求助 Ubuntu 17.10 安装Ralink MT7601U驱动(TPlink WN726 免驱版)
carlchen1984
系统: ubuntu 17.10
帖子 carlchen1984 » 2018-03-10 20:19
安装ubuntu 17.10时,网卡可以正常识别和使用,但是系统升级以后就无法识别了,和上回安装linux mint一样的现象,安装网上的办法重新编译和安装了驱动都没有效果,求助一下还有什么好的办法
carl@carlchen:~$ uname -r
4.13.0-36-generic
carl@carlchen:~$ lsusb
Bus 002 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 012: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
carl@carlchen:~$ lsmod | grep mt
mt7601u               102400  0
mac80211              782336  1 mt7601u
cfg80211              614400  2 mac80211,mt7601u
carl@carlchen:~$ sudo lshw -C network
  *-network
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: enp3s0
       version: 06
       serial: 8c:89:a5:c1:a4:1b
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.0.101 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:26 ioport:d000(size=256) memory:f7104000-f7104fff memory:f7100000-f7103fff
感觉识别成了usb,但是没有识别成网卡,还是网卡驱动问题吧,但是更新驱动以后还是无效,怎么解决啊?
