/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda1: LABEL="ESP" UUID="58C3-A62E" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="98d54c9e-259f-4073-84d6-5c0a8ebd4390"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="f093ad88-6415-4f1d-a9f6-d8f39c4fc32d"
/dev/sda3: LABEL="OS" UUID="5E2C2E672C2E3A83" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="c4862d26-2611-4f8e-8ab1-947e8e7ef859"
/dev/sda4: UUID="78201021200FE54A" TYPE="ntfs" PARTUUID="45684cca-94bc-49e7-b4dd-2f748446760e"
/dev/sda5: LABEL="M-fM-^VM-0M-eM-^JM- M-eM-^MM-7" UUID="AACEC979CEC93DF7" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="ba1c923a-4445-4e5b-a918-87dcd6b0a262"
/dev/sda6: LABEL="M-fM-^VM-0M-eM-^JM- M-eM-^MM-7" UUID="3AFE6EE6FE6E99C1" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="7edd4f0f-a9d6-4717-b96e-93b56a4707f8"
/dev/sda7: LABEL="M-fM-^VM-0M-eM-^JM- M-eM-^MM-7" UUID="0C76843E76842A92" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="dc4720ac-d966-4b4b-9b45-8ce7eada3e2b"
/dev/sda8: UUID="0bad3354-4cd7-434d-92b8-092986513163" TYPE="swap" PARTLABEL="Basic data partition" PARTUUID="16a1e484-99bb-4e73-ac1e-aed05ca8a9a1"
/dev/sda9: UUID="8ddb1efb-d2c3-4e8a-85c7-ec14baf27818" TYPE="ext4" PARTUUID="482a5464-ab92-4342-9d3e-d1b74ee306a2"
/dev/sda10: LABEL="WINRETOOLS" UUID="A86C3F0E6C3ED732" TYPE="ntfs" PARTUUID="826344f5-3993-4b6e-93fa-c9b0bcddfe59"
/dev/sda11: LABEL="Image" UUID="AABC3FAABC3F6FC5" TYPE="ntfs" PARTUUID="b594a668-345f-4362-bfc2-84ee4f4e368e"
/dev/sdb1: LABEL="My Passport" UUID="242CA68C2CA65916" TYPE="ntfs" PARTLABEL="My Passport" PARTUUID="c40806e7-0ed5-4a21-8668-662de886b18b"
/dev/sdb2: LABEL="My Passport2" UUID="7A844B9D844B5B31" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="37c51df9-c12d-4ffd-aa41-6eac215bc466"
/dev/sdb3: LABEL="My Passport3" UUID="C652565852564D75" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="2d37e0e9-009f-45ca-8c24-ab3cf4c638d7"
/dev/sdc1: LABEL="three" UUID="4E5C0A865C0A68D3" TYPE="ntfs" PARTUUID="00023f15-01"
/dev/sdc2: LABEL="two" UUID="02F815ADF8159FC9" TYPE="ntfs" PARTUUID="00023f15-02"
/dev/sdc3: LABEL="one" UUID="3C40228A40224B4A" TYPE="ntfs" PARTUUID="00023f15-03"
/dev/sdc5: LABEL="zero" UUID="C8EC3470EC345B40" TYPE="ntfs" PARTUUID="00023f15-05"
/dev/loop8: TYPE="squashfs"
/dev/loop9: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop13: TYPE="squashfs"
/dev/loop14: TYPE="squashfs"
/dev/loop15: TYPE="squashfs"
/dev/loop16: TYPE="squashfs"
/dev/loop17: TYPE="squashfs"
/dev/loop18: TYPE="squashfs"
/dev/loop19: TYPE="squashfs"
/dev/loop20: TYPE="squashfs"
/dev/loop21: TYPE="squashfs"
/dev/loop22: TYPE="squashfs"
/dev/loop23: TYPE="squashfs"
/dev/loop24: TYPE="squashfs"
/dev/loop25: TYPE="squashfs"
1 # /etc/fstab: static file system information.
2 #
3 # Use 'blkid' to print the universally unique identifier for a
4 # device; this may be used with UUID= as a more robust way to name devices
5 # that works even if disks are added and removed. See fstab(5).
6 #
7 # <file system> <mount point> <type> <options> <dump> <pass>
8 # / was on /dev/sda9 during installation
9 UUID=8ddb1efb-d2c3-4e8a-85c7-ec14baf27818 / ext4 errors=remount-ro 0 1
10 # /boot/efi was on /dev/sda1 during installation
11 UUID=58C3-A62E /boot/efi vfat umask=0077 0 1
12 /swapfile none swap sw 0 0
啓動的時候啓動不了, 需要進入恢復模式,才能進入系統。。。。
啓動的時候進入不了系統,看不到登陸界面, 需要進入恢復模式,才能進入系統。
- durongze
Re: 啓動的時候進入不了系統,看不到登陸界面, 需要進入恢復模式,才能進入系統。
1. 使用同一版本 Ubuntu Live USB 開機
登入 試用桌面 把下面指令 複製 貼進終端機 執行
1-1. uname -r
1-2. sudo efibootmgr -v
1-3. sudo parted -l print
1-4. sudo ls -al /dev/disk/by-uuid/*
1-5. sudo ls -al /dev/disk/by-partuuid/*
把指令及結果全部直接 選取/複製/貼上來
不要摘錄 以免遺漏重要訊息
不要擷圖 方便回文直接引用你貼上來的資料 方便你閱讀
1-1. uname -r
不要摘錄 以免遺漏重要訊息
