安装时没有预装synaptics
sudo apt-get install xserver-xorg-input-synaptics
earl@earl-Ubuntu:~$ sudo apt-get install xserver-xorg-input-synaptics
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
xserver-xorg-input-synaptics : Depends: xorg-input-abi-20
Depends: xserver-xorg-core (>= 2:1.14.99.902)
E: Unable to correct problems, you have held broken packages.
