ubuntu16.04无法链接wifi
zhidadiyu
系统: ubuntu16.04LST
ubuntu16.04无法链接wifi
帖子 zhidadiyu » 2018-07-08 22:12
这个是详细信息
########## wireless info START ##########
Report from: 08 Jul 2018 19:58 CST +0800
Booted last: 08 Jul 2018 00:00 CST +0800
Script from: 10 Jan 2018 20:04 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
##### kernel ############################
Linux 4.15.0-25-generic #27~16.04.1-Ubuntu SMP Mon Jul 2 17:05:41 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
libkmod: ERROR ../libkmod/libkmod-config.c:635 kmod_config_parse: /etc/modprobe.d/asus_nb_wmi.conf line 1: ignoring bad line starting with '“options'
03:00.0 Network controller [0280]: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01)
Subsystem: AzureWave AW-NB037H 802.11bgn Wireless Half-size Mini PCIe Card [AR9002WB-1NGCD] [1a3b:2c37]
Kernel driver in use: ath9k
05:00.0 Ethernet controller [0200]: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet [1969:1083] (rev c0)
Subsystem: ASUSTeK Computer Inc. AR8151 v2.0 Gigabit Ethernet [1043:1851]
Kernel driver in use: atl1c
##### lsusb #############################
Bus 002 Device 003: ID 1bcf:0005 Sunplus Innovation Technology Inc. Optical Mouse
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 1bcf:2883 Sunplus Innovation Technology Inc.
Bus 001 Device 003: ID 0cf3:3005 Atheros Communications, Inc. AR3011 Bluetooth
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
##### PCMCIA card info ##################
##### rfkill ############################
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
1: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
2: asus-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
3: asus-bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
##### lsmod #############################
asus_nb_wmi 28672 0
asus_wmi 28672 1 asus_nb_wmi
sparse_keymap 16384 1 asus_wmi
mxm_wmi 16384 0
wl 6447104 0
ath9k 151552 0
ath9k_common 36864 1 ath9k
ath9k_hw 475136 2 ath9k,ath9k_common
ath 28672 3 ath9k_hw,ath9k,ath9k_common
mac80211 778240 1 ath9k
cfg80211 622592 5 wl,mac80211,ath9k,ath,ath9k_common
wmi 24576 2 asus_wmi,mxm_wmi
video 45056 2 asus_wmi,i915
##### interfaces ########################
[/etc/network/interfaces]
auto lo
iface lo inet loopback
##### ifconfig ##########################
enp5s0 Link encap:Ethernet HWaddr <MAC 'enp5s0' [IF1]>
inet addr:192.168.3.167 Bcast:192.168.3.255 Mask:255.255.255.0
inet6 addr: fe80::1b23:cb79:bd97:61b5/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4874 errors:0 dropped:1 overruns:0 frame:0
TX packets:5663 errors:0 dropped:0 overruns:0 carrier:1
collisions:0 txqueuelen:1000
RX bytes:2873898 (2.8 MB) TX bytes:1003772 (1.0 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:539 errors:0 dropped:0 overruns:0 frame:0
TX packets:539 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:68193 (68.1 KB) TX bytes:68193 (68.1 KB)
wlp3s0 Link encap:Ethernet HWaddr <MAC 'wlp3s0' [IF2]>
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
##### iwconfig ##########################
lo no wireless extensions.
enp5s0 no wireless extensions.
wlp3s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=off
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.3.1 0.0.0.0 UG 100 0 0 enp5s0
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 enp5s0
192.168.3.0 0.0.0.0 255.255.255.0 U 100 0 0 enp5s0
##### resolv.conf #######################
nameserver 127.0.1.1
search lan
##### network managers ##################
Installed:
NetworkManager
Wicd
Running:
root 951 1 0 19:51 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
##### NetworkManager info ###############
GENERAL.DEVICE: enp5s0
GENERAL.TYPE: ethernet
GENERAL.NM-TYPE: NMDeviceEthernet
GENERAL.VENDOR: Qualcomm Atheros
GENERAL.PRODUCT: AR8151 v2.0 Gigabit Ethernet
GENERAL.DRIVER: atl1c
GENERAL.DRIVER-VERSION: 1.0.1.1-NAPI
GENERAL.FIRMWARE-VERSION:
GENERAL.HWADDR: <MAC 'enp5s0' [IF1]>
