笔记本14.04安装nvidia显卡驱动后各种开机黑屏,求帮助!
- 系统: ubuntu 16.04
1.笔记本,intel和nvidia的双显卡,在设置中的“软件和更新”的“附加驱动”页面,不能识别出驱动型号
2.选择非开源驱动来安装, 开机后黑屏。
3.黑屏后,我ctrl+Alt+F1进入控制台apt-get remove nvidia-*
4.重启后正常开机进入图形界面
5.重新在“附加驱动”中选择其他的驱动安装,重启还是黑屏
uname -r
4.2.0-27-generic
sudo lshw -numeric -class video
*-display UNCLAIMED
product: GM107M [GeForce GTX 960M] [10DE:139B]
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:df000000-df07ffff
*-display
product: Intel Corporation [8086:191B]
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
resources: irq:129 memory:dd000000-ddffffff memory:a0000000-bfffffff ioport:f000(size=64)
sudo lspci -knn
00:00.0 Host bridge [0600]: Intel Corporation Sky Lake Host Bridge/DRAM Registers [8086:1910] (rev 07)
Subsystem: CLEVO/KAPOK Computer Device [1558:0152]
00:01.0 PCI bridge [0604]: Intel Corporation Sky Lake PCIe Controller (x16) [8086:1901] (rev 07)
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:191b] (rev 06)
Kernel driver in use: i915
00:14.0 USB controller [0c03]: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller [8086:a12f] (rev 31)
00:14.2 Signal processing controller [1180]: Intel Corporation Sunrise Point-H Thermal subsystem [8086:a131] (rev 31)
00:16.0 Communication controller [0780]: Intel Corporation Sunrise Point-H CSME HECI #1 [8086:a13a] (rev 31)
Kernel driver in use: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Sunrise Point-H SATA Controller [AHCI mode] [8086:a103] (rev 31)
Kernel driver in use: ahci
00:1c.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #3 [8086:a112] (rev f1)
00:1c.3 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #4 [8086:a113] (rev f1)
00:1f.0 ISA bridge [0601]: Intel Corporation Sunrise Point-H LPC Controller [8086:a14e] (rev 31)
00:1f.2 Memory controller [0580]: Intel Corporation Sunrise Point-H PMC [8086:a121] (rev 31)
00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-H HD Audio [8086:a170] (rev 31)
00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-H SMBus [8086:a123] (rev 31)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM107M [GeForce GTX 960M] [10de:139b] (rev a2)
02:00.0 Network controller [0280]: Intel Corporation Wireless 3165 [8086:3165] (rev 81)
Subsystem: Intel Corporation Dual Band Wireless AC 3165 [8086:4010]
Kernel driver in use: iwlwifi
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device [10ec:5287] (rev 01)
Kernel driver in use: rtsx_pci
03:00.1 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
Kernel driver in use: r8169
以上是我的详细信息
请求大神帮忙看看~我这个还有救吗?
4.重启后正常开机进入图形界面
uname -r
4.2.0-27-generic
*-display UNCLAIMED
physical id: 0
version: a2
width: 64 bits
clock: 33MHz
*-display
physical id: 2
version: 06
width: 64 bits
clock: 33MHz
sudo lspci -knn
以上是我的详细信息
请求大神帮忙看看~我这个还有救吗?
Re: 笔记本14.04安装nvidia显卡驱动后各种开机黑屏,求帮助!
1. nVidia 顯卡 目前沒有合適的驅動作用中*-display UNCLAIMED
2. 開源驅動 nouveau
https://nouveau.freedesktop.org/wiki/CodeNames/
GM107M GeForce GTX 960M 不在支援名單內
GM107 GeForce GTX 960M 在支援名單內
3. 閉源驅動 nvidia 建議試試 364.19
3-1. http://www.nvidia.com/Download/driverRe ... 1818/en-us
Version: 364.19
GeForce 900M Series (Notebooks):
GeForce GTX 960M
3-2. 從這個 ppa:graphics-drivers 安裝 nvidia-graphics-drivers-364 及 nvidia-settings笔记本14.04
