我用的是debian stretch unstable
比如我现在要安装个软件
apt-get install unzip
~ % sudo apt-get install 7zip 17-02-06 13:49
[sudo] password for gux:
Reading package lists... Done
Building dependency tree
E: Unable to locate package 7zip
~ % sudo apt-get install unzip 17-02-06 13:49
unzip is already the newest version (6.0-21).
unzip set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 51 not upgraded.
48 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up mariadb-common (10.1.21-5) ...
update-alternatives: error: alternative path /etc/mysql/mariadb.cnf doesn't exist
dpkg: error processing package mariadb-common (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of mariadb-server-core-10.1:
mariadb-server-core-10.1 depends on mariadb-common (>= 10.1.21-5); however:
Package mariadb-common is not configured yet.
dpkg: error processing package mariadb-server-core-10.1 (--configure):
dpkg: dependency problems prevent configuration of mariadb-client-core-10.1:
mariadb-client-core-10.1 depends on mariadb-common (>= 10.1.21-5); however:
dpkg: error processing package mariadb-client-core-10.1 (--configure):
dpkg: dependency problems prevent configuration of default-mysql-client-core:
default-mysql-client-core depends on mariadb-client-core-10.1; however:
Package mariadb-client-core-10.1 is not configured yet.
dpkg: error processing package default-mysql-client-core (--configure):
dpkg: dependency problems prevent configuration of default-mysql-server-core:
default-mysql-server-core depends on mariadb-server-core-10.1; however:
Package mariadb-server-core-10.1 is not configured yet.
dpkg: error processing package default-mysql-server-core (--configure):
dpkg: dependency problems prevent configuration of akonadi-backend-mysql:
akonadi-backend-mysql depends on default-mysql-client-core | virtual-mysql-client-core; however:
Package default-mysql-client-core is not configured yet.
Package virtual-mysql-client-core is not installed.
Package mariadb-client-core-10.1 which provides virtual-mysql-client-core is not configured yet.
akonadi-backend-mysql depends on default-mysql-server-core | virtual-mysql-server-core; however:
Package default-mysql-server-core is not configured yet.
Package virtual-mysql-server-core is not installed.
Package mariadb-server-core-10.1 which provides virtual-mysql-server-core is not configured yet.
dpkg: error processing package akonadi-backend-mysql (--configure):
dpkg: dependency problems prevent configuration of akonadi-server:
akonadi-server depends on akonadi-backend-mysql (= 4:16.04.3-4) | akonadi-backend-sqlite (= 4:16.04.3-4) | akonadi-backend-postgresql (= 4:16.04.3-4); however:
Package akonadi-backend-mysql is not configured yet.
Package akonadi-backend-sqlite is not installed.
Package akonadi-backend-postgresql is not installed.
dpkg: error processing package akonadi-server (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadicore-bin:
libkf5akonadicore-bin depends on akonadi-server (>= 4:16.04.3-4); however:
Package akonadi-server is not configured yet.
dpkg: error processing package libkf5akonadicore-bin (--configure):
dpkg: dependency problems prevent configuration of libkf5ksieveui5:amd64:
libkf5ksieveui5:amd64 depends on libkf5akonadicore-bin; however:
Package libkf5akonadicore-bin is not configured yet.
dpkg: error processing package libkf5ksieveui5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadicalendar5:amd64:
libkf5akonadicalendar5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5akonadicalendar5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkolab1:
libkolab1 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkolab1 (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadimime5:amd64:
libkf5akonadimime5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5akonadimime5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5alarmcalendar5:amd64:
libkf5alarmcalendar5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5alarmcalendar5:amd64 (--configure):
dpkg: dependency problems prevent configuration of kmail:
kmail depends on akonadi-server (>= 4:16.04); however:
kmail depends on libkf5akonadicalendar5 (>= 15.07.90); however:
Package libkf5akonadicalendar5:amd64 is not configured yet.
kmail depends on libkf5akonadimime5 (>= 4:15.12.0); however:
Package libkf5akonadimime5:amd64 is not configured yet.
kmail depends on libkf5alarmcalendar5; however:
Package libkf5alarmcalendar5:amd64 is not configured yet.
kmail depends on libkf5ksieveui5; however:
Package libkf5ksieveui5:amd64 is not configured yet.
