orange123sdr
系统: ubuntu12.04
帖子 orange123sdr » 2016-10-28 9:48
是输入
-v./build-gnuradio
vickycq
来自: 山东省寿光县
帖子 vickycq » 2016-10-28 9:51
orange123sdr 写了:是输入 -v./build-gnuradio 吗
./build-gnuradio -v
orange123sdr
系统: ubuntu12.04
帖子 orange123sdr » 2016-10-28 10:58
大神,我输入代码后一直提示
您可能需要运行“apt-get -f install”来纠正下列错误:
下列软件包有未满足的依赖关系:
 libc6 : 破坏: libc6:i386 (!= 2.19-0ubuntu6) 但是 2.15-0ubuntu10.4 正要被安装
 libc6:i386 : 破坏: libc6 (!= 2.15-0ubuntu10.4) 但是 2.19-0ubuntu6 正要被安装
 libcppunit-dev : 依赖: libcppunit-1.13-0 (= 1.13.1-2ubuntu1) 但是它将不会被安装
E: 有未能满足的依赖关系。请尝试不指明软件包的名字来运行“apt-get -f install”(也可以指定一个解决办法)。
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
libboost1.48-all-dev 已经是最新的版本了。
下列软件包有未满足的依赖关系:
然后我执行sudo apt-get -f install后又报错
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
正在更正依赖关系... 完成
下列软件包是自动安装的并且现在不需要了:
  gir1.2-timezonemap-1.0 gir1.2-json-1.0 libjson0:i386 gir1.2-xkl-1.0
使用'apt-get autoremove'来卸载它们
将会安装下列额外的软件包:
  libc6 libc6:i386
建议安装的软件包:
  glibc-doc glibc-doc:i386 locales:i386
下列软件包将被升级:
  libc6 libc6:i386
升级了 2 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 2338 个软件包未被升级。
有 8 个软件包没有被完全安装或卸载。
需要下载 0 B/8,746 kB 的软件包。
解压缩后会消耗掉 218 kB 的额外空间。
您希望继续执行吗?[Y/n]y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: 资源暂时不可用
(正在读取数据库 ... 系统当前共安装有 260927 个文件和目录。)
正预备替换 libc6 2.15-0ubuntu10.4 (使用 .../libc6_2.19-0ubuntu6_amd64.deb) ...
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
dpkg:处理 /var/cache/apt/archives/libc6_2.19-0ubuntu6_amd64.deb (--unpack)时出错:
我该怎么改?
vickycq
来自: 山东省寿光县
帖子 vickycq » 2016-10-28 11:12
我输入代码后一直提示
1. 建议不要节选,而是从输入命令的提示符开始一直到出错退出的内容全部复制贴上来;
2. 执行以下指令将结果全部复制贴上来
grep DISTRIB_RELEASE /etc/lsb-release
cat /etc/apt/sources.list
apt-cache policy libc6
sudo fuser -v /var/cache/debconf/config.dat
./build-gnuradio -v
orange123sdr
系统: ubuntu12.04
帖子 orange123sdr » 2016-10-28 11:29
这是我按您说的输入代码以后的代码
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-dev : 依赖: python (= 2.7.5-5ubuntu3) 但是 2.7.3-0ubuntu2.2 正要被安装
              依赖: libpython-dev (= 2.7.5-5ubuntu3) 但是它将不会被安装
              依赖: python2.7-dev (>= 2.7.5-1~) 但是 2.7.3-0ubuntu3.2 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libfftw3-dev : 依赖: libfftw3-bin (= 3.3.3-7ubuntu3)
                依赖: libfftw3-double3 (= 3.3.3-7ubuntu3) 但是它将不会被安装
                依赖: libfftw3-long3 (= 3.3.3-7ubuntu3) 但是它将不会被安装
                依赖: libfftw3-quad3 (= 3.3.3-7ubuntu3) 但是它将不会被安装
                依赖: libfftw3-single3 (= 3.3.3-7ubuntu3) 但是它将不会被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libusb-dev : 依赖: libusb-0.1-4 (= 2:0.1.12-23.3ubuntu1) 但是 2:0.1.12-20 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libusb-1.0-0-dev : 依赖: libusb-1.0-0 (= 2:1.0.17-1ubuntu2) 但是 2:1.0.9~rc3-2ubuntu1 正要被安装
                    推荐: libusb-1.0-doc 但是它将不会被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libsdl1.2-dev : 依赖: libsdl1.2debian (= 1.2.15-8ubuntu1) 但是 1.2.14-6.4ubuntu3.1 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-wxgtk2.8 : 依赖: libwxbase2.8-0 (>= 2.8.12.1+dfsg) 但是 2.8.12.1-6ubuntu2 正要被安装
                   依赖: libwxgtk-media2.8-0 (>= 2.8.12.1+dfsg) 但是它将不会被安装
                   依赖: libwxgtk2.8-0 (>= 2.8.12.1+dfsg) 但是 2.8.12.1-6ubuntu2 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libqt4-dev : 依赖: libqt4-dbus (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-declarative (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-designer (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-dev-bin (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4)
              依赖: libqt4-help (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-network (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-qt3support (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-script (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-scripttools (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-sql (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-svg (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-test (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-xml (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqt4-xmlpatterns (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqtcore4 (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: libqtgui4 (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
              依赖: qt4-linguist-tools (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4)
              依赖: qt4-qmake (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4)
