当前时区为 UTC + 8 小时
发表新帖 回复这个主题  [ 3 篇帖子 ]
作者 内容
1 楼
 文章标题 : OBOOK 20 PLUS支持问题
帖子发表于 : 2018-02-03 11:42
注册: 2015-09-03 4:29
系统: ubuntu
送出感谢: 2
接收感谢: 1
用livecd启动。看到没有wifi,触屏,蓝牙,电池图标,摄像头。
代码:
[email protected]:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 093a:2521 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 004: ID 1017:1006 Speedy Industrial Supplies, Pte., Ltd
Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 002: ID 125f:312b A-DATA Technology Co., Ltd. Superior S102 Pro
 用户资料
2 楼
 文章标题 : Re: OBOOK 20 PLUS支持问题
帖子发表于 : 2018-02-03 11:44
注册: 2015-09-03 4:29
系统: ubuntu
送出感谢: 2
接收感谢: 1
代码:
[email protected]:~$ lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register (rev 22)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers (rev 22)
00:03.0 Multimedia controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit (rev 22)
00:0b.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Power Management Controller (rev 22)
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 22)
00:1a.0 Encryption controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine (rev 22)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU (rev 22)
 用户资料
3 楼
注册: 2015-09-03 4:29
系统: ubuntu
送出感谢: 2
接收感谢: 1
代码:
ubuntu
    description: Laptop
    product: OBOOK 20 PLUS (0001)
    vendor: ONDA
    version: Type1 - TBD by OEM
    serial: Type1 - 123456
    width: 64 bits
    capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
    configuration: boot=normal chassis=laptop family=2in1 sku=0001 uuid=78563412-D0C8-BD45-A79F-54EA5FBD3D97
  *-core
       description: Motherboard
       product: T210REV03
       vendor: iNet
       physical id: 0
       version: Type2 - Board Version
       serial: Type2 - Board Serial Number
       slot: Type2 - Board Chassis Location
     *-firmware
          description: BIOS
          vendor: INSYDE Corp.
          physical id: 0
          version: ONDAx.DT210.OVBEEEA02
          date: 08/08/2016
          capacity: 3008KiB
          capabilities: pci upgrade shadowing cdboot bootselect edd int9keyboard int14serial int17printer int10video acpi usb zipboot biosbootspecification netboot uefi
     *-cpu
          description: CPU
          product: Intel(R) Atom(TM) x5-Z8300  CPU @ 1.44GHz
          vendor: Intel Corp.
          physical id: 4
          bus info: [email protected]
          version: Intel(R) Atom(TM) x5-Z8300  CPU @ 1.44GHz
          serial: To Be Filled By O.E.M.
          slot: CHV
          capacity: 1840MHz
          width: 64 bits
          clock: 83MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology tsc_reliable nonstop_tsc aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes rdrand lahf_lm 3dnowprefetch epb tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms dtherm ida arat cpufreq
          configuration: cores=4 enabledcores=4 threads=4
        *-cache:0
             description: L1 cache
             physical id: 6
             slot: L1 Cache
             capacity: 32KiB
             capabilities: synchronous internal write-back instruction
             configuration: level=1
        *-cache:1
             description: L2 cache
             physical id: 7
             slot: L2 Cache
             capacity: 1MiB
             capabilities: synchronous internal write-back unified
             configuration: level=2
     *-cache
          physical id: 5
          slot: L1 Cache
          capacity: 24KiB
          capabilities: synchronous internal write-back data
     *-memory
          description: System Memory
          physical id: 17
          slot: System board or motherboard
        *-bank
             description: DIMM DDR3 Synchronous 1066 MHz (0.9 ns)
             vendor: 0000
             physical id: 0
             serial: 00000000
             slot: ChannelA-DIMM0
             width: 16 bits
             clock: 1066MHz (0.9ns)
     *-pci
          description: Host bridge
          product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register
          vendor: Intel Corporation
          physical id: 100
          bus info: [email protected]:00:00.0
          version: 22
          width: 32 bits
          clock: 33MHz
          configuration: driver=iosf_mbi_pci
          resources: irq:0
        *-display
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers
             physical id: 2
             bus info: [email protected]:00:02.0
             version: 22
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi vga_controller bus_master cap_list rom
             resources: irq:297 memory:d0000000-d0ffffff memory:c0000000-cfffffff ioport:1000(size=64) memory:c0000-dffff
        *-multimedia UNCLAIMED
             description: Multimedia controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit
             physical id: 3
             bus info: [email protected]:00:03.0
             version: 22
             width: 32 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: latency=0
             resources: memory:d1000000-d13fffff
        *-generic:0
             description: Signal processing controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Power Management Controller
             physical id: b
             bus info: [email protected]:00:0b.0
             version: 22
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm bus_master cap_list
             configuration: driver=proc_thermal latency=0
             resources: irq:298 memory:d1818000-d1818fff
        *-usb
             description: USB controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller
             physical id: 14
             bus info: [email protected]:00:14.0
             version: 22
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:296 memory:d1800000-d180ffff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 4.10.0-19-generic xhci-hcd
                physical id: 0
                logical name: usb1
                version: 4.10
                capabilities: usb-2.00
                configuration: driver=hub slots=7 speed=480Mbit/s
              *-usb:0
                   description: Mass storage device
                   product: ADATA USB Flash Drive
                   vendor: ADATA
                   physical id: 1
                   bus info: [email protected]:1
                   logical name: scsi0
                   version: a.00
                   serial: 000000000000000176
                   capabilities: usb-2.10 scsi emulated scsi-host
                   configuration: driver=usb-storage maxpower=500mA speed=480Mbit/s
                 *-disk
                      description: SCSI Disk
                      product: USB Flash Drive
                      vendor: ADATA
                      physical id: 0.0.0
                      bus info: [email protected]:0.0.0
                      logical name: /dev/sda
                      version: 1.00
                      capabilities: removable
                      configuration: ansiversion=6 logicalsectorsize=512 sectorsize=512
                    *-medium
                         physical id: 0
                         capabilities: partitioned partitioned:dos
                         configuration: signature=a9c5900a
                       *-volume:0
                            description: Windows NTFS volume
                            physical id: 1
                            logical name: /dev/sda1
                            logical name: /isodevice
                            version: 3.1
                            serial: 1f57-6584
                            capacity: 14GiB
                            capabilities: primary ntfs initialized
                            configuration: clustersize=4096 created=2016-01-21 16:06:24 filesystem=ntfs label=boot mount.fstype=fuseblk mount.options=rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 state=mounted
                       *-volume:1
                            description: Windows FAT volume
                            vendor: MSDOS5.0
                            physical id: 2
                            logical name: /dev/sda2
                            logical name: /media/ubuntu/ESP
                            version: FAT16
                            serial: 8c81-d5b3
                            capacity: 99MiB
                            capabilities: primary fat initialized
                            configuration: FATs=2 filesystem=fat label=ESP mount.fstype=vfat mount.options=rw,nosuid,nodev,relatime,uid=999,gid=999,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro state=mounted
              *-usb:1
                   description: USB hub
                   product: USB2.0 Hub
                   vendor: Genesys Logic, Inc.
                   physical id: 2
                   bus info: [email protected]:2
                   version: 85.36
                   configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
                 *-usb:0
                      description: Keyboard
                      vendor: Speedy Industrial Supplies, Pte., Ltd
                      physical id: 1
                      bus info: [email protected]:2.1
                      version: 1.00
                      capabilities: usb-1.10
                      configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
                 *-usb:1
                      description: Mouse
                      product: USB OPTICAL MOUSE
                      vendor: Pixart Imaging, Inc.
                      physical id: 2
                      bus info: [email protected]:2.2
                      version: 1.00
           *-usbhost:1
                physical id: 1
                logical name: usb2
                version: 4.10
                capabilities: usb-3.00
                configuration: driver=hub slots=6 speed=5000Mbit/s
        *-generic:1
             description: Encryption controller
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine
             physical id: 1a
             bus info: [email protected]:00:1a.0
             version: 22
             width: 32 bits
             clock: 33MHz
             configuration: driver=mei_txe latency=0
             resources: irq:299 memory:d1700000-d17fffff memory:d1600000-d16fffff
        *-isa
             description: ISA bridge
             product: Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU
             physical id: 1f
             bus info: [email protected]:00:1f.0
             version: 22
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             resources: irq:0
  *-battery
       description: 锂离子 Battery
       product: SR Real Battery
       vendor: Intel SR 1
       physical id: 1
       version: Date
       serial: 123456789
       slot: I2C2
       configuration: voltage=3.8V
  *-power UNCLAIMED
       description: OEM Define 1
       product: OEM Define 5
       vendor: OEM Define 2
       physical id: 2
       version: OEM Define 6
       serial: OEM Define 3
       capacity: 42mWh
 用户资料
显示帖子 :  排序
当前时区为 UTC + 8 小时
在线用户
正在浏览此版面的用户:没有注册用户 和 2 位游客
不能 在这个版面发表主题
不能 在这个版面回复主题
不能 在这个版面编辑帖子
不能 在这个版面删除帖子
不能 在这个版面提交附件
前往 :
简体中文语系由 王笑宇 翻译