dpkg: error processing package kmail (--configure):
dpkg: dependency problems prevent configuration of kdepim-runtime:
kdepim-runtime depends on akonadi-server (>= 1.8); however:
kdepim-runtime depends on libkf5akonadicalendar5 (>= 15.07.90); however:
kdepim-runtime depends on libkf5akonadicore-bin; however:
kdepim-runtime depends on libkf5akonadimime5 (>= 15.07.90); however:
kdepim-runtime depends on libkf5alarmcalendar5; however:
kdepim-runtime depends on libkolab1 (>= 1.0.2); however:
Package libkolab1 is not configured yet.
dpkg: error processing package kdepim-runtime (--configure):
dpkg: dependency problems prevent configuration of libkf5kdepimdbusinterfaces5:amd64:
libkf5kdepimdbusinterfaces5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5kdepimdbusinterfaces5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5templateparser5:
libkf5templateparser5 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5templateparser5 (--configure):
dpkg: dependency problems prevent configuration of kdepim-addons:
kdepim-addons depends on libkf5akonadicore-bin; however:
dpkg: error processing package kdepim-addons (--configure):
dpkg: dependency problems prevent configuration of libkf5kaddressbookgrantlee5:amd64:
libkf5kaddressbookgrantlee5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5kaddressbookgrantlee5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadisearchdebug5:amd64:
libkf5akonadisearchdebug5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5akonadisearchdebug5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadicontact5:amd64:
libkf5akonadicontact5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5akonadicontact5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5incidenceeditor5:amd64:
libkf5incidenceeditor5:amd64 depends on libkf5akonadicalendar5 (>= 15.07.90); however:
libkf5incidenceeditor5:amd64 depends on libkf5akonadicontact5 (>= 15.07.90); however:
Package libkf5akonadicontact5:amd64 is not configured yet.
libkf5incidenceeditor5:amd64 depends on libkf5akonadicore-bin; however:
libkf5incidenceeditor5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
libkf5incidenceeditor5:amd64 depends on libkf5kdepimdbusinterfaces5 (>= 4:15.12); however:
Package libkf5kdepimdbusinterfaces5:amd64 is not configured yet.
dpkg: error processing package libkf5incidenceeditor5:amd64 (--configure):
dpkg: dependency problems prevent configuration of korganizer:
korganizer depends on kdepim-runtime; however:
Package kdepim-runtime is not configured yet.
korganizer depends on libkf5akonadicalendar5 (>= 15.07.90); however:
korganizer depends on libkf5akonadicontact5 (>= 15.07.90); however:
korganizer depends on libkf5akonadimime5 (>= 15.07.90); however:
korganizer depends on libkf5incidenceeditor5 (>= 16.04); however:
Package libkf5incidenceeditor5:amd64 is not configured yet.
korganizer depends on libkf5kdepimdbusinterfaces5 (>= 4:15.12); however:
dpkg: error processing package korganizer (--configure):
dpkg: dependency problems prevent configuration of libkf5pimcommon5:amd64:
libkf5pimcommon5:amd64 depends on libkf5akonadicontact5 (>= 15.07.90); however:
libkf5pimcommon5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5pimcommon5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5incidenceeditor-bin:
libkf5incidenceeditor-bin depends on libkf5akonadicalendar5 (>= 15.07.90); however:
libkf5incidenceeditor-bin depends on libkf5akonadicore-bin; however:
libkf5incidenceeditor-bin depends on libkf5incidenceeditor5 (>= 16.04); however:
dpkg: error processing package libkf5incidenceeditor-bin (--configure):
dpkg: dependency problems prevent configuration of libkf5mailtransport5:amd64:
libkf5mailtransport5:amd64 depends on libkf5akonadicore-bin; however:
libkf5mailtransport5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
dpkg: error processing package libkf5mailtransport5:amd64 (--configure):
dpkg: dependency problems prevent configuration of knotes:
knotes depends on kdepim-runtime; however:
knotes depends on libkf5akonadisearchdebug5; however:
Package libkf5akonadisearchdebug5:amd64 is not configured yet.
knotes depends on libkf5pimcommon5 (>= 4:16.04); however:
Package libkf5pimcommon5:amd64 is not configured yet.
dpkg: error processing package knotes (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadisearch-bin:
libkf5akonadisearch-bin depends on libkf5akonadicore-bin; however:
libkf5akonadisearch-bin depends on libkf5akonadimime5 (>= 15.07.90); however:
dpkg: error processing package libkf5akonadisearch-bin (--configure):
dpkg: dependency problems prevent configuration of libkf5messageviewer5:amd64:
libkf5messageviewer5:amd64 depends on libkf5akonadicontact5 (>= 15.07.90); however:
libkf5messageviewer5:amd64 depends on libkf5akonadicore-bin; however:
libkf5messageviewer5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
libkf5messageviewer5:amd64 depends on libkf5kaddressbookgrantlee5; however:
Package libkf5kaddressbookgrantlee5:amd64 is not configured yet.
