两分区文件系统均为新创建,无任何污染。Cannot access the Hardware Clock via any known method.
Use the --debug option to see the details of our search for an access method.
Unable to set System Clock to: The Dec 10 15:14:03 UTC 2009 ... (warning).
Activation swap...done.
Checking root file system...fsck from util-linux-ng 2.16.1
/lib/init/rw/rootdev: clean, 18434/612000 files, 164691/2441872 blocks done.
[ 5.838201] EXT3 FS on sda1, internal journal
Setting the system clock.
fsck.ext3: No such file or directory while trying to open /dev/sda5
/dev/sda5:
The superblock could not be read or dose not describe a correct ext2 filesystem. If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
fsck died with ext status 8
failed (code 8).
File system check failed. A log is being saved in /var/log/fsck/checkfs if that location is writable. Please repair the file system manually. ... failed!
Give root password for maintenance
(or type Control-D to continue):
~ # cat /etc/fstab
proc /proc proc defaults 0 0
/dev/sda1 / ext3 defaults 0 1
/dev/sda5 /home ext3 defaults 0 2
~ # cat /var/log/fsck/checkfs
Log of fsck -C -R -A -a
Thu Dec 10 23:26:27 2009
/dev/sda5: clean, 212/1224000 files, 109480/4883752 blocks
The Dec 10 23:26:28 2009
