linux (ubuntu17.04) 下用小度wifi做无线网卡连接无线网,能识别,但是始终无法连接上
- fcgzjb
- 系统: ubuntu 16.10
我的是ubuntu17.04,安装后能识别网络,但是总是连接失败,一次也没有连接上
请问应该如何处理?
在windows下,能够正常完美使用。
本机,一直使用的是无线网,没有有线网
请问应该如何处理?
在windows下,能够正常完美使用。
本机,一直使用的是无线网,没有有线网
- fcgzjb
- 系统: ubuntu 16.10
Re: linux (ubuntu17.04) 下用小度wifi做无线网卡连接无线网,能识别,但是始终无法连接上
qisha@qisha-Lenovo:~$ uname -a
Linux qisha-Lenovo 4.10.0-13-generic #15-Ubuntu SMP Thu Mar 9 20:28:05 UTC 2017 i686 i686 i686 GNU/Linux
qisha@qisha-Lenovo:~$ lsusb
Bus 001 Device 004: ID 2955:1001
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 002 Device 002: ID 1a2c:0b28 China Resource Semico Co., Ltd
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
qisha@qisha-Lenovo:~$ sudo lshw -C net
[sudo] qisha 的密码:
*-network
product: 88E8057 PCI-E Gigabit Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: ens33
version: 10
serial: 44:87:fc:dc:f4:55
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 latency=0 link=no multicast=yes port=twisted pair
resources: irq:26 memory:feafc000-feafffff ioport:d800(size=256) memory:feac0000-feadffff
*-network
product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
physical id: 4
bus info: pci@0000:03:04.0
logical name: enp3s4
version: 10
serial: 14:cf:92:f5:27:85
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=64 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
resources: irq:20 ioport:e800(size=256) memory:febffc00-febffcff memory:febc0000-febdffff
*-network
physical id: 3
bus info: usb@1:4
logical name: wlx64d954a39f23
serial: 86:6d:b5:03:f9:4d
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=mt7601u driverversion=4.10.0-13-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11
[sudo] qisha 的密码:
*-network
physical id: 0
logical name: ens33
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 4
version: 10
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
*-network
physical id: 3
bus info: usb@1:4
- fcgzjb
- 系统: ubuntu 16.10
[sudo] qisha 的密码:
*-network
physical id: 0
logical name: ens33
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 4
version: 10
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
*-network
physical id: 3
bus info: usb@1:4
[sudo] qisha 的密码:
*-network
physical id: 0
logical name: ens33
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 4
version: 10
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
*-network
physical id: 3
bus info: usb@1:4
1. 已經獲分配 logical namesudo lshw -C net
*-network
physical id: 3
bus info: usb@1:4
驅動應該已經啟動
是否啟動成功 ? 是否需要安裝 firmware ? 待查證
2. 把下面指令 複製 貼進終端機 執行
2-1. sudo ifconfig -a
2-2. sudo route -nv
2-3. sudo rfkill list all
2-4. sudo nmcli dev status
2-5. sudo dhclient -v
把結果全部直接 選取/複製/貼上來
2-6. sudo iwlist scan
把你的 ESSID 那一段落 直接 選取/複製 貼上來
1. 您可以通过添加内核参数 net.ifnames=0 biosdevname=0 来禁用诸如 'wlx64d954a39f23' 一类网卡名称。NetworkManager 遇见此类超长网卡名称时可能会由于一些已知 bug 导致无法连接。fcgzjb 写了: logical name: wlx64d954a39f23
事实上正确的“修复”实际上应该是禁用NetworkManager的mac地址欺骗。 禁用systemd的可预测的界面名称,虽然(巧合?)那样也可以工作,但现在我猜这是一个过度的杀戮。
长话短说,
编辑 /etc/NetworkManager/NetworkManager.conf 并添加
[device]
wifi.scan-rand-mac-address=no
`systemctl restart NetworkManager`
它就可能开始为你工作。
上次由 vickycq 在 2017-06-23 23:18,总共编辑 2 次。
- fcgzjb
- 系统: ubuntu 16.10
增加内核参数方法,我尝试永久增加,sudo gedit /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT 增加内核参数,这个参数,具体填写什么?
填写这个?
GRUB_CMDLINE_LINUX_DEFAULT="ro splash vt.handoff=7 net.ifnames=0 biosdevname=0
这个参数,具体是什么意思?只有左边的单引号?
在网上搜索了一下,没明白具体啥意思
ro splash
vt.handoff=7
net.ifnames=0
biosdevname=0
填写这个?
在网上搜索了一下,没明白具体啥意思
ro splash
vt.handoff=7
net.ifnames=0
biosdevname=0
- fcgzjb
- 系统: ubuntu 16.10
填写这个?
在网上搜索了一下,没明白具体啥意思
ro splash
vt.handoff=7
net.ifnames=0
biosdevname=0
填写这个?
在网上搜索了一下,没明白具体啥意思
ro splash
vt.handoff=7
net.ifnames=0
biosdevname=0
抱歉,漏了右侧双引号。只要增加 net.ifnames=0 biosdevname=0 两个参数即可,用空格分隔。前面的参数仅用于示例默认参数,无需添加。fcgzjb 写了:只有左边的单引号?
保存后执行 sudo update-grub,重新启动计算机。
- fcgzjb
- 系统: ubuntu 16.10
可以识别,能够连上。是logical name 字符太长的bug引起的。
- fcgzjb
- 系统: ubuntu 16.10
vickycq 写了:1. 您可以通过添加内核参数 net.ifnames=0 biosdevname=0 来禁用诸如 'wlx64d954a39f23' 一类网卡名称。NetworkManager 遇见此类超长网卡名称时可能会由于一些已知 bug 导致无法连接。fcgzjb 写了: logical name: wlx64d954a39f23
2. mt7601 方案的驱动十分不完善,使用中遇到问题属正常。我也有一块 mt7601 网卡,已经扔掉了。
附增加内核参数方法
1 - 临时增加
开机到 GRUB 界面时,按 e 进入编辑界面
在 'linux' 一行末尾增加内核参数。看起来像这样:ro splash vt.handoff=7 net.ifnames=0 biosdevname=0
按 Ctrl+x 启动
2 - 永久增加
编辑 /etc/default/grub 在 GRUB_CMDLINE_LINUX_DEFAULT 中增加内核参数
看起来像这样:
保存后执行 update-grub
在ubuntu可以连接无线了。
上次由 fcgzjb 在 2017-04-01 15:01,总共编辑 1 次。
- fcgzjb
- 系统: ubuntu 16.10
还有就是在打开firefox看网页的时候,在调出终端,比如输入gedit编辑器,
打开的gedit文本编辑器,显示的一部分留有firefox打开窗口的重影,怎么都消除不掉。是什么原因?是显卡驱动的原因吗?我的是联想电脑,
- fcgzjb
- 系统: ubuntu 16.10
现在ubuntu下小度wifi能够作为无线网卡,连接无线网,正常上网了。vickycq 写了:抱歉,漏了右侧双引号。只要增加 net.ifnames=0 biosdevname=0 两个参数即可,用空格分隔。前面的参数仅用于示例默认参数,无需添加。fcgzjb 写了:只有左边的单引号?
解决了这个问题,结果返回xp,WIN XP又连接不上了。在WIN XP里面小度wifi连接不上。
- fcgzjb
- 系统: ubuntu 16.10
WIN XP又连接不上了。
- fcgzjb
- 系统: ubuntu 16.10
删除连接几次,重新建立,可以了。
长话短说,
并运行
它就可能开始为你工作。
长话短说,
[device]
它就可能开始为你工作。
