求救/ubuntu11.04开机慢
luxiaoyong
求救/ubuntu11.04开机慢
帖子 luxiaoyong » 2011-08-02 15:08
不知道为什么,今天早上开机突然发现,我的ubuntu开机需要几分钟,一直停留在那个进入登录界面之前的画面。我是新手,恳请各位大侠相助。
monk
Re: 求救/ubuntu11.04开机慢
帖子 monk » 2011-08-02 15:18
输入 dmesg
看看哪里用的时间长了
*********宁静致远*********
如果我说的有什么不对,请看签名第一行
luxiaoyong
帖子 luxiaoyong » 2011-08-02 15:43
monk 写了:输入 dmesg
看看哪里用的时间长了
[ 0.384070] pci 0000:00:15.0: bridge window [io 0xe000-0xefff]
[ 0.384081] pci 0000:00:15.0: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.384089] pci 0000:00:15.0: bridge window [mem 0xf9f00000-0xf9ffffff 64bit pref]
[ 0.384102] pci 0000:00:16.0: PCI bridge to [bus 04-04]
[ 0.384104] pci 0000:00:16.0: bridge window [io disabled]
[ 0.384115] pci 0000:00:16.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.384123] pci 0000:00:16.0: bridge window [mem pref disabled]
[ 0.384145] pci 0000:00:09.0: setting latency timer to 64
[ 0.384400] ACPI: PCI Interrupt Link [LRP0] enabled at IRQ 23
[ 0.384418] pci 0000:00:0c.0: PCI INT A -> Link[LRP0] -> GSI 23 (level, low) -> IRQ 23
[ 0.384427] pci 0000:00:0c.0: setting latency timer to 64
[ 0.384625] ACPI: PCI Interrupt Link [LRP3] enabled at IRQ 22
[ 0.384632] pci 0000:00:15.0: PCI INT A -> Link[LRP3] -> GSI 22 (level, low) -> IRQ 22
[ 0.384641] pci 0000:00:15.0: setting latency timer to 64
[ 0.384837] ACPI: PCI Interrupt Link [LRP4] enabled at IRQ 21
[ 0.384844] pci 0000:00:16.0: PCI INT A -> Link[LRP4] -> GSI 21 (level, low) -> IRQ 21
[ 0.384853] pci 0000:00:16.0: setting latency timer to 64
[ 0.384859] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.384862] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.384864] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.384867] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.384869] pci_bus 0000:00: resource 8 [mem 0x80000000-0xfbffffff]
[ 0.384872] pci_bus 0000:00: resource 9 [mem 0xfe000000-0xfebfffff]
[ 0.384874] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7]
[ 0.384877] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff]
[ 0.384879] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.384882] pci_bus 0000:01: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.384884] pci_bus 0000:01: resource 8 [mem 0x80000000-0xfbffffff]
[ 0.384887] pci_bus 0000:01: resource 9 [mem 0xfe000000-0xfebfffff]
[ 0.384889] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.384891] pci_bus 0000:02: resource 1 [mem 0xfaf00000-0xfbffffff]
[ 0.384894] pci_bus 0000:02: resource 2 [mem 0xe0000000-0xf7ffffff 64bit pref]
[ 0.384897] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 0.384899] pci_bus 0000:03: resource 1 [mem 0xfea00000-0xfeafffff]
[ 0.384902] pci_bus 0000:03: resource 2 [mem 0xf9f00000-0xf9ffffff 64bit pref]
[ 0.384904] pci_bus 0000:04: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.384948] NET: Registered protocol family 2
[ 0.385029] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.385287] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.385815] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.386084] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.386087] TCP reno registered
[ 0.386090] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.386101] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.386210] NET: Registered protocol family 1
[ 0.440195] pci 0000:02:00.0: Boot video device
[ 0.440231] PCI: CLS 64 bytes, default 64
[ 0.440263] Simple Boot Flag at 0xef set to 0x1
[ 0.440477] cpufreq-nforce2: No nForce2 chipset.