libkf5messageviewer5:amd64 depends on libkf5mailtransport5; however:
Package libkf5mailtransport5:amd64 is not configured yet.
libkf5messageviewer5:amd64 depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package libkf5messageviewer5:amd64 (--configure):
dpkg: dependency problems prevent configuration of kaddressbook:
kaddressbook depends on libkf5akonadicontact5 (>= 15.07.90); however:
kaddressbook depends on libkf5akonadisearchdebug5; however:
kaddressbook depends on libkf5kaddressbookgrantlee5; however:
kaddressbook depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package kaddressbook (--configure):
dpkg: dependency problems prevent configuration of libkf5mailcommon5:amd64:
libkf5mailcommon5:amd64 depends on libkf5akonadicontact5 (>= 4:15.12.0); however:
libkf5mailcommon5:amd64 depends on libkf5akonadicore-bin; however:
libkf5mailcommon5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
libkf5mailcommon5:amd64 depends on libkf5mailtransport5; however:
libkf5mailcommon5:amd64 depends on libkf5messageviewer5 (>= 4:15.12); however:
Package libkf5messageviewer5:amd64 is not configured yet.
libkf5mailcommon5:amd64 depends on libkf5pimcommon5 (>= 4:16.04); however:
libkf5mailcommon5:amd64 depends on libkf5templateparser5 (>= 4:15.12); however:
Package libkf5templateparser5 is not configured yet.
dpkg: error processing package libkf5mailcommon5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5calendarsupport5:amd64:
libkf5calendarsupport5:amd64 depends on libkf5akonadicalendar5 (>= 15.07.90); however:
libkf5calendarsupport5:amd64 depends on libkf5akonadicore-bin; however:
libkf5calendarsupport5:amd64 depends on libkf5kdepimdbusinterfaces5 (>= 4:15.12); however:
libkf5calendarsupport5:amd64 depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package libkf5calendarsupport5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5messagecomposer5:amd64:
libkf5messagecomposer5:amd64 depends on libkf5akonadicontact5 (>= 15.07.90); however:
libkf5messagecomposer5:amd64 depends on libkf5akonadicore-bin; however:
libkf5messagecomposer5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
libkf5messagecomposer5:amd64 depends on libkf5mailtransport5; however:
libkf5messagecomposer5:amd64 depends on libkf5messageviewer5 (>= 4:15.12); however:
libkf5messagecomposer5:amd64 depends on libkf5pimcommon5 (>= 4:16.04); however:
libkf5messagecomposer5:amd64 depends on libkf5templateparser5 (>= 4:15.12); however:
dpkg: error processing package libkf5messagecomposer5:amd64 (--configure):
dpkg: dependency problems prevent configuration of accountwizard:
accountwizard depends on libkf5mailtransport5; however:
dpkg: error processing package accountwizard (--configure):
dpkg: dependency problems prevent configuration of libkf5libkdepim5:amd64:
libkf5libkdepim5:amd64 depends on libkf5akonadicontact5 (>= 4:15.12.0); however:
libkf5libkdepim5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5libkdepim5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadisearchpim5:amd64:
libkf5akonadisearchpim5:amd64 depends on libkf5akonadicore-bin; however:
dpkg: error processing package libkf5akonadisearchpim5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5mailimporter5:amd64:
libkf5mailimporter5:amd64 depends on libkf5akonadicore-bin; however:
libkf5mailimporter5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
libkf5mailimporter5:amd64 depends on libkf5libkdepim5 (>= 16.04); however:
Package libkf5libkdepim5:amd64 is not configured yet.
dpkg: error processing package libkf5mailimporter5:amd64 (--configure):
dpkg: dependency problems prevent configuration of kdepim-themeeditors:
kdepim-themeeditors depends on libkf5akonadicontact5 (>= 15.07.90); however:
kdepim-themeeditors depends on libkf5kaddressbookgrantlee5; however:
kdepim-themeeditors depends on libkf5messageviewer5 (>= 4:16.04.0); however:
kdepim-themeeditors depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package kdepim-themeeditors (--configure):
dpkg: dependency problems prevent configuration of libkf5akonadisearch-plugins:amd64:
libkf5akonadisearch-plugins:amd64 depends on libkf5akonadicore-bin; however:
libkf5akonadisearch-plugins:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
libkf5akonadisearch-plugins:amd64 depends on libkf5akonadisearchpim5 (>= 15.07.90); however:
Package libkf5akonadisearchpim5:amd64 is not configured yet.
