ubuntu16.04.03 LTS 无法识别Inter X520 10Gb网卡
- 系统: ubuntu16.04
服务器版本是ubuntu16.04.03 LTS,安装了Inter X520 10Gb网卡,系统无法识别,求问ubuntun哪个版本集成了这个网卡的驱动,如果单独下载驱动哪里可以下载到?麻烦大神给点帮助
Re: ubuntu16.04.03 LTS 无法识别Inter X520 10Gb网卡
用
看下具体的型号
sudo lshw -C network
- 系统: ubuntu16.04
网卡型号:
*-network:0 DISABLED
product: Ethernet 10G 2P X520 Adapter
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:84:00.0
logical name: enp132s0f0
version: 01
serial: b4:96:91:1e:e9:7c
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress vpd bus_master cap_list rom ethernet physical fibre 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=ixgbe driverversion=4.2.1-k firmware=0x800008bd latency=0 link=no multicast=yes port=fibre
resources: irq:79 memory:c8100000-c81fffff ioport:8020(size=32) memory:c8204000-c8207fff memory:c8280000-c82fffff memory:3c000000000-3c0000fffff memory:3c000100000-3c0001fffff
*-network:1 DISABLED
physical id: 0.1
bus info: pci@0000:84:00.1
logical name: enp132s0f1
version: 01
serial: b4:96:91:1e:e9:7e
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress vpd bus_master cap_list ethernet physical fibre 1000bt-fd autonegotiation
resources: irq:113 memory:c8000000-c80fffff ioport:8000(size=32) memory:c8200000-c8203fff memory:3c000200000-3c0002fffff memory:3c000300000-3c0003fffff
机器型号: dell poweredge r730
问了dell厂商,730官方支持列表里是没有ubuntu的,740才支持,不知道是不是硬件问题