[ 0.440627] audit: initializing netlink socket (disabled)
[ 0.440640] type=2000 audit(1312293033.436:1): initialized
[ 0.450099] highmem bounce pool size: 64 pages
[ 0.450109] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.452018] VFS: Disk quotas dquot_6.5.2
[ 0.452087] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.452796] fuse init (API version 7.16)
[ 0.452894] msgmni has been set to 1678
[ 0.453155] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.453180] io scheduler noop registered
[ 0.453182] io scheduler deadline registered
[ 0.453197] io scheduler cfq registered (default)
[ 0.453703] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.453731] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.453807] intel_idle: MWAIT substates: 0x3122220
[ 0.453809] intel_idle: does not run on family 6 model 23
[ 0.453931] ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 0.453987] ACPI: AC Adapter [AC0] (on-line)
[ 0.454091] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[ 0.500026] ACPI: Power Button [PWRB]
[ 0.500112] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1
[ 0.509137] Freeing initrd memory: 12560k freed
[ 0.528033] ACPI: Sleep Button [SLPB]
[ 0.528141] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input2
[ 0.530358] ACPI: Lid Switch [LID]
[ 0.530416] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.530421] ACPI: Power Button [PWRF]
[ 0.530650] ACPI: acpi_idle registered with cpuidle
[ 0.531377] Monitor-Mwait will be used to enter C-1 state
[ 0.531414] Monitor-Mwait will be used to enter C-3 state
[ 0.531443] Monitor-Mwait will be used to enter C-3 state
[ 0.531456] Marking TSC unstable due to TSC halts in idle
[ 0.539508] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.539511] ACPI: Thermal Zone [THRM] (65 C)
[ 0.539539] ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 0.539614] ERST: Table is not found!
[ 0.539685] isapnp: Scanning for PnP cards...
[ 0.544109] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.576082] ACPI: Battery Slot [BAT0] (battery present)
[ 0.899543] isapnp: No Plug & Play device found
[ 0.928664] Linux agpgart interface v0.103
[ 0.930055] brd: module loaded
[ 0.930697] loop: module loaded
[ 0.930786] i2c-core: driver [adp5520] using legacy suspend method
[ 0.930788] i2c-core: driver [adp5520] using legacy resume method
[ 0.931132] ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 20
[ 0.931148] pata_acpi 0000:00:0b.0: PCI INT A -> Link[LSA0] -> GSI 20 (level, low) -> IRQ 20
[ 0.931181] pata_acpi 0000:00:0b.0: setting latency timer to 64
[ 0.931193] pata_acpi 0000:00:0b.0: PCI INT A disabled
[ 0.931544] Fixed MDIO Bus: probed
[ 0.931584] PPP generic driver version 2.4.2
[ 0.931627] tun: Universal TUN/TAP device driver, 1.6
[ 0.931629] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.931716] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.931918] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 23
[ 0.931922] ehci_hcd 0000:00:04.1: PCI INT B -> Link[LUB2] -> GSI 23 (level, low) -> IRQ 23
[ 0.931932] ehci_hcd 0000:00:04.1: setting latency timer to 64
[ 0.931935] ehci_hcd 0000:00:04.1: EHCI Host Controller
[ 0.931978] ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
[ 0.932053] ehci_hcd 0000:00:04.1: debug port 1
[ 0.932062] ehci_hcd 0000:00:04.1: cache line size of 64 is not supported
[ 0.932081] ehci_hcd 0000:00:04.1: irq 23, io mem 0xfae7ec00
[ 0.944016] ehci_hcd 0000:00:04.1: USB 2.0 started, EHCI 1.00
[ 0.944154] hub 1-0:1.0: USB hub found
[ 0.944159] hub 1-0:1.0: 11 ports detected
[ 0.944437] ACPI: PCI Interrupt Link [UB12] enabled at IRQ 22