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.REASON: 0 (No reason given)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/enp5s0
GENERAL.IP-IFACE: enp5s0
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: Wired connection 1
GENERAL.CON-UUID: e13c49cb-8feb-3da5-8ad4-0a78a7aff6d2
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/0
GENERAL.METERED: no (guessed)
CAPABILITIES.CARRIER-DETECT: yes
CAPABILITIES.SPEED: 100 Mb/s
CAPABILITIES.IS-SOFTWARE: no
WIRED-PROPERTIES.CARRIER: on
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{0}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: e13c49cb-8feb-3da5-8ad4-0a78a7aff6d2 | Wired connection 1
IP4.ADDRESS[1]: 192.168.3.167/24
IP4.GATEWAY: 192.168.3.1
IP4.ROUTE[1]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP4.DNS[1]: 192.168.3.1
IP4.DOMAIN[1]: lan
DHCP4.OPTION[1]: requested_subnet_mask = 1
DHCP4.OPTION[2]: requested_rfc3442_classless_static_routes = 1
DHCP4.OPTION[3]: subnet_mask = 255.255.255.0
DHCP4.OPTION[4]: domain_name_servers = 192.168.3.1
DHCP4.OPTION[5]: ip_address = 192.168.3.167
DHCP4.OPTION[6]: requested_static_routes = 1
DHCP4.OPTION[7]: dhcp_server_identifier = 192.168.3.1
DHCP4.OPTION[8]: requested_time_offset = 1
DHCP4.OPTION[9]: broadcast_address = 192.168.3.255
DHCP4.OPTION[10]: requested_interface_mtu = 1
DHCP4.OPTION[11]: dhcp_rebinding_time = 6300
DHCP4.OPTION[12]: requested_domain_name_servers = 1
DHCP4.OPTION[13]: dhcp_message_type = 5
DHCP4.OPTION[14]: requested_broadcast_address = 1
DHCP4.OPTION[15]: routers = 192.168.3.1
DHCP4.OPTION[16]: dhcp_renewal_time = 3600
DHCP4.OPTION[17]: requested_domain_name = 1
DHCP4.OPTION[18]: domain_name = lan
DHCP4.OPTION[19]: requested_routers = 1
DHCP4.OPTION[20]: expiry = 1531057914
DHCP4.OPTION[21]: host_name = zheng
DHCP4.OPTION[22]: requested_netbios_scope = 1
DHCP4.OPTION[23]: requested_wpad = 1
DHCP4.OPTION[24]: requested_ms_classless_static_routes = 1
DHCP4.OPTION[25]: requested_netbios_name_servers = 1
DHCP4.OPTION[26]: network_number = 192.168.3.0
DHCP4.OPTION[27]: requested_domain_search = 1
DHCP4.OPTION[28]: next_server = 192.168.3.1
DHCP4.OPTION[29]: requested_ntp_servers = 1
DHCP4.OPTION[30]: requested_host_name = 1
DHCP4.OPTION[31]: dhcp_lease_time = 7200
IP6.ADDRESS[1]: fe80::1b23:cb79:bd97:61b5/64
IP6.GATEWAY:
GENERAL.DEVICE: wlp3s0
GENERAL.TYPE: wifi
GENERAL.NM-TYPE: NMDeviceWifi
GENERAL.PRODUCT: AR9285 Wireless Network Adapter (PCI-Express) (AW-NB037H 802.11bgn Wireless Half-size Mini PCIe Card [AR9002WB-1NGCD])
GENERAL.DRIVER: ath9k
GENERAL.DRIVER-VERSION: 4.15.0-25-generic
GENERAL.FIRMWARE-VERSION: N/A
GENERAL.HWADDR: <MAC 'wlp3s0' [IF2]>
GENERAL.MTU: 1500
GENERAL.STATE: 20 (unavailable)
GENERAL.REASON: 2 (Device is now managed)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/net/wlp3s0
GENERAL.IP-IFACE:
GENERAL.CONNECTION: --
GENERAL.CON-UUID: --
GENERAL.CON-PATH: --
GENERAL.METERED: unknown
CAPABILITIES.CARRIER-DETECT: no
CAPABILITIES.SPEED: unknown
WIFI-PROPERTIES.WEP: yes
WIFI-PROPERTIES.WPA: yes
WIFI-PROPERTIES.WPA2: yes
WIFI-PROPERTIES.TKIP: yes
WIFI-PROPERTIES.CCMP: yes
WIFI-PROPERTIES.AP: yes
WIFI-PROPERTIES.ADHOC: yes
WIFI-PROPERTIES.2GHZ: yes
WIFI-PROPERTIES.5GHZ: no
SSID BSSID MODE CHAN FREQ RATE SIGNAL BARS SECURITY ACTIVE *
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
##### Netplan config ####################
##### iw reg get ########################
Region: Asia/Shanghai (based on set time zone)
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
##### iwlist channels ###################
lo no frequency information.
enp5s0 no frequency information.
wlp3s0 14 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Channel 14 : 2.484 GHz
##### iwlist scan #######################
lo Interface doesn't support scanning.
wlp3s0 Interface doesn't support scanning : Network is down
enp5s0 Interface doesn't support scanning.
