uname -r
4.8.0-58-generic
sudo lspci -knn
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:5910] (rev 05)
Subsystem: Dell Device [1028:0798]
00:01.0 PCI bridge [0604]: Intel Corporation Sky Lake PCIe Controller (x16) [8086:1901] (rev 05)
Kernel modules: shpchp
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:591b] (rev 04)
DeviceName: Onboard IGD
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller [1180]: Intel Corporation Skylake Processor Thermal Subsystem [8086:1903] (rev 05)
Subsystem: Dell Skylake Processor Thermal Subsystem [1028:0798]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:14.0 USB controller [0c03]: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller [8086:a12f] (rev 31)
Subsystem: Dell Sunrise Point-H USB 3.0 xHCI Controller [1028:0798]
00:14.2 Signal processing controller [1180]: Intel Corporation Sunrise Point-H Thermal subsystem [8086:a131] (rev 31)
Subsystem: Dell Sunrise Point-H Thermal subsystem [1028:0798]
00:15.0 Signal processing controller [1180]: Intel Corporation Sunrise Point-H LPSS I2C Controller #0 [8086:a160] (rev 31)
Subsystem: Dell Sunrise Point-H Serial IO I2C Controller [1028:0798]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Signal processing controller [1180]: Intel Corporation Sunrise Point-H LPSS I2C Controller #1 [8086:a161] (rev 31)
00:16.0 Communication controller [0780]: Intel Corporation Sunrise Point-H CSME HECI #1 [8086:a13a] (rev 31)
Subsystem: Dell Sunrise Point-H CSME HECI [1028:0798]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 RAID bus controller [0104]: Intel Corporation 82801 Mobile SATA Controller [RAID mode] [8086:282a] (rev 31)
Subsystem: Dell 82801 Mobile SATA Controller [RAID mode] [1028:0798]
Kernel driver in use: ahci
Kernel modules: ahci
00:1c.0 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #5 [8086:a114] (rev f1)
00:1c.5 PCI bridge [0604]: Intel Corporation Sunrise Point-H PCI Express Root Port #6 [8086:a115] (rev f1)
00:1f.0 ISA bridge [0601]: Intel Corporation Sunrise Point-H LPC Controller [8086:a152] (rev 31)
Subsystem: Dell Sunrise Point-H LPC Controller [1028:0798]
00:1f.2 Memory controller [0580]: Intel Corporation Sunrise Point-H PMC [8086:a121] (rev 31)
Subsystem: Dell Sunrise Point-H PMC [1028:0798]
00:1f.3 Audio device [0403]: Intel Corporation Device [8086:a171] (rev 31)
Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-H SMBus [8086:a123] (rev 31)
Subsystem: Dell Sunrise Point-H SMBus [1028:0798]
Kernel modules: i2c_i801
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1c8c] (rev a1)
Kernel modules: nvidiafb, nouveau
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: Dell RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1028:0798]
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Network controller [0280]: Intel Corporation Wireless 3165 [8086:3165] (rev 79)
Subsystem: Intel Corporation Wireless 3165 [8086:4410]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
sudo lshw -numeric -class network
*-network
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 15
serial: d4:81:d7:89:40:ab
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:125 ioport:d000(size=256) memory:d5104000-d5104fff memory:d5100000-d5103fff
*-network
product: Wireless 3165 [8086:3165]
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 79
serial: 70:1c:e7:84:79:8e
width: 64 bits
clock: 33MHz
configuration: broadcast=yes driver=iwlwifi driverversion=4.8.0-58-generic firmware=22.391740.0 ip=192.168.1.113 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:129 memory:d5000000-d5001fff
sudo ifconfig -a
enp2s0 Link encap:以太网 硬件地址 d4:81:d7:89:40:ab
inet6 地址: fe80::1791:de1c:4034:87b7/64 Scope:Link
接收数据包:685 错误:0 丢弃:0 过载:0 帧数:0
发送数据包:1308 错误:0 丢弃:0 过载:0 载波:0
碰撞:0 发送队列长度:1000
接收字节:139794 (139.7 KB) 发送字节:185374 (185.3 KB)
enp2s0:avahi Link encap:以太网 硬件地址 d4:81:d7:89:40:ab
inet 地址:169.254.9.34 广播:169.254.255.255 掩码:255.255.0.0
lo Link encap:本地环回
inet6 地址: ::1/128 Scope:Host
接收数据包:8440 错误:0 丢弃:0 过载:0 帧数:0
发送数据包:8440 错误:0 丢弃:0 过载:0 载波:0
碰撞:0 发送队列长度:1
接收字节:2276669 (2.2 MB) 发送字节:2276669 (2.2 MB)
ppp0 Link encap:点对点协议
inet 地址:100.69.166.171 点对点:100.69.128.1 掩码:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 跃点数:1