[ 0.944442] ehci_hcd 0000:00:06.1: PCI INT B -> Link[UB12] -> GSI 22 (level, low) -> IRQ 22
[ 0.944451] ehci_hcd 0000:00:06.1: setting latency timer to 64
[ 0.944454] ehci_hcd 0000:00:06.1: EHCI Host Controller
[ 0.944493] ehci_hcd 0000:00:06.1: new USB bus registered, assigned bus number 2
[ 0.944535] ehci_hcd 0000:00:06.1: debug port 1
[ 0.944543] ehci_hcd 0000:00:06.1: cache line size of 64 is not supported
[ 0.944560] ehci_hcd 0000:00:06.1: irq 22, io mem 0xfae7e800
[ 0.956015] ehci_hcd 0000:00:06.1: USB 2.0 started, EHCI 1.00
[ 0.956123] hub 2-0:1.0: USB hub found
[ 0.956127] hub 2-0:1.0: 1 port detected
[ 0.956195] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.956397] ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 21
[ 0.956401] ohci_hcd 0000:00:04.0: PCI INT A -> Link[LUB0] -> GSI 21 (level, low) -> IRQ 21
[ 0.956410] ohci_hcd 0000:00:04.0: setting latency timer to 64
[ 0.956413] ohci_hcd 0000:00:04.0: OHCI Host Controller
[ 0.956451] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 3
[ 0.960039] ohci_hcd 0000:00:04.0: irq 21, io mem 0xfae7f000
[ 1.018103] hub 3-0:1.0: USB hub found
[ 1.018108] hub 3-0:1.0: 11 ports detected
[ 1.018378] ACPI: PCI Interrupt Link [UB11] enabled at IRQ 20
[ 1.018382] ohci_hcd 0000:00:06.0: PCI INT A -> Link[UB11] -> GSI 20 (level, low) -> IRQ 20
[ 1.018391] ohci_hcd 0000:00:06.0: setting latency timer to 64
[ 1.018394] ohci_hcd 0000:00:06.0: OHCI Host Controller
[ 1.018433] ohci_hcd 0000:00:06.0: new USB bus registered, assigned bus number 4
[ 1.018473] ohci_hcd 0000:00:06.0: irq 20, io mem 0xfae7d000
[ 1.074106] hub 4-0:1.0: USB hub found
[ 1.074111] hub 4-0:1.0: 1 port detected
[ 1.074178] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.074269] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.077102] i8042: Detected active multiplexing controller, rev 1.1
[ 1.080184] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.080189] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.080221] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.080248] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.080275] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.080393] mousedev: PS/2 mouse device common for all mice
[ 1.080601] rtc_cmos 00:08: RTC can wake from S4
[ 1.084064] rtc_cmos 00:08: rtc core: registered rtc_cmos as rtc0
[ 1.084113] rtc0: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
[ 1.084196] device-mapper: uevent: version 1.0.3
[ 1.084276] device-mapper: ioctl: 4.19.1-ioctl (2011-01-07) initialised: dm-devel@redhat.com
[ 1.084350] device-mapper: multipath: version 1.2.0 loaded
[ 1.084353] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 1.084425] EISA: Probing bus 0 at eisa.0
[ 1.084429] EISA: Cannot allocate resource for mainboard
[ 1.084431] Cannot allocate resource for EISA slot 1
[ 1.084433] Cannot allocate resource for EISA slot 2
[ 1.084435] Cannot allocate resource for EISA slot 3
[ 1.084436] Cannot allocate resource for EISA slot 4
[ 1.084438] Cannot allocate resource for EISA slot 5
[ 1.084440] Cannot allocate resource for EISA slot 6
[ 1.084442] Cannot allocate resource for EISA slot 7
[ 1.084444] Cannot allocate resource for EISA slot 8
[ 1.084445] EISA: Detected 0 cards.
[ 1.084567] cpuidle: using governor ladder
[ 1.084669] cpuidle: using governor menu
[ 1.084964] TCP cubic registered
[ 1.085100] NET: Registered protocol family 10
[ 1.085702] NET: Registered protocol family 17
[ 1.085719] Registering the dns_resolver key type
[ 1.086623] Using IPI No-Shortcut mode
[ 1.086720] PM: Hibernation image not present or could not be loaded.
