求大神指点Ubuntu16.04电脑能够链接WiFi,但是火狐浏览器却打不开网页
- 系统: linux和windows
1 网页显示找不到服务器
2 ping www.baidu.com 显示ping:unknown host www.baidu.com
3 wifi链接信息 ipv4
IP地址 192.168.0.104
广播地址 192.168.0.255
子网掩码 255.255.255.0
默认路由 192.168.0.1
用的是邻居家的WiFi
4 用有线宽带也是如此
3 wifi链接信息 ipv4
IP地址 192.168.0.104
广播地址 192.168.0.255
子网掩码 255.255.255.0
默认路由 192.168.0.1
用的是邻居家的WiFi
4 用有线宽带也是如此
Re: 求大神指点Ubuntu16.04电脑能够链接WiFi,但是火狐浏览器却打不开网页
执行以下指令将结果全部复制贴上来
uname -a
cat /etc/issue
sudo lshw -numeric -C net
sudo ls -l /etc/resolv.conf
sudo cat /etc/resolv.conf
sudo cat /etc/NetworkManager/NetworkManager.conf
dpkg -l | grep 'dnsmasq\|resolv'
ping -c3 114.114.114.114
ping -c3 www.sohu.com
- 系统: linux和windows
mickerhao@mickerhao-Da-Mai-III:~$ uname -a
Linux mickerhao-Da-Mai-III 4.10.0-28-generic #32~16.04.2-Ubuntu SMP Thu Jul 20 10:19:48 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
mickerhao@mickerhao-Da-Mai-III:~$ cat /ect/issue
cat: /ect/issue: 没有那个文件或目录
mickerhao@mickerhao-Da-Mai-III:~$ sudo lshw -numeric -C net
[sudo] mickerhao 的密码:
*-network
product: Wireless 3160 [8086:8B3]
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 83
serial: 00:1e:64:d2:02:c1
width: 64 bits
clock: 33MHz
configuration: broadcast=yes driver=iwlwifi driverversion=4.10.0-28-generic firmware=17.459231.0 ip=192.168.0.104 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:50 memory:e2200000-e2201fff
*-network
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 0c
serial: 543a:5d:05:19
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-2_0.0.1 02/06/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:45 ioport:4000(size=256) memory:e2100000-e2100fff memory:e2000000-e2003fff
mickerhao@mickerhao-Da-Mai-III:~$ sudo ls -l /etc/resolv.conf
lrwxrwxrwx 1 root root 29 8月 22 08:47 /etc/resolv.conf -> ../run/resolvconf/resolv.conf
mickerhao@mickerhao-Da-Mai-III:~$ sudo cat /etc/resolv.conf
nameserver 127.0.1.1
mickerhao@mickerhao-Da-Mai-III:~$ sudo cat /etc/NetworkManager/NetworkManager.conf
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
mickerhao@mickerhao-Da-Mai-III:~$ dpkg -l | grep 'dnsmasq\|resolv'
ii dnsmasq-base 2.75-1ubuntu0.16.04.2 amd64 Small caching DNS proxy and DHCP/TFTP server
ii libgeoip1:amd64 1.6.9-1 amd64 non-DNS IP-to-country resolver library
ii resolvconf 1.78ubuntu4 all name server information handler
mickerhao@mickerhao-Da-Mai-III:~$ ping -c3 114.114.114.114
PING 114.114.114.114 (114.114.114.114) 56(84) bytes of data.
64 bytes from 114.114.114.114: icmp_seq=1 ttl=95 time=18.0 ms
64 bytes from 114.114.114.114: icmp_seq=2 ttl=87 time=17.0 ms
64 bytes from 114.114.114.114: icmp_seq=3 ttl=91 time=16.4 ms
--- 114.114.114.114 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 16.464/17.159/18.009/0.640 ms
mickerhao@mickerhao-Da-Mai-III:~$ ping -c3 www.sohu.com
PING fzz.a.sohu.com (61.158.246.131) 56(84) bytes of data.
