新德利里面的是1.9.1 版本的。 没有最新的1.9.2
最新的本版好像要:
Step 1. Installing MinGW cross compiler
Workrave for Windows is compiled using MinGW. MinGW can be obtained
from
http://mingw.org/.
On Ubuntu/Debian, the following three package need to be installed.
mingw32 (4.2.1)
mingw32-binutils (2.20)
mingw32-runtime (3.15.2)
Alternatively, you can run the 'build-cross.sh" script from the
'build/win32/crossbuild' directory to download, extract, configure,
compile and install the MinGW packages. The cross compiler tool chain
is installed in /usr/local/cross-tools. Note that this
script is no
longer maintained in favour of the standard Ubuntu/Debian packages
(运行了'build-cross.sh‘但是完成后没有找到/usr/local/cross-tools文件夹)
Step 2. Installing required packages
Workrave requires a number of 3rd party packages. All of these
packages can be downloaded, extracted, configured, compiled and
installed by running the 'build-packages.sh" script from the
'build/win32/crossbuild'. The cross compiled packages are installed in
/usr/local/cross-packages.
(运行了'build-packages.sh‘但是完成后没有找到/usr/local/cross-packages文件夹)
Step 3. Installing InnoSetup
Workrave uses InnoSetup to create the installer. InnoSetup 5 must be
installed with wine.
(不知道什么是InnoSetup)
Step 4. Build Harpoon and Applet——
更弄不明白了!!
This step must be executed on Window...
- Install the Window 7 SDK
- Open a Command Prompt, go to the common/win32 directory and run buildall.cmd
- In the Command Prompt window, go to frontend/win32/applet/src/ directory and run buildall.cmd
The generated DLLs and EXEs must be
copied to Linux for step 5.
Step 5. Setup Workrave's Tinderbox
- Copy the 'build/win32/tinderbox' directory to ~/src/tinderbox (You
need to edit build/win32/tinderbox/Makefile if you choose a
different location)
- Create the following empty directories
- ~/src/tinderbox/snapshots
- ~/src/tinderbox/prebuilt/Debug
- ~/src/tinderbox/prebuilt/Debug64
- ~/src/tinderbox/prebuilt/Release
- ~/src/tinderbox/prebuilt/Release64
- Copy the harpoon en applet DLLs and EXEs build in step 4 to the
prebuilt directories
Step 6. Compile Workrave
In the ~/src/tinderbox directory,
run 'make all'.
Tinderbox will checkout the latest version from git, compile it and
generate an installer.
看起来像是for windows,但确实是linux的安装步骤。
高手帮忙看以下