[ 1.086732] registered taskstats version 1
[ 1.087107] Magic number: 7:327:836
[ 1.087261] rtc_cmos 00:08: setting system clock to 2011-08-02 13:50:34 UTC (1312293034)
[ 1.087264] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.087266] EDD information not available.
[ 1.087377] Freeing unused kernel memory: 700k freed
[ 1.087716] Write protecting the kernel text: 5192k
[ 1.087774] Write protecting the kernel read-only data: 2148k
[ 1.110462] <30>udev[69]: starting version 167
[ 1.117801] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.225201] ahci 0000:00:0b.0: version 3.0
[ 1.225221] ahci 0000:00:0b.0: PCI INT A -> Link[LSA0] -> GSI 20 (level, low) -> IRQ 20
[ 1.225281] ahci 0000:00:0b.0: irq 40 for MSI/MSI-X
[ 1.225354] ahci 0000:00:0b.0: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3 impl IDE mode
[ 1.225358] ahci 0000:00:0b.0: flags: 64bit ncq sntf led pio slum part sxs
[ 1.225363] ahci 0000:00:0b.0: setting latency timer to 64
[ 1.228186] scsi0 : ahci
[ 1.231560] scsi1 : ahci
[ 1.233794] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.233814] r8169 0000:03:00.0: enabling device (0001 -> 0003)
[ 1.234028] ACPI: PCI Interrupt Link [LN3A] enabled at IRQ 19
[ 1.234043] r8169 0000:03:00.0: PCI INT A -> Link[LN3A] -> GSI 19 (level, low) -> IRQ 19
[ 1.234084] r8169 0000:03:00.0: setting latency timer to 64
[ 1.234134] r8169 0000:03:00.0: irq 41 for MSI/MSI-X
[ 1.234687] r8169 0000:03:00.0: eth0: RTL8168d/8111d at 0xf8022000, 48:5b:39:7f:f4:8d, XID 083000c0 IRQ 41
[ 1.234706] scsi2 : ahci
[ 1.238831] scsi3 : ahci
[ 1.241860] scsi4 : ahci
[ 1.242786] scsi5 : ahci
[ 1.242988] ata1: SATA max UDMA/133 abar m8192@0xfae76000 port 0xfae76100 irq 40
[ 1.242991] ata2: SATA max UDMA/133 abar m8192@0xfae76000 port 0xfae76180 irq 40
[ 1.242994] ata3: DUMMY
[ 1.242995] ata4: DUMMY
[ 1.242997] ata5: DUMMY
[ 1.242998] ata6: DUMMY
[ 1.428108] usb 1-7: new high speed USB device using ehci_hcd and address 4
[ 1.560023] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.560040] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.561429] ata1.00: ATA-8: WDC WD3200BEVT-80A0RT0, 01.01A01, max UDMA/133
[ 1.561432] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.562719] ata2.00: ATAPI: Slimtype DVD A DS8A4S, JA22, max UDMA/100
[ 1.562926] ata1.00: configured for UDMA/133
[ 1.563067] scsi 0:0:0:0: Direct-Access ATA WDC WD3200BEVT-8 01.0 PQ: 0 ANSI: 5
[ 1.563273] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.563281] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.563325] sd 0:0:0:0: [sda] Write Protect is off
[ 1.563328] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.563363] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.563966] ata2.00: configured for UDMA/100
[ 1.567254] scsi 1:0:0:0: CD-ROM Slimtype DVD A DS8A4S JA22 PQ: 0 ANSI: 5
[ 1.572341] sr0: scsi3-mmc drive: 24x/8x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.572344] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.572449] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.572513] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.701798] sda: sda1 sda2 < sda5 sda6 sda7 sda8 sda9 >
[ 1.702254] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.944111] usb 3-1: new full speed USB device using ohci_hcd and address 2
[ 2.166108] hub 3-1:1.0: USB hub found
[ 2.169028] hub 3-1:1.0: 4 ports detected
[ 2.488017] usb 3-4: new low speed USB device using ohci_hcd and address 3
[ 2.736140] input: MLK RAPOO 1800 as /devices/pci0000:00/0000:00:04.0/usb3/3-4/3-4:1.0/input/input5
[ 2.736243] generic-usb 0003:1BCF:05C2.0001: input,hidraw0: USB HID v1.00 Keyboard [MLK RAPOO 1800] on usb-0000:00:04.0-4/input0
[ 2.748502] input: MLK RAPOO 1800 as /devices/pci0000:00/0000:00:04.0/usb3/3-4/3-4:1.1/input/input6
