求助 ubuntu 12.0.4 重复登陆
morgin
系统: ubuntu12.0.4
帖子 morgin » 2018-09-14 18:06
一台dell t630,安装了12.0.4版本,一次重启后无限次进入循环登陆:
相关log:
more .xsession-errors
stdin: is not a tty
Failed to start message bus: '=' character not found or has no value following it
EOF in dbus-launch reading address from bus daemon
2:
less /var/log/lightdm/x-0-greeter.log
** (unity-greeter:10763): WARNING **: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
** (process:10765): WARNING **: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
Failed to launch bus: Failed to connect to session bus[+0.00s] DEBUG: unity-greeter.vala:912: Starting unity-greeter 0.2.9 UID=104 LANG=en_US.UTF-8
[+0.00s] DEBUG: unity-greeter.vala:915: Setting cursor
[+0.00s] DEBUG: unity-greeter.vala:919: Creating background surface
[+0.00s] DEBUG: unity-greeter.vala:922: Loading command line options
[+0.00s] DEBUG: unity-greeter.vala:950: Setting GTK+ settings
[+0.01s] DEBUG: unity-greeter.vala:973: Creating Unity Greeter
[+0.01s] DEBUG: Connecting to display manager...
[+0.01s] DEBUG: Wrote 17 bytes to daemon
[+0.01s] DEBUG: Read 8 bytes from daemon
[+0.01s] DEBUG: Read 120 bytes from daemon
[+0.01s] DEBUG: Connected version=1.2.3 default-session=ubuntu show-manual-login=true hide-users=false has-guest-account=false
[+0.01s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.02s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.03s] DEBUG: settings-daemon.vala:97: Could not start gnome-settings-daemon over DBus: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.03s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.04s] WARNING: menubar.vala:195: Could not get set environment for indicators: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.04s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.05s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.05s] WARNING: menubar.vala:195: Could not get set environment for indicators: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.06s] WARNING: menubar.vala:195: Could not get set environment for indicators: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.06s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.07s] DEBUG: menubar.vala:356: Could not set DBUS_NAME: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.07s] DEBUG: menubar.vala:359: LANG=en_US.UTF-8 LANGUAGE=(null)
[+0.07s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.08s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.08s] CRITICAL: g_error_free: assertion `error != NULL' failed
[+0.09s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.10s] DEBUG: get entries
[+0.10s] DEBUG: menubar.vala:541: Adding indicator object 0x18e0078 at position 0
[+0.10s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.11s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.12s] DEBUG: Evaluating bitmask for '%l:%M %p'
[+0.12s] DEBUG: Checking against 2 possible times
[+0.12s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.12s] DEBUG: Guessing max time width: 62
[+0.12s] DEBUG: get entries
[+0.12s] DEBUG: menubar.vala:541: Adding indicator object 0x19351b8 at position 1
[+0.13s] WARNING: IndicatorObject class does not have an accessible description.
[+0.13s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.14s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.15s] WARNING: IndicatorObject class does not have an accessible description.
[+0.15s] DEBUG: get entries
[+0.15s] DEBUG: menubar.vala:541: Adding indicator object 0x19d1898 at position 2
[+0.15s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.16s] DEBUG: menubar.vala:365: LANG=en_US.UTF-8 LANGUAGE=(null)
[+0.16s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.16s] DEBUG: Ignoring session /usr/share/xsessions/gnome-shell.desktop
[+0.16s] DEBUG: Loaded session /usr/share/xsessions/ubuntu-2d.desktop (Ubuntu 2D, This session logs you into Ubuntu 2D Mode)
[+0.16s] DEBUG: Loaded session /usr/share/xsessions/ubuntu.desktop (Ubuntu, This session logs you into Ubuntu)
[+0.16s] DEBUG: Ignoring session /usr/share/xsessions/gnome.desktop
[+0.16s] DEBUG: session-chooser.vala:42: Adding session ubuntu (Ubuntu)
[+0.16s] DEBUG: session-chooser.vala:42: Adding session ubuntu-2d (Ubuntu 2D)
[+0.17s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.18s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.19s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited。。。
[+0.30s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.30s] DEBUG: Loading user /org/freedesktop/Accounts/User1000
[+0.32s] DEBUG: Loading user /org/freedesktop/Accounts/User1001
[+0.33s] DEBUG: Loading user /org/freedesktop/Accounts/User1002
[+0.35s] DEBUG: Loading sessions from org.freedesktop.DisplayManager
[+0.35s] DEBUG: unity-greeter.vala:334: Adding/updating user eryansuo (eryansuo)
[+0.35s] DEBUG: unity-greeter.vala:334: Adding/updating user logdemon ()
[+0.35s] DEBUG: unity-greeter.vala:334: Adding/updating user view (view)
[+0.35s] DEBUG: Starting authentication for user eryansuo...