64 bytes from 131.246.158.61.ha.cnc (61.158.246.131): icmp_seq=1 ttl=57 time=11.2 ms
64 bytes from 131.246.158.61.ha.cnc (61.158.246.131): icmp_seq=2 ttl=57 time=10.6 ms
64 bytes from 131.246.158.61.ha.cnc (61.158.246.131): icmp_seq=3 ttl=57 time=10.6 ms
--- fzz.a.sohu.com ping statistics ---
rtt min/avg/max/mdev = 10.623/10.861/11.262/0.297 ms
就在我回复你刚刚,火狐浏览器莫名其妙的能够上百度,就如同今天凌晨上网正嗨之时,莫名其妙的找不到服务器,不知其中何故?还请大神解答疑惑。
*-network
physical id: 0
version: 83
width: 64 bits
clock: 33MHz
*-network
physical id: 0
version: 0c
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
[main]
dns=dnsmasq
[ifupdown]
managed=false
您可以尝试编辑 /etc/NetworkManager/NetworkManager.conf,在 dns=dnsmasq 这一行的开头加上 # 符号,将其注释掉。
然后,在 NetworkManager “编辑连接”的图形界面中选择 Automatic (DHCP) addresses only,然后填入固定的 DNS 服务器,例如 114.114.114.114,如下图所示
这样,当您重新启动计算机或重新启动 NetworkManager 后,您会发现 /etc/resolv.conf 变成了这样
以上是猜测,不一定正确
lu@lu-X455LD:~$ cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 114.114.114.114
- 系统: linux和windows
我没有权限更改,现在我正在为获得权限而绞尽脑汁
我按照这篇文章http://blog.csdn.net/sunxiaoju/article/details/51993091
试图获取root权限,就差最后一步,不知该怎么搞
- 系统: linux和windows
刚刚又莫名其妙的找不到服务器了
您不需要启用 root 用户。您只需使用 sudo 或 gksu (需安装) 命令启动文本编辑器编辑文件即可。例如使用 sudo nano /etc/NetworkManager/NetworkManager.conf,编辑后按 Ctrl-x,y,回车保存退出Micker Hao 写了:我没有权限更改,现在我正在为获得权限而绞尽脑汁
- 系统: linux和windows
我用终端试图打开cat /etc/resolv.conf
却显示找不到文件目录
却显示找不到文件目录
执行以下指令将结果全部复制贴上来Micker Hao 写了:我用终端试图打开cat /etc/resolv.conf却显示找不到文件目录
sudo cat /var/run/NetworkManager/resolv.conf
- 系统: linux和windows
nameserver 8.8.8.8
nameserver 8.8.4.4
mickerhao@mickerhao-Da-Mai-III:~$ sudo cat /var/run/NetworkManager/resolv.conf
nameserver 8.8.8.8
[main]
#dns=dnsmasq
[ifupdown]
managed=false
64 bytes from 114.114.114.114: icmp_seq=1 ttl=75 time=192 ms
64 bytes from 114.114.114.114: icmp_seq=2 ttl=83 time=25.1 ms
64 bytes from 114.114.114.114: icmp_seq=3 ttl=72 time=259 ms
rtt min/avg/max/mdev = 25.114/159.009/259.345/98.524 ms
64 bytes from 131.246.158.61.ha.cnc (61.158.246.131): icmp_seq=1 ttl=57 time=20.0 ms
64 bytes from 131.246.158.61.ha.cnc (61.158.246.131): icmp_seq=2 ttl=57 time=10.7 ms
64 bytes from 131.246.158.61.ha.cnc (61.158.246.131): icmp_seq=3 ttl=57 time=107 ms
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 10.729/46.241/107.978/43.818 ms
nameserver 8.8.8.8
nameserver 8.8.4.4
nameserver 8.8.8.8
[main]
#dns=dnsmasq
[ifupdown]
managed=false
现在还有问题吗?
可以把 DNS 换成国内的
可以把 DNS 换成国内的
- 系统: linux和windows
没问题啦,但是翻墙工具却打不开网页啦,为什麽?我用的是shadowsocks-qt5 翻墙的
用手机客户端连接试试,看问题出在哪个环节。Micker Hao 写了:没问题啦,但是翻墙工具却打不开网页啦,为什麽?我用的是shadowsocks-qt5 翻墙的
- 系统: linux和windows
- 系统: linux和windows
我用翻墙工具试图打开google,但网页一直是空白页,左下角一直显示等待www.google.com或正在与google握手,长时间都是空白,没有任何显示
