No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux stable-updates (sid)
Release: stable-updates
Codename: sid
过于在sources.list中一直设定为stretch版本,现在换成stable,这样算是变成稳定版了吗?请各位高手指教如何变成稳定版。
看https://www.debian.org/doc/manuals/debi ... ng.en.html提到:
3.1.4 If I were to decide to change to another distribution, Can I do that?
Yes, but it is a one way process. You can go from stable --> testing --> unstable. But the reverse direction is not "possible". So better be sure if you are planning to install/upgrade to unstable.
Actually, if you are an expert and if you are willing to spend some time and if you are real careful and if you know what you are doing, then it might be possible to go from unstable to testing and then to stable. The installer scripts are not designed to do that. So in the process, your configuration files might be lost and....