[ 2.748693] generic-usb 0003:1BCF:05C2.0002: input,hiddev0,hidraw1: USB HID v1.00 Mouse [MLK RAPOO 1800] on usb-0000:00:04.0-4/input1
[ 2.748769] usbcore: registered new interface driver usbhid
[ 2.748771] usbhid: USB HID core driver
[ 3.370603] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[ 19.827447] <30>udev[382]: starting version 167
[ 19.850844] lp: driver loaded but no devices found
[ 19.893037] Adding 2095100k swap on /dev/sda9. Priority:-1 extents:1 across:2095100k
[ 19.951707] asus_laptop: Asus Laptop Support version 0.42
[ 19.951875] asus_laptop: BSTS called, 0xdd5f returned
[ 19.951889] asus_laptop: K40IE model detected
[ 20.033440] i2c i2c-0: nForce2 SMBus adapter at 0x4d00
[ 20.033447] ACPI: resource nForce2_smbus [io 0x4e00-0x4e3f] conflicts with ACPI region SM00 [io 0x4e00-0x4e3f]
[ 20.033449] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 20.067224] asus_laptop: Backlight controlled by ACPI video driver
[ 20.067326] input: Asus Laptop extra buttons as /devices/platform/asus_laptop/input/input7
[ 20.069402] Registered led device: asus::mail
[ 20.069451] Registered led device: asus::touchpad
[ 20.077333] acpi device:0c: registered as cooling_device2
[ 20.077426] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:09/LNXVIDEO:00/input/input8
[ 20.077498] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 20.087964] EXT4-fs (sda8): re-mounted. Opts: errors=remount-ro
[ 20.174227] type=1400 audit(1312264253.581:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=660 comm="apparmor_parser"
[ 20.174237] type=1400 audit(1312264253.581:3): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=668 comm="apparmor_parser"
[ 20.175084] type=1400 audit(1312264253.581:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=660 comm="apparmor_parser"
[ 20.175097] type=1400 audit(1312264253.581:5): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=668 comm="apparmor_parser"
[ 20.175626] type=1400 audit(1312264253.581:6): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=660 comm="apparmor_parser"
[ 20.175640] type=1400 audit(1312264253.581:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=668 comm="apparmor_parser"
[ 20.251728] Linux video capture interface: v2.00
[ 20.266001] cfg80211: Calling CRDA to update world regulatory domain
[ 20.351007] uvcvideo: Found UVC 1.00 device USB Video Device (174f:1120)
[ 20.392111] input: USB Video Device as /devices/pci0000:00/0000:00:04.1/usb1/1-7/1-7:1.0/input/input9
[ 20.392278] usbcore: registered new interface driver uvcvideo
[ 20.392281] USB Video Class driver (v1.0.0)
[ 20.427848] nvidia: module license 'NVIDIA' taints kernel.
[ 20.427853] Disabling lock debugging due to kernel taint
[ 20.478621] type=1400 audit(1312264253.885:8): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=823 comm="apparmor_parser"
[ 20.484044] psmouse serio4: ID: 10 00 64
[ 20.486394] type=1400 audit(1312264253.893:9): apparmor="STATUS" operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" pid=822 comm="apparmor_parser"
[ 20.498183] type=1400 audit(1312264253.905:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=823 comm="apparmor_parser"
[ 20.498744] type=1400 audit(1312264253.905:11): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=823 comm="apparmor_parser"
[ 20.580211] elantech: assuming hardware version 2, firmware version 4.1.1
[ 20.591269] cfg80211: World regulatory domain updated:
[ 20.591274] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 20.591277] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 20.591280] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 20.591283] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 20.591285] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 20.591288] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 20.629423] elantech: Synaptics capabilities query result 0x7e, 0x13, 0x0d.