https://launchpad.net/~graphics-drivers ... ubuntu/ppa
nvidia-graphics-drivers-364 364.19-0ubuntu0~gpu14.04.3
nvidia-settings 364.15-0ubuntu0~gpu14.04.1
3-3. 安裝方法 參閱
3-3-1. http://www.webupd8.org/2016/06/how-to-i ... rs-in.html
3-3-2. https://help.ubuntu.com/community/Binar ... wto/Nvidia
3-3-2. http://us.download.nvidia.com/XFree86/L ... index.html
4. 內建顯卡 Intel*-display
目前作用中開源驅動 i915
等上面 nVidia 閉源驅動安裝好了 有興趣 再來探討
5. 不要急著動手 先看看 上面參考文章4.重启后正常开机进入图形界面
有何問題 先貼上來討論
6. 參閱在设置中的“软件和更新”的“附加驱动”页面,不能识别出驱动型号
- 系统: ubuntu 16.04
首先,非常感谢您的帮助
我参考了那个博客的描述,博客说的就是我平时使用的办法:直接图形化安装
也参考使用了官方的方法,禁用开源驱动,然后命令行安装什么的。
可是都是结果都是一样的:黑屏。。。
唉,表示说我也是很无奈
以前装16.04的kylin,无法进入系统
现在14.04 LTS,驱动装不上,我这也是够惨的,哈哈哈
最近还要上课,不折腾了,每一次来兴趣折腾Ubuntu都是遍体鳞伤而归,表示说我还是太年轻了
以后再说吧
非常感谢您
可是都是结果都是一样的:黑屏。。。
唉,表示说我也是很无奈
以后再说吧
非常感谢您
在你加入這個 APP我参考了那个博客的描述,博客说的就是我平时使用的办法:直接图形化安装
以後
才會出現 nvidia-graphics-drivers-364 364.19-0ubuntu0~gpu14.04.3
讓你選擇
在 Ubuntu 或者說 Linux我平时使用的办法:直接图形化安装
直接图形化安装 只代表一小部份安裝方法
強而有力的方法 許多都是指令安裝
特別是 硬件廠商官方提供的閉源驅動
意思是 排斥指令安裝方法
將損失體驗 硬件廠商提供的閉源驅動 的機會
- 系统: ubuntu 16.04
我已经添加那个PPA了哦~
指令的我也尝试过了哦~
一般搜索到的博客什么的都是推荐指令安装的,所以我也做出了很多尝试。
可是。。。
指令的我也尝试过了哦~
可是。。。
請把你使用的完整指令及回應文字 全部複製貼上來我已经添加那个PPA了哦~
指令的我也尝试过了哦~
才能幫你
摘錄或口述 恐怕遺漏重要資訊
從 PPA 安裝 完整指令 參見
- 系统: ubuntu 16.04
我的代码,其实就是添加完了那个PPA以后
sudo apt-get install nvidia-364 nvidia-settings nvidia-prime
反馈嘛,就是各种输出咯,没有任何错误发生,一切正常的就执行到最后,然后命令返回了
我打算明天试一试bumblebee呢,这个能行么
1. Ubuntu 的 Linux Kenrel (包含基於 Ubuntu 的發行版)我打算明天试一试bumblebee呢,这个能行么
已經支援 Nvidia-Optimus 雙顯卡
不需要額外安裝 bumblebee
1-1. 參閱
https://wiki.ubuntu.com/X/Config/HybridGraphics
1-2. 如果抱著體驗的目的 在 Ubuntu 額外安裝 bumblebee 還是值得鼓勵
https://wiki.ubuntu.com/Bumblebee
2. Ubuntu 以外的其它 Linux 發行版
Nvidia-Optimus 雙顯卡
需要額外安裝 bumblebee
https://github.com/Bumblebee-Project/Bu ... -and-usage
Install and usage
3. 歡迎體驗 bumblebee 後的經驗分享
- 系统: ubuntu 16.04
老实说,我最最认可的桌面环境还是Ubuntu的unity,所以如果Ubuntu可以安装好驱动,自然我是更愿意接着用Ubuntu的
但是驱动总是安装失败。我也挺迷茫的,你给出的链接我也都照顾到了,各种各样的方式我也都试过的,可是就是不成功呢,奇怪的说
我曾经在Linux Mint 17.3 Xfce这个发行版上,使用它自带的驱动管理器,完美安装了NVIDIA驱动
貌似Mint的驱动就是Ubuntu定制的,那么我在Ubuntu下应该也能成功安装啊,没道理各种黑屏的
所以就有了尝试一下bumblebee的想法,看看能否有奇迹出现咯
- 系统: ubuntu 16.04
尝试完了,没有奇迹发生,一样是失败
看来我的电脑很排斥Linux啊,怎么装都不成功
使用bumblebee的官方说法,输入sudo apt-get install bumblebee bumblebee-nvidia primus linux-headers-generic
然后,华丽丽的在控制台接下来的执行过程中卡住了,屏幕保持不变,键盘鼠标都无效,没办法只能强行关机
然后开机以后出现登录界面,登录完成直接黑屏
殊途同归啊,各种黑屏
我该怎么办?难道一定要回到微软怀抱。。。
图形化安装不行,apt-get install 也不行,大黄蜂也没用,看来我这屏幕亮度是不用调了,Dota2也不用玩了
殊途同归啊,各种黑屏
现在14.04 LTS,驱动装不上
建議 鎖定 Ubuntu 16.04 試試GeForce GTX 960M
可以安裝
nvidia-graphics-drivers-367 367.27-0ubuntu0~gpu16.04.1
通常 版本越新 可能支援度越好
只有一句失敗尝试完了,没有奇迹发生,一样是失败
很難幫你
你提供的資訊越詳細
獲得可行協助的速度越快
- 系统: ubuntu 16.04
我其实没啥信息可以提供。。。。我就是按照官方或者博客的方法做的,一切都是正常,也没有任何错误发生,但是就是重启黑屏
没有任何提示,我怎么提供信息
经过尝试mint 17.3使用附加驱动图形化安装Nvidia驱动,完美运行,同样都是ubuntu14.04的驱动,Ubuntu下就不行,Mint下就完美,这是怎么回事。。。
没有任何提示,我怎么提供信息
開機 是一連串的程序重启黑屏
1. https://en.wikipedia.org/wiki/Linux_startup_process
2. https://wiki.ubuntu.com/Booting
什麼程序出現黑屏
影響研判出現黑屏的原因及方法
不知道什麼程序出現黑屏 就提供給你意見
恐怕讓你白忙
建议安装新版16.04版的吧,不过也有双显问题存在,问题不大,我的只有集显示,禁了独显。就看看网页电影呀就没了,网络交流也就BBS和WEB应用级的。
先要添加最新N卡驱动ppa源
看自己的N卡型号最新驱动版本号,看操作系统linux 64的版本号
http://www.nvidia.cn/Download/index.aspx?lang=cn
驱动不是越新越好,而是适合的自己的最新版,参照N卡官网给的型号驱动建议
先要添加最新N卡驱动ppa源
linux新人,不停的尝鲜,请多多指教.