##### module infos ######################
[wl]
filename: /lib/modules/4.15.0-25-generic/updates/dkms/wl.ko
license: MIXED/Proprietary
srcversion: 00D38A27B7E3C7B97C238FC
depends: cfg80211
retpoline: Y
vermagic: 4.15.0-25-generic SMP mod_unload
parm: passivemode:int
parm: wl_txq_thresh:int
parm: oneonly:int
parm: piomode:int
parm: instance_base:int
parm: nompc:int
parm: intf_name:string
[ath9k]
filename: /lib/modules/4.15.0-25-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k.ko
license: Dual BSD/GPL
description: Support for Atheros 802.11n wireless LAN cards.
author: Atheros Communications
srcversion: F4328CE52BA6067DD4EDE7B
depends: mac80211,ath9k_hw,ath9k_common,cfg80211,ath
retpoline: Y
intree: Y
parm: debug:Debugging mask (uint)
parm: nohwcrypt:Disable hardware encryption (int)
parm: blink:Enable LED blink on activity (int)
parm: led_active_high:Invert LED polarity (int)
parm: btcoex_enable:Enable wifi-BT coexistence (int)
parm: bt_ant_diversity:Enable WLAN/BT RX antenna diversity (int)
parm: ps_enable:Enable WLAN PowerSave (int)
parm: use_chanctx:Enable channel context for concurrency (int)
parm: use_msi:Use MSI instead of INTx if possible (int)
[ath9k_common]
filename: /lib/modules/4.15.0-25-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
description: Shared library for Atheros wireless 802.11n LAN cards.
srcversion: 94213E6B06C24095311E862
depends: ath9k_hw,cfg80211,ath
retpoline: Y
intree: Y
[ath9k_hw]
filename: /lib/modules/4.15.0-25-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
srcversion: D5984DFEF6457DDB060988E
depends: ath
retpoline: Y
intree: Y
[ath]
filename: /lib/modules/4.15.0-25-generic/kernel/drivers/net/wireless/ath/ath.ko
description: Shared library for Atheros wireless LAN cards.
srcversion: 555BBBB9D4FCA58A05E7C0D
depends: cfg80211
retpoline: Y
intree: Y
[mac80211]
filename: /lib/modules/4.15.0-25-generic/kernel/net/mac80211/mac80211.ko
license: GPL
description: IEEE 802.11 subsystem
srcversion: 1CEA5CF286EDB289C1D0BF8
depends: cfg80211
retpoline: Y
intree: Y
parm: minstrel_vht_only:Use only VHT rates when VHT is supported by sta. (bool)
parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211]
filename: /lib/modules/4.15.0-25-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: D5B0789D4C423C81CCFB437
depends:
retpoline: Y
intree: Y
parm: bss_entries_limit:limit to number of scan BSS entries (per wiphy, default 1000) (int)
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[ath9k]
blink: 0
bt_ant_diversity: 0
btcoex_enable: 0
led_active_high: -1
nohwcrypt: 0
ps_enable: 0
use_chanctx: 0
use_msi: 0
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
minstrel_vht_only: Y
probe_wait_ms: 500
[cfg80211]
bss_entries_limit: 1000
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
##### modprobe options ##################
[/etc/modprobe.d/amd64-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/asus_nb_wmi.conf]
“options asus_nb_wmi wapf=4”
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist-bcm43.conf]
blacklist b43
blacklist b43legacy
blacklist ssb
blacklist bcm43xx
blacklist brcm80211
blacklist brcmfmac
blacklist brcmsmac
blacklist bcma
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
##### dmesg #############################
[ 11.679078] ath: phy0: Set BT/WLAN RX diversity capability
[ 11.728882] ath: phy0: ASPM enabled: 0x42
[ 11.728883] ath: EEPROM regdomain: 0x60
[ 11.728884] ath: EEPROM indicates we should expect a direct regpair map
[ 11.728885] ath: Country alpha2 being used: 00
[ 11.728886] ath: Regpair used: 0x60
[ 13.738764] ath9k 0000:03:00.0 wlp3s0: renamed from wlan0
[ 27.735554] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 27.796428] IPv6: ADDRCONF(NETDEV_UP): enp5s0: link is not ready
[ 27.797169] atl1c 0000:05:00.0: atl1c: enp5s0 NIC Link is Up<100 Mbps Full Duplex>
########## wireless info END ############
Re: ubuntu16.04无法链接wifi
帖子 astolia » 2018-07-09 17:56
你从哪里的文章上看到的配置文件的修改方法?你完全弄错了
/etc/modprobe.d/asus_nb_wmi.conf 里面不应该有引号
/etc/modprobe.d/iwlwifi.conf 的内容也是错的
wifi无法用是因为网卡没启用
你还改了哪些东西?
zhidadiyu
系统: ubuntu16.04LST
帖子 zhidadiyu » 2018-07-10 11:20
astolia 写了: 2018-07-09 17:56 你从哪里的文章上看到的配置文件的修改方法?你完全弄错了
wifi无法用是因为网卡没启用
你还改了哪些东西?
谢谢您的回复,我的问题已经解决了,我的驱动已经装好了,只是原因是我没有开启wifi的硬件开关。
zhidadiyu
系统: ubuntu16.04LST
帖子 zhidadiyu » 2018-07-10 11:28
谢谢您的回复,我的问题已经解决了,顺便给后来的朋友和我一样遇到这个问题的朋友说下怎么解决的,实际上在安装Ubuntu的pool文件夹里就有大部分网卡驱动的安装包,之前我一直安装不上去实际上是因为自带的那个驱动已经过时,其实只用到Ubuntu官网里下载最新的bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu4_amd64.deb,这个包就可以解决大部分网卡的问题,sudo dpkg -i 安装包就可以了.如果还有朋友不明白的如果我能帮助到大家可以给我邮箱留言zhi_da_di_yu@163.com