[ 21.539643] HDA Intel 0000:00:08.0: power state changed by ACPI to D0
[ 21.539649] HDA Intel 0000:00:08.0: power state changed by ACPI to D0
[ 21.539870] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 23
[ 21.539876] HDA Intel 0000:00:08.0: PCI INT A -> Link[LAZA] -> GSI 23 (level, low) -> IRQ 23
[ 21.539878] hda_intel: Disable MSI for Nvidia chipset
[ 21.539908] HDA Intel 0000:00:08.0: setting latency timer to 64
[ 21.613113] r8169 0000:03:00.0: eth0: link down
[ 21.613120] r8169 0000:03:00.0: eth0: link down
[ 21.614758] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 21.621734] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio4/input/input10
[ 21.643915] ACPI: PCI Interrupt Link [LN4A] enabled at IRQ 18
[ 21.643933] ath9k 0000:04:00.0: PCI INT A -> Link[LN4A] -> GSI 18 (level, low) -> IRQ 18
[ 21.643943] ath9k 0000:04:00.0: setting latency timer to 64
[ 21.694388] ath: EEPROM regdomain: 0x60
[ 21.694390] ath: EEPROM indicates we should expect a direct regpair map
[ 21.694394] ath: Country alpha2 being used: 00
[ 21.694395] ath: Regpair used: 0x60
[ 21.694418] cfg80211: Updating information on frequency 2412 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694421] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694423] cfg80211: Updating information on frequency 2417 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694425] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694428] cfg80211: Updating information on frequency 2422 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694430] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694432] cfg80211: Updating information on frequency 2427 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694435] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694437] cfg80211: Updating information on frequency 2432 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694440] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694442] cfg80211: Updating information on frequency 2437 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694444] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694447] cfg80211: Updating information on frequency 2442 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694449] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694451] cfg80211: Updating information on frequency 2447 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694454] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694456] cfg80211: Updating information on frequency 2452 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694458] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694460] cfg80211: Updating information on frequency 2457 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694463] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694465] cfg80211: Updating information on frequency 2462 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694468] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694470] cfg80211: Updating information on frequency 2467 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694472] cfg80211: 2457000 KHz - 2482000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694475] cfg80211: Updating information on frequency 2472 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694477] cfg80211: 2457000 KHz - 2482000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.694479] cfg80211: Updating information on frequency 2484 MHz for a 20 MHz width channel with regulatory rule:
[ 21.694482] cfg80211: 2474000 KHz - 2494000 KHz @ KHz), (N/A mBi, 2000 mBm)
[ 21.696992] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
[ 21.723320] ieee80211 phy0: Selected rate control algorithm 'ath9k_rate_control'
[ 21.724741] Registered led device: ath9k-phy0::radio
[ 21.724765] Registered led device: ath9k-phy0::assoc
[ 21.724788] Registered led device: ath9k-phy0::tx
[ 21.724813] Registered led device: ath9k-phy0::rx
[ 21.724822] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xf8200000, irq=18
[ 22.276026] hda_codec: ALC269: BIOS auto-probing.
