我现在想卸载r语言,rmp -e R不管用,说是没有R
> sudo zypper rm R
root's password:
Loading repository data...
Reading installed packages...
'R' not found in package names. Trying capabilities.
Resolving package dependencies...
The following 34 packages are going to be REMOVED:
R-base R-base-devel R-boot R-class R-cluster R-codetools R-compiler
R-core-devel R-core-packages R-datasets R-foreign R-graphics R-grDevices
R-grid R-KernSmooth R-lattice R-MASS R-Matrix R-Matrix-devel R-methods R-mgcv
R-nlme R-nnet R-parallel R-recommended-packages R-rpart R-spatial R-splines
R-stats R-stats4 R-survival R-tcltk R-tools R-utils
34 packages to remove.
After the operation, 38.2 MiB will be freed.
Continue? [y/n/? shows all options] (y): n
他先说没有找到R,然后Trying capabilities.
Resolving package dependencies...什么意思?
以下34个包,他都要删,(这里应该没问题)但是如果有一个包名字叫R-anything,这个包不属于r语言,他会删掉吗?
总之我想问,他删除这34个R-。。。的包的依据是什么,会不会误删别的软件
还有如果我到r的安装目录下,把文件都删了,这样子,和卸载有什么区别?