[+0.35s] DEBUG: Wrote 24 bytes to daemon
[+0.35s] DEBUG: unity-greeter.vala:976: Showing greeter
[+0.35s] DEBUG: unity-greeter.vala:359: Showing main window
[+0.35s] DEBUG: New style for time label
[+0.35s] DEBUG: Evaluating bitmask for '%l:%M %p'
[+0.35s] DEBUG: Checking against 2 possible times
[+0.35s] DEBUG: Guessing max time width: 62
[+0.36s] DEBUG: background.vala:315: Regenerating backgrounds
[+0.36s] DEBUG: background.vala:67: Making background /usr/share/backgrounds/warty-final-ubuntu.png at 1600x900
[+0.36s] DEBUG: New style for time label
[+0.36s] DEBUG: Evaluating bitmask for '%l:%M %p'
[+0.36s] DEBUG: Checking against 2 possible times
[+0.36s] DEBUG: Guessing max time width: 62
[+0.43s] DEBUG: unity-greeter.vala:989: Starting main loop
[+0.43s] DEBUG: Read 8 bytes from daemon
[+0.43s] DEBUG: Read 38 bytes from daemon
[+0.43s] DEBUG: Prompt user with 1 message(s)
[+0.43s] WARNING: Unable to get session bus: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.44s] WARNING: Unable to get session bus: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.44s] DEBUG: user-list.vala:309: Error registering user list dbus object: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.44s] WARNING: Could not grab DBus proxy for com.canonical.indicator.datetime: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.52s] DEBUG: unity-greeter.vala:317: starting system-ready sound
[+0.53s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+0.54s] DEBUG: background.vala:116: Render of background /usr/share/backgrounds/warty-final-ubuntu.png complete
[+0.54s] DEBUG: Restarting service 'com.canonical.indicator.session' count 1
[+0.55s] DEBUG: Restarting service 'com.canonical.indicator.datetime' count 1
[+0.55s] DEBUG: Restarting service 'com.canonical.indicator.sound' count 1
[+0.55s] DEBUG: Restarting service 'com.canonical.indicator.application' count 1
[+0.80s] DEBUG: Restarting service 'com.canonical.indicator.session' count 2
[+1.12s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+1.12s] DEBUG: Restarting service 'com.canonical.indicator.datetime' count 2
[+1.12s] DEBUG: Restarting service 'com.canonical.indicator.sound' count 2
[+1.13s] DEBUG: Restarting service 'com.canonical.indicator.application' count 2
[+1.13s] DEBUG: Setting keyboard layout to 'us'
[+1.15s] WARNING: Command line `dbus-launch --autolaunch=8bc711183a0d791a52e078f6000001e9 --binary-syntax --close-stderr' exited with non-zero exit status 1: EOF in dbus-launch reading address from bus daemon\n
[+1.55s] DEBUG: Restarting service 'com.canonical.indicator.session' count 3
[+1.64s] DEBUG: Restarting service 'com.canonical.indicator.datetime' count 3
[+1.65s] DEBUG: Restarting service 'com.canonical.indicator.sound' count 3
[+1.65s] DEBUG: Restarting service 'com.canonical.indicator.application' count 3
[+2.46s] DEBUG: Restarting service 'com.canonical.indicator.session' count 4
[+2.46s] DEBUG: Restarting service 'com.canonical.indicator.datetime' count 4
[+2.46s] DEBUG: Restarting service 'com.canonical.indicator.sound' count 4
[+2.47s] DEBUG: Restarting service 'com.canonical.indicator.application' count 4
[+4.07s] DEBUG: Restarting service 'com.canonical.indicator.session' count 5
