大家好
对不起。我的中文很糟糕
我是外国人。我住在中国。
我想买一台笔记本电脑。有可能将BIOS设置更改为英文吗?
I want to buy a laptop in China and I want to make sure I can change the BIOS setting to english so I can use Ubuntu on it.
Maybe ThinkPad E475
thank you!
改BIOS设置为英文
- 系统: galliumos
Re: 改BIOS设置为英文
Try to ask for help by visiting the English Forum :
https://forums.lenovo.com/t5/English-Co ... mmunity-EN
Re: 改BIOS设置为英文
The default should be English,I did not buy a computer or motherboard in recent years,but in the past(about 3 years ago),the default is English, though it support Chinese
- tedchina
Re: 改BIOS设置为英文
You must have solved the issue.
If not, in normal case there is always a language setting entry in BIOS, you just need someone nearby to help to you switch the language.
@onlylove, his BIOS should be referring to UEFI which has Chinese as the default language in many SKUs.
- TeliuTe
- 系统: 16/18/20/w7
- 来自: 新疆博乐
Re: 改BIOS设置为英文
在BIOS首页看看有没有语言设置的选项
