出现这种不明白的提示就直接按输入"?"(不含双引号)就可以了
firefox-esr{a}
-W, --show-why
In the preview displayed before packages are installed or removed,
show which manually installed package requires each automatically
installed package. For instance:
$ aptitude --show-why install mediawiki
libapache2-mod-php5{a} (for mediawiki) mediawiki php5{a} (for mediawiki)
php5-cli{a} (for mediawiki) php5-common{a} (for mediawiki)
php5-mysql{a} (for mediawiki)
When combined with -v or a non-zero value for
Aptitude::CmdLine::Verbose, this displays the entire chain of
dependencies that lead each package to be installed. For instance:
$ aptitude -v --show-why install libdb4.2-dev
libdb4.2{a} (libdb4.2-dev D: libdb4.2) libdb4.2-dev
The following packages will be REMOVED:
libdb4.4-dev{a} (libdb4.2-dev C: libdb-dev P<- libdb-dev)
This option will also describe why packages are being removed, as
shown above. In this example, libdb4.2-dev conflicts with
libdb-dev, which is provided by libdb-dev.
This argument corresponds to the configuration option
Aptitude::CmdLine::Show-Why and displays the same information that
is computed by aptitude why and aptitude why-not.
但man中并没有描述{a}后缀的含义
只是根据上下文语境猜测是"自动安装"的意思
有无更加直接的描述参考?