[+4.25s] DEBUG: Restarting service 'com.canonical.indicator.datetime' count 5
[+4.25s] DEBUG: Restarting service 'com.canonical.indicator.sound' count 5
[+4.25s] DEBUG: Restarting service 'com.canonical.indicator.application' count 5
[+7.46s] DEBUG: Restarting service 'com.canonical.indicator.session' count 6
[+7.46s] DEBUG: Restarting service 'com.canonical.indicator.datetime' count 6
[+7.47s] DEBUG: Restarting service 'com.canonical.indicator.sound' count 6
[+7.47s] DEBUG: Restarting service 'com.canonical.indicator.application' count 6
3:
less /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.2.3, UID=0 PID=2271
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: Registered seat module xlocal
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Adding default seat
[+0.00s] DEBUG: Starting seat
[+0.00s] DEBUG: Starting new display for greeter
[+0.00s] DEBUG: Starting local X display
[+0.00s] DEBUG: X server :0 will replace Plymouth
[+0.03s] DEBUG: Using VT 7
[+0.03s] DEBUG: Activating VT 7
[+0.03s] DEBUG: Logging to /var/log/lightdm/x-0.log
[+0.11s] DEBUG: Writing X server authority to /var/run/lightdm/root/:0
[+0.11s] DEBUG: Launching X Server
[+0.11s] DEBUG: Launching process 2323: /usr/bin/X :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch -background none
[+0.11s] DEBUG: Waiting for ready signal from X server :0
[+0.11s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.11s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+1.33s] DEBUG: Got signal 10 from process 2323
[+1.33s] DEBUG: Got signal from X server :0
[+1.33s] DEBUG: Stopping Plymouth, X server is ready
[+1.35s] DEBUG: Connecting to XServer :0
[+1.35s] DEBUG: Starting greeter
[+1.35s] DEBUG: Started session 2901 with service 'lightdm', username 'lightdm'
[+1.56s] DEBUG: Session 2901 authentication complete with return value 0: Success
[+1.56s] DEBUG: Greeter authorized
[+1.57s] DEBUG: Logging to /var/log/lightdm/x-0-greeter.log
[+1.58s] DEBUG: Session 2901 running command /usr/lib/lightdm/lightdm-greeter-session /usr/sbin/unity-greeter
[+2.39s] DEBUG: Greeter connected version=1.2.3
[+2.39s] DEBUG: Greeter connected, display is ready
[+2.39s] DEBUG: New display ready, switching to it
[+2.39s] DEBUG: Activating VT 7
[+3.11s] DEBUG: Greeter start authentication
[+3.11s] DEBUG: Started session 3353 with service 'lightdm', username '(null)'
[+3.11s] DEBUG: Session 3353 got 1 message(s) from PAM
[+3.11s] DEBUG: Prompt greeter with 1 message(s)
[+666.45s] DEBUG: Continue authentication
[+666.46s] DEBUG: Session 3353 got 1 message(s) from PAM
[+666.46s] DEBUG: Prompt greeter with 1 message(s)
[+670.96s] DEBUG: Continue authentication
[+670.99s] DEBUG: Session 3353 authentication complete with return value 0: Success
[+670.99s] DEBUG: Authenticate result for user root: Success
[+671.01s] DEBUG: User root authorized
[+671.01s] DEBUG: Greeter requests default session
[+671.01s] DEBUG: Stopping greeter
[+671.01s] DEBUG: Session 2901: Sending SIGTERM
[+671.02s] DEBUG: Greeter closed communication channel
[+671.02s] DEBUG: Session 2901 exited with return value 0
[+671.02s] DEBUG: Greeter quit
[+671.03s] DEBUG: Dropping privileges to uid 0