              依赖: qtchooser
              推荐: libqt4-opengl-dev (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是 4:4.8.1-0ubuntu4.9 正要被安装
 libqt4-opengl-dev : 依赖: libqt4-dev (= 4:4.8.1-0ubuntu4.9) 但是 4:4.8.5+git192-g085f851+dfsg-2ubuntu4 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-numpy : 依赖: libblas3 但是它将不会被安装 或
                        libblas.so.3
                依赖: liblapack3 但是它将不会被安装 或
                        liblapack.so.3
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-opengl : 依赖: python:any (>= 2.7.5-5~)
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libgsl0-dev : 依赖: libgsl0ldbl (= 1.16+dfsg-1ubuntu1) 但是 1.15+dfsg-1build1 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-lxml : 依赖: libxml2 (>= 2.9.0) 但是 2.7.8.dfsg-5.1ubuntu4.6 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 qt4-dev-tools : 依赖: qtchooser
                 依赖: libqtdbus4 (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) 但是它将不会被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libqwt5-qt4-dev : 依赖: libqwt5-qt4 (= 5.2.3-1) 但是 5.2.2-1ubuntu2 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libqwtplot3d-qt4-dev : 依赖: libqwtplot3d-qt4-0 (= 0.2.7+svn191-7) 但是 0.2.7+svn191-5ubuntu2 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 pyqt4-dev-tools : 依赖: python-qt4 (= 4.10.4+dfsg-1ubuntu1) 但是 4.9.1-2ubuntu1 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-qwt5-qt4 : 依赖: libqwt5-qt4 (>= 5.2.3) 但是 5.2.2-1ubuntu2 正要被安装
                   依赖: python-numpy (>= 1:1.8.0) 但是 1:1.6.1-6ubuntu1 正要被安装
                   依赖: python-qt4 (>= 4.10.4+dfsg) 但是 4.9.1-2ubuntu1 正要被安装
                   依赖: sip-api-11.0
                   推荐: libqwt-dev 但是它将不会被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 cmake : 依赖: libarchive13 但是它将不会被安装
         依赖: cmake-data (>= 2.8.12.2) 但是 2.8.7-0ubuntu5 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libxi-dev : 依赖: libxi6 (= 2:1.7.1.901-1ubuntu1) 但是 2:1.7.1.901-1ubuntu1~precise3 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-docutils : 依赖: docutils-common (= 0.11-3) 但是 0.8.1-4ubuntu1 正要被安装
                   推荐: python-pil 但是它将不会被安装
                   推荐: docutils-doc (= 0.11-3) 但是 0.8.1-4ubuntu1 正要被安装
                   破坏: python-sphinx (< 1.1.3+dfsg-7~) 但是 1.1.3+dfsg-2ubuntu2.1 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 gtk2-engines-pixbuf : 依赖: libgtk2.0-0 (= 2.24.23-0ubuntu1) 但是 2.24.10-0ubuntu6.3 正要被安装
                       破坏: gtk2-engines-pixbuf:i386 (!= 2.24.23-0ubuntu1) 但是 2.24.10-0ubuntu6.3 正要被安装
 gtk2-engines-pixbuf:i386 : 破坏: gtk2-engines-pixbuf (!= 2.24.10-0ubuntu6.3) 但是 2.24.23-0ubuntu1 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 r-base-dev : 依赖: r-base-core (>= 3.0.2-1ubuntu1) 但是 2.14.1-1 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-tk : 依赖: libtcl8.6 (>= 8.6.0) 但是它将不会被安装
             依赖: libtk8.6 (>= 8.6.0) 但是它将不会被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 liborc-0.4-0 : 破坏: liborc-0.4-0:i386 (!= 1:0.4.18-1ubuntu1) 但是 1:0.4.16-1ubuntu2 正要被安装
 liborc-0.4-0:i386 : 破坏: liborc-0.4-0 (!= 1:0.4.16-1ubuntu2) 但是 1:0.4.18-1ubuntu1 正要被安装
 liborc-0.4-dev : 依赖: liborc-0.4-0 (= 1:0.4.16-1ubuntu2) 但是 1:0.4.18-1ubuntu1 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 liborc-0.4-dev : 依赖: liborc-0.4-0 (= 1:0.4.18-1ubuntu1) 但是 1:0.4.16-1ubuntu2 正要被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libasound2-dev : 依赖: libasound2 (= 1.0.27.2-3ubuntu7)
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-glade2 : 依赖: python-gtk2 (= 2.24.0-3) 但是 2.24.0-3ubuntu3 正要被安装
 python-gtk2 : 依赖: libpango-1.0-0 (>= 1.22.0) 但是它将不会被安装
               依赖: libpangocairo-1.0-0 (>= 1.21.4) 但是它将不会被安装
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
E: 未发现软件包 libzmq
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 libzmq-dev : 依赖: libzmq1 (= 2.2.0+dfsg-5)
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
下列软件包有未满足的依赖关系:
 python-requests : 依赖: python:any (>= 2.7.5-5~)
                   依赖: python-urllib3 (>= 1.7.1) 但是它将不会被安装
Done
extras.
Is this OK?y
via the Internet
=======> THIS MAY TAKE QUITE SOME TIME <=========
Fetching Gnu Radio via GIT...Cloning into 'gnuradio'...
大神,还是有很多提示运行apt-get -f install,现在终端还在运行,但我估计也不会安装成功,还有救吗?
vickycq
来自: 山东省寿光县
帖子 vickycq » 2016-10-28 11:35
orange123sdr 写了:还是有很多提示运行apt-get -f install,
怀疑可能混源了,即 12.04 使用了 14.04 的软件源
按 6 楼 2. 的步骤确认一下。无需运行后两条指令。
orange123sdr
系统: ubuntu12.04
帖子 orange123sdr » 2016-10-28 11:54
大神,是我之前安装gnuradio没有卸载干净,我重新卸载应该可以成功的,还是我学术不精,十分感谢大神的帮助,谢谢啦