[ 22.600403] input: HDA NVidia Mic as /devices/pci0000:00/0000:00:08.0/sound/card0/input11
[ 22.600541] input: HDA NVidia Headphone as /devices/pci0000:00/0000:00:08.0/sound/card0/input12
[ 22.601085] ACPI: PCI Interrupt Link [LPMU] enabled at IRQ 22
[ 22.601092] nvidia 0000:00:03.5: PCI INT B -> Link[LPMU] -> GSI 22 (level, low) -> IRQ 22
[ 22.601312] ACPI: PCI Interrupt Link [LN0A] enabled at IRQ 17
[ 22.601328] nvidia 0000:02:00.0: PCI INT A -> Link[LN0A] -> GSI 17 (level, low) -> IRQ 17
[ 22.601341] nvidia 0000:02:00.0: setting latency timer to 64
[ 22.601348] vgaarb: device changed decodes: PCI:0000:02:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 22.601634] NVRM: loading NVIDIA UNIX x86 Kernel Module 270.41.06 Mon Apr 18 14:54:25 PDT 2011
[ 22.603031] HDA Intel 0000:02:00.1: PCI INT A -> Link[LN0A] -> GSI 17 (level, low) -> IRQ 17
[ 22.603035] hda_intel: Disable MSI for Nvidia chipset
[ 22.603087] HDA Intel 0000:02:00.1: setting latency timer to 64
[ 23.226872] r8169 0000:03:00.0: eth0: link up
[ 23.227031] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.937224] EXT4-fs (sda8): re-mounted. Opts: errors=remount-ro,commit=0
[ 33.760012] eth0: no IPv6 routers present
[ 199.902328] vesafb: framebuffer at 0xf7000000, mapped to 0xf9480000, using 1216k, total 1216k
[ 199.902332] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 199.902334] vesafb: scrolling: redraw
[ 199.902337] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 199.902507] Console: switching to colour frame buffer device 80x30
[ 199.902521] fb0: VESA VGA frame buffer device
[ 199.929953] ppdev: user-space parallel port driver
[ 199.940787] audit_printk_skb: 24 callbacks suppressed
[ 199.940791] type=1400 audit(1312264433.349:20): apparmor="STATUS" operation="profile_replace" name="/usr/lib/cups/backend/cups-pdf" pid=1307 comm="apparmor_parser"
[ 199.941806] type=1400 audit(1312264433.349:21): apparmor="STATUS" operation="profile_replace" name="/usr/sbin/cupsd" pid=1307 comm="apparmor_parser"
[ 200.115750] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 200.115798] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 200.115853] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 200.115896] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 200.115938] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 200.115980] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 200.116058] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 200.174791] ioremap error for 0x7ffb0000-0x7ffb1000, requested 0x10, got 0x0
[ 204.864999] EXT4-fs (sda8): re-mounted. Opts: errors=remount-ro,commit=0
[ 206.713902] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
[ 2044.079068] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 2044.079115] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 2044.079170] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 2044.079213] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 2044.079255] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 2044.079297] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 2044.079339] ACPI Warning: For \_SB_.PCI0.XVR0.VGA_.NVIF: Excess arguments - needs 2, found 3 (20110112/nspredef-319)
[ 2238.472974] exe (3556): /proc/3556/oom_adj is deprecated, please use /proc/3556/oom_score_adj instead.
[ 3286.231182] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[ 3286.235443] SGI XFS Quota Management subsystem
[ 3286.255172] JFS: nTxBlock = 8192, nTxLock = 65536
[ 3286.287620] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 3286.316737] QNX4 filesystem 0.2.3 registered.
[ 3286.400175] Btrfs loaded
这里一搭陀东西,看不懂,麻烦您帮我看一下咯。
癞蛤蟆
帖子 癞蛤蟆 » 2014-07-27 22:16
我也是,升级后就这样啦,ubuntu kylin
你的世界我曾经来过~~~
帖子 poloshiao » 2014-07-28 7:48
這個訊息出現很多次
檢查看看
/dev/sda 硬盤 電源線 / 訊號線 有沒有 接觸不良 電壓太低 ... 分割區 有問題 等等
另外 許多資訊跟主版 Bios 配置有關
開機 登入 Bios
看看 最後一個標籤 有沒有
reload default 選項
意思是 恢復 出廠設定值
重新設定 Bios
再重新開機
試試
如果你是 Bios 新手
最好找個有經驗的朋友幫你
最後 有一些 acpi 的問題
可能跟你更新後
沒有妥適啟動合適的驅動有關
把下面指令 複製 貼進終端機 執行
sudo lshw -numeric -class video
把結果直接複製 貼上來
