wubi安装重启时就显示
(initramfs)stdin:I/O error
/scripts/casper-premount/20iso_scan:line46:can't open /dev/sr0: No medium found
Could not find the ISO /ubuntu/install/instalation.iso This could also happen if the file system is not clean because of an operating system crash, an interrapted boot process,an improper shutdown, or unplugging of a removable device without first unmounting or ejecting it, To fix this,simply reboot into windows,let it fully start,log in, run"chkdsk /r",then gracefully shut down and reboot back into windows,After this you should you should be able to reboot again and resume the installation.
我用chkdsk也试过,还是不行,求各位大侠帮帮忙啊
wubi安装怎么一直显示找不到iso文件啊啊啊啊啊
- 系统: windows7
- 系统: Kubuntu + Windows 10
Re: wubi安装怎么一直显示找不到iso文件啊啊啊啊啊
有没有按照以下方法安装?
把CD版的ISO和从ISO文件抽取出来的wubi.exe放在非系统盘的iso文件夹,ISO文件改名为installation.iso,之后选择非系统盘(强烈建议在iso文件夹所属的盘),选择尺寸后安装。
- 系统: windows7
- photor
- 系统: windows7
硬盘什么问题啊?中文卷标或者文件路径又是什么问题啊
- photor
一两句话解释不清楚,你在网上或者坛子里搜一下吧baoch100 写了:硬盘什么问题啊?中文卷标或者文件路径又是什么问题啊