[+671.04s] DEBUG: Restoring privileges
[+671.04s] DEBUG: Dropping privileges to uid 0
[+671.04s] DEBUG: Writing /root/.dmrc
[+671.04s] DEBUG: Starting session ubuntu as user root
[+671.04s] DEBUG: Session 3353 running command /usr/sbin/lightdm-session gnome-session --session=ubuntu
[+671.06s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
[+671.99s] DEBUG: Session 3353 exited with return value 0
[+671.99s] DEBUG: User session quit
[+671.99s] DEBUG: Stopping display
[+671.99s] DEBUG: Sending signal 15 to process 2323
[+672.26s] DEBUG: Process 2323 exited with return value 0
[+672.26s] DEBUG: X server stopped
[+672.26s] DEBUG: Removing X server authority /var/run/lightdm/root/:0
[+672.26s] DEBUG: Releasing VT 7
[+672.26s] DEBUG: Display server stopped
[+672.26s] DEBUG: Display stopped
[+672.26s] DEBUG: Active display stopped, switching to greeter
[+672.26s] DEBUG: Switching to greeter
[+672.26s] DEBUG: Starting new display for greeter
[+672.26s] DEBUG: Starting local X display
[+672.26s] DEBUG: Using VT 7
[+672.26s] DEBUG: Logging to /var/log/lightdm/x-0.log
[+672.26s] DEBUG: Writing X server authority to /var/run/lightdm/root/:0
[+672.26s] DEBUG: Launching X Server
[+672.26s] DEBUG: Launching process 3844: /usr/bin/X :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+672.26s] DEBUG: Waiting for ready signal from X server :0
[+672.46s] DEBUG: Got signal 10 from process 3844
[+672.46s] DEBUG: Got signal from X server :0
[+672.46s] DEBUG: Connecting to XServer :0
[+672.46s] DEBUG: Starting greeter
[+672.46s] DEBUG: Started session 3863 with service 'lightdm', username 'lightdm'
[+672.48s] DEBUG: Session 3863 authentication complete with return value 0: Success
[+672.48s] DEBUG: Greeter authorized
[+672.48s] DEBUG: Logging to /var/log/lightdm/x-0-greeter.log
[+672.48s] DEBUG: Session 3863 running command /usr/lib/lightdm/lightdm-greeter-session /usr/sbin/unity-greeter
[+672.53s] DEBUG: Greeter connected version=1.2.3
[+672.53s] DEBUG: Greeter connected, display is ready
[+672.53s] DEBUG: New display ready, switching to it
[+672.53s] DEBUG: Activating VT 7
[+672.53s] DEBUG: Stopping greeter display being switched from
[+672.87s] DEBUG: Greeter start authentication
[+672.87s] DEBUG: Started session 4272 with service 'lightdm', username '(null)'
[+672.87s] DEBUG: Session 4272 got 1 message(s) from PAM
[+672.87s] DEBUG: Prompt greeter with 1 message(s)
[+677.09s] DEBUG: Greeter start authentication for test
[+677.09s] DEBUG: Session 4272: Sending SIGTERM
[+677.09s] DEBUG: Started session 4386 with service 'lightdm', username 'test'
4:
startx
_XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
(EE)
Fatal server error:
(EE) Cannot establish any listening sockets - Make sure an X server isn't already running(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyxinit: giving up
xinit: unable to connect to X server: Resource temporarily unavailable
xinit: server error
在百度搜索后,大概有4-6种方式都试过了,没有用处,所以来此处寻求帮助!
感谢!!
九天星
Re: 求助 ubuntu 12.0.4 重复登陆
帖子 九天星 » 2018-09-17 21:54
切换到tty1模式登陆。
在主用户目录下,执行
cd ~/
ls -a
将看到的结果复制上来,因为有个文件名我记不住了。删掉那个文件就行了。
morgin
系统: ubuntu12.0.4
帖子 morgin » 2018-09-20 20:35
不是那个 .Xauthority问题,我的 .Xauthority字节大小是0,权限没有错