接收数据包:277 错误:0 丢弃:0 过载:0 帧数:0
发送数据包:456 错误:0 丢弃:0 过载:0 载波:0
碰撞:0 发送队列长度:3
接收字节:40243 (40.2 KB) 发送字节:74651 (74.6 KB)
wlp3s0 Link encap:以太网 硬件地址 70:1c:e7:84:79:8e
UP BROADCAST MULTICAST MTU:1500 跃点数:1
接收数据包:9973 错误:0 丢弃:0 过载:0 帧数:0
发送数据包:9099 错误:0 丢弃:0 过载:0 载波:0
碰撞:0 发送队列长度:1000
接收字节:5346548 (5.3 MB) 发送字节:1577558 (1.5 MB)
wlp3s0:avahi Link encap:以太网 硬件地址 70:1c:e7:84:79:8e
inet 地址:169.254.9.33 广播:169.254.255.255 掩码:255.255.0.0
sudo route -nv
内核 IP 路由表
目标 网关 子网掩码 标志 跃点 引用 使用 接口
0.0.0.0 100.69.128.1 0.0.0.0 UG 100 0 0 ppp0
0.0.0.0 0.0.0.0 0.0.0.0 U 1002 0 0 enp2s0
0.0.0.0 0.0.0.0 0.0.0.0 U 1003 0 0 wlp3s0
100.69.128.1 0.0.0.0 255.255.255.255 UH 100 0 0 ppp0
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 enp2s0
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 wlp3s0
sudo dhclient -v
Internet Systems Consortium DHCP Client 4.3.3
Copyright 2004-2015 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlp3s0/70:1c:e7:84:79:8e
Sending on LPF/wlp3s0/70:1c:e7:84:79:8e
Listening on LPF/enp2s0/d4:81:d7:89:40:ab
Sending on LPF/enp2s0/d4:81:d7:89:40:ab
Sending on Socket/fallback
DHCPREQUEST of 192.168.1.113 on wlp3s0 to 255.255.255.255 port 67 (xid=0xca3815)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 3 (xid=0x6ed82757)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 5 (xid=0x6ed82757)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 13 (xid=0x6ed82757)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 3 (xid=0x8496a317)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 7 (xid=0x8496a317)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 13 (xid=0x8496a317)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 9 (xid=0x8496a317)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 10 (xid=0x6ed82757)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 10 (xid=0x8496a317)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 21 (xid=0x6ed82757)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 9 (xid=0x6ed82757)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 11 (xid=0x8496a317)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 15 (xid=0x6ed82757)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 11 (xid=0x6ed82757)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 12 (xid=0x8496a317)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 21 (xid=0x8496a317)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 8 (xid=0x8496a317)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 20 (xid=0x6ed82757)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 20 (xid=0x8496a317)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 7 (xid=0x6ed82757)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 8 (xid=0x6ed82757)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 18 (xid=0x8496a317)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 12 (xid=0x6ed82757)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 17 (xid=0x8496a317)
DHCPDISCOVER on wlp3s0 to 255.255.255.255 port 67 interval 14 (xid=0x8496a317)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 18 (xid=0x6ed82757)
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
DHCPREQUEST of 192.168.1.113 on wlp3s0 to 255.255.255.255 port 67 (xid=0x22262260)
DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 3 (xid=0xc88b7a31)
DHCPACK of 192.168.1.113 from 192.168.1.1
RTNETLINK answers: File exists
bound to 192.168.1.113 -- renewal in 3022 seconds.
sudo cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
sudo ls -al /etc/resolv.conf
lrwxrwxrwx 1 root root 29 5月 19 19:00 /etc/resolv.conf -> ../run/resolvconf/resolv.conf
sudo cat /run/resolvconf/resolv.conf
nameserver 127.0.1.1
search DHCP HOST
******************安装后*********************************
sudo lspci -knnsudo lshw -numeric -class network
lspci: -s: Invalid slot number
Win10 和 ubuntu16.04双系统,有线网络连不上
- 系统: ubuntu16.04
上次由 rockan007 在 2017-07-07 20:20,总共编辑 1 次。
Re: Win10 和 ubuntu16.04双系统,有线网络连不上
连接无线网络后执行以下指令rockan007 写了:4.8.0-58-generic
wget http://kr.archive.ubuntu.com/ubuntu/pool/universe/r/r8168/r8168-dkms_8.043.02-1_all.deb
sudo apt install ./r8168-dkms_8.043.02-1_all.deb
- 系统: ubuntu16.04
兩行指令sudo lspci -knnsudo lshw -numeric -class network
sudo lspci -knn
