安装windows10和ubuntu双系统,ubuntu未发现wifi适配器
乌邦小白
系统: windows10+ubuntu18.0
帖子 乌邦小白 » 2018-07-15 0:19
各位高手们,请教一下,在windows10下连接网络没有任何问题,但是在ubuntu下却不能发现wifi适配器,我看了几个帖子,但是看不太懂,我电脑是惠普暗影精灵3,我运行了下面4个命令,向高手们请教一下是什么原因。谢谢。
zhoubin@zb-computer:~$ uname -a
Linux zb-computer 4.15.0-23-generic #25-Ubuntu SMP Wed May 23 18:02:16 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
zhoubin@zb-computer:~$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:01.0 PCI bridge: Intel Corporation Skylake PCIe Controller (x16) (rev 05)
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04)
00:04.0 Signal processing controller: Intel Corporation Skylake Processor Thermal Subsystem (rev 05)
00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-H Serial IO I2C Controller #0 (rev 31)
00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31)
00:17.0 SATA controller: Intel Corporation Sunrise Point-H SATA Controller [AHCI mode] (rev 31)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #6 (rev f1)
00:1c.6 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #7 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31)
00:1f.3 Audio device: Intel Corporation CM238 HD Audio Controller (rev 31)
00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31)
01:00.0 VGA compatible controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Ti Mobile] (rev a1)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
04:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b822
05:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
06:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961
zhoubin@zb-computer:~$ sudo lshw -C network
[sudo] zhoubin 的密码:
*-network
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 16
serial: 48:ba:4e:47:55:5c
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=124.16.109.46 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:130 ioport:c000(size=256) memory:dfe04000-dfe04fff memory:dfe00000-dfe03fff
*-network UNCLAIMED
product: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:04:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: ioport:b000(size=256) memory:dfd00000-dfd0ffff
zhoubin@zb-computer:~$ iwconfig
enp3s0 no wireless extensions.
lo no wireless extensions.
oneleaf
论坛管理员
系统: Ubuntu 12.04
Re: 安装windows10和ubuntu双系统,ubuntu未发现wifi适配器
帖子 oneleaf » 2018-07-15 11:03
sudo apt-get update
sudo apt-get purge bcmwl-kernel-source
sudo apt-get install linux-generic bcmwl-kernel-source
执行后重启试试看。
乌邦小白
帖子 乌邦小白 » 2018-07-15 21:28
大神,不行诶,我三个代码都打了,重启后还是未发现适配器。
oneleaf
论坛管理员
系统: Ubuntu 12.04
帖子 oneleaf » 2018-07-16 9:58
那就反过来,试试
sudo apt-get remove bcmwl-kernel-source
echo "blacklist ssb" | sudo tee -a /etc/modprobe.d/blacklist.conf
echo "blacklist b43" | sudo tee -a /etc/modprobe.d/blacklist.conf
乌邦小白
帖子 乌邦小白 » 2018-07-16 22:59
还是不行诶。重启了还是显示“未发现wifi适配器,请确认你已插入wifi适配器并打开。“
乌邦小白
帖子 乌邦小白 » 2018-07-16 23:00
哦哦,还有,我在附加驱动里只有显卡的驱动,其他的啥都没有。
onlylove
帖子 onlylove » 2018-07-16 23:47
应该是这个
Realtek 8822BE Wireless LAN 802.11ac PCI-E NIC
这个在4.14里面已经支持了啊……你kernel是4.15,应该是没问题的,想不通为什么……
去realtek网站搜了下,8822be居然俩版本,RTL8822BE和RTL8822BEH-VR,果然rtl一贯作风
看看这个能用不吧……
https://blog.csdn.net/sbqwww2011/articl ... s/80033962
https://github.com/torvalds/linux/tree/ ... /rtl8822be
乌邦小白
帖子 乌邦小白 » 2018-07-17 19:54
结果显示这个。。。。算了,我还是用手机开USB网络共享吧。
zhoubin@zb:~/rtlwifi-next/rtlwifi-next$ sudo modprobe -rv rtl8822be
modprobe: FATAL: Module rtl8822be not found.
tianyuan008
帖子 tianyuan008 » 2019-01-22 12:50
这篇文章解决了这个问题,很简单
https://blog.csdn.net/biggoodloong/arti ... s/81038922
其中第三种方法,安装后,先点工具栏上的“打开Wi-Fi”按钮,而后点刷新,就能看见你所需要的无线网络了