dpkg: error processing package libkf5akonadisearch-plugins:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5eventviews5:amd64:
libkf5eventviews5:amd64 depends on libkf5akonadicalendar5 (>= 15.07.90); however:
libkf5eventviews5:amd64 depends on libkf5akonadicore-bin; however:
libkf5eventviews5:amd64 depends on libkf5calendarsupport5 (>= 4:15.12); however:
Package libkf5calendarsupport5:amd64 is not configured yet.
libkf5eventviews5:amd64 depends on libkf5libkdepim5 (>= 16.04); however:
dpkg: error processing package libkf5eventviews5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5messagecore5:amd64:
libkf5messagecore5:amd64 depends on libkf5akonadicore-bin; however:
libkf5messagecore5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
dpkg: error processing package libkf5messagecore5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5messagelist5:amd64:
libkf5messagelist5:amd64 depends on libkf5akonadicore-bin; however:
libkf5messagelist5:amd64 depends on libkf5akonadimime5 (>= 15.07.90); however:
libkf5messagelist5:amd64 depends on libkf5akonadisearchpim5 (>= 15.07.90); however:
libkf5messagelist5:amd64 depends on libkf5messagecore5 (>= 4:15.12); however:
Package libkf5messagecore5:amd64 is not configured yet.
libkf5messagelist5:amd64 depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package libkf5messagelist5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5gravatar5:amd64:
libkf5gravatar5:amd64 depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package libkf5gravatar5:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5mailcommon-plugins:amd64:
libkf5mailcommon-plugins:amd64 depends on libkf5mailcommon5 (>= 4:15.12); however:
Package libkf5mailcommon5:amd64 is not configured yet.
dpkg: error processing package libkf5mailcommon-plugins:amd64 (--configure):
dpkg: dependency problems prevent configuration of akregator:
akregator depends on libkf5libkdepim5 (>= 16.04); however:
akregator depends on libkf5messageviewer5 (>= 4:16.04.0); however:
akregator depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package akregator (--configure):
dpkg: dependency problems prevent configuration of libkf5pimcommon-plugins:amd64:
libkf5pimcommon-plugins:amd64 depends on libkf5pimcommon5 (>= 4:16.04); however:
dpkg: error processing package libkf5pimcommon-plugins:amd64 (--configure):
dpkg: dependency problems prevent configuration of libkf5libkdepim-plugins:amd64:
libkf5libkdepim-plugins:amd64 depends on libkf5libkdepim5 (>= 16.04); however:
dpkg: error processing package libkf5libkdepim-plugins:amd64 (--configure):
dpkg: dependency problems prevent configuration of kde-config-mailtransport:amd64:
kde-config-mailtransport:amd64 depends on libkf5mailtransport5; however:
dpkg: error processing package kde-config-mailtransport:amd64 (--configure):
mariadb-common
akonadi-server
libkolab1
kmail
kdepim-runtime
kdepim-addons
korganizer
knotes
kaddressbook
accountwizard
kdepim-themeeditors
akregator
这如何是好啊,用apt-get install -f 也是一样的错误信息
不想重装啊,求大神指点下啊
安装kde出错,卸载不了啦,然后apt-get 也出问题了
- loveofmaria
Re: 安装kde出错,卸载不了啦,然后apt-get 也出问题了
1. 目前應該是 debian stretch (testing)我用的是 debian stretch unstable
2. 為何有 17-02-06 13:49 ?~ % sudo apt-get install 7zip 17-02-06 13:49
3. 詳細參見
3-1. https://packages.debian.org/search?suit ... words=7zip
3-2. https://packages.debian.org/stretch/p7zip
套件: p7zip (16.02+dfsg-2)
4. sudo cat /etc/apt/sources.listE: Unable to locate package 7zip
把結果複製貼上來
- loveofmaria
非常感谢你的回复,这个问题我自己google解决了,我用的oh-my-zsh,所有后面显示时间poloshiao 写了:1. 目前應該是 debian stretch (testing)我用的是 debian stretch unstable2. 為何有 17-02-06 13:49 ?~ % sudo apt-get install 7zip 17-02-06 13:49
3. 詳細參見
套件: p7zip (16.02+dfsg-2)4. sudo cat /etc/apt/sources.listE: Unable to locate package 7zip
把結果複製貼上來
