安装ccache时怎么把lxde的一些组件自动给移除了?
最大的社区版本,Ubuntu的发源地
科学之子
系统: Debian 9
帖子 科学之子 » 2016-05-24 23:25
难道是因为我之前把lxde的metapackage给卸载了的关系吗?
root@debian:~# aptitude
(Reading database ... 143770 files and directories currently installed.)
Removing galculator (2.1.3-1) ...
Removing gksu (2.0.2-9) ...
Removing leafpad (0.8.18.1-4) ...
Removing libgksu2-0 (2.0.13~pre1-8) ...
update-alternatives: using /usr/share/libgksu/debian/gconf-defaults.libgksu-sudo to provide /usr/share/gconf/defaults/10_libgksu (libgksu-gconf-defaults) in auto mode
Removing libgtop2-7 (2.28.5-2+b1) ...
Removing libgtop2-common (2.28.5-2) ...
Removing lxappearance (0.6.1-1) ...
Removing lxappearance-obconf (0.2.2-1) ...
Removing lxinput (0.3.4-1) ...
Removing lxrandr (0.3.0-1) ...
Removing xarchiver (1:0.5.4-1) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for gconf2 (3.2.6-3) ...
Processing triggers for libc-bin (2.19-18+deb8u1) ...
Selecting previously unselected package ccache.
(Reading database ... 143120 files and directories currently installed.)
Preparing to unpack .../ccache_3.1.10-1_i386.deb ...
Unpacking ccache (3.1.10-1) ...
Setting up ccache (3.1.10-1) ...
Updating symlinks in /usr/lib/ccache ...
Press Return to continue.
上次由 科学之子 在 2016-05-25 2:49,总共编辑 1 次。
vickycq
来自: 山东省寿光县
Re: 安装ccache时怎么把lxde的一些组建自动给移除了?
帖子 vickycq » 2016-05-24 23:43
实测 debian 的 aptitude 默认情况下会自动 autoremove
也就是说,这些包之前一直处于 autoremovable 状态
可重新安装 lxde 的虚包或根据 /var/log/apt/history.log 将误杀的包装回
